chiki
787 will soon have 3 Variants of Widebody Aircraft Being Produced
Fri May 05, 2017 6:38 am
With the 787-10 actively testing now we will soon be having all 3 variants of a passenger widebody being produced at the same time. I know this has happened with freighters included but having 3 variants of a passenger widebody in production is quite a feat.
Your comments if there other examples i might have might have missed
intotheair
Re: 787 will soon have 3 Variants of Widebody Aircraft Being Produced
Fri May 05, 2017 6:49 am
Some I can think of:
767. CO took delivery of 767-200ERs and -400ERs at about the same time, also not to mention that other airlines were still getting -300ERs.
The A340 was produced in four different lengths. There was a period when Airbus was building A343s, A345s, and A346s at the same time, though production of the A342 ended long before.
Also, the CRJ has had several models in production at once (and I suppose it theoretically still does). I'm not sure when the last CRJ-100/200 was built, but the 700, 900, and 1000 were/are produced concurrently and are still available for order.
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
anshabhi
Fri May 05, 2017 6:51 am
A358/359/35X soon all of them will be in production.
scbriml
Fri May 05, 2017 6:55 am
The A350-800 is not currently scheduled to be produced and likely never will be.
CARST
Fri May 05, 2017 6:56 am
There was the 767 ... which had -200s, -300s and -400s produced. I think some -200ERs might still have rolled off the line when the shortlived -400 was produced?
And of course you could argue about the A340/A330, which are more or less the same plane, just that one has 4 and the other 2 engines. So we had 4 to 5 models in production at the same time here (A332, A333, A343X, A345, A346).
I'm not sure if all three length variants of the L1011 were produced at the same time? (-100, -200, -500)
And I'm sure the 777 had 77E, 77L and 77W (so 200ER, 200LR, 300ER) in production at the same time, because when the 77L was launched in 2005, it was too heavy, with too much range for many airlines and they kept ordering 77Es.
I think that's it. Perhaps there are other examples, too?
c933103
Fri May 05, 2017 7:06 am
Were 747-100/100B/200B/SP made in the same timeframe?
A300 have plenty of variants especially if you also count A310 as such.
I think DC-10 also have those like -10/-30/-40
So, from the aboce posts, A300/A330/767/777/787/L1011/DC10 and possibly 747 have all seen 3 variants being made in the same time frame, so only il-86/96/A380/MD11 have not? With A350 waiting to see will they give it a further stretch or relaunch 358
When no other countries around the world is going to militarily stop China and its subordinate fom abusing its citizens within its national boundary, it is unreasonable to expect those abuse can be countered with purely peaceful means.
b747400erf
Fri May 05, 2017 8:09 am
Not a jumbo of course but 4 models of the 737 is quite a feat. 737-600,700,800,900
BartSimpson
Fri May 05, 2017 8:59 am
The OP was specifically referring to widebody frames.
keesje
Fri May 05, 2017 9:05 am
How many 787-8's are in the backlog? The production overlap between -8 and -10 might not last for very long.
https://leehamnews.com/2016/03/21/pontifications-787-8-no-longer-favored-boeing/
KarelXWB
Fri May 05, 2017 9:17 am
This has been done before: 767-200/300/400 and 777: -200A/200ER/300A/300ER.
reidar76
Fri May 05, 2017 10:09 am
A330-200, A330F, A330 MRTT, A330 Beluga XL, A330-300, A330 regional, A330-800neo, A330-900neo. These are different variants (certification).
One could argue that the A300/A310, and at least the A340 are different variants of the same basic widebody design as the A330. They have to some extent more in common than a 737 Jurassic has with a 737 MAX.
b747400erf
Fri May 05, 2017 10:10 am
One could argue that the A300, A310, and at least the A340 are different variants of the same basic widebody design. The were produced at the same FAL, and has to some extent more in common than a 737 Jurassic has with a 737 MAX.
But most of your list had not been produced at the same time.
dtw2hyd
Fri May 05, 2017 10:56 am
-8 won't be in production for too long.
Newbiepilot
Fri May 05, 2017 11:02 am
Currently 89 787-8s are in the backlog.
Channex757
Fri May 05, 2017 11:03 am
As the first A339 has been built, only the A338 remains to be constructed. The Beluga XL is also at the stage where it is being bolted together. So all of those aircraft except the future A330-800neo are in current production.
Polot
Fri May 05, 2017 12:43 pm
I think by "variants" the OP meant lengths. Things like 777-200 vs 777-200ER or especially A330-300 Regional vs regular A330-300 is starting to split hairs. Might as well start breaking planes down by engine type and paper MTOWs too at that point.
ikramerica
Fri May 05, 2017 12:55 pm
Then you would have so many 747 variants your head would spin. -100, -200, F, C, M, SR, SP, 3 different engine makers and engine variants...
The OP obviously meant different lengths.
cledaybuck
Fri May 05, 2017 1:02 pm
It is hard to determine where to draw the line. The 77E and 77L are the same length, but definitely different planes. That said, is this the first time we have had three different length widebodies in production with the same wing?
As we celebrate mediocrity, all the boys upstairs want to see, how much you'll pay for what you used to get for free.
lightsaber
Fri May 05, 2017 1:13 pm
This is a milestone. Since the 777 only has two lengths until the -8/-9, it hasn't matched.
The A350 currently only has two lengths, but might gain the 1100 (the 800 is dead and won't be produced).
We did see the 767 in three lengths as already noted.
But this is an accomplishment. Let's celebrate. Now new engine PIPs and airframe PIPs always improve the economics of the larger variants more than the smaller, that is just the economics of aircraft. The days of the 787-8 are numbered. Cest la vie, we still have 3 in production in 2017.
LIghtsaber
chiki
Fri May 05, 2017 1:26 pm
I agree its different lengths eg 777-200/200ER/200LR have same lengths though engines, capabilities differ.
Boeing778X
Fri May 05, 2017 3:18 pm
They may, for a short while, do 777F/778/77W/779 production.
I'm fairly certain interest in the 787-8 will decrease as we go forward.
United Airlines: $#!ttin' On Everyone Since 1931
airzona11
Fri May 05, 2017 3:23 pm
Pretty cool feat for the 787. I think this is the first time that 1 airline will have operated all 3+ variants of the widebody (if going by length) family. UA, NH and BA soon will. Side note but these same airlines operate 3 777 models side by side and did 3 747 families too.
Would Boeing prevent airlines from ordering the 788?
The 762ER had not sold in a while when CO placed their order.
BonaireFly
And in a few years we'll have the 737 Max-7, Max-8, Max-200, Max-9 and Max-10 all in production. 5 models, now that's a feat.
dtw2hyd
Fri May 05, 2017 4:09 pm
Boeing didn't implement any of -9/-10 performance improvements in -8, effectively making it less desirable.
Polot
Fri May 05, 2017 4:18 pm
Well that and since they didn't implement those improvements it raises the cost to build -8 vs the -9/-10 (or you can look at it the other way, it raises the costs to build the -9/-10 but they have higher margins built into their price) as their is less commonality between the variants.
That said if an airline really wants the -8 Boeing will sell it to them and build it. Some on A.net have a tendency to use the link that Keesje posted to say that Boeing is ending -8 production after 2020 because of apparent reading comprehension problems.
cledaybuck
Fri May 05, 2017 4:54 pm
While I don't think anyone thinks the 788 is going to be a large volume seller in the future, it is not dead yet. It's last order was just over a month ago.
neutrino
Sat May 06, 2017 5:54 am
And maybe Scoot too.
They are currently operating both the -8 and -9.
Parent SQ has 30 -10s on the books, with 19 more (excluding 6 options) to be firmed up pretty soon, if not already.
Hopefully a few or more of that large number will go to Scoot.
Potestatem obscuri lateris nescitis
b747400erf
Sat May 06, 2017 8:24 am
The first reply mentioned the CRJ and I added what I explained was not a widebody to that. Not difficult.
dtw2hyd
Sat May 06, 2017 1:37 pm
Order book is not showing any sign of interest from airlines. It is probably not up to spec in both weight and reliability and -9 and -10 are better alternatives. It may not have much resale value either. Nothing to do with English comprehension.
Arion640
Sat May 06, 2017 3:32 pm
From someone with a little bit less knowledge on the 787 compared to some.
What performance improvements do the 9 and 10 have that the 8 doesn't?
223 319 320 321 333 346 359 388 733 73G 738 744 752 753 763 764 772 77E 773 77W 788 789 MD83 E145 E175 E195 RJ85 F70 DH8C DH8D AT75
Brexit - It’s time for global Britain.
TWA772LR
Sat May 06, 2017 5:45 pm
Since people are throwing in RJs, we can also add the EMB 135/140/145/145XR (the last one is still a 145 on paper, but a much more robust airframe with external differences), and the E-jets.
When wasn't America great?
