AA300B
LA600: Lima - Los Angeles on an A320?
Thu May 11, 2017 7:58 pm
Today as I was browsing FlightRadar24 I noticed that the daily rotation Lima- Los Angeles as Latam flight 600 is being operated by an A320 instead of the usual 787. This flight has a block time of around 8:30 hours which would be stretching it for an A320. Is a stop required before continuing on to LAX? Somewhere in Mexico perhaps?
Found this quite odd and this was a first for me, maybe someone in the forum can give us some insight.
E145, E170, E190, A310, A300, A319, A320, A321, A330, A340, A380, 717 727, 737, 747, 757, 767, 777, 77W, 787
masgniw
Re: LA600: Lima - Los Angeles on an A320?
Thu May 11, 2017 8:03 pm
Are you sure this is accurate? I just looked at FlightAware and I don't see any such usage of the A320.
https://flightaware.com/live/flight/LAN ... /SPJC/KLAX
Brick
Thu May 11, 2017 8:24 pm
It's a Flightradar24 error. CC-BFU is currently flying Calamal to Santiago.
A noble spirit embiggens the smallest man...
GCT64
My guess, given that FR24 is reporting A320 CC-BFU to be in two places at once, is that a 787 is flying around miscoded with ModeS code E80278 (the code properly associated with CC-BFU) and so it appears incorrectly on FR24.
Flown in: A20N,A21N,A30B,A306,A310,A319,A320,A321,A332,A333,A343,A346,A359,A388,BA11,BU31,(..56 more types..),VC10,WESX
Brick
Thu May 11, 2017 8:35 pm
For every question like this in this forum, before posting one should always:
1. Check Flightradar24
2. Check Flightaware
3. Check the flight status on the airline's website (most show the aircraft type).
Most of the time this will answer their question right there and avoid these kinds of topics.
catiii
Thu May 11, 2017 8:44 pm
Or #4, you don't have to click into the topic and read it...
MalevTU134
Thu May 11, 2017 8:47 pm
Yeah, but imagine the sheer quantity of threads that would clog these fora if everybody started one without even an ounce of background checking...
I think that is what he meant...
catiii
Fri May 12, 2017 12:55 am
The OP did do some background checking.
Much better than the "will Airbus stretch the A350 and make it 4 engines?" nonsense you see on this forum. But you know what I do? I'm pass right over it...
