zeke wrote:It's a dumb idea, should have been a tunnel from the outset. Cutting edge, no way. Lack of planning from the start.
atcsundevil wrote:This seems like far more of an imaged-based decision rather than a functional one. I would have to imagine a tunnel would cause fewer operational disruptions during construction, and would cost significantly less given the scale and scope of the bridge. I'm sure it'll look great, but from a functional perspective, it's just not the best idea, nor the best use of funds.
ILUVDC10S wrote:Sounds like a possible spotters dream eh? yet I agree what a odd decision to make. I think tunnels at HKG are not done as one other poster said due to water issues. If memory serves me correct aint HKG built on reclaimed land like KIX was?
c933103 wrote:ILUVDC10S wrote:Sounds like a possible spotters dream eh? yet I agree what a odd decision to make. I think tunnels at HKG are not done as one other poster said due to water issues. If memory serves me correct aint HKG built on reclaimed land like KIX was?
weren't the latest concourse connected by underground transit system?
Newbiepilot wrote:Isn't this for the little North satellite concourse? This is not for the mid concourse. Was the north satellite ever in the master plan? It seems like an afterthought since the main terminal gates all are widebody sized. Having some smaller gates for narrowbodies makes sense but the location of the north satellite seems odd like HKG never thought they would get many 737s and A320s.
ILUVDC10S wrote:I don't think tunnelling is a problem - they already link T1, T2 and the mid level concourse using underground trains. Seems to me that they need more retail space and a bridge will help provide that!!Sounds like a possible spotters dream eh? yet I agree what a odd decision to make. I think tunnels at HKG are not done as one other poster said due to water issues. If memory serves me correct aint HKG built on reclaimed land like KIX was?
Q wrote:Hong Kong airport that you can't digging under ground to make tunnel do you know why? There are all rocks and dirt under water used to be. They filled rocks and dirt to make an airport land. If they digging it will be disastrous flooding or sank hole. That's why simple to built bridge that's the only way to do built it. You can't dig under ground due rock and dirt was filled to land. If airport was on real soil or crust landmark. It is ok to dig to make tunnel. Hong Kong engineering are not stupid to do built tunnel. They know what they are doing right thing to do.
Q
CCA wrote:What a waste of money and resources for such a small satellite, as said there is no forethought when it comes to Hong Kong, even the new terminal and taxiway design is terrible.
Clearly if Heathrow has morphed over the years into the "letterbox" design like Atlanta then clearly record breaking airports (LHR & ATL) need this design, it may not be aesthetically pretty but they are clearly the most functional designs.
HK should have copied Atlanta from the beginning or at least have done it for the new second terminal and now morph the current appalling 1st terminal like Heathrow is doing.
ILUVDC10S wrote:I think tunnels at HKG are not done as one other poster said due to water issues. If memory serves me correct aint HKG built on reclaimed land like KIX was?
CXGabriel wrote:I have used the northern satelite concourse a few times. The bus ride wasn't that bad, just need to account for it as far as managing boarding time and all. Although it's originally for low cost carriers, it is used by all airlines with narrowbodies. I am surprised that HKG didn't put gates that are only for narrowbodies at the new mid-concourse.
Q
zeke wrote:All done via ground transport as far as I know, no disruption to aircraft at all. Just do some back of the napkin numbers for how many buses you think you could buy and run for the cost of building that bridge. I think HKIA would be in a different location by the time that bridge pays for itself.
vhtje wrote:How is the satellite building serviced? I assume there are shops etc. in the satellite concourse? If so, how are these serviced? How is terminal staff ferried across? Is it alll by transport vehicles? If so that constant traffic must be very disruptive to aircraft movement.
I agree that the tunnel option would make much more sense than a bridge.
