Cointrin330 wrote:Was Delta the launch customer for the 767-200?
717atOGG wrote:Cointrin330 wrote:Was Delta the launch customer for the 767-200?
No, they were not the launch customer. United was. They were an early customer for the type, though.
TNST3B wrote:The 762 has nearly the same trip cost as the 763, while carrying a good bit less payload.
ChrisFallon77 wrote:I used to fly often from EWR to IAH on CO 762 in the mid 2000s. I loved the aircraft but remember that they didnt carry a lot of passengers. I believe the 757s had more seats.
rbavfan wrote:ChrisFallon77 wrote:I used to fly often from EWR to IAH on CO 762 in the mid 2000s. I loved the aircraft but remember that they didnt carry a lot of passengers. I believe the 757s had more seats.
757-300 has common pilot type rating, similar number of seats & burns a lot less fuel. Delta got 16 757-300 in the NW purchase & they had 14 767-200 at the time. So it was easy to swap them if they wanted the same seating on a route, but the shuffled the fleet around instead.
gsg013 wrote:If I remember correctly the seating for the 762 vs 757 -200 & 300 were as stated below.
sCO 767-200: 174 pax
sCO 757-200: 176
oldannyboy wrote:gsg013 wrote:If I remember correctly the seating for the 762 vs 757 -200 & 300 were as stated below.
sCO 757-200: 176
..or perhaps vice versa?
Nope, the 752 sat slightly more people than the 762 in CO's configuration. CO's 762s were fairly premium heavy for its size, hence the lower number of seats.
jetjack74 wrote:The 762's were long gone by the time the merger took place. The merger was 2008, he 762s were gone by early to 05
N126DL wrote:rbavfan wrote:ChrisFallon77 wrote:I used to fly often from EWR to IAH on CO 762 in the mid 2000s. I loved the aircraft but remember that they didnt carry a lot of passengers. I believe the 757s had more seats.
I think DL flew the last 762 flight in 2006 or so. Merger didn't happen until the end of 2009.
oldannyboy wrote:rbavfan wrote:ChrisFallon77 wrote:I used to fly often from EWR to IAH on CO 762 in the mid 2000s. I loved the aircraft but remember that they didnt carry a lot of passengers. I believe the 757s had more seats.
Actually, the 757-300 is quite a bit bigger seating-wise than the 762, at least in current configs. Max pax capacity is 289 for the 762 vs 295 for the 753 in high density.
To put things in perspective, at CO at least, the 762 sat *I think?* 3 pax more than the 757-200, and operationally cost just as much as 763. The 753 is even bigger PLUS cheaper.
...But the merger and the acquisition of NW 753s happened later.. after the demise of the 762 fleet.
But, yes, I know, the 762 was a lovely airplane.... sweet...
AWACSooner wrote:jetjack74 wrote:The 762's were long gone by the time the merger took place. The merger was 2008, he 762s were gone by early to 05
I flew the 762 ATL-SLC and ONT-ATL in Feb and Mar of '05...they were retired around May-June.
AWACSooner wrote:jetjack74 wrote:I flew the 762 ATL-SLC and ONT-ATL in Feb and Mar of '05...they were retired around May-June.The 762's were long gone by the time the merger took place. The merger was 2008, he 762s were gone by early to 05
rbavfan wrote:N126DL wrote:rbavfan wrote:757-300 has common pilot type rating, similar number of seats & burns a lot less fuel. Delta got 16 757-300 in the NW purchase & they had 14 767-200 at the time. So it was easy to swap them if they wanted the same seating on a route, but the shuffled the fleet around instead.
I don't remember when the 762's went.
AWACSooner wrote:Damn, I could've swore the pilot on the ONT-ATL flight told me the planes were going to be retired in a few months from that point...maybe he meant THAT plane (N103DL)?
I miss seeing the 762's...I always liked them over any other 76 variant
CF-CPI wrote:I always liked the -200 as well, and with the lower weights, takeoff was pretty zippy. In the early 2000s several of them were painted in the Deltaflot 'beach towel' colors and looked great.
CF-CPI wrote:AWACSooner wrote:Damn, I could've swore the pilot on the ONT-ATL flight told me the planes were going to be retired in a few months from that point...maybe he meant THAT plane (N103DL)?
FYI, N103DL is the one that almost went into the Pacific on takeoff from LAX back in the early days. Fuel feed had two large toggle switches mounted on the back of the center pedestal. By mistake, the PF reached back and inadvertently cut off the fuel flow. Could have been Surfing USA.
A protective semi-cover was later added to make the fuel toggles less exposed.
