KTPAFlyer
What is the absolute farthest a 777-200LR can fly in a pax config with restrictions?
Sun May 28, 2017 10:13 pm
Hello A.net,
SQ was unique amongst airlines in that it had a special pax configuration for ULH routes as it had a weight penalty needed to make those routes work. With the advent of the 777-200LR, we now have a plane that has way more range than any airline currently uses. Before anyone flames me, I am more than aware that this has a snowball's chance in hell of happening, but it's more out of curiosity than anything else. Assuming a similar premium only config like SQ and a weight penalty, what's the closest a 77L could get to Boeing's advertised 13,422 miles on the record flight with a pax load? Specifically, would it be able to make a routing like ATL-PER or would that be pushing the range of even the 77L too far?
ben175
Re: What is the absolute farthest a 777-200LR can fly in a pax config with restrictions?
Sun May 28, 2017 10:17 pm
I would say a 77L could comfortably make LAX-PER in a premium-heavy (but still 3/4 class) config. Anything further is probsbly a stretch.
Irehdna
Sun May 28, 2017 11:16 pm
I think SYD-JFK eastbound may be possible, westbound not so much (considering SQ SIN-EWR was already "restricted" with only 100 seats).
ElroyJetson
Sun May 28, 2017 11:39 pm
Ai occasionally flies DEL to SFO direct....not great circle route to catch a westbound tailwind. They report the flight is 15,000km....the longest in the world.
How far the 77L can truly fly with a full load? I don't know but I would guess at least 8,000nm.
707 717 727 72S 737 733 737-700 747 757 753 767-300 764 A319 A320 DC-9-10 DC-9-30 DC-9-50, MD-82 MD-88 MD-90 DC-10-10 DC-10-40 F-100
NZ321
Mon May 29, 2017 12:53 am
Qatar operates DOH-AKL, AKL DOH (daily, 77L). That's 9032 miles or 14535 km), considerably longer than SFO-DEL. Flight time is around typically about 16 hrs eastbound and 17 hrs 40 west bound although looking at actual sector times on flightaware over the past week you will see that on one occasion the AKl-DOH flight was 18 hrs 9 minutes!
Plane mad!
FriscoHeavy
Mon May 29, 2017 12:57 am
DEL-SFO flies EASTWARD to take advantage of the tailwind, not West.
Whatever
ElroyJetson
Mon May 29, 2017 1:07 am
You are correct.....it was eastbound. :smile: And according to Air India the longest in the world non great circle. Here's the link.
https://qz.com/817225/air-india-flew-14 ... co-flight/
CHI787ORD
Mon May 29, 2017 1:18 am
I thought it flew eastward only seasonally. When DEL-SFO was first launched it was a westward route similar to DEL-JFK/ORD.
GalaxyFlyer
Mon May 29, 2017 1:26 am
DEL-SFO would, more accurately, be described as NORTHWARD, followed by SOUTHWARD.
GF
Slcpilot
Mon May 29, 2017 12:44 pm
Back in 1986, when the Voyager flew around the world, I had similar questions. I wondered if fuel replaced all payload on any existing aircraft, if an around the world flight was possible. If it was, then the flight was not a technical challenge, just an economic one to make it happen.
With the state of engine technology back then, in restrospect, it almost certainly was not possible. Today I'm not so certain, but have no idea what the numbers would generate.
Cheers!
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
KarelXWB
Mon May 29, 2017 12:47 pm
Boeing's payload/range chart should provide several answers:
dtw2hyd
Mon May 29, 2017 1:25 pm
Does premium heavy config result in weight reduction. You may be carrying fewer humans but, those F/J suites weigh a ton and galley cart requirement per F/J pax is way higher than avg Y passenger.
emiratesdriver
Mon May 29, 2017 1:38 pm
I was told by an EK skipper who was dead heading back from AKL that in EK config at a reduced MTOW, you could fill it with 8F 42J and 216Y, put 16 Tonnes of cargo on, and arrive back into DXB from AKL after 17hrs with 8 tonnes of fuel onboard.
7BOEING7
Tue May 30, 2017 12:16 am
Cheers!
SLCPilot
Rumor has it a 777F with bladder tanks on the main deck and taking off over MTGW could theoretically make it. An engine failure on takeoff would be a bit of a problem however.
texdravid
Tue May 30, 2017 2:22 am
MAA/BLR/HYD--DFW/IAH
I said it, my airliners-India frenemies!
:) :rotfl:
Cmon we know North Indian centric AI would never do it, so relax you North Indians.
Tort reform now. Throw lawyers in jail later.
