KarelXWB
FAA fines UA for failure to inspect 787 maintenance
Wed May 31, 2017 11:31 am
Sloppy inspection work at UA results in a $435,000 penalty:
The U.S. Department of Transportation’s Federal Aviation Administration (FAA) proposes a $435,000 civil penalty against United Airlines for allegedly operating an aircraft that was not in an airworthy condition.
The FAA alleges that on June 9, 2014, United mechanics replaced a fuel pump pressure switch on a Boeing 787 in response to a problem that a flight crew had documented two days before. However, the airline failed to perform a required inspection of the work before returning the aircraft to service, the agency alleges.
United operated the aircraft on 23 domestic and international passenger flights before performing the required inspection on June 28, 2014, the FAA alleges. Two of those flights allegedly occurred after the FAA had notified United that it had not performed the inspection.
Article
https://www.faa.gov/news/press_releases ... wsId=21714
traindoc
Re: UA fined for operating 787 in not an airworthy condition
Wed May 31, 2017 11:41 am
The aircraft was airworthy, just not the paperwork.
HighBypass
Wed May 31, 2017 11:42 am
That's a black eye in the face of in-house maintenance. Particularly with the focus recently falling upon outsourced (and often offshore) MRO work as a subject worthy of concern.
backseatdriver
Wed May 31, 2017 11:51 am
FAA does not distinguish between the two.
Newbiepilot
Wed May 31, 2017 11:56 am
Problems related to Human Factors don't care what company someone works for. A mechanic not correctly reading or understanding the dispatch deviation guide can happen anywhere in the world.
Most dispatch deviation guide procedures to deactivate a component don't have a test requirement. While it is not excuseable, it is possible that someone under pressure may miss a step in the procedure. It can have big consequences, but unfortunately it is all too common around the world.
Virtual737
Wed May 31, 2017 11:58 am
The article suggests that the inspection wasn't done, not just the paperwork on the inspection. This would further suggest the maintenance guys didn't know the aircraft was airworthy or not. Paperwork wouldn't have made any difference to the actual safety of flight.
CriticalPoint
Wed May 31, 2017 12:17 pm
This event is 3 years old. In 2014 the 787 and its mechanics were still brand new. No excuse however the drama in the article title is a bit overblown. The plane was never unsafe or "unfit". Not airworthy is a term that most people outside the industry don't understand. The phrase makes people think the plane could not stay airborne.
I used to fly an airplane that wasn't airworthy if the tire pressure wasn't checked every 48 hours.
Revo1059
Re: FAA fines UA for failure to inspect 787 maintenance
Wed May 31, 2017 12:51 pm
This is the part that is the most concerning to me.
Newbiepilot
Wed May 31, 2017 1:13 pm
That shows a bit of a disconnect between engineering in headquarters and the operation. It may have taken a few hours for the FAA notification to make its way through the planning organization. There is no colored phone to stop the plane when the FAA calls like in the movies.
luftaom
Wed May 31, 2017 1:14 pm
Whilst the initial oversight is concerning and shouldn't happen (but invariably does from time to time) - What is particularly concerning is the fact that once the FAA notified them about the unairworthy aircraft, the aircraft was operated for a further 2 services. If an airline can't react immediately to a notification from the regulator that there is an unairworthy aircraft currently in revenue service then that doesn't reflect especially well on the airline and something needs to change to ensure that they can and do react immediately to the regulator notifying them that a plane is not airworthy.
mjoelnir
Thu Jun 01, 2017 3:54 pm
It seems to be that the frame was operated 23 times in not airworthy condition.
https://mobile.nytimes.com/2017/05/31/b ... cebook.com
Sooner787
Thu Jun 01, 2017 4:07 pm
Wonder how many UA employees get axed over this ? :(
CriticalPoint
Thu Jun 01, 2017 4:10 pm
Mistakes happen. Remember the wiring bundle fiasco at AA on the MD-80s? No one will lose there job.
iahcsr
Thu Jun 01, 2017 4:31 pm
If I understand this correctly a repair/replacement was done on this switch, but the required inspection step afterwards was missed. An audit of the paperwork a week+ later caught the error, yes? Who was doing the audit, FAA personnel or UA? Presuming FAA, the additional delay would be slightly more understandable than if UA spotted the problem and didn't call flight ops first to hold the aircraft for the inspection AND then notify the FAA.
dtw2hyd
Thu Jun 01, 2017 4:46 pm
iahcsr wrote:
...Who was doing the audit, FAA personnel or UA? Presuming FAA, ..
Industry is self regulated . FAA audits paperwork years later and fines airline. Usually airline pays 10% of initial fine amount after 10 years. There are several examples in the past.
iahcsr
Thu Jun 01, 2017 5:43 pm
That's what I thought. The logical explanation for the two additional flights was a simple case of damage being done, wait for the plane to arrive back at a location where the inspection could be completed.
B737900ER
Thu Jun 01, 2017 6:30 pm
It wasn't a safety of flight issue. Since it was paperwork related it was logical to fly it out of wherever it was to satisfy the additional inspection requirement.
Maintenance paperwork can be complex and at times confusing when you're trying to figure out who needs to see what and when. UA does a pretty good job of paperwork audits before an aircraft is released for service so these types of errors are not common but also not unheard of either.
kellmark
Thu Jun 01, 2017 11:16 pm
If the inspection was not accomplished it was not airworthy. If the paperwork was not done it was not airworthy. The only legal way to have moved it would have been to obtain a special ferry permit to maintenance approved by the FAA. No passengers allowed.
Also, if anyone in maintenance knew that the airplane was not airworthy, especially if notified officially by the FAA, they could have contacted the Operational Control Center and advised them that the aircraft was grounded. That should have been the end of it. Normally something like this would go through the Director/VP of Maintenance to the Director/VP of Operations and then right to the Ops control center. It can happen very quickly. You advise the captain and dispatcher that the airplane is grounded and flight is cancelled unless they have another aircraft to operate the flight. No reason that the airplane should operate two additional flights after being notified.
QueenoftheSkies
Fri Jun 02, 2017 1:03 am
Right and how is it be known that the aircraft is truly airworthy if the paperwork is not on point? It has to be black and white. Minimizing the severity of any sort of safety related matters is inexcusable.
B737900ER
Fri Jun 02, 2017 3:30 am
Airworthiness and safety can at times be unrelated. There are times where the paperwork is complete but the job is done in an unsafe condition. Which would you rather have?
Not minimizing safety, just speaking logically.
QueenoftheSkies
Fri Jun 02, 2017 4:07 am
So it's unlogical to say that both the paperwork and the work has to be done appropriately? The only acceptable "option" is BOTH are to be done appropriately otherwise face the penalties. That is what I meant by black and white......
juliuswong
Fri Jun 02, 2017 5:53 am
Both paperwork and repair/ maintenance must be done effectively and efficiently in timely manner. No compromise AT ALL.
TigerFlyer
Fri Jun 02, 2017 6:03 am
There are a number of misconceptions here.
First, as an airline, you NEVER fly an airplane with known airworthiness discrepancy, whether legal or physical. That turns an inadvertent and innocent violation into a willful one (much higher penalty), and calls your overall compliance disposition into question. You get the inspection done on the spot (which was most likely available to United), or get a ferry permit to where the inspection can be done. Likely a regular Airframe and Powerplant mechanic (A&P) performed and signed off the work, but it did not receive the second set of eyes by an Inspector Authorization mechanic (IA). As has been noted, this was likely caused by a breakdown in internal communications, after United was put on notice by FAA.
Second, the industry is not self regulated. Airlines strive to maintain the highest service standards and do self audit. But it is the FAA that regulates and imposes fines.
Third, FAA civil penalty cases take nowhere near 10 years to work their way through the system. There is some delay between when the FAA maintenance inspector finds the discrepancy, and when the civil penalty notice is issued. It has to be evaluated by legal, and in a high dollar case like this, approved by FAA senior leadership.
Fourth, usual settlement is not 10% of the proposed penalty. More likely 80% of the proposed penalty if you can show mitigating circumstances, or zero dollars if you have a great defense and can prove the FAA inspector was wrong. Also, if you discover the error through your own internal audit program and self-report before the FAA finds it, the proposed penalty is likely to be much less when and if the notice of civil penalty is issued.
In my opinion FAA penalty amounts have gotten out of hand, as airlines are indeed highly self-motivated to be compliant. High penalties, except for egregious and willful violations, does not serve much of a purpose other than to drive up the cost of doing business. United has generally very good maintenance and procedures, and unfortunately it had to dual failures here in not getting the required secondary IA sign off, and in not getting the word out quickly enough to the field to prevent the final two flights.
Planesmart
Fri Jun 02, 2017 10:55 am
If an aircraft is flown in a defined non-airworthy condition, whether due to physical and/or document deficiencies, unless 'ferry' type approval is obtained, then the airline will have breached the terms and conditions of it's insurance and finance (or leasing) agreements. Not a small matter.
dtw2hyd
Fri Jun 02, 2017 11:21 am
No misconceptions here
Southwest
For a violation 2006, FAA proposed $12 Million fine in 2014, settled for $2.8 Million in December,2015.
https://www.faa.gov/news/press_releases ... wsId=16754
https://www.usatoday.com/story/travel/f ... /77717566/
American
For a violation in 2006, FAA proposed $162 Million fine in 2012, settled for $24.9 Million in 2013.
https://www.dallasnews.com/business/air ... n-airlines
https://www.dallasnews.com/business/air ... lty-to-faa
So from initial violation to final payment, it is 10 years.
B737900ER
Fri Jun 02, 2017 11:25 am
Mistakes will get made. It's called human factors, and they are built into aircraft procedures to prevent disasters. My point is that unknowingly missing a sign off block on paperwork is different from a safety of flight standpoint then knowingly missing an o ring or safety wire on a component.
To say that there is no compromise AT ALL is to be ignorant of the human factor of aviation. That's why pilots and mechanics can self report mistakes to the FAA and NASA without fear of reprisal. If there were no compromise AT ALL as you suggest aviation would be a much more dangerous place.
thewizbizman
Fri Jun 02, 2017 11:31 am
Paperwork needs to be done before that plane makes it to the runway. Sounds like United to me. They really need to get there act together. Every airline should follow all aspects of aviation, aviation law and FAA regulation.
~Zac
TigerFlyer
Fri Jun 02, 2017 12:34 pm
Absolute perfection is just not realistic. Every major airline has numerous civil penalty cases a year, some for minor foot-faults, some for more serious issues. Work properly performed by an A&P and missing a secondary IA sign off falls in the realm of a foot fault. The FAA has started jacking up civil penalty amounts and issuing press releases to accompany them. So now they are news whereas the thousands of these cases that have gone on in the past were routine behind the scenes administrative procedures. Should United have had the secondary IA sign off. Of course. Do human mistakes happen. Inevitable.
TigerFlyer
Fri Jun 02, 2017 12:57 pm
In the scheme of things, this was a minor screw up compared to events past:
"Southwest Airlines Co. grounded 128 of its Boeing 737-700 aircraft Tuesday after it discovered that the airplanes had not received required inspections."
https://www.dallasnews.com/business/air ... nspections
"American Airlines canceled about 325 flights Wednesday so its crews could inspect wiring aboard its MD-80 aircraft.
The action came after a Federal Aviation Administration (FAA) audit raised questions about how a certain bundle of wires is secured to the MD-80 aircraft"
http://www.seattletimes.com/business/bo ... of-wiring/
thewizbizman
Fri Jun 02, 2017 1:00 pm
Yes, however an airline knows what planes they can fly and which ones they can't. They pay people to plan flights, they knew they were not regulated to book that specific airplane. Doing so, they took a risk and they got reprimanded by the FAA. This way 100% there fault.
~Zac
TigerFlyer
Fri Jun 02, 2017 1:19 pm
From what little we know from the article, there is no evidence that this was a willful violation and that United knowingly "took a risk". Yes, there was an oversight, but no airline is going to risk enforcement action from FAA when getting an IA sign off for previously and property performed work is a simple thing.
B737900ER
Fri Jun 02, 2017 1:43 pm
~Zac
Yes it was UAs fault. As mentioned above paperwork can sometimes be a tricky thing to sort out. When you have literally 350,000+ blocks for mechanics to sign on service checks fleet wide daily, some things will get missed. New technology helps mitigate a lot of it with a computer program double checking task compliance, but with paper and manual sign offs human factors play a role. And UAs 787s are not yet electronically controlled. But to paint it as them knowingly operating an aircraft in an unsafe condition is disingenuous.
B737900ER
Fri Jun 02, 2017 1:44 pm
Delete
Double post
luftaom
Fri Jun 02, 2017 8:10 pm
B737900ER wrote:
... to paint it as them knowingly operating an aircraft in an unsafe condition is disingenuous.
They flew it for 2 more revenue services after being told there was an issue.
ac888yow
Fri Jun 02, 2017 9:38 pm
These are the only statements that truly matter in relation to this story.
People often shrug off "paperwork" as if it's a minor detail, but a lack of auditable evidence is as good as "it wasn't done".
mjoelnir
Sat Jun 03, 2017 12:56 am
The moment UA new about it and kept flying it was wilful.
thewizbizman
Sat Jun 03, 2017 1:04 am
I think you meant *Knew
But, yes that is correct and I am sure they knew before the FAA repiminded them. They probobly did not ground them so they could complete the pre-planned flights assigened to the airport.
TigerFlyer
Sat Jun 03, 2017 1:41 am
thewizbizman wrote:
...I am sure they knew before the FAA repiminded them. They probobly did not ground them so they could complete the pre-planned flights assigened to the airport.
On what basis are you "sure" UA knew about the missing sign off?
I am not "sure", but based on a few decades of airline experience, regulatory compliance, and defending dozens of FAA cases for multiple carriers, I think this is a very unlikely scenario. UA committed a violation, and dropped the ball on internal communication when it was put on notice. But it is highly unlikely that it was done intentionally.
CriticalPoint
Sat Jun 03, 2017 1:55 am
Yeah that's not the case at all. You fail to recognize and understand the safety culture at United. There is no plane pushing, crew pushing or maintenance pushing. If the plane is broke flight is cancelled. To say that an airline with the safety culture of United willfully flew an unairworthy aircraft is misguided and inflammatory.
Kiwigondi
Sat Jun 03, 2017 4:30 am
As the switch is a chapter 28 task its also a CDCCL item and my suspicion is that these additional steps were the missed inspection. Its a pretty major thing to miss and was certainly an AD but has now been incorporated into the AMM so not sure if the AD has expired or not.
luftaom
Sat Jun 03, 2017 3:29 pm
I agree that UA don't deliberately push the envelope when it comes to safety.
However, I think that it is fair to say that UA need to make some improvements as a result of this - if they can't pull a plane out of service immediately upon being told by the FAA (no less) that something wasn't right - then they need to improve their systems in order to make sure that they can (and do) pull a plane immediately.
mjoelnir
Sat Jun 03, 2017 4:19 pm
It is very simple a fact and United is fined for exactly that, flying an aircraft not airworthy knowingly.
