rj777
Why are E170/175 windows misaligned?
Wed Jun 07, 2017 5:07 pm
I've flown on DL E175s before and it seams like no matter what seat I sit in........ the window is misaligned. What's the deal?
Polot
Re: Why are E170/175 windows misaligned?
Wed Jun 07, 2017 5:11 pm
Embraer designed and spaced them so that each row in an all Y class configuration gets a window. When you start throwing in First class and Y+ (classes not found on most RJs ~10+ years ago) the alignment gets all screwed up.
Someone83
Wed Jun 07, 2017 6:28 pm
Well, all windows doesn't align on most E-jet operators with one class seating neither
32andBelow
Wed Jun 07, 2017 6:40 pm
The airline can put the seats wherever they want on he tracks.
ikramerica
Wed Jun 07, 2017 6:44 pm
E was too smart for their own good. One window per row, at 32" spacing, if you put the seats exactly as they intended in an all Y.
Except they didn't factor in 2 class, ultra dense or scope clause limited aircraft. So now most have small, misaligned windows. It's a major flaw in an otherwise great plane.
cosyr
Wed Jun 07, 2017 7:07 pm
Plus, when they were built they were space 32" apart, as seat pitch has dropped to 30-31" apart, and sometimes less. Even if they could have centered the plane, so the rows toward the front and back are only a little off, but as others have said, First, and Y+ throw off the front of the plane, so everyone it seems is out of sync. I love Embraer's huge windows, but I do wish it didn't come at the expense of spacing.
Seabear
Wed Jun 07, 2017 7:09 pm
Then the airlines should be required to put the windows on a track as well. ;-)
ooslc
Wed Jun 07, 2017 7:12 pm
So strange. I just looked at seatguru for DL E175, all Y- window seats say misaligned window. That sucks. My last flight on an AS/OO E175 I was in 8A and had a perfect view. Don't know about the rest of the plane.
    Ironically, I don't work for OO anymore, and I'm not in SLC anymore. PDX based, aviation enthusiast, non-aviation worker.
BrunoSBGR
Wed Jun 07, 2017 7:28 pm
I've flown on AA's E175s and E190 and windows are indeed misaligned in Y.
I noticed that the further to the front of Y, the smaller the misalignment though. Rows 7, 8 & 9 tend to have pretty much aligned windows (or very little misaligned). I also remember the the last rows in the back also have a smaller misalignment compared to the center portion of the plane.
It's a shame these great planes have this flaw.
Private pilot. Frequent flyer. Aviation geek. Proud of all 3.
Cubsrule
Wed Jun 07, 2017 7:30 pm
Help me with "major flaw." What is a window configuration that does not have this "major flaw?" It seems to me that any aircraft where multiple seating configurations are possible has the same issue.
rrlopes
Wed Jun 07, 2017 8:34 pm
The fuselage frames had to be irregularly spaced to accommodate the perfectly aligned windows (with a 32" pitch). So the irony is that it was likely costly in terms of engineering effort and aircraft weight to have them. :banghead:
767333ER
Wed Jun 07, 2017 9:35 pm
This is the issue I have with flying on CRJs or anything built by Embraer. They space their windows out too much. I did a trip once on an E90 then two CRJs,and then the last flight on the A320neo and when I got on the A320 I wasn't used the number of windows because I had become so used to planes with hardly any windows.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T PA-28-180
2 ears for spatial hearing, 2 eyes for depth perception, 2 ears for balance... How did Boeing think 1 sensor was good enough?!
32andBelow
Thu Jun 08, 2017 12:51 am
This happens on 737s and every type that single a single density
ikramerica
Thu Jun 08, 2017 1:03 am
It's one window per row. Often the window is so far forward you can't look out without putting your head against the seat in front. Other aircraft have more windows so they are misaligned but it's usually easy to look out one of the two windows in your row.
Cubsrule
Thu Jun 08, 2017 1:10 am
Fair, though I would note that the windows are pretty large.
queb
Thu Jun 08, 2017 1:47 am
or one window between each two frames (which have 16 inches between each other)
queb
Thu Jun 08, 2017 1:48 am
queb wrote:
or one window between each two frames (which have 20 inches between each other)
