nitepilot79
DL 5508 Aborts Takeoff At ATL Due To Deflation Of Two Tires
Wed Aug 09, 2017 4:43 pm
The airport spokesman says that two tires "deflated" during takeoff forcing the crew to abort:
http://www.miamiherald.com/news/nation- ... 08057.html
Article quote:
"Authorities say a Delta Air Lines jet bound for Oklahoma was forced to abort its takeoff on a runway at Atlanta's airport when two tires went flat. Airport spokesman Reese McCranie tells The Associated Press that passengers were removed from the plane, and no injuries were reported. Atlanta-based Delta said in a statement that Flight 5508, operating as Delta Connection from Atlanta to Tulsa, aborted its takeoff around 9:22 a.m. Wednesday after two tires deflated."
Antarius
Re: DL 5508 Aborts Takeoff At ATL Due To Deflation Of Two Tires
Wed Aug 09, 2017 4:47 pm
With respect to the thread on the NE Patriots new 767s.... someone call Ted Wells!!
2019: SIN HKG NRT DFW IAH HOU CLT LGA JFK SFO SJC EWR SNA EYW MIA BOG LAX ORD DTW OAK PVG BOS DCA IAD ATL LAS BIS CUN PHX OAK SYD CVG PHL MAD ORY CDG SLC SJU BQN MHT YYZ STS BIS DOH BLR KTM MFM MEX MSY BWI DEN
Atlwarrior
Wed Aug 09, 2017 5:04 pm
Is that common? How strange! Hopefully the runway is open again.
nitepilot79
Wed Aug 09, 2017 6:00 pm
Anyway, it struck me as unusual because I've heard of burst tires during takeoff, but it sounds like these tires deflated during the acceleration down the runway, which seems more uncommon.
flight152
Wed Aug 09, 2017 6:08 pm
Why don't we hold outself to a higher standard and not call this a Delta flight since it wasn't operated by Delta?
nitepilot79
Wed Aug 09, 2017 6:13 pm
Higher? Seems like the mainlines, by far, are the ones with the most problems overall. And I still think legacy carriers own a big part of trouble regional airlines get into.
BoeingGuy
Wed Aug 09, 2017 6:19 pm
What speed did he RTO? Boeing guidance is to not reject above 80 knots for tire failure. Not sure what the other manufacturers advise.
b747400erf
Wed Aug 09, 2017 7:44 pm
It has DELTA painted on the aircraft, people that buy tickets buy them on DELTA, and DELTA hire the regional carrier. For the general public, it is a DELTA flight.
superbizzy73
Wed Aug 09, 2017 8:22 pm
Aircraft type? I hate it when a news article doesn't say the type of aircraft...just a personal pet-peeve.
flight152
Wed Aug 09, 2017 8:27 pm
Please. Spare me the rhetoric. I'm aware of all of this and the article clearly says delta connection. A quick flightaware search said it was operated by Expressjet.
ILNFlyer
Wed Aug 09, 2017 8:45 pm
Article quote:
I hate to ask the obvious but.....was Tom Brady there?
jetblueguy22
Wed Aug 09, 2017 9:09 pm
Airlines are quick to claim credit for service on their regional partners, and even quicker to run away and say it wasn't mainline's fault when something goes wrong. If they don't want the publicity make the airlines run their flights without the DL banner.
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
AAlaxfan
But it departed the gate on time and was not cancelled!! :stirthepot:
Grumpy. Not a dwarf, not an attitude. It's a lifestyle.
BravoOne
Thu Aug 10, 2017 12:23 am
Boeing guidance cannot cover all events. I had something like this happen in PHX many years ago when the 727 LMLG deflated during the TO roll, The vibration was incredible and we rejected somewhere near 100+. Got the airplane stopped without really knowing what the exact problem was. Two things stand out, the tower through no fault of there own launched a DC9 behind us as we cleared the runway, and of course he went through the torn up tire casings on the runway. On a post flight inspection we could see rubber marks along side the fuselage close to the #1 engine. A flat no rejects above 80Kts simply does work for all circumstances. No rejects above V1-5 or something along those lines makes a lot more sense. You might note, Boeing trains for the hi speed rejects and seldom if ever addresses the low speed rejects in there training syllabus. Train as you fly, fly as you train is pretty good advice.
b747400erf
Thu Aug 10, 2017 5:52 am
Rhetoric? I explained the reasoning. To the media and the general public, it is a Delta flight, the article said Delta Connection. If Delta does not like being associated with regional carriers that fly under their banner, they can change the routes to mainland.
fly4ever78
Thu Aug 10, 2017 6:06 am
I'm pretty sure Boeing would recommend aborting a takeoff at 80 knots if BOTH main tires on one side blew??!!! Continuing a takeoff from 80 to 160 knots with only 2 main tires would probably result in at the least a fire and more likely a exit of the runway/accident.
BobPatterson
Thu Aug 10, 2017 6:10 am
According to flight history at FlightRadar24 a CRJ9 is used for DL5508.
The flight eventually left about 2 hours late. I don't know if it left on the original aircraft after tires were fixed/replaced.
As for another poster questioning the attribution of this to Delta rather than to Delta Connection or Endeavor, others have already mentioned that, to the public, they are dealing with Delta.
I had Comcast come to my house to check out a problem a few days ago. They sent a subcontractor. I was not dealing with the subcontractor, I was dealing with Comcast.
Same with Delta and their subcontractors.
Facts are fragile things. Treat them with care. Sources are important. Alternative facts do not exist.
wjcandee
Thu Aug 10, 2017 7:02 am
The difference in the distinction to me is that when I hear "Delta Connection", I think "small jet". When it's a mainline DL aircraft, we could be talking about a 777 ending up with deflated tires on takeoff, which I think would be more interesting than it happening to an RJ.
leoben
Thu Aug 10, 2017 9:21 am
Not for those onboard...
tootallsd
Thu Aug 10, 2017 9:24 am
Seriously the four digit flight number beginning with a 5 tells you this was a regional and not a 777.
mjoelnir
Thu Aug 10, 2017 10:12 am
It is Delta and Delta seems to know that. The article clearly states that Atlanta based Delta made the statement about the incident.
LAX772LR
Thu Aug 10, 2017 10:49 am
It's not as 1-sided as you seem to believe.
Mainline carriers often have contractual arrangements where the express operator agrees to those very terms:
mainline gets the credit for good news, operator takes the liability for the bad; in exchange for access to the mainline's pax network.
We got a lot of public insight into this during the Colgan crash.
If the regional operator doesn't like it, then they're under no obligation to agree.
kalvado
Thu Aug 10, 2017 11:46 am
And that is exactly why I think it is a must to go against deceptive PR and blame the carrier for problems of subcontractors - catering, baggage handling, regional flying etc.
nitepilot79
Thu Aug 10, 2017 12:37 pm
Thanks for the responses.
BravoOne
Thu Aug 10, 2017 3:14 pm
Nothing to see here, just more bashing from b747erf. It really get old and so much misinformation from this source.
TVNWZ
Thu Aug 10, 2017 3:39 pm
More importantly that which airline was involved, who made the tires?
nitepilot79
Thu Aug 10, 2017 4:23 pm
wjcandee wrote:
... When it's a mainline DL aircraft, we could be talking about a 777 ending up with deflated tires on takeoff, which I think would be more interesting than it happening to an RJ.
That was the last thing on my mind when I made the title.
litz
Thu Aug 10, 2017 6:25 pm
Actually, it would probably be a lot LESS interesting ... because a 777 has many more tires. 1-2 deflating is more of a non-event when there's 12 of them underneath your back end vs 4, or even 2.
coolian2
Thu Aug 10, 2017 9:51 pm
Funny. I'm sure I had a post in here that's gone missing.
Q300/ATR72-600/737-200/-300/-400/-700/-800/A320/767-200/-300/757-200/777-300ER/
747-200/-300/-400/ER/A340-300/A380-800/MD-83/-88/CRJ-700/-900
wjcandee
Fri Aug 11, 2017 12:51 am
You say "tomayto", I say "tomahto".
WesternA318
Fri Aug 11, 2017 10:34 pm
Not to beat a dead horse but...was this a Patriots charter?
