bw50505 wrote:I saw an article with a picture of DL aircraft (presumably at IAH or HOU) with most of the fuselages almost completely underwater. I don't know if this image is Harvey related, but how extensive and expensive is the damage on aircraft that are submerged underwater during floods?
iahcsr wrote:bw50505 wrote:I saw an article with a picture of DL aircraft (presumably at IAH or HOU) with most of the fuselages almost completely underwater. I don't know if this image is Harvey related, but how extensive and expensive is the damage on aircraft that are submerged underwater during floods?
IAH has no flooding on the Field itself ... aircraft are not in danger. access roads are completely different matter
jetero wrote:bw50505 wrote:I saw an article with a picture of DL aircraft (presumably at IAH or HOU) with most of the fuselages almost completely underwater. I don't know if this image is Harvey related, but how extensive and expensive is the damage on aircraft that are submerged underwater during floods?
Well why not share said photo?
smokeybandit wrote:
bw50505 wrote:jetero wrote:bw50505 wrote:I saw an article with a picture of DL aircraft (presumably at IAH or HOU) with most of the fuselages almost completely underwater. I don't know if this image is Harvey related, but how extensive and expensive is the damage on aircraft that are submerged underwater during floods?
I would if I had a link to it/had saved a screenshot of it. I saw it in my Facebook feed and I can't find it anymore (which is why I said it was presumably of a Houston area airport since I only saw it once and wasn't able to confirm myself that it wasn't a stock photo).
This one? I know its bad quality sorry
I got this in a groupchat today
HOMER71 wrote:Plus that's not the Houston skyline in the background
jbpdx wrote:PDX likely one of the major US airports least affected by the catastrophe/cancellations, with only UA PDX-IAH 2x/day and zero to HOU since WN discontinued the route a few weeks ago.
readytotaxi wrote:"The US military has released water from two major reservoirs earlier than planned to protect central Houston, a move that could itself flood several thousands homes. Water is being released from the Addicks and Barker reservoirs in western Houston. Residents nearby have been told to monitor water levels and evacuate if they are in danger, but to wait until daylight before they do so.
The release is expected push up the Buffalo Bayou – one of Houston’s major waterways – by up to 6 inches (15 cm) an hour. The bayou is already suffering catastrophic flooding in the west of the city, at more than 7ft above flooding point."
Looks like a sacrifice for some to save others.
https://www.theguardian.com/us-news/liv ... WEML6619I2
Narfish641 wrote:It's comfirmed. Seems like Harvey wants to take another at Houston. Its starting to move up into Louisiana.
aemoreira1981 wrote:How many aircraft are actually on the ground that could have been inundated with water? I suspect that United could have more problems as IAH is closer to the coast than HOU.
thomasphoto60 wrote:jbpdx wrote:PDX likely one of the major US airports least affected by the catastrophe/cancellations,
Well, goodie.....goodie....for PDX!
ty97 wrote:IAH now closed until Thursday at Noon per FAA.
jetero wrote:ty97 wrote:IAH now closed until Thursday at Noon per FAA.
No, it isn't.
First off, FAA wouldn't (and I believe can't) do that--HAS owns operates the airport, and according to them, it's closed until further notice.
What it has stated is it "expects" IAH to open Thursday at noon.
ty97 wrote:jetero wrote:ty97 wrote:IAH now closed until Thursday at Noon per FAA.
No, it isn't.
Not sure what you are disagreeing with? I have no idea who makes these determinations, but I got this information from fly.faa.gov, and as I (and you) said, at least until Noon Thursday.
So I'm awfully confused by your response.
Either way, the airport is closed until at least Noon Thursday. Appears we agree on that.
jetero wrote:ty97 wrote:jetero wrote:
No, it isn't.
NO it is not.
FAA says they "expect" the airport to reopen on Thursday. HAS says closed until further notice. That's very different than saying that the airport IS CONCLUSIVELY, DEFINITIVELY CLOSED until Thursday. Likely? Probably. But what you wrote, i.e., that the FAA has closed IAH until Thursday, is not factually correct:
"IAH now closed until Thursday at Noon per FAA."
FAA can close ATC facilities but I don't believe they can close airports. That's done by the airport operator.
NO it is not.
I honestly can't even comprehend what you're arguing about at this point. I hope you have a good day.
packcheer wrote:Any idea why the Texas Dept of Public Safety is doing laps at 18,000 ft?
https://www.flightradar24.com/N243TX/ea5e85b
The hurricane, yes, I know. What is this aircraft used for specifically? And what Texas local activities related to the hurricane happen at 18,000?
csavel wrote:I read that Houston built a lot of highways and other municipal infrastructure "to flood" in that they know they live in a hot and humid thunderstorm hurricane prone area so if they build it a certain way, the damage is less than would be elsewhere. At least that is why it bounced back relatively quickly from ALison and other hurricanes.
Of course something like this will challenge even that design because built to flood and built to handle 50 inches of flood in three days are two separate things.
NO it is not.
Well I'm not surprised if you don't understand the distinction between saying:
"The airport is closed until Thursday" (which is what you claimed and is not true)
and
"The airport is closed indefinitely." (which is true)
NO it is not.
and
NO it is not.
and
and
Dude, calm down. No need to shout or get bent out of shape over semantics. IAH is closed and isn't expected to reopen before Thursday. HOU is closed am door isn't expected to reopen until Wednesday. As with everything, things can change. The FAA may not be the one closing the airport, but they maintain the website and provide the notifications that the airport is closed.IADCA wrote:Dude, the horse is dead. Stop beating it. The airport will open whenever it opens, notwithstanding any semantic disputes on a.net.
I'm actually surprised at how well things seem to be bearing up right now considering the flooding that happens in Houston with much, much less rain. Hope everybody down there stays safe.
DUDES, if you need any evidence that semantics are important:ICadet985 wrote:I'm confused. On here, I'm reading that IAH is closed until Thursday. On the FAA's airport statuses, it says closed until 1200L August 28, which is in about an hour.
What's the correct information?
The correct information is that they are both closed indefinitely.
