Scorpio wrote:Could you please remove the 'BREAKING' from the topic title? This really doesn't count as breaking news worthy of the tag...
enilria wrote:The thought of allowing any single airline to effectively control every gate at an airport should make everyone shudder. It's already too concentrated. WN would be arguing the opposite if we were talking about LGA or DCA.
jplatts wrote:Is Southwest wanting to add nonstop service from DAL to Buffalo, Cincinnati, Cleveland, Hartford, Louisville, Minneapolis/St. Paul, Newark, Tucson, and/or West Palm Beach? It appears that Southwest might be wanting to serve some of these destinations nonstop from DAL, and Southwest has previously considered adding nonstop service from DAL to MSP and EWR.
Is Southwest wanting to add additional nonstops from DAL to Seattle and Portland in order to better compete against AS?
Is Southwest wanting to add additional nonstop service from DAL to Boston, Detroit, Fort Lauderdale, Orlando, Raleigh/Durham, Tampa, and/or other destinations that are currently served nonstop from DAL?
jplatts wrote:Is Southwest wanting to add additional nonstops from DAL to Seattle and Portland in order to better compete against AS?
jimbo737 wrote:[threeid][/threeid]enilria wrote:The thought of allowing any single airline to effectively control every gate at an airport should make everyone shudder. It's already too concentrated. WN would be arguing the opposite if we were talking about LGA or DCA.
And then there's Porter who absolutely dominate CYTZ, the downtown airport in, by far, Canada's largest city and aviation market, with 80% of the slots both now and of any new slots granted over at least the next 15 years.
jplatts wrote:
Southwest actually does 126 departures per day out of only 10 gates out of Terminal 1 at LAX (which comes out to an average of 12.6 departures per day per gate at LAX), but Southwest does its LAX operation under constraints that it does not face at DAL, including construction associated with Terminal 1 renovations at LAX.
According to the Southwest Airlines city fact sheet for SJC (which can be found at https://www.swamedia.com/media_storage/city_fact_sheets/SJC.pdf), Southwest currently operates 76 departures per day out of only out of 7 gates at SJC (which comes out to an average of 10.9 departures per day per gate at LAX), and Southwest is going to be adding 15 additional nonstops per day out of SJC in 2018. Is Southwest going to be acquiring additional gates at SJC to add 15 additional flights out of SJC?
Is Southwest planning on squeezing in additional flights out of its existing gates at DAL like it is doing at LAX and SJC?
seat1a wrote:No. No allowed under the latest agreement.Can remote stands be used at DAL, as a way to alleviate the gate issue? The rumor around SEA is that busing passengers to remote stands may begin because of the gate situation; wondering if DAL could do this.
seat1a wrote:Can remote stands be used at DAL, as a way to alleviate the gate issue? The rumor around SEA is that busing passengers to remote stands may begin because of the gate situation; wondering if DAL could do this.
blink182 wrote:Similarly, there may be caps on aircraft capacity or type so that Delta, for example, can't schedule 763s and A330s on their five flights to maximize pax count and use air stairs in lieu of a jet bridge.
AAvgeek744 wrote:IMO, WN has spread itself too thin at DAL in order to expand to so many cities in their system. It's not always an ideal place for connections when flying to/from cities with only one or two flights a day.
TVNWZ wrote:If other airlines want to come in..let them build more gates. Or let the city just build more gates. Yeah, I know, WA2.
ScottB wrote:TVNWZ wrote:If other airlines want to come in..let them build more gates. Or let the city just build more gates. Yeah, I know, WA2.
Agreed 100%. The cap on gates at DAL should never have been put in place.
cjpark wrote:ScottB wrote:TVNWZ wrote:If other airlines want to come in..let them build more gates. Or let the city just build more gates. Yeah, I know, WA2.
The gate limit was insisted upon by the City of Dallas. The area around the airport cannot support the additional traffic to and from the airport additional gates and flights with large aircraft would generate. The number of gates currently allowed at DAL was based on a study the city commissioned to determine the affect of DAL without the Wright Amendment would have on the area around the airport. The original 30+ gate airport plan was based on airlines using aircraft that could meet the seat limitations in the original Wright Amendment for long distance flights outside the 5 state area.
727200 wrote:Did you read any of the posts in this topic before you started banging on your keyboard? Especially the one 2 up that talks of the constraints due to traffic and road limitations or did that one just go over your head? I don't like sitting in any traffic that doesn't allow for productivity and waiting for traffic to flow certainly fits in that mode. Read the posts if you want to be part of the conversation so you don't waste others time.
ADrum23 wrote:It's time to lift all the remaining restrictions at DAL and allow them to build more gates.
Alternatively, WN can bite the bullet and move to DFW airport so they can operate wherever they want.
Not intending to undermine you point, just an FYI, SJC is adding two gates at the southeast end of Terminal B.
But yes, you'd think they could up the gate utilization at DALbased on your numbers. Unless there is some operational difference based on the where these airports are, geographically.
AAvgeek744 wrote:ADrum23 wrote:It's time to lift all the remaining restrictions at DAL and allow them to build more gates.
WA2 is locked in to the early/mid 20's I believe. I'm not sure WN has a desire to use DFW given the monopoly at DAL. While I mentioned earlier lack of connections at DAL is not optimal, it's O&D base is large. If DAL add more gates, I would expect NK to waltz in. The Metroplex is big enough to have a full service international airport and an airport that caters to locals and price sensitive pax who don't want to drive to DFW. Then again, had you told me a few years ago WN would be in LGA, I would have laughed my ass off. They are full on competition to the Big 3, which is really the Big 4 with Southwest.
ADrum23 wrote:AAvgeek744 wrote:ADrum23 wrote:It's time to lift all the remaining restrictions at DAL and allow them to build more gates.
The WA2 should be invalidated on antitrust grounds. It is outdated and anti-competitive. Southwest is no longer a niche LCC, it is a major US airline that has surpassed UA in total passengers flown. It's time they get the same treatment AA gets at DFW. If that means expanding DAL or moving to DFW (didn't they try to lure WN after DL closed their DFW hub in the mid-2000's?), WN deserves more gates, and more gates should be built for new competitors as well. After all, it's not good to have one airline controlling most, if not all of the traffic out of an airport.
AAvgeek744 wrote:727200 wrote:Did you read any of the posts in this topic before you started banging on your keyboard? Especially the one 2 up that talks of the constraints due to traffic and road limitations or did that one just go over your head? I don't like sitting in any traffic that doesn't allow for productivity and waiting for traffic to flow certainly fits in that mode. Read the posts if you want to be part of the conversation so you don't waste others time.
Back when DAL was the main airport, there was much less development. The gazillion new highrise condos and other developments between DAL and downtown have changed that dynamic greatly. A lot of those folks have dollars that politicians wouldn't mind seeing.
USAirKid wrote:I'm also curious if AS considers adjusting by leaving VX up as a corporate shell selling tickets out of DAL on AS/QX/OO operated planes?
Okie wrote:USAirKid wrote:I'm also curious if AS considers adjusting by leaving VX up as a corporate shell selling tickets out of DAL on AS/QX/OO operated planes?
They do not have to. The lease automatically shifted to AS. The lease is subleased from AMR.
One of our AS contributors has continuously stated that AS is not leaving DAL period. The additional airframes required to keep the gates times came along with the AS acquisition of VX, no shell is required.
Even if WN decided to shift operations yesterday to DFW, WN would request I suspect at least 30+ gates. DFW does not have 30+ extra gates.
As a matter of fact DFW has been baffled for 5 years or more what the heck they are going to do to remodel terminal B and more time than that (8 or 9yrs) about construction of terminal F.
The pace that DFW operates I would not expect them to have a terminal G ready for WN until mid century if they decided to move yesterday.
I could be wrong but I would expect a lot of blowback from AMR every step of the way.
Okie
USAirKid wrote:What I find fascinating is that WN is trying to drag AS into this fight.
AS is going after California, one of WN's core markets. I wonder how much dragging AS into this is retaliation for the battle that is starting in CA?
I would sat Southwest end of Terminal B. If they add them to the southeast end of the terminals they would have to reroute the roadways for traffic. Or have cars drive around & under the planes.
usflyguy wrote:
Isn't there something in the agreement that prohibits AA codeshare partners from operating at the airport?
jordanh wrote:AAvgeek744 wrote:727200 wrote:Did you read any of the posts in this topic before you started banging on your keyboard? Especially the one 2 up that talks of the constraints due to traffic and road limitations or did that one just go over your head? I don't like sitting in any traffic that doesn't allow for productivity and waiting for traffic to flow certainly fits in that mode. Read the posts if you want to be part of the conversation so you don't waste others time.
I lived in Dallas in the late 60's and 70's, when Dallas Love Field was the only airport. The road to there was a two lane asphalt from downtown (Lemmon Avenue) and the other road.to get there from the freeway was also two lane (Mockingbird Lane).
Now when I go back I see both are six lanes, with plenty of room for traffic. There are more condos and more development between downtown and the airport, but that doesn't mean it isn't accessable. It only means there are more people who whine about the airport being there, even if it was there before they moved in.
I guess that is the American way: expect everyone else to sacrifice so you can have your way.
bob75013 wrote:ADrum23 wrote:It's time to lift all the remaining restrictions at DAL and allow them to build more gates.
Pulleassee ..
you do know that WN is the grantor of the $500 million in bonds used to buiid the new terminal ----don't you???
WN will wait until 2024 when it will shake up the local market by flying to other area airports without giving up DAL gates. I see McKinney -- and wouldn't service to Meacham shake up the pols as well as DFW airport and American airlines higher ups? FT Worth is a much bigger market than it was 25 years ago. I look forward to the day ...
strfyr51 wrote:bob75013 wrote:ADrum23 wrote:It's time to lift all the remaining restrictions at DAL and allow them to build more gates.
Pulleassee ..
And that means what? If they Closed LUV Tomorrow? Other than the moving costs to DFW? Southwest would be no worse for the wear.
with all of this Hoopla? Might be better th CLOSE Love Field.
StrandedAtMKG wrote:One airline should not be allowed to control 18 of 20 gates at a major airport in a major city. This is why we have antitrust laws and the FTC. WN can effectively charge whatever they want for the flights they're running at DAL with no competition. What on earth are the regulators doing?
ADrum23 wrote:StrandedAtMKG wrote:One airline should not be allowed to control 18 of 20 gates at a major airport in a major city. This is why we have antitrust laws and the FTC. WN can effectively charge whatever they want for the flights they're running at DAL with no competition. What on earth are the regulators doing?
What on earth were the regulators doing when they put all sorts of restrictions of DAL in the first place that caused this? There shouldn't be a gate restriction at DAL. If they fully opened up the airport and allowed for as many gates as physically possible, WN could expand to everywhere they want from DAL, while competitors could come in and start service.
But nope, gotta protect that AA monopoly at DFW.
ADrum23 wrote:What on earth were the regulators doing when they put all sorts of restrictions of DAL in the first place that caused this? There shouldn't be a gate restriction at DAL. If they fully opened up the airport and allowed for as many gates as physically possible, WN could expand to everywhere they want from DAL, while competitors could come in and start service.
