AMollenhauer9
Ethiopian to launch Chicago O'Hare service
Tue Nov 07, 2017 2:04 pm
http://thereporterethiopia.com/article/ethiopian-fly-chicago
Looks like they plan to launch service in June of 2018. It will be Chicago's only service to Africa.
atcsundevil
Re: Ethiopian to launch Chicago O'Hare service
Tue Nov 07, 2017 2:11 pm
Interesting. I assume this will be with a 788?
smi0006
Tue Nov 07, 2017 2:12 pm
Always exciting to see ET expand. Hoping to see them in AU/MEL one day! Wishing them the best of luck!
izbtmnhd
Tue Nov 07, 2017 2:43 pm
Is this direct both ways? No fuel stop in FCO? Or has the 788 ended the need for that?
Midwestindy
Tue Nov 07, 2017 2:49 pm
Exciting news!
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
smi0006
What is their fleet plan? Wiki seems a bit out of date? 359 for long haul? 788/789 for midhaul and 77W& L fo high density?
Skyblue39
Tue Nov 07, 2017 3:19 pm
They don't fuel stop in Rome any more. That was moved to Dublin over a year ago.
They route from Addis Ababa to Los Angeles, Washington and Toronto all via Dublin.
Washington and Toronto are all nonstop eastbound, whereas Los Angeles goes back to ADD via DUB
ET have transport rights on Addis - Dublin - LAX - Dublin - Addis.
izbtmnhd
Tue Nov 07, 2017 3:36 pm
Thank you!
behramjee
Tue Nov 07, 2017 3:57 pm
I would have rather have them do ADD-LOS-IAH 3-4 weekly on the B787/A359 as its way higher yielding + bigger demand.
ORD most likely will also end up being operated via DUB but I reckon it will be on the B789 or A359 as the B788 may not be able to operate with a full payload nonstop from ORD to ADD.
ORDfan
Tue Nov 07, 2017 4:34 pm
Awesome news! Looking forward to seeing them grace the airfield and T5!
Ya because you know what's better and better yielding for the airline than its executives. Who exactly is operating ADD-IAH or Africa anywhere to IAH today? Using "higher" yields/demand that you cannot prove to justify what you'd rather see based on self-interest makes ZERO sense to me.
oldannyboy
Tue Nov 07, 2017 4:42 pm
Is the flight via Dublin?
Great news! Love ET!!!
United787
Tue Nov 07, 2017 5:35 pm
Great news for ORD! Chicago seems to be on a roll lately with new international carriers! Also nice for UA to have another *Alliance partner at their largest hub.
smi0006
Tue Nov 07, 2017 5:41 pm
Does the Nigerian bilateral allow this? I suspect maybe more expensive in many ways for an African stop overs, over an established semi scissor hub on DUB.
thomasphoto60
Tue Nov 07, 2017 5:47 pm
Indeed, not too bad for a city if you believe all the media reports is on the verge of economic Armageddon (well, at least according to one media outlet anyways).
"Show me the Braniffs"
jbs2886
Tue Nov 07, 2017 5:48 pm
I mentioned on the ORD thread, but I wonder if SNN is a possibility for a stop. This would be similar to the current DUB stops by ET, but would pick up passengers otherwise on the now-cancelled UA flight. Will be interesting.
dfwjim1
Tue Nov 07, 2017 5:54 pm
Why Chicago?
RJNUT
Tue Nov 07, 2017 6:03 pm
EWR is routed thru Lome and offers very good connections to West,Cental and Southern Africa. could Chicago route the same?
LAXdude1023
LOS-IAH is a massive market (much, MUCH larger than ORD-ADD). Its also very high yielding. UA flew it for years. It tanked when oil tanked.
Frankly, ADD-LOS-IAH makes more sense than ORD-ADD. I dont think the bilateral allows it though.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
Skyblue39
Tue Nov 07, 2017 6:14 pm
Not a chance! They’ll consolidate all Ireland ops at DUB
stlgph
Tue Nov 07, 2017 6:31 pm
So, what are the chances this thing stops in Ireland, does pre-customs clear, and comes and goes from T1 at O'Hare?
if assumptions could fly, airliners.net would be the world's busiest airport
drerx7
Tue Nov 07, 2017 6:38 pm
Atlas operates IAH-LAD for Sonair in a premium heavy 744 2x weekly.
HOUSTON, TEXAS
berari
Tue Nov 07, 2017 7:08 pm
dfwjim1 wrote:
Why Chicago?
Connectivity opportunities with UA come to mind, like what's available in all its US destinations. I can't find information Africans living in the ORD area.
It could also be an opportunity to consolidate Midwest originating traffic at ORD while IAD focuses on traffic from the Eastern US (will capture those that are now spending a night at IAD to catch ET to ADD and beyond.) I have noticed in the past that the first UA flight out of ORD into IAD was tight for connection onto the ET flight to ADD, and now there's no longer any connectivity because the first UA flight arrives later in the AM.
Interestingly ET had wanted to fly into JFK but couldn't make the slots work for it, so it switched to EWR. It has the advantage of flying into a UA hub for the sake of connectivity, but if one were doing LOS-LFW-EWR-XXX for example, they're likely better off doing LOS-Europe-XXX. The existing service tends to be ideal for West Africa-NYC O&D traffic.
ADD-LHR-IAH also makes sense, or ADD-LAD-IAH, if we were to throw out random options without consideration to rights and hub operations. But the reality is that ET has consolidated its West African operations in and out of LFW. LOS, while a source of high yields for many airlines, is not easy to get rights in/out of and ET has historically threaded carefully in that space. ET has gone for more landing rights into more Nigerian cities rather than focusing on growing LOS alone. If ET is to pursue an ex-LOS service, then it'd miss out on connectivity from other West African cities that it would have ex-LFW. The appetite for ET to set up shop may also not be there, recent upheaval following rumours of ET buying/taking over Arik were a true test.
What LFW offers ET is the ability for it to tap into additional Nigerian markets beyond LOS. KP (Asky) only has a daily flight into LOS and four flights a week to Abuja. Neither city gets a large aircraft, with Q400s primarily and some flights operated using 73Ws. LOS does not appear to be a high traffic destination for KP, with its larger 738s going to places like DLA and DKR instead. LFW also provides connectivity to other central and West African cities including LAD if/when KP starts flying there.
If LOS-IAH was still attractive, UA would have remained albeit with reduced frequency.
Finally, going back to the original topic, it will be interesting to see how ADD-ORD will be routed. The flight can make it to ADD banks similar to what IAD and YYZ service (DUB-ORD is only 260 miles farther than DUB-IAD.) Routing via LFW will require the aircraft to remain on the ground at ORD for a long period.
Doubtful. If anything, ET would have such scenario from/via an existing city in its network that it has developed well before looking at a new city like SNN. I was doubtful about DUB working for the LAX flight, but there is some traffic ex-DUB to LAX and Africa that supports that scenario.
LAXdude1023
Another thing is that Chicago has a very small African born community. Minneapolis, Atlanta, Dallas, Houston, Boston, and Seattle all have bigger African foreign born communities.
jbs2886
Tue Nov 07, 2017 7:23 pm
Okay, we get it, you clearly don't think ORD should get this flight - you keep posting reasons other cities would be better. ET apparently disagrees, not sure what you are actually contributing to the conversation.
LAXdude1023
Tue Nov 07, 2017 7:27 pm
Go back and re-read the thread history. I responded to ORDFan vomiting ignorance about Houston. It never would have come up otherwise.
Rdh3e
Tue Nov 07, 2017 7:30 pm
LAXdude1023 wrote:
dfwjim1 wrote:
behramjee wrote:
1. Chicago is the third largest city in the US
2. ORD is the largest hub of their largest North American Partner
3. ORD connections will create significant numbers of new unique itineraries for ET.
4. ORD-DUB is a large market they will have local rights in
LAXdude1023
Tue Nov 07, 2017 8:01 pm
United787 wrote:
I have found that the options for ORD-IAD-Europe/MiddleEast are surprisingly low... poor connection times and limited flights. Better to fly ORD-FRA-and beyond...
Why ORD? Over IAH, SFO, DEN or LAX... because ORD offers 1 stop connections to almost every US market not already served from EWR and IAD that doesn't involve some sort of backtracking. DEN would also provide that but has a much smaller O&D. Yes, IAH has a bigger O&D to Africa than ORD but IAH isn't geographically desirable for Europe connections.
This is a much better, more accurate response. I didnt expect ET to show up at either IAH or ORD, but if there is an argument to be made for ORD over IAH, this is it.
United787
Tue Nov 07, 2017 8:02 pm
I have found that the options for ORD-IAD-Europe/MiddleEast are surprisingly low... poor connection times and limited flights between ORD & IAD. Better to fly ORD-FRA-and beyond...
Why ORD? Over IAH, SFO, DEN or LAX... because ORD offers 1 stop connections to almost every US market not already served from EWR and IAD that doesn't involve some sort of backtracking. DEN would also provide that but has a much smaller O&D. Yes, IAH has a bigger O&D to Africa than ORD but IAH isn't geographically desirable for Europe/MiddleEast/NorthernAfrica connections.
ORDfan
Tue Nov 07, 2017 8:28 pm
Right, because Sonair is effectively a charter service for oil industry workers so naturally that means ADD-IAH makes more sense? You got me. IAH has twice weekly service to Africa, so naturally ADD-IAH makes more sense. :roll:
Cubsrule
Tue Nov 07, 2017 8:29 pm
Is the ethnic traffic to Africa from worth chasing yield-wise? IAH oil traffic is, but ADD is not in the right part of Africa for most of that traffic.
ORDfan
Tue Nov 07, 2017 8:42 pm
Indeed one of the bright spots of Ethiopia's is economy is its agricultural industry. The country is a large grower and importer of cereal grains for feed and for its own livestock cultivation, while it focuses on exporting soft commodities like coffee and cotton. There are plenty of synergies between Chicago's logistics, trading, and exchange community and Addis Ababa, particularly as the ECX consulted with the CME when it was launching one of the few viable exchanges outside of South Africa. But sure, what do the execs at ET and Star know about synergies....
berari
Tue Nov 07, 2017 8:47 pm
Ethiopian has shown that with its network and ability to connect pax at ADD, it can make many cities work despite not always being the direct route.
Ethnic traffic to Africa is not the only target market for ET and other airlines. Tourism has been picking up in many parts of Africa. Recorded economic growth also registers additional traffic to the continent.
LAXdude1023
Tue Nov 07, 2017 8:52 pm
O&D between Houston and Africa is much greater than between Chicago and Africa. ORD-ADD makes sense the same way DFW-SYD makes sense. Its a large hub for a partner and the geography makes more sense. But dont think for a moment that this has anything to do with ties between the city of Chicago and Africa.
IrishAyes
Tue Nov 07, 2017 9:32 pm
For those saying that there will be local traffic rights from ORD to DUB, remember that this could be routed the same way that IAD and YYZ are, in that ET will operate a nonstop from ORD to ADD on the Eastbound leg and make a technical stopover in DUB on the return. In this case, I don't believe local traffic rights ensure if its not bi-directional like LAX-DUB-ADD is.
One thing that has always surprised me is how ET is able to operate ADD-GRU nonstop but has to route all of their North American flights via an intermediary station. Is this due to polar winds (North vs. South?) because ET used to fly to GRU (and GIG for awhile) via LFW.
rukundo
Tue Nov 07, 2017 10:44 pm
Another thing is that Chicago has a very small African born community. Minneapolis, Atlanta, Dallas, Houston, Boston, and Seattle all have bigger African foreign born community
From Chicago, Ethiopian targets mainly passengers (both Americans and Africans) flying between North America and East and Southern America. Lots of Americans come to East Africa and Southern Africa, both for tourism and business. Americans make huge investments in East Africa and Chicago is a major world financial center.
There is a huge Ethiopian diaspora in USA, but biggest Africans diaspora in USA come from West and North Africa (Ghana, Cape Verde, Sudan, Morocco, Egypt & Nigeria), followed by diaspora from Kenya, Eritrea, South Africa and Somalia.
Ghana, Morocco,Cape Verde, Egypt & Nigeria have already flights to USA. Pax who want to fly between USA & West Africa with Ethiopian, can already fly from Newark (United Airlines hub) to Lome and then connect at Lome on Asky flight to West Africa.
ORD is a big Star Alliance hub, Ethiopian will be able to provide many connecting via United. Houston (another Star Alliance hub) is in the pipeline, since 2015-2016 : https://www.flightglobal.com/news/artic ... te-429682/
eamondzhang
Tue Nov 07, 2017 10:58 pm
Maybe (and that's a big maybe) their GRU flight doesn't carry cargo, similar to their East Asia flight (CAN, PEK, PVG, HKG & CTU) on the outbound trip.
Michael
LH658
Tue Nov 07, 2017 11:06 pm
Also cause the Midwest has lot of Africans from Somalia, Eriteria, Ethiopia, and etc. Though IAH - LOS - ADD, IAH - ACC - ADD, or IAH - FCO - ADD, IAH - VIE - ADD, would be nice addition.
drerx7
Wed Nov 08, 2017 12:50 am
No...You asked what routes exist between Africa and IAH...I gave you the answer. I didn't say that was the reason. Chill out dude.
HOUSTON, TEXAS
usflyer msp
Wed Nov 08, 2017 1:25 am
That is a very poorly written article - I would take anything it says with a grain of salt until ET officially confirms...
stlgph
Wed Nov 08, 2017 1:36 am
Says who? You? Are you fluent in Amharic?
thomasphoto60
Wed Nov 08, 2017 1:41 am
I was thinking the same thing. One thing I have learned over the years is to take these articles with a HUGE grain of salt, they are quite often inaccurate.
CHI2DFW
Wed Nov 08, 2017 1:50 am
I’ll believe it when I see it. SA announced ORD years ago and dropped it before it started. I don’t know the figures, but would think SA would do not as bad.
Again it’s Hub to Hub, but that still doesn’t matter if there’s minimal O&D for such a long flight, and Y fares at that.
Damn article said starting in 2017! Looks like a yahoo wrote this!
Freshside3
Wed Nov 08, 2017 2:11 am
You got that one right. ORD really doesn't need the flight, on a local basis. But bundling up the SEA/MSP/DTW/SFO(and other) connections via UA's hub feed, well, this flight will do fine.
kngkyle
Wed Nov 08, 2017 2:25 am
Interesting and unexpected news. Looking forward to seeing the ET tails at ORD.
CHI2DFW
Wed Nov 08, 2017 2:32 am
Would be a great addition, but I’m hesitant until I see an official news release from the airline or City of Chicago.
Now if NZ, SA, SQ, QF, and flights to ATH, BOG, EZE, KBP, LIM, LIS, MXP, OSL, and SVO/DME would happen...
usflyer msp
Wed Nov 08, 2017 3:57 am
Thanks to my job, I actually can speak some Amharic and Oromo - however I don't see why that matters as the article and associated newspaper are english language publications...
rbavfan
Wed Nov 08, 2017 4:55 am
Due to high altitude & hot climate I'm guessing a fuel stop westbound.
rbavfan
Wed Nov 08, 2017 4:59 am
Yes when oil prices tanked so did all those high yeilding passengers that made it profitable. Otherwise UA would have kept it.
AF022
Wed Nov 08, 2017 10:46 am
ADD-GRU is a lot shorter than ADD-IAD.
IrishAyes
Wed Nov 08, 2017 4:23 pm
Only by a mere 1,000 mi....
