Balloonchaser wrote:Maybe they could make an artificial airport in the bay or on the beach. That would benefit LAX and maybe even turn into a TNCM senario
DCAfan wrote:I thought El Toro was the best bet to be the counterweight to LAX. What a lost opportunity.
BreezyIAH wrote:I posted a while back about the "what if" scenario if the El Toro MCAS in Orange County had actually become a commercial airport, but for the second largest market in the US and one of the top globally, something has to happen eventually right? Or not? I don't know of what locations could even be available. SNA is strictly limited, BUR is also, LGB has the size? airfield wise but not infrastructure, or agreeable surrounding residents, ONT is in not a convenient alternative and small as well. Something has to happen eventually as LAX can only expand while adding to more congestion for so long, right? Maybe a north of LA option would be more practical like in Ventura Co or somewhere? Sorry for a question full of questions
janders wrote:Does Los Angeles basin really need another airport?
Airports like BUR and ONT already operate way below their capacity, while both LGB and SNA might have all their air carrier slots fully allocated but aircraft size could always rise if demand required it.
It seems to me there is hardly the need for yet another field when existing ones have room for growth, and that regions demographics($$) and population favors use of LAX anyhow.
greg3322 wrote:
Yes, LAX does not have sufficient infrastructure to handle what they are doing now. It can easily take 30-45 minutes to drive the loop around the airport. I have never rented a car here, but friends have complained about having to allow an extra hour to return cars and get a shuttle to the terminal. .
LAXLHR wrote:BreezyIAH wrote:I posted a while back about the "what if" scenario if the El Toro MCAS in Orange County had actually become a commercial airport, but for the second largest market in the US and one of the top globally, something has to happen eventually right? Or not? I don't know of what locations could even be available. SNA is strictly limited, BUR is also, LGB has the size? airfield wise but not infrastructure, or agreeable surrounding residents, ONT is in not a convenient alternative and small as well. Something has to happen eventually as LAX can only expand while adding to more congestion for so long, right? Maybe a north of LA option would be more practical like in Ventura Co or somewhere? Sorry for a question full of questions
There is so much wasted space at LAX its not even funny. Open in google maps and take a look. Things could be moved around a bit on the western 2/3 of land (expensive yes) but would be necessary to open up the space. The parking lots on the NE side of the airport that belong to the city could be downsized or stacked elsewhere. If JFK can spend $10 billion plus in the late 90s tearing down the vast majority of Terminals and replacing them, then LAX can embark on a proper 15-25bn improvement no sweat. But no, cause the corruption is massive surrounding LAX. Massive!!
Its a disgrace to build a new 3bn departure lounge at the TBIT and leave the older A380 hanger there. Utter disgrace!. I still like LAX and it works well for me, but its a sad sad sad sad sad place.
dc10lover wrote:Ontario, Airport is your best bet.
zeke wrote:Apparently large slot constrained hub airports like LAX are a thing of the past, everyone is flying point to point in 787s.....
janders wrote:zeke wrote:Apparently large slot constrained hub airports like LAX are a thing of the past, everyone is flying point to point in 787s.....
LAX has no slots.
zeke wrote:janders wrote:zeke wrote:Apparently large slot constrained hub airports like LAX are a thing of the past, everyone is flying point to point in 787s.....
LAX has no slots.
It does if you use the WSG definition but not the FAA definition. LAX is a Level 2 FAA airport, but in reality you cannot operate there unless you have approval at the time you wish to.
N62NA wrote:There's still time to take those billions for the "high speed train" between LA and SFO and instead funnel those funds into a truly high speed rail link from Downtown LA, the Valley and Orange County to ONT.
janders wrote:FAA several years ago designated airports like ORD, LAX, SFO, (and EWR still) level-2 airports which as posted above allows airlines to coordinate schedules without fear of legal violations, and allows the FAA to come to the table and share overall traffic activity of other airlines with each other.
This does not mean the airports are slot controlled or have formal slot programs in place. Its simply an advisory, or consultation process that is protected legally. The FAA has built this into a review and approval process, and by defacto, nothing is denied by the FAA as its not in the place to do so, as airports dont rise to the levels of needing formal slot programs.
LAXintl wrote:In 26-years at the airport including schedule management, never recall airline schedules requiring adjustment due FAA. CBP on the other hand on plenty of times has forced airlines to reschedule, but their staffing and processing limitations is not runway movement related obviously.
Per FAA latest 2014 national capacity analysis, LAX hourly aircraft operations don't even reach 85% during peak periods, with much of the day in the 60-70% range.
greg3322 wrote:janders wrote:Does Los Angeles basin really need another airport?
Yes, LAX does not have sufficient infrastructure to handle what they are doing now. It can easily take 30-45 minutes to drive the loop around the airport. I have never rented a car here, but friends have complained about having to allow an extra hour to return cars and get a shuttle to the terminal. Unless you live here, it is hard to comprehend how long it takes to get places certain times of the day. Where I live, it is virtually the same mile distance to SNA and LAX. It can take up to twice as long to get to LAX than SNA. LGB is always my first choice, but limited flights and the fact my carrier of choice (UA) does not even fly there makes it an infrequently used airport for me. SNA is good, but again, limited flights and often quite high ticket prices drive me back to LAX. BUR is not an option. It can take 2-3 hours to get there in the afternoon. ONT is OK, but traffic is horrible getting there. The airfield itself is great and they have a lot of room. It would be the best option for a true reliever, but it is too far from most people.
LAX has made some progress modernizing the airfield - rebuilding terminals, the rebuilding/moving of runway 25L a few years ago, etc. But they have done virtually nothing to upgrade parking or access to the airport since before the 1984 olympics.
RDUDDJI wrote:greg3322 wrote:
Or perhaps make a consolidated rental car facility there (optimally with a train)?
JHwk wrote:While I don't think LAX is going far enough (or fast enough), the major issues are being addressed. I 5-10 years, they will need to look at extending the Sepulveda tunnel or something similar, and likely in that same time frame there will be pressure to address the uninhabitable zone between the 110 and 710 north of the 105, as the space is too valuable to the community to waste away as is forever.
CHI2DFW wrote:ONT should fit that. If not, Los Angeles Peotone has marketing potential!
strfyr51 wrote:CHI2DFW wrote:ONT should fit that. If not, Los Angeles Peotone has marketing potential!
Peotone?? The "proposed" airport south of Chicago?? Are you Kidding??
mcogator wrote:After moving to LA, the major problem with LAX is just the car traffic. My personal idea would be to build a large car park for employees and travelers next to where the new stadium is going up in Inglewood. Build a people mover system, and limit LAX to only commercial buses and rideshare for pickup and drop Off. Maybe even not allow any vehicles into LAX, except for busses.
LAXintl wrote:No sir. No formal "approval" needed. There is no program for landing or take off slot management by the airport.
