guyanam wrote:Zidane wrote:Agreed.
Would some expansion in ANU, BGI and UVF make sense? They do well out of the US.
Perhaps a few leisure routes from TAB?
Not sure why all the talk of expansion when BW is replacing 12 737-800 with the MAX version on a one for one basis meaning that there will not be a net increase in aircraft. In addition the transatlantic routes mentioned would imply another foray into 763 or getting 787s. Its already established that a small fleet of wide bodies cannot be sustained, and even with a joint code with PY to AMS I dont see how this changes.
BW is not a factor in the leisure market. I went to a CTO (Caribbean Tourism Org) event in NYC where they were making a presentation. All BW had on offer as leisure destinations out of NYC were MBJ, GND, and TAB. The consensus in the room was that this doesn't provide enough range and volume for the travel trade. They have since dropped GND, In addition, with the exception of KX, Caribbean carriers have not been able to service leisure routes and remain viable. Air Jamaica, successful in its market presence, generated losses and became extremely indebted as a result. The result being that it no longer exists.
BGI doesn't need BW and that would have been the best market given that it has a larger component of VFR and outbound (to the USA) travel than do the other islands mentioned. With AA and B6 battling it out between them (now 4x daily out of SoFL and 2x out of NY) there is no room for BW.
Even TAB is only on Sundays and also shared with POS. Also, will the weekly JFK-SVD survive?
BW will always be at a disadvantage compared with the big boys who can efficiently deploy their aircraft and crews from their hubs. At least BW has less competition on VFR routes to POS and GEO from YYZ and JFK.
