hkcanadaexpat
Re: Airbus A350 Production/Delivery Thread 2018
Tue Aug 28, 2018 8:54 am
MSN 169 (CX#25) sporting its final regs (B-LXB). Delivery imminent
MSN 172 (QR#31) new engine run and taxi test
7BOEING7
Tue Aug 28, 2018 3:47 pm
Asiaflyer wrote:
7BOEING7 wrote:
What is with all the engine changes — is there an issue here?m
You only need to scroll up to reply #168 to find the answer.
CA isn't QR.
hkcanadaexpat
Wed Aug 29, 2018 8:33 am
MSN 163 (QR#29) was moved to the delivery centre this morning
Eyad89
Wed Aug 29, 2018 9:07 am
And so the delivery target for this year is 105, and since the program is expected to start generating a positive cash flow sometime this year, 120 frames for 2019 all generating a positive cash flow should be good news for Airbus.
Eyad89
Wed Aug 29, 2018 9:29 am
And KLM delays its first A359 to 2021.
https://www.ainonline.com/aviation-news ... eries-2021
Along with the rumored EY's deferments/cancellations, Airbus has some early slots to fill.
qf789
Wed Aug 29, 2018 11:36 am
Hong Kong Airlines A359 MSN235 returning from test flight
https://twitter.com/cliper31/status/1034764113606586368
Forum Moderator
Geoff1947
Wed Aug 29, 2018 2:58 pm
Airbus current target is Rate10 which equates to 110 per year as they count a year as 11 business months.
Geoff
hkcanadaexpat
Wed Aug 29, 2018 8:11 pm
MSN 98 (HU/JD) new engine run
MSN 220 (SQ#22) out on another test flight #AIB04FZ
MSN 223 (SQ#23) out on a second test flight #AIB02HE
MSN 236 (PR#3) out on a second test flight #AIB02HH
MSN 235 (HX#5) sporting its final regs (B-LGE). Delivery imminent
MSN 240 (CA#5) initial engine run
Morvious
Wed Aug 29, 2018 9:08 pm
The way I read it is that the AirFrance-KLM group is just shuffeling planes within their group instead of delaying the planes at Airbus. So instead of KLM taking deliverie in 2019 they will go to Joon.
I could be wrong though because the article isn’t very clear on that.
have a good day,
HereThen
hkcanadaexpat
Wed Aug 29, 2018 9:36 pm
That is correct. Nothing in the H1-2018 financial report by AF-KLM hints towards the Group delaying deliveries.
hkcanadaexpat
Thu Aug 30, 2018 8:05 am
MSN 110 (QR#30) active at the delivery centre this morning
MSN 178 (CA#2) sporting its final regs (B-1085). Delivery imminent
qf789
Thu Aug 30, 2018 8:08 am
Rear fuselage for Virgin Atlantic's first A350-1000
https://twitter.com/Tobias_Gudat/status ... 3092691968
Forum Moderator
patschinger
Thu Aug 30, 2018 8:12 am
Hey Folks
Is anybody aware about the technical figures from the 942 Version for JAL ? I mean such as MTOW, Engine thrust/type, Range etc.
Couldn't find anything under https://www.easa.europa.eu/sites/defaul ... -07-09.pdf
TC957
Thu Aug 30, 2018 10:35 am
Any regs or names allocated to VS's 350's yet ?
itisi
Thu Aug 30, 2018 10:38 am
Will they get this before 071?
737-300/400/500 ... are NOT classics :)
Someone83
Thu Aug 30, 2018 12:28 pm
Air China #2 flying home today
Airbus A350 -941 178 B-1085 Air China delivery 30aug18 TLS-TSN ex F-WZGZ
hkcanadaexpat
Thu Aug 30, 2018 7:23 pm
MSN 178 (CA#2) on delivery flight. #49 of 2018. #3 in August
MSN 240 (CA#5) RTO. First flight scheduled for Friday
audidudi
Fri Aug 31, 2018 1:19 pm
The third A35K for Cathay Pacific was delivered today:
Airbus A350-1041 169 B-LXB Cathay Pacific delivery 31 Aug18 TLS-HKG ex F-WZGW
audidudi
Fri Aug 31, 2018 2:09 pm
The fifth A350 for Hong Kong Airlines was delivered today. #5 in August...#51 in 2018.
Airbus A350-941 235 B-LGE Hong Kong Airlines delivery 31 Aug18 TLS-HKG ex F-WZHJ
MileHFL400
Fri Aug 31, 2018 2:50 pm
How many 1000’s delivered so far? Who’s getting one next?
Thanks and best Regards
AA
audidudi
Fri Aug 31, 2018 3:03 pm
Two to QR... A7-ANA and A7-ANB
Three to CX...B-LXA, B-LXB and B-LXC
I don't have as much insider information as others on here, but possibly A7-ANC for QR will be next.
StTim
Fri Aug 31, 2018 3:22 pm
Still no autoland capability in the EASA documents.
LaunchDetected
Fri Aug 31, 2018 4:11 pm
patschinger wrote:
Hey Folks
From what i heard it will be a 210t MTOW and max flight cycles multiplied by 3.
Caravelle lover
pabloeing
Fri Aug 31, 2018 4:44 pm
IB A350 number 3 is in production......
patschinger
Fri Aug 31, 2018 6:52 pm
LaunchDetected wrote:
patschinger wrote:
Hey Folks
Someone83
Fri Aug 31, 2018 6:59 pm
Isn’t it their first delivered?
hkcanadaexpat
Fri Aug 31, 2018 7:34 pm
MSN 98 (HU/JD) RTO. First flight scheduled for Monday
MSN 169 (CX#25) on its way home. Delivery #50 of 2018. #4 in August
MSN 217 (CA#3) customer acceptance engine run
MSN 226 (HU/GS) exited paint hangar and returned to the flightline (no pictures yet so not sure which livery its in)
MSN 235 (HX#5) on its way home. Delivery #51 of 2018. #5 in August
MSN 240 (CA#5) new RTO. First flight now scheduled for Monday
trex8
Fri Aug 31, 2018 7:52 pm
patschinger wrote:
Hey Folks
the last digit in the airbus code usually signifies engine difference and usually higher number means higher thrust though not always
are the SQ regional A359s going to be certified for increased cycles too? Original order reports suggest only down grade to 250K MTOW
https://www.flightglobal.com/news/artic ... 18-447149/
Stitch
Fri Aug 31, 2018 8:00 pm
trex8 wrote:
Are the SQ regional A359s going to be certified for increased cycles too? Original order reports suggest only down grade to 250K MTOW
In 2013 when discussing the type, Leahy did say that in addition to lower Operating Weights and de-rated engine thrust, the A350-900 Regional would have a higher flight-cycle limit to reflect being used on shorter stage lengths allowing more turns per day. However he did not give any hints on to what that cycle-limit would be.
LaunchDetected
Fri Aug 31, 2018 9:16 pm
I have a small question about that, what's the point of reducing the MTOW? If it's a maximum number.
Caravelle lover
Kindanew
Fri Aug 31, 2018 9:23 pm
Lower airport charges.
Stitch
Fri Aug 31, 2018 10:33 pm
Airport and Navigation fees are calculated at least in part based on the listed Operating Weights of the frame, so by de-rating them to lower values, and airline can save money on those fees.
qf789
Sat Sep 01, 2018 9:38 am
Cathay Pacific third A350-1000 departing TLS on delivery to HKG
https://twitter.com/CAlloing/status/1035546053158858753
Forum Moderator
CX Flyboy
Sat Sep 01, 2018 12:07 pm
No, this is their 5th. Perhaps you are thinking of Hainan Airlines?
JerseyFlyer
Sat Sep 01, 2018 3:23 pm
If lower MTOW means that a frame can fly 3x more cycles, as suggested re JAL above, due presumably to less wear and tear from lighter take-offs, that is a huge gain.
Worth a large airline keeping a separate sub-fleet limited to the lower weight.
3rdGen
Sat Sep 01, 2018 3:29 pm
I know of some airlines that simply change the official MTOW of an aircraft depending on the sector. A placard is kept in the cockpit which states the aircraft MTOW. For certain sectors it is changed and the aircraft is now magically recertified to a lower MTOW.
It's a way to pay lower airport fees in this case.
And yes increasing weights may require other expenses that one may not immediately realise, such as required extra maintainance, checks etc. There's also a question of the upfront cost, the manufacturers may charge a price for higher weight options. It's a matter of the airline deciding whether they really need that extra weight for their operation or not
لا اله الا الله محمد رسول الله
Stitch
Sat Sep 01, 2018 5:59 pm
Yes, lower TOWs and LWs will help with the wear and tear, though I fully expect Airbus and suppliers will be performing strengthening of the fuselage, wings and landing gear to allow for higher cycle limits, just as Boeing did with the specialized domestic models of the 747 they developed for ANA and JAL.
LaunchDetected
Mon Sep 03, 2018 5:35 am
Thank you for your answers. Reducing the MTOW from 280 to 210 will have a great impact on the economics.
FYI, the A359 "JAL Domestic" Design Service Goal (DSG) would be around 35.000 FC (to be confirmed though).
Entry in service is scheduled in June 2019 with MSN 321 so we have to wait for more detailed informations about this very interesting version.
Caravelle lover
JerseyFlyer
Mon Sep 03, 2018 7:33 am
Could this strengthening work have wider application, such as the higher weight required for the Qantas Project Sunrise?
SXDFC
Mon Sep 03, 2018 7:59 am
When will the first JAL A350 enter final assembly/ paint?
hkcanadaexpat
Mon Sep 03, 2018 8:57 am
MSN 163 (QR#29) preparing to depart on its first CAF #AIB05GF
MSN 172 (QR#31) new RTO (could be change of engines)
LaunchDetected
Mon Sep 03, 2018 9:08 am
Entry in service June 2019 with MSN 321 so let's say April 2019.
Caravelle lover
smartplane
Mon Sep 03, 2018 9:55 am
And engine de-rate translates to lower PBTH costs.
trex8
Mon Sep 03, 2018 2:23 pm
Do higher cycle costs outweigh higher weight costs over the lifetime of the frame or vice versa? I guess it depends on lots of variables but overall can one say its usually less one way or other?
Stitch
Mon Sep 03, 2018 4:01 pm
You are likely looking at different areas for an overall Operating Weight increase compared to a Cycle Limit increase. The goal for a short-range modification is to make the frame stronger specifically in the areas that are stressed during take-offs and landings and eliminating empty weight structure. It will be interesting to see if the domestic birds have winglets, for example, since they are unnecessary for short-haul and they add weight (the 747-400D omitted them for these reasons, though they could be added back when necessary for longer missions).
A domestic frame could end up being lighter than standard, both due to cabin configuration (lighter premium cabin seating and significantly more Economy seats as a percentage of total) and lightening of certain structural elements. In the end, I guess it depends on whether JAL wants these frames solely for domestic and short-haul international use (Guam and Saipan, for example) or if they want the ability to use them on longer missions, as well (like charters to Hawaii).
hkcanadaexpat
Mon Sep 03, 2018 6:22 pm
MSN 98 (HU/JD) first flight #AIB01FR
MSN 172 (QR#31) second test flight #AIB02DW (new engines i believe)
MSN 206 (CX#26) initial engine run
MSN 226 (HU/GS) new engine run (post painting)
LAX772LR
Mon Sep 03, 2018 7:12 pm
Would certainly be cool/interesting to see what an A350 sans winglets looks like... especially an A35K.
Slug71
Mon Sep 03, 2018 7:29 pm
Any movement on MSNs 52 and 55?
Wildlander
Mon Sep 03, 2018 7:32 pm
I suspect that there are few if any changes beyond a paper MTOW reduction and lower max thrust. Easier then to swap "domestic" and international aircraft at heavy check times to even out the hours/cycles across the fleet. I imagine the major cabin monuments will be located so as to facilitate the interior switchover.
Tedd
Mon Sep 03, 2018 7:51 pm
Yep! I`m of the opinion either A350 would look better without winglets, but then I`m not a fan of any winglet,
I think the B787 wing looks spot-on.
