Bostrom
Re: Airbus Beluga XL Production Thread
Thu Jul 26, 2018 4:41 pm
Airbus has released a video of the first flight: https://www.youtube.com/watch?v=zBI_Z4sr9p8
pugman211
Thu Jul 26, 2018 8:01 pm
4th flight already. This frame is putting in some good hours.
StTim
Fri Jul 27, 2018 9:23 am
She is up again now on the 5th flight - quite some speed on this test campaign.
LoganTheBogan
Sun Jul 29, 2018 1:45 pm
Indeed. The faster they certify it, the faster they can get to work with increased production rates.
Anyone who has never made a mistake has never tried anything new.
pugman211
Sun Jul 29, 2018 7:49 pm
The runway at Broughton is like a bee hive at present. The runway is in full swing to being upgraded and resurfaced in preparation to the XL going into service next year.
pugman211
Tue Sep 18, 2018 11:26 am
Just a quick update, the Beluga XL seems to be on it's 24th flight to date and is currently doing touch and go's at Toulouse airport. Looking on FR history some flights are over 2 hours long and others are as short as 20 minutes.
Anyone have a more detailed update of the program?
qf789
Tue Sep 18, 2018 11:41 am
BelugaXL doing a go around this morning
https://twitter.com/Frenchpainter/statu ... 2051656704
Forum Moderator
WIederling
Tue Sep 18, 2018 12:12 pm
trpmb6 wrote:
I didn't realize how stubby it was but it's probably just an optical illusion due to the fuselage height.
1m bigger fuselage and the tail has become "fatter".
( IMU the hold reaches further back into the tail and is thus fuller
and vertical stab has been moved upwards.)
Being overall longer probably does not suffice to keep the proportions of the 1st gen Beluga?
Murphy is an optimist
Erebus
Tue Sep 18, 2018 1:10 pm
Is there any technical reason why Airbus went with with the Trent 700 over the other engines for this role?
StTim
Tue Sep 18, 2018 1:26 pm
Most popular engine on the A330-200 nwhich is the base frame.
Aircellist
Tue Sep 18, 2018 6:27 pm
Still hoping for (lots of) side-by-side comparisons between the new and the old ones
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
LoganTheBogan
Wed Oct 03, 2018 8:02 am
Additional information on the Beluga frames:
https://www.flightglobal.com/news/artic ... xl-452363/
WIederling
Wed Oct 03, 2018 9:15 am
What might the reduced MTOW version be good for?
( apparently a paper derate ?)
flipdewaf
Wed Oct 03, 2018 9:28 am
I was wondering the same, seems like a bit of a weird one as it much reduces flexibility. Unless somehow it means they can declare it as a totally different variant and then make another 5 under the same rules?
Fred
WIederling
Wed Oct 03, 2018 9:46 am
Fred
you think? It is an EASA decision not FAA. Would not work.
LoganTheBogan
Wed Oct 03, 2018 10:50 am
Any airports with weight restrictions where the runways can't be reinforced?
Stitch
Wed Oct 03, 2018 11:23 am
WIederling wrote:
What might the reduced MTOW version be good for? ( apparently a paper derate ?)
As with most paper de-rates, it is likely to reduce airport landing fees and in-flight navigation fees. I would not be surprised if this was a dynamic weight that can be chosen per flight so when they need the range, they can use the higher TOW and when they do not, they can use the lower and save on fees. Airbus offers this option on their commercial frames to airline, as well.
Wed Oct 03, 2018 11:24 am
Lower navigation charges and airport charges which are based upon MTOW. For most of their work they simply don’t need to carry that much weight. Even a pair of wings would not be that heavy, while being bulky it is mainly air.
Francoflier
Wed Oct 03, 2018 11:26 am
Several commercial aircraft have more than one certified MTOW. It allows for lower airport fees where the operator does not need the full take off weight of the airplane. Typically larger aircraft on short routes.
Since Airbus will mostly use the Belugas on short flights across western Europe, I'm guessing that's the goal here.
LoganTheBogan
Mon Oct 15, 2018 12:08 pm
it's been confirmed as route/airport charges.
https://www.flightglobal.com/news/artic ... xl-452601/
LoganTheBogan
Sat Jan 12, 2019 11:01 am
Any update on the XL?
pugman211
Sat Jan 12, 2019 2:27 pm
I've heard it's due to be at Broughton in February to do testing there touch and go's etc etc. The blast fences are up now on the end of runway 04 I think, not sure about the other end.
smartplane
Sat Jan 12, 2019 6:07 pm
And a big incentive to beat possible changes to grandfathering eligibility and application rules.
Aircellist
Sat Jan 12, 2019 8:53 pm
With those different WV, will the exploitant (Airbus, for that matter) be able to declare one WV when the plane flies loaded, and another one when it flies back empty?
smartplane
Sun Jan 13, 2019 12:05 am
Variable MTOW's also a good hedge for the proposed extension of CORSIA to dedicated freight aircraft, as it reduces penalties applied for operating light/empty flights.
pugman211
Wed Feb 06, 2019 7:10 pm
AIRBUS has revealed that the Beluga XL will debut at Broughton on Valentine's day next week (weather permitting)
https://www.google.co.uk/amp/s/www.ches ... 789975.amp
LoganTheBogan
Fri Feb 08, 2019 5:37 am
Any news on when it will be certified?
pugman211
Fri Feb 08, 2019 7:49 am
In the above link it says between September and October this year.
Grizzly410
Fri Feb 08, 2019 9:08 am
Enjoy :)
She spent this week in Sevilla, it's been a while I didn't see that much spotters around the factory !!
In order to be old and wise, one must first be young and dumb.
JerseyFlyer
Sat Feb 16, 2019 12:51 pm
Airbus to build a sixth Beluga XL. And trying to sell the original A300-based frames.
https://www.bloomberg.com/news/articles ... bo-jet-era
pugman211
Sat Feb 16, 2019 12:58 pm
That link goes to an A380 story. And I can't find an article about a 6th Beluga XL anywhere.
Wildlander
Sat Feb 16, 2019 1:53 pm
Scroll down past the A380 story to find the 6th Beluga XL info.
JerseyFlyer
Sat Feb 16, 2019 2:24 pm
pugman211
Sat Feb 16, 2019 3:03 pm
JerseyFlyer wrote:
Thanks, interesting that Airbus is going to add a 6th XL, surely that can only mean A350 and A320 rates are going to go higher, although an increasing number of A320 family travel by road now.
WIederling
Sat Feb 16, 2019 3:25 pm
Either they have found a way to get around the limit of 5 frames under an experimental cert
or they intend to fully certify the XL?
PS and apropos: who certified the original set of 5 -600ST Belugas ?
Already Euro EASA or was that one of the national precursors.
https://www.easa.europa.eu/sites/defaul ... 052010.pdf
original cert by French DGAC ? ( or JAA )
SQ22
Sat Feb 16, 2019 6:51 pm
pugman211 wrote:
A320 going to 63 monthly has already been announced.
https://www.flightglobal.com/news/artic ... 63-455775/
smartplane
Sat Feb 16, 2019 7:36 pm
The number of units permitted is based on the original US approval granted to Aero Spacelines.
By capping at 5 units, the FAA set a precedent, which the EU followed for the Beluga.
No reason why the EA cannot set a new number like 6, or 10, or even removing the capping.
Perhaps Airbus see some commercial opportunities for sales, and are planning to obtain a CoA.
Or the more onerous documentation and reporting environment operating a quasi-commercial operation as experimental, cost justifies making the model 'mainstream'.
N14AZ
Sat Feb 16, 2019 7:49 pm
Interesting. Who might buy them?
Finn350
Sat Feb 16, 2019 8:04 pm
As per the article, specialist cargo operators such as Cargolux and Russian outsize-freight carrier Volga-Dnepr Group.
pugman211
Sat Feb 16, 2019 10:25 pm
Thanks for the link. I was referring to A320 going higher than 63. I've head of rumours of more, but till engine deliveries stabilise I don't think it will happen just yet.
N14AZ
Wed Feb 20, 2019 9:35 am
Ooops, caught in the act for not reading the article properly before posting... :shy:
I cannot imagine that one single operator will take over five units. We shall see...
speedygonzales
Thu Feb 21, 2019 7:46 am
The second Beluga XL is online on FR24 now:
https://www.flightradar24.com/BGA1853/
Ignorance kills. :tombstone:
bspc
Fri Feb 22, 2019 2:10 am
This page has a good test Flight history for the Beluga XL - https://aibfamily.flights/beluga/1824
art
Re: Airbus A350 Production/Delivery Thread - 2019
Wed Mar 20, 2019 12:01 pm
Another BelugaXL (capable of transporting 2 x A350 wings) rolls out:
https://www.flightglobal.com/news/artic ... xl-456781/
Erebus
Thu Mar 21, 2019 6:42 pm
This cap of 5 units, was it the absolute limit for the operation of this class of transport? Or (in theory) can they make a few cosmetic changes, call it a brand new type and add 5 more, sort of getting around the limit for a specific model? The limit didn't quite make sense to me in that regard.
Also, can anyone confirm if the current Beluga uses a 3 man cockpit with a flight engineer? Tried to find pictures but they seem to be quite elusive. :grumpy:
mjoelnir
Thu Mar 21, 2019 6:59 pm
The 5 unit cap is already gone, at least at EASA. Airbus already plans to do 6.
StTim
Thu Mar 21, 2019 7:02 pm
Also the cockpit is from the A330. It will be a two man cockpit
pugman211
Thu Mar 21, 2019 8:19 pm
But also has a load master. However I'm not sure if that role is replacing the flight engineer. I'm also sure I saw a flight global article stating that the B-XL had an area for additional crew seats? Can't seem to find the link though.
StTim
Thu Mar 21, 2019 8:35 pm
But is the load master a travelling role - or an assigned role at each site?
WIederling
Thu Mar 21, 2019 9:00 pm
I could imagine something like a loadmaster.
the base airplane is an A300-600 with FF cockpit and a crew of two.!?
