KarelXWB
Scoot 787 door ripped off at Changi
Mon Jan 08, 2018 7:54 am
Somebody broke the L2 door.
A Scoot Boeing 787-8 had its left-front door ripped from the airframe during preparation for routine maintenance at Singapore Changi airport on 7 January.
According to social media reports, the aircraft had rolled backwards when the chocks were removed without the tug attached but with the aerobridge still connected.
Article
https://www.flightglobal.com/news/artic ... gi-444671/
neomax
Re: Scoot 787 door ripped off at Changi
Mon Jan 08, 2018 8:15 am
I'm gonna go ahead and call this one a writeoff.
That is some expensive as hell "routine maintenance."
strfyr51
Mon Jan 08, 2018 8:46 am
yhis can be fixed. I've seen worse! depending on their insurance? the Boeing AOG team can and will for this. I saw them fix an Air China B747sp that had Far worse damage. Those guys are flat out GOOD!! and the Best I've ever seen!
conaly
Mon Jan 08, 2018 9:16 am
Why? The have been much worse accidents been repaired:
Condor A321 D-AIAF, lamp post fell onto fuselage, fully repaired:
http://european-aviation.net/wp-content ... rash21.jpg
http://pic.carnoc.com/file/151204/15120404115731.jpg
https://www.flickr.com/photos/[email protected] ... otostream/
https://www.flickr.com/photos/[email protected]/29305260211/
Ethiopian B787 ET-AOP, fire in rear cabin damaging the fuselage, repaired:
http://www.nycaviation.com/newspage/wp- ... /snip6.jpg
And even Singapore Airlines' T7 9V-SWB, where the whole right wing burned up completely was repaired and is back in service:
https://i.imgur.com/sZh8eDQ.jpg
Airports 2019: ADB, ALG, AMD, ATL, BOG, BOS, CDG, CTS, DEL, DTW, DUS, EWR, FRA, FUK, HAM, HFT, HIJ, HND, HVG, IST, ITM, JFK, MUC, NGO, NUE, OKA, PHL, SIN, STN, TOS, YYZ, ZRH
Airports 2020: ALG, CTS, FRA, HKG, HND, MSQ, MUC, NUE, TLV, ZRH
devron
Mon Jan 08, 2018 9:27 am
Neomax was being sarcastic and refering to Airliners tendency to write off everythinf asap.
Seriously how much woudl this cost to repear?
teme82
Mon Jan 08, 2018 9:38 am
I feel like some one is going to lose his job. One would think that there would be procedures to taken into account when moving plane from the gate. But I think that is easy fix. Noting like the other issues mentioned in this thread.
Flying high and low
strfyr51
Mon Jan 08, 2018 9:46 am
Because thus is a composite airplane? I'd say $750K- $1.2M. it wil require the interior fwd of the door to be removed at the least and mabe the door frame repaired.
but I doubt a lot of air frame at this picture. It may take 3-6 weeks to repair after the extent of damage has been revealed. Definitely a LOT of engineering work and paper to be generated.
downdata
Mon Jan 08, 2018 10:05 am
I think he was being sarcastic....
conaly
Mon Jan 08, 2018 10:58 am
Sorry, didn't notice the sarcasm.
Faro
Mon Jan 08, 2018 11:04 am
That is...impressively expensive...it is because of CFRP considerations?...
Faro
The chalice not my son
eamondzhang
Mon Jan 08, 2018 11:23 am
I bet you mean the China Airlines 747SP instead of the Air China ones?
This one shouldn't take too long, it's pretty common these days. And uncommon incidents happen at Changi..... Especially when you have a significantly deteriorated level of profession from SATS!
Michael
Wildlander
Mon Jan 08, 2018 11:42 am
I suspect that the door hinge is designed to fail well before the fuselage is at risk of damage. If so, this should be a quick and (relatively) inexpensive fix limited to a new door assembly to get the plane back into service while the old one is repaired.
neutrino
Mon Jan 08, 2018 1:11 pm
You are likely correct.
Not so for some armchair engineers upthread.
Potestatem obscuri lateris nescitis
SomebodyInTLS
Mon Jan 08, 2018 1:22 pm
I agree - while the pictures are "impressive" they don't show any damage at all! I would be more interested in seeing the view from the inside to get an idea if it's just broken hinges or if there's serious damage on the door frame...
"As with most things related to aircraft design, it's all about the trade-offs and much more nuanced than A.net likes to make out."
Flaps
Mon Jan 08, 2018 2:18 pm
Quick yes. I dont think there is such a thing as an inexpensive door repair. Ive seen several 320 series door repairs like that in the $200K range.
Flaps
Mon Jan 08, 2018 2:19 pm
I would definitely think 787 would be north of than figure.
neutrino
Mon Jan 08, 2018 3:46 pm
Flaps wrote:
Relatively inexpensive as was stated. As compared to fuselage frame damage.
Hard to tell but that door might just need only some really minor repairs after its removed and a new one put in place.
Utah744
Mon Jan 08, 2018 4:05 pm
Another question would be "what would it cost NOT to fix?"
You are never too old to learn something stupid
QuarkFly
Mon Jan 08, 2018 5:09 pm
So, some airport ramps have inclines where aircraft roll away without chocks? No parking brakes on aircraft either apparently.
Yes, I would hope doors are designed for this situation... where all damage is limited to the door assembly and the fuselage is undamaged.
Always take the Red Eye if possible
Antarius
Mon Jan 08, 2018 5:23 pm
One roll of duct tape
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
747megatop
Mon Jan 08, 2018 7:37 pm
Plus the cost of hauling it to the scrap yard.
