http://onemileatatime.boardingarea.com/ ... T+Facebook
Irehdna wrote:Big capacity decrease on LAX-JFK.
MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
smi0006 wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
And you know the route is unprofitable how?
With feed from MEL,SYD,BNE with a better opportunity to command yield than AA, I’m not sure it is unprofitable. As QF have stated they would consider the route non-stop from SYD, I don’t see them exiting the route after developing it so, only to restart it non-stop. They have the relationship and market to make it work over the long term.
MaverickM11 wrote:It's a half full widebody on a 5+ hour flight with a prorated fare that is likely vastly inferior to the local LAXJFK fare, and that's before you consider the costs of a 747. There's no way it's profitable.
qf002 wrote:MaverickM11 wrote:It's a half full widebody on a 5+ hour flight with a prorated fare that is likely vastly inferior to the local LAXJFK fare, and that's before you consider the costs of a 747. There's no way it's profitable.
Break even (or slightly loss making) with a 744 should mean good profits with a 789. If it was a major loss maker then it wouldn't have lasted the massive round of cuts five years ago.
MaverickM11 wrote:smi0006 wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
DTWLAX wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
Better than having the aircraft sit at LAX for 16+ hours with no revenue.
Irehdna wrote:Wouldn't it make more sense to have a SYD-LAX-JFK direct flight rather than BNE-LAX-JFK? I would imagine there are more people travelling SYD-JFK than BNE-JFK, so it would make more sense to have the SYD flight rather than BNE flight continue to JFK.
Irehdna wrote:QF could do 7x SYD-LAX-JFK on B789 and perhaps a 4x SYD-LAX terminator, also on the B789 to match the capacity of the A380. I would imagine that SYD is also a more premium market than BNE.
777PHX wrote:DTWLAX wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
That depends if it's turning a profit or not. An aircraft sitting on the ground doing nothing is more profitable than an airplane in the air that's operating at a loss.
Irehdna wrote:Why won't they just make the full BNE-LAX-JFK QF15 rather than making LAX-JFK QF11?
smi0006 wrote:I suppose this brings the question - which route is better suited to 3 weekly flights as a start up? ORD/DFW/SEA?
redroo wrote:I once paid $14,000 for a business class fare from SYD to JFK.
There are who organisation full of Australian executives that would not dream of flying anyone else but qantas to JFK by LAX.
It’s not a low yield route by any means.
Unless you have some way to prove it, you can't say it's unprofitable. It's not like they are flying empty on the round trip. A 789 will make it much more economical.
RyanairGuru wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
Average load is somewhere around 200 people. There is no way that AA, or any other interline partner, has the open capacity to accommodate Qantas’ passengers.
qf789 wrote:Irehdna wrote:Wouldn't it make more sense to have a SYD-LAX-JFK direct flight rather than BNE-LAX-JFK? I would imagine there are more people travelling SYD-JFK than BNE-JFK, so it would make more sense to have the SYD flight rather than BNE flight continue to JFK.
The LAX-JFK sector is just an equipment swap. QF11 originates from SYD and the A380 is simply too big to operate LAX-JFK. As already mentioned the flight gets fed from BNE, SYD & MEL. This is no different than the US3 having domestic flights on say a 737, than an international flight under the same flight number on say a 772. One of the prime reasons QF got the 789 was so they could operate long thin routes which could not be done under the existing fleet of which will primarily been used on routes from the likes of MEL & BNE and to a lesser extent PER where SYD will keep the larger aircraft
777PHX wrote:That depends if it's turning a profit or not. An aircraft sitting on the ground doing nothing is more profitable than an airplane in the air that's operating at a loss.
MaverickM11 wrote:redroo wrote:I once paid $14,000 for a business class fare from SYD to JFK.
No one said anything about SYDJFK being low yieldAAvgeek744 wrote:MaverickM11 wrote:It's a half full widebody on a 5+ hour flight with a prorated fare that is likely vastly inferior to the local LAXJFK fare, and that's before you consider the costs of a 747. There's no way it's profitable.
Sure, it could be the only tag on the planet that is profitable, while airlines can't get rid of 747s fast enough. Extremely unlikely though.RyanairGuru wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
I think that's what it comes down to. I still all but guarantee that the JFKLAX leg is far from positive, but without it, and being able to control the beyond inventory to Australia, the LAX-Australia legs would suffer disproportionately.
RTW00 wrote:Is it a QF's pseudo hub? (if such thing even be called....)
RTW00 wrote:So they are using the aircraft 789 coming from BNE and continuing to JFK as an extension of SYD-LAX fligh QF11. Smart move. Anyway passengers need to clear customs @LAX and helps to connect well timely QF passengers arriving from SYD, MEL and BNE going to JFK.
AAvgeek744 wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
IMO, so they can say they serve NYC. Not sure what the PDEW is. This probably makes more sense than the 744, and pax can still connect to SYD or MEL.
325i wrote:fone if you're in syd but no one wants to change terminals in Sydney. From bne or mel adds 5 hours plus fue to min connecting yime at sydHi folks, there is an alternative to the Los Angeles NewYork route and in my opinion far better.
Sydney to New York via Dallas.
Have done this trip 4 times and in spite of some delays due to New Yorks weather it is quite civil compared to Los Angeles.
BWIAirport wrote:AAvgeek744 wrote:MaverickM11 wrote:Why does QF bother with JFKLAX? It only drags down profitability
Additionally, when they can get ahold of an aircraft that can do JFK-SYD nonstop profitably, they'll already have their feet in the water at JFK. You'll probably see JFK-LAX go away at that point.
Agreed. JFK and LHR from SYD/MEL are coming (likely just SYD to JFK). I expect DFW will get a nonstop by AA or QF.
325i wrote:Hi folks, there is an alternative to the Los Angeles NewYork route and in my opinion far better.
klakzky123 wrote:I think if the AA-QF JV ever gets approved, the LAX-JFK flight will quickly go away. But QF clearly feels invested in having a presence in JFK and will probably want to hold onto its slots there so it can fly nonstop when the time comes. But if the AA-QF JV ever gets approved, then that argument goes away.
