pabloeing
LATAM B787-8 to Victorville (RR engine issues)
Tue Feb 06, 2018 6:27 pm
Amazing.....in this moment a LATAM B787 is going to the desert......more B787's of LATAM in the next month will do the same travel....CC-BBA-BBB-BBC
¿Whats happen with this B787?
The plane today to Victorville is the CC-BBD
https://www.flightradar24.com/LAN9982/1058f8ce
Here in Spanish the news:
https://desdeelpatioblog.com/2018/02/06 ... -de-latam/
Reason: Title updated
pabloeing
Re: LATAM B787-8 to the desert ( Victorville)
Tue Feb 06, 2018 6:29 pm
¿Is not possible another airline for this planes?...only have 3 years.
ILNFlyer
Tue Feb 06, 2018 6:30 pm
Did the airline fail?
Mistral1
Tue Feb 06, 2018 6:38 pm
Guess LATAM will stick only with the B 787-9...
A388
Tue Feb 06, 2018 6:41 pm
I wonder why this 787 is sent to be parked so soon. Was this 787 one of the so-called terrible teens? Or is it phased out because of market conditions that may have resulted in lower income to the airline? Or were some of the 787-8's temporarily leased until the 787-9 arrived? According to the article posted here, there will be more 787's to be phased out.
A388
aemoreira1981
Tue Feb 06, 2018 6:42 pm
Engine replacement at VCV? All of the LATAM Dreamliners have RR Trent 1000s. Norwegian is leasing in A330 metal for the same reason (engine issues).
thgsr08
Tue Feb 06, 2018 6:43 pm
CC-BBA has flown normally letelly as well as CC-BBB and there are schedules flights the following days. Both could be going there to get new LATAM livery or mainteince.
CC-DDB is already painted into LATAM new CS but FR24 doens't show the destination and it just departed from SCL.
:checkeredflag:
thgsr08
Tue Feb 06, 2018 6:55 pm
Well, I've searched a little bit more and I what I found is nothing. HAHAHA.
However, I found a AV's 787 (N784AV) also parked in BOG engineless, it's probably engine problems and CC-BBD might have it replaced,
because there's no reason to park it. LATAM Brasil is expanding from GRU and it's not happening faster because of lack of planes.
Also, LA had retired all 767's schedule flights from SCL and it's slowly deploying their 787 from LIM.
There must be another reason for this Dreamliner to be going to MZJ or VCV.
:checkeredflag:
reffado
Tue Feb 06, 2018 7:05 pm
Upon research, it appears that the reason is, indeed, issues with the RR engines. "The aircraft will be temporarily stored, awaiting a solution for the global problems affecting the RR power plant used."
http://modocharlie.com/2018/02/cc-bbd-p ... Y.whatsapp
CC-BBE should be the next one.
1989worstyear
Tue Feb 06, 2018 7:29 pm
First time I'm hearing about the 763's being retired. The fleet is overall quite young.
Stuck at age 15 thanks to the certification date of the A320-200 and my parents' decision to postpone having a kid by 3 years. At least there's Dignitas...
prchan
Tue Feb 06, 2018 7:31 pm
Not being retired, just being moved to other franchises outside Chile. All JJs 767 came from LA, for example.
Motorhussy
Retired from SCL base and moved to new one ar LIM (it says).
come visit the south pacific
ikolkyo
Tue Feb 06, 2018 7:33 pm
RR needs to get it in gear with these issues, seems things are getting worse rather than better with more and more 787s being stored.
thgsr08
Tue Feb 06, 2018 7:41 pm
All 767's were retired from SCL.
The newer ones went to JJ and others are operating in LIM and BOG with some more to be sent to JJ, not withdraw from use forever. hehe
:checkeredflag:
thgsr08
Tue Feb 06, 2018 7:43 pm
Problem solved.
No one in sane conditions would store a 3y/o aircraft.
:checkeredflag:
Swadian
Tue Feb 06, 2018 7:57 pm
What are the current longest LATAM 767 routes? Are the JJ units in LATAM livery or old red TAM livery?
thgsr08
Tue Feb 06, 2018 7:58 pm
Longest route: LIM - BCN
PT-MSY and PT-MOD in new LATAM livery,
:checkeredflag:
deltal1011man
Tue Feb 06, 2018 8:27 pm
They have a solutions the problem now is shop space to get the engines fixed.
Delta's Trent shop will be coming on-line soon and will help a little bit.
KLM747er
Wed Feb 07, 2018 10:12 am
according to skyliners.net CC-BBD returned to the lease compony.
Boeing 787 -8 38484 118 CC-BBD Latam Chile ferried 06feb17 SCL-VCV on return to lessor.
KLM747er
727200
Wed Feb 07, 2018 2:06 pm
What does DL have to do with 787-8 and RR engines? A plane DL has never taken and regreats. On a different note: I noticed you will inject DL in pretty much every topic you post regardless 8f its germain to topic.
reffado
Wed Feb 07, 2018 2:36 pm
KLM747er
Unless LA plans on getting rid of the 788 altogether... I doubt the accuracy of this. Still, I’m sure we’ll hear more about the situation soon.
wiss
LATAM Chile B788 CC-BBD stored at VCV
Wed Feb 07, 2018 9:01 pm
Hello,
Yesterday the LATAM Chile B788 CC-BBD positioned from SCL to VCV for temporary storage. According to the specialized Chilean aviation website ModoCharlie, and many discussions in different facebook groups, the reasons for this storage are related to the low reliability of the RR engines. For me it seems to be a bit weird why this plane will be stored in VCV instead of having it in SCL or another Chilean airport.
This frame is only 4 and a half years old, and considering that SCL experienced a record growth in passengers last year, the decision of LATAM (as the main operator in this airport, by far) to park one B788, might indicate that this particular plane had so severe problems, that it was better to store it than having it at least partially active and helping with this passenger growth.
Is important to note that sister plane CC-BBE hasn't flown in a week, possibly due to the same reasons.
Have any other airlines with RR equipped B787's decided to temporary park their planes while the issues are solved?
http://modocharlie.com/2018/02/cc-bbd-primer-787-8-dreamliner-de-latam-que-sera-preservado-temporalmente/
jordanh
Wed Feb 07, 2018 9:10 pm
Perhaps you should read his post before complaining. You might "regreat" your comments.
Our RR 787's are going to have their engine repairs done. Delta's Technical Operations will be starting to do repairs. They don't have to fly the same plane in order to be qualified to repair these engines.
DL757NYC
Wed Feb 07, 2018 9:11 pm
Deltaman is one knowledgeable person. He injects DL look at his name. He shares a lot of good info. Chill out
boefan
Re: LATAM Chile B788 CC-BBD stored at VCV
Wed Feb 07, 2018 10:06 pm
wiss wrote:
Hello,
Airlines that have parked their 787s are :
ANA : 9 Aircraft (2 inside hangar getting the fix at the moment) rest stored [8 days-1.5 month]
Air China : 1 aircraft (next one to get new engines ) [20+ days ]
Air New Zealand : 3 aircraft [2 months]
Avianca : 1 aircraft [4 months] +1 maintenance in EZE
LAN : 2 aircraft
Thai Airways : 1 aircraft maintenance for over 20 days getting new engines also
Virgin Atlantic : 2 aircraft [4+ months]
can't provide source for RR shipments (confidentiality) but FR24 is a good start to search for grounded 787s
QXAS
Thu Feb 08, 2018 1:12 am
When did the issues with the Trent come up? What are the issues specifically? Is it just a 787 problem or could it also effect the A350 down the road? How has the Trent been selling on the 787 since these issues popped up? Pardon my ignorance on the matter.
I am NOT an employee of any airline or manufacturer. I speak for myself, not on the behalf of any company.
yeogeo
Thu Feb 08, 2018 1:57 am
ANA : 9 Aircraft (2 inside hangar getting the fix at the moment) rest stored...
So that explains why I saw at least 2 NH 788's sitting at HND yesterday with empty cowlings.
yeo
7673mech
Thu Feb 08, 2018 2:54 am
DL has a very successful MRO business that services aircraft and engines outside of it's fleet.
O530CarrisPT
Thu Feb 08, 2018 3:15 am
It seems that the Rolls-Royce Trent 1000 engines suffer from corrosion issues which are causing the blades of the engine to crack. I also don't know if has chances to also affect the A350XWB (powered, as is known, by the Rolls-Royce Trent XWB), but it seems that may not likely be the case, since the Trent XWB, despite being part of the same family, is completely different from the Trent 1000.
Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity. - Martin Luther King Jr. (1929-1968)
727200
Thu Feb 08, 2018 3:54 am
I stand corrected.
lightsaber
Thu Feb 08, 2018 4:15 am
How many engines are now effected. This is effecting more airframes than I expected. The initial reports were a small fraction of engines.
Lightsaber
Winter is coming.
seabosdca
Thu Feb 08, 2018 7:22 am
LAN : 2 aircraft
Ouch. That's going to cost RR a few pennies.
O530CarrisPT
Thu Feb 08, 2018 7:55 am
This Trent 1000 corrosion issue is also being costly for Rolls-Royce and is already compromising the operation of the airlines which are affected by this problem (with the fact that the problem is forcing airlines to ground their 787s).
RB211trent
Thu Feb 08, 2018 8:03 am
Lightsaber
It has nothing to do with RR issues the aircraft plus other -8s are going into long term storage in VCV.
yeogeo
Thu Feb 08, 2018 10:46 am
Then how do you explain the link above which reads (roughly):
"Today (6 Feb) at 2:37 p.m... from Arturo Merino Benítez Airport (SCL), bound for Victorville (VCV) the CC-BBD registered plane, the first Boeing 787-8 Dreamliner from LATAM, will be stored for an undetermined time at that US airport.
[It] will remain for a period in Victorville, waiting for the global problems of its RR power plants to be solved."
yeo
pabloeing
Thu Feb 08, 2018 10:51 am
boefan wrote:
wiss wrote:
Hello,
LAN : 2 aircraft
¿4 months for a engine change in Virgin?
RB211trent
Thu Feb 08, 2018 11:06 am
yeo
What’s their source? LATAM are removing 4 787-8 from their fleet. Other airlines are interested.
yeogeo
Thu Feb 08, 2018 11:14 am
Unknown.
What's your source for "long-term storage"?
jordanh
Thu Feb 08, 2018 11:19 am
"... the aircraft plus other -8s are going into long term storage in VCV" means "RR cannot supply the parts promptly and these aircraft will be out of operation longer than expected."
SheikhDjibouti
Thu Feb 08, 2018 12:03 pm
Just for idle curiosity I checked FR24.
At this precise moment, worldwide it shows 174 Boeing 787-8 airborne (or with active ADS-B whilst still on the ground).
And - I genuinely have not made this up - that is exactly 50.000% of the 348 that Wikipedia tells us have been delivered. :lol:
Of course somebody should replicate that exercise with another a/c type to see how it compares.
juliuswong
Thu Feb 08, 2018 12:06 pm
It seems RR can't get a grip on the issue, while solution has been found, the fixing is taking longer than expected. If an airline has a big 787 might not be an issue, but what if the airline has only a small fleet? Royal Brunei for example has cancelled or ground their flight a few times over the past few years since its introduction. Their operation was severely impacted.
- Life is a journey, travel it well -
rbavfan
Thu Feb 08, 2018 12:12 pm
Delta has a trent engine overhaul facility coming online that will do MRO in the US. They have RR approval to do overhauls. So yes this is germane to topic of engine overhauls.
Slash787
Thu Feb 08, 2018 12:39 pm
Iran Air could have used these planes.
RB211trent
Thu Feb 08, 2018 12:42 pm
Yes, Delta Tech Ops will be the MRO in the US after TAESL closed. The T7000 is essentially a T1000 and they will be overhauling both, so why should DL not be relevant?
RB211trent
Thu Feb 08, 2018 12:44 pm
Total rubbish
trex8
Thu Feb 08, 2018 12:45 pm
pabloeing wrote:
boefan wrote:
wiss wrote:
Hello,
LAN : 2 aircraft
a day or two for the change, 4 months+ waiting for the engine
gokmengs
Thu Feb 08, 2018 2:00 pm
RB211trent wrote:
Total rubbish
So what are you saying? Is it false info? These aircraft are going to desert for other reasons please tell us
Yaşa Mustafa Kemal Paşa Yaşa, Adın Yazılacak Mücevher Taşa
PW100
Thu Feb 08, 2018 4:54 pm
Amazingly, the answer is already in the thread . . . :
So in other words: a fix has been designed and approved. Parts are available. But the enigne shops simply do not have sufficient capacity to turn all those engines in short time frame.
Speedbirdasia
Fri Feb 09, 2018 4:48 am
According to Skyliner Aviation website LATAM has retired the four planes back to Boeing due to wing root cracks.
thgsr08
Fri Feb 09, 2018 6:39 am
yeo
LATAM is not givin up on their 4 788's. The reason they're (will be) stored is only because of the engine issue.
:checkeredflag:
