Springs1816 wrote:If there are no restrictions below 51 seats then how come someone can't come up with a decent replacement? I know the economics at that passenger amount aren't ideal but if airlines are still using CR2s and 145s wouldn't anything newly designed be better.
hOMSaR wrote:Springs1816 wrote:If there are no restrictions below 51 seats then how come someone can't come up with a decent replacement? I know the economics at that passenger amount aren't ideal but if airlines are still using CR2s and 145s wouldn't anything newly designed be better.
That's basically the problem. Nobody is going to spend the money necessary to come up with a new design for a plane whose economics and size aren't going to be ideal. Airlines won't want to pay the prices a manufacturer would have to charge in order to pay for the development costs. Eventually you'd need something, but they're not at the point yet where they're desperate to replace 50-seaters due to age (right now it's mostly economics, and new types don't solve that).
Springs1816 wrote:Did you read Cranky Flier too?
Varsity1 wrote:Low end mainline aircraft will take the current 76 seat routes, 76 seaters will take the current 50 seat routes on less frequency.
dc10lover wrote:Isn't Delta Connection using some Embraer 175's into a 70 passenger jet? Why not AA and UA do the same? Especially UA of course.
LOWS wrote:Springs1816 wrote:Did you read Cranky Flier too?
I did, but after I posted this! He usually has good stuff.
I've been thinking about it for a while, but the impetus was that I just booked a trip on UA that's literally:
Outbound: 175 to 145
Inbound: 170 to 175
For major spoke to hub or even hub to hub, it's still incredible to me that the best UA can do is a 145 or 170. Especially when your competitors are running multiple 717s or 737s/319s at the same time on what is basically a spoke to spoke route for them.Varsity1 wrote:Low end mainline aircraft will take the current 76 seat routes, 76 seaters will take the current 50 seat routes on less frequency.
This is about what I figured. Which makes it seem nonsensical to me that UA hasn't bit the bullet and ordered CS100s or E2s.
Trying to get more scope is just going to upset the pilots (rightly so) and delay the inevitable small aircraft order. Especially if Scott Kirby is so hell-bent on optimizing the connection possibilities at the hubs: http://crankyflier.com/2018/01/29/a-conversation-with-myself-about-uniteds-domestic-growth-plan/
LOWS wrote:Hi all:
It's a fact that the CR2 is rapidly approaching the end of its life as the frame, gear, etc. just weren't originally designed for a regional jet with high cycles. I can't imagine the E145 is much better off.
Q400 is an option CO tried right before the merger. I flew one in 2011 and it seemed ok,
flyguy84 wrote:They are trying to fix the problem created by Smisek but they simply don’t have enough mainline aircraft.
DiamondFlyer wrote:There's a large number of 200's in IGM, it may well be a simple equation, short term, of parking the high cycle birds in service now to replace them with birds that have been there for years, sitting, not accumulating cycles and hours. United is certainly more dependent on the 50 seater than anyone else, and it's going to hurt them more. Long term, Delta has made it clear that by 2023 ASM on 50 seaters is going to be down 50% from today. I would expect that when it gets to that, OO will be the sole 50 seat operator (well, one of 3 DCI carriers in general).
dc10lover wrote:dc10lover wrote:Isn't Delta Connection using some Embraer 175's into a 70 passenger jet? Why not AA and UA do the same? Especially UA of course.
I found something to add to my post. It's called the E75S. Interesting though.
https://flightaware.com/live/aircrafttype/E75S
93Sierra wrote:The 50s ( The Deuce and the jungle jet) are doing great it today's market. Pax may not like them, but as a pilot that flies one for one, we are almost always full. From larger markets to small town America we are constantly at a 90 percent plus load percentage. And while daddy d or uncle u, tries to figure out its scope position and where to place aircraft, the 50s wil solider on. There are so many markets where a larger 70 seater doesn't work. The 200 is built much better than the 145 as far as construction and cycles.
MIflyer12 wrote:flyguy84 wrote:They are trying to fix the problem created by Smisek but they simply don’t have enough mainline aircraft.
If that's the case they should be using $3 Billion on aircraft purchases and leases, not share buybacks.
http://newsroom.united.com/2017-12-07-U ... se-Program
Spacepope wrote:DiamondFlyer wrote:There's a large number of 200's in IGM, it may well be a simple equation, short term, of parking the high cycle birds in service now to replace them with birds that have been there for years, sitting, not accumulating cycles and hours. United is certainly more dependent on the 50 seater than anyone else, and it's going to hurt them more. Long term, Delta has made it clear that by 2023 ASM on 50 seaters is going to be down 50% from today. I would expect that when it gets to that, OO will be the sole 50 seat operator (well, one of 3 DCI carriers in general).
I'm thinking you may be correct there for a short while at least. CRJ2s are limited to what? 40,000 cycles? You may be able to park one that's cycle limited (and there is a bubble of these birds out there coming down the pipe) and pick up one that will soldier on for another 5 years, but in the end, that's just a band-aid that kicks the can down the road a little further that in the end leaves you even less slack to address the issue when it rears its head again. How's that for metaphor salad?
bomber996 wrote:dc10lover wrote:dc10lover wrote:Isn't Delta Connection using some Embraer 175's into a 70 passenger jet? Why not AA and UA do the same? Especially UA of course.
This is simply an ATC code to differentiate between the two different types of E175s. The E75S is the older style winglets, and the E75L is the newer style winglets. Think of it at E175 Short wing (E75S) and E175 Long wing (E75L). All new deliveries of E175s are the E75L.
Peace
DiamondFlyer wrote:bomber996 wrote:dc10lover wrote:I found something to add to my post. It's called the E75S. Interesting though.
Peace
Correct, but Embraer, Delta and Skywest are all calling the 70 seat 175 a 175SC, as a marketing term. Very confusing.
WorldFlier wrote:hOMSaR wrote:Springs1816 wrote:If there are no restrictions below 51 seats then how come someone can't come up with a decent replacement? I know the economics at that passenger amount aren't ideal but if airlines are still using CR2s and 145s wouldn't anything newly designed be better.
The Chinese would do it. The question is if anyone (outside of China) will buy it...or if they could make it on-time, on-spec, etc.
See: ARJ-21, C919, etc
Flighty wrote:93Sierra wrote:The 50s ( The Deuce and the jungle jet) are doing great it today's market. Pax may not like them, but as a pilot that flies one for one, we are almost always full. From larger markets to small town America we are constantly at a 90 percent plus load percentage. And while daddy d or uncle u, tries to figure out its scope position and where to place aircraft, the 50s wil solider on. There are so many markets where a larger 70 seater doesn't work. The 200 is built much better than the 145 as far as construction and cycles.
I think this is a worthwhile view. Others have said the unit cost of the 50 is bad, and they are right too. But I especially agree with your point that "there are so many markets where a larger 70 seater doesn't work." In my experience as a former HQ employee, this was true. What you describe, constant 50 seat loads, really suggests unmet demand, and a 70 seater will be better. But constant 37-42 seat loads on CRJ, those can be profitable to the network on a 50 seater, but would be a piss poor result on a 70 seater. There are still many of those markets.
The load carrying ability of the 50 seaters is a problem, but they provide a lower trip cost that small cities need. The 50 seater is what you use to keep your network active along its weaker areas. The next step is not necessarily expansion; the next step may be cutting the flight entirely. Not only depriving small markets of flights, but eliminating the pilot jobs as well.
MIflyer12 wrote:50-seaters came into being ~25 years ago on two things:
1. A wave of U.S. pilots willing to work for low wages expecting (not merely hoping) to move into mainline with ever-rising wages. 9/11 and a bunch of bankruptcy cram-downs showed the fragility of that plan.
2. Very low and quite stable fuel prices.
LOWS wrote:Q400 is an option CO tried right before the merger. I flew one in 2011 and it seemed ok, minus the usual turbulence of hot days out of IAH.
Springs1816 wrote:Did you read Cranky Flier too? Kind of wrote about that today with UA and the scope clauses. If there are no restrictions below 51 seats then how come someone can't come up with a decent replacement? I know the economics at that passenger amount aren't ideal but if airlines are still using CR2s and 145s wouldn't anything newly designed be better.
raylee67 wrote:Would manufacturers like Dassault or Gulfstream be interested in stretching their business jets to make it a 50-seater? That's where CRJ came from in the first place. While manufacturers are not willing to put money to develop a clean sheet 50-seat RJ, a stretched new business jet would surely have better economics than the 20-year-old CRJ or ERJ?
TWA772LR wrote:How much weight savings would there be if a new 50 seat RJ came out made of CFRP versus a current gen aluminum RJ?
TSS wrote:
First off, what are the cycle limits and maintenance requirements of current Dassault and Gulfstream business jets versus CRJs and ERJs?
ThatsNotAPlane wrote:From an ATC standpoint, I hope whatever it is can climb AND speed up at the same time. Not one or the other...
JBo wrote:The simple reason is that turboprops are far more economical than jets for aircraft with 50 or fewer seats, but despite that fact no one wants to operate turboprops because of the negative perception.
Flighty wrote:
How about a re-engine option for the CR7-CR9?
