MIflyer12 wrote:So, what engine on what frame of 100+-30 seats would be appropriate?
CRJ900 wrote:Delta's B717s probably have a lot lower cycles on them, Hawaiian could buy some of the newest from that fleet as DL is introducing the CS100.
diverted wrote:CRJ900 wrote:Delta's B717s probably have a lot lower cycles on them, Hawaiian could buy some of the newest from that fleet as DL is introducing the CS100.
Honestly, something like that could be a good idea....have HA and DL sublease a few 717's off eachother for a few years, say in between heavy C or D checks. Would allow HA to extend the life of their fleet, by rotating 717's to DL to be used on less cycle intensive flying. Of course there's no reason for DL to want to do that, other than if HA were to offer a nice reason to ($$) but I see no reason they couldn't rotate frames through. The DL birds won't accumulate THAT many cycles over a 4-5 year lease, and it would help balance the cycles/hours on HA's birds.
RyanairGuru wrote:MIflyer12 wrote:So, what engine on what frame of 100+-30 seats would be appropriate?
ATR-72, but that lacks cargo payload. Other than that I can’t think of any aircraft capable of doing 18 30 minute sectors per day. The 717s are good for another 10+ years and I expect HA will fly them until the wings fall off.
Amiga500 wrote:What cruise altitude do they run at? If they topped out at say, FL100, then you wouldn't put a complete pressure cycle on the fuselage.
Amiga500 wrote:RyanairGuru wrote:MIflyer12 wrote:So, what engine on what frame of 100+-30 seats would be appropriate?
But its not that simple either.
lightsaber wrote:I think if HA goes turboprop, they will wait for the next generation.
TheDBCooper wrote:I feel "next HA aircraft must be capable of X amount of cycles, just like the B717" to be one of those A.net myths.
The number one fact is the 717 is going to be leaving the HA fleet at some point in the future. If the replacement aircraft they choose can't handle those sorts of cycles, then the schedule will need to be adjusted, or alternatives measures are taken. Whether that is reducing the frequency of the schedule, or more aircraft working the same schedule, who knows?
trex8 wrote:What makes the BR engines on the 717 so much better for these short hops than a CFM ( or IAE) on a 737 or A320 etc
NWAROOSTER wrote:Hawaiian Air 717s have a lot of cycles and are exposed to good amount of salt water air. Which may expedite corrosion on them. I question whether they can get another 10+ years out of them before the wings fall off. They may wind up as parts planes for Delta.
lightsaber wrote:Agreed, but you still must service them off weight off wheels. A touch and go counts as a cycle. The LOV doesn't change based on the type of cycle.
Low altitude cruise has a known issue, it doesn't dry out the airframe (there is condensation during decent). So there can be more corrosion...
I think if HA goes turboprop, they will wait for the next generation. Or MRJ... Or C-series... or E2 (190 or 195, I'm not sure which, it could be both).
Lightsaber
msp747 wrote:NWAROOSTER wrote:Hawaiian Air 717s have a lot of cycles and are exposed to good amount of salt water air. Which may expedite corrosion on them. I question whether they can get another 10+ years out of them before the wings fall off. They may wind up as parts planes for Delta.
How old was the DC-9 fleet when HA retired them?
