mcdu wrote:It doesn’t appear to be affecting the other 737 operators with mass cancellations.
MIflyer12 wrote:mcdu wrote:It doesn’t appear to be affecting the other 737 operators with mass cancellations.
AA/DL/UA have much smaller fleets of early-delivery 737NGs, both with respect to count and as a fraction of mainline aircraft. This situation is entirely predictable. Watch Alaska.
smokeybandit wrote:How long would it take to inspect engines? Rephrased, how long would a plane be out of service?
Depending on the inspectors, 6-8 hours for both engines if they find no problems and another 6-12 per engine if they have to replace any fan blades.
smokeybandit wrote:Would Southwest be obliged to publicly announce the results of their testing? I'd sure be embarrassing to have to say "we found similar issues in X% of our engines"
skyharborshome wrote:smokeybandit wrote:Would Southwest be obliged to publicly announce the results of their testing? I'd sure be embarrassing to have to say "we found similar issues in X% of our engines"
This was my first thought when inspections were announced; glad I am not the only one. My answer:
Probably not. However, let us assume that they announce no other engines had the same issues. That would lead us to believe one of two things:
1) WN had two extremely unlikely events in their fleet that were each one-off anomalies and we are to trust it will not happen again
2) The inspection process being used cannot detect the defect/fatigue until it reaches a point where it separates and causes engine destruction
This would pose a very interesting PR conundrum; if a few cracks were found, do you say they were detected and fixed admitting that there is now a known issue and the inspections spared further damage and possibly a life or two or do you say you found none and trust the public to go "ok"? Each has their own set of pros and cons.
As of now, all I have heard are lots of inspections and clearing aircraft to return to service. I would think to reassure the flying public at large they will report a few older engines did have repairs performed out of an abundance of caution. Only time will tell.
flyingclrs727 wrote:I bet these emergency inspections are a lot more expensive than the routine inspections the FAA wanted would have been.
TWA302 wrote:I am going to assume that each fan blade will have to be removed and inspected. I found a pretty detailed video on the process.
https://www.youtube.com/watch?v=V9EJLE9_ELI
sunking737 wrote:Better to do what is needed, then to have another engine failure. I'm sure every 737 operators are giving every plane worldwide extra TLC.
mcdu wrote:Yesterday southwest canceled around 50 flights for engine inspections. Today they are already at 111 flights canceled. Are the findings worse than anticipated? It doesn’t appear to be affecting the other 737 operators with mass cancellations.
https://www.cnn.com/2018/04/23/us/southwest-flight-disruption/index.html
chrisair wrote:TWA302 wrote:I am going to assume that each fan blade will have to be removed and inspected. I found a pretty detailed video on the process.
Interesting video. I find it fascinating that something so expensive and built so precisely needs Vaseline to lubricate the blade removal.
And the guy removing it is wearing a tie.
INFINITI329 wrote:skyharborshome wrote:smokeybandit wrote:Would Southwest be obliged to publicly announce the results of their testing? I'd sure be embarrassing to have to say "we found similar issues in X% of our engines"
WN wont release the findings voluntary I think.... I am almost certain that those findings will be subpoenaed.. the likely hood of the results staying under wraps are slim to none
dmg626 wrote:It will all be ok now, Chuck Schumer managed to find a camera crew and made an announcement that he is calling on the FAA to hold airlines more accountable for maintenance, thank God for Chuck Schumer, I don’t know how we would be able to manage life without his guidance.
barney captain wrote:mcdu wrote:Yesterday southwest canceled around 50 flights for engine inspections. Today they are already at 111 flights canceled. Are the findings worse than anticipated? It doesn’t appear to be affecting the other 737 operators with mass cancellations.
Just for perspective, 111 flights equates to less than 3 percent of the 4000 daily flights. I'm not sure that qualifies as "mass cancellations".
mcdu wrote:barney captain wrote:mcdu wrote:Yesterday southwest canceled around 50 flights for engine inspections. Today they are already at 111 flights canceled. Are the findings worse than anticipated? It doesn’t appear to be affecting the other 737 operators with mass cancellations.
It looks like WN is up to 129 cancels 3% of schedule with 788 delays or 29% of their schedule. That appears to be a mass schedule impact. AS has the next highest cancels with 10 and that is a company struggling in a merger. The next US carrier is AA with a total of 5 cancels. So I would argue that the WN cancels are massive in comparison to their peers.
Tucker1 wrote:While they're at it, will they inspect more parts of the engine? Maybe a full over?
Are all of those cxnld and delayed flights related to the AD, or are they all things operationally? How does 788 delayed flights compare to an average day?
Considering what's going on, I'm surprised it's not more.
32andBelow wrote:[twoid][/twoid]TWA302 wrote:I am going to assume that each fan blade will have to be removed and inspected. I found a pretty detailed video on the process.
Are you sure they aren’t just NDT them on wing?
I don’t track WN on a daily basis. I do know they rank very low in on-time percentage but I would be surprised if they have 30% of their flights delayed on a daily basis. It could just be the normal operational difficulty that WN has on a daily basis with the airplane groundings added into the mix. You are a WN guy so I am sure you could share the daily delay/cancel rate with everyone.
PlanesNTrains wrote:dmg626 wrote:It will all be ok now, Chuck Schumer managed to find a camera crew and made an announcement that he is calling on the FAA to hold airlines more accountable for maintenance, thank God for Chuck Schumer, I don’t know how we would be able to manage life without his guidance.
Politicians make me sick, particularly in an election year. Yes, they do some good as well. Some.
WN does have abysmal on-time performance. For the month, only 46.1% of their flights have departed on-time. This is about normal for them, give or take a few percentage points.
PITingres wrote:"Negligent" is a word fraught with legal implications. WN were not negligent. They understandably didn't want to disrupt their operations to the extent we're seeing today, for a situation that at the time appeared to be a one-off. (And, without an inspection mandate, I doubt that they would have gotten as much help from CFM, making it even more of a mess.) With 20-20 hindsight, AND assuming that the inspections turn up something useful, we can say that they should have disrupted things anyway, but there's no way that anyone could have predicted that from the initial incident. And we still have no proof that the inspections would have found anything relevant to the accident.
At this stage, calling WN negligent is just lawyer baiting IMO.
PITingres wrote:I have never heard that WN fought the need for inspection. They fought the timeframe for the original order because it wildly under-estimated the number of engines that WN would have to inspect. That's not quite the same thing.
I don't disagree that there should have been more urgency felt all around, but again, that's 20-20 hindsight. Nobody predicted that another fan blade would break AND shred an inlet AND hit just the wrong place on the fuselage within the next couple years. In any case, it was the word "negligence" that I was (and am) objecting to.
