AC853
WestJet uses 737Max on Alberta to Hawaii
Wed Apr 25, 2018 12:43 am
I noticed WestJet WS1884 (YEG-OGG) and WS1851 (OGG-YYC) today are operated by a B737 Max instead of the normal B763. As the seasonal service is coming to a close are they using the 737 with less less passengers or does it actually have the range to fly non-stop with a full load? Next season WestJet will be the only carrier flying widebodid aircraft to Hawaii from Canada. Hope this does not change.
WJtter
Re: WestJet uses 737Max on Alberta to Hawaii
Wed Apr 25, 2018 12:48 am
The 767 that was supposed to operate had a MNTC issue. So it was down gauged to a MAX for the flight yesterday.
Thenoflyzone
Wed Apr 25, 2018 12:58 am
B737 MAX 8 range is 3550 nm with 162 passengers.
YEG-OGG is 2760 nm. So even with some headwinds, the route is doable on a Max8.
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
Newbiepilot
YEG-OGG should be within 737-8 range. It is 2800nm, which is shorter than some routes that the 737MAX flies which are over 3000nm. OGG-YEG may be a problem due to the short runway at OGG.
Next year GOL is planning nonstop flights from Brazil to Florida with the MAX which excees 3200nm.
Acey
Wed Apr 25, 2018 1:35 am
6 hours, 44 minutes flying time this morning on YEG-OGG. Climbed directly to FL380.
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
