BravoOne
Re: Flying 2000 miles over open water in twins powered by CFM56-7
Tue May 15, 2018 10:01 am
ETOPS applies for Part 121 operators anytime you are operating over a route that contains a point farther than 60 minutes flying time from an adequate airport under standard conditions in still air. The FAA defines an adequate airport in Part 121 & 121.7. So yes be it land o water the rules apply regardless.
Worth noting that this does not apply to Tris, Quads or Freighters.
c933103
Tue May 15, 2018 10:10 am
I thought they now applies to tri/quad when they are 180 mins away from adequate airport under singl engine out situation
When no other countries around the world is going to militarily stop China and its subordinate fom abusing its citizens within its national boundary, it is unreasonable to expect those abuse can be countered with purely peaceful means.
BravoOne
Tue May 15, 2018 10:30 am
You are correct but 180+ is an whole new ballgame and the 737, 757, 767 are not players. I should have been more explicit.:) The most common ETOPS extension is a 207 minute rule for Asia to the US West coast.
mjoelnir
Tue May 15, 2018 12:23 pm
IMO actually the only current problem with flying an aircraft powered by CFM56-7 2000 miles over open water is, when the CFM56-7 are rather old and do not have had a recent fan blade inspection. I am rather astonished that those problems have not lead to ETOPS restrictions for those engines.
BravoOne
Tue May 15, 2018 12:29 pm
How do you know what has, or hasn't been done regarding these issues??
mjoelnir
Tue May 15, 2018 2:23 pm
There have been two uncontained engine failure due to failing fan blades of high cycle/hours CFM56-7. After the first failure the airlines were protesting a fast inspection of those fan blades. SW for example would not accept a 18 month target for those inspections. After the second failure, their seem to be now an accelerated inspection regime in place. I have neither read about when those inspections should be finished, nor about an ETOPS restriction by the FAA on frames having one or two of those engines.
If you have better information, please tell me, in the absence of some information I would regard flying ETOPS on a frame having CFM56-7 as not confidence inspiring.
BravoOne
Tue May 15, 2018 3:21 pm
Based on your answer ..you don't know other than what you find on the Net? hanks for sharing:)
flyingclrs727
The only ETOPS rated 737's WN has are 737-800's which are much newer.
