rj777
Effect of Kilauea eruption on Hawaii Aviation
Mon May 14, 2018 10:46 pm
Has anybody heard anything of how the eruption of Kilauea is affecting aviation in the area?
DC10LAXJFK
Re: Effect of Kilauea eruption on Hawaii Aviation
Mon May 14, 2018 11:17 pm
Just got back from OGG, flew out Thursday 5/10. While I was there, the tradewinds were blowing (I believe from the Northeast), so no impact to Maui (so likely none of the other islands) and no impact to ITO or KOA as of then.
However, the tradewinds started dying down on Thursday the 10th and they were expecting that some of the vog (volcanic fog) was going to start to make its way over, along with the sulfur by Friday the 11th, so they were a bit worried about breathing impact, especially those with difficulties. Not sure whether that happened or got worse or better.
My guess is that, unless there's an explosive event that shoots ash above 1000 fee and the winds start coming from the southeast), there won't be an impact to commercial aviation. I believe they've imposed a no fly zone over the area, though. Only caveat is that ITO could be impacted before KOA or OGG and only if bad HNL.
I'd also suspect that if you start to see a lot of 1/2 way turnarounds or diverts to HNL, then that will be the sign that things have gone downhill fast.
azjubilee
Mon May 14, 2018 11:51 pm
There's been no impact yet, from the Kilauea eruption. Even on non tradewind days, the vog that is often apparent, isn't impacting people and aviation more than it usually does. As mentioned, it would likely take an explosive eruption, which they're warning about, for it to make negative impacts on aviation in the state. Even then, the impact would be difficult to predict.
zululima
Tue May 15, 2018 12:17 am
There's a lot of media hype around the eruption, but I wouldn't expect any major aviation impact. Kilauea just doesn't erupt that way. Hawaii is all shield volcanoes and not the explosive stratovolcano type where gasses from a subducting ocean plate build up under a continental plate and then blow skyward.
I didn't get a 'Harumph' outta that guy!
Bobloblaw
Tue May 15, 2018 12:19 am
not that type of volcano.
PSU.DTW.SCE
Tue May 15, 2018 1:26 am
I was too young to remember but I thought some of the eruptions back in the mid-80s impacted ITO and KOA at times with vog.
rj777
Wed May 16, 2018 5:37 pm
Kilauea is now a Code Red- meaning a significant danger to aviation:
https://www.cnbc.com/2018/05/16/ash-clo ... ation.html
aloha73g
Wed May 16, 2018 7:04 pm
The vog last week Friday (5/11) was bad, but no worse than any other bad "voggy day" in the past 30+ years that Kilauea has been erupting.
If there is a 1924 style explosive eruption at Kilauea, depending on the winds at that time Hilo is most likely to be affected as in 1924 the ash cloud traveled about 15 miles north of Hilo. Other than a few possible interisland flight cancellations or delays I don't see much impact ... Keep in mind that the ash cloud has to go higher than 13,000 feet to get past Mauna Loa which is blocking Kona and the rest of the islands. Anyone who has ever been to Kilauea knows how imposing and HUGE Mauna Loa is. The ash cloud yesterday only reached 12,000 feet and was blown out over Ka'u and then the ocean (away from ITO and KOA).
-Aloha!
Aloha Airlines - The Spirit Moves Us. Gone but NEVER Forgotten. Aloha, A Hui Hou!
BN727227Ultra
Kīlauea erupts to FL 300:
Thu May 17, 2018 6:18 pm
it's not new magma, but pulverized old rock that isn't as damaging to fan blades--but nothing you want to fly through. Discrete explosion that lasted a few minutes. The govt scientists state that there could be more, maybe bigger eruptions, but nothing like Eyjafjallajökull in terms of a high-traffic area. Probably won't even affect KOA, but it might put down some ash at ITO. Of course it happened before sun-up, so no photos.
Sooner787
Re: Kīlauea erupts to FL 300:
Thu May 17, 2018 6:36 pm
I just read the plume was drifting southeast, so shouldn't effect the airways int HNL for the time being.
Spacepope
Thu May 17, 2018 6:43 pm
As a geologist, I just want to point out that if you're flying through magma, you've got bigger problems.
New rock, old rock, in the end it's all ash and terrible on turbines.
reffado
Thu May 17, 2018 7:27 pm
This comment made my day.
BN727227Ultra
Thu May 17, 2018 7:31 pm
No doubt :-) I don't remember where I read it, but the tenor of the article was that tephra had a nasty habit of melting in the combustion chamber and glazing the turbines, while there was less of this with lithics such as this old, altered rock that was pulverized and sent up today--just plain old abrading.
Spacepope
Thu May 17, 2018 11:12 pm
The rocks themselves that make tephra is very different in comparison to the basaltic rocks we are dealing with here in Hawaii. Felsic (Feldspar and Silicate) rocks from stratovolcanoes has a much lower melt temp than Mafic (magnesium and iron based) rocks in shield volcanoes. All this really means in practice if you fly through an ash plume is the mafic ash will erode your turbine blades a bit more before killing the engine outright.
BN727227Ultra
Fri May 18, 2018 1:21 pm
Thanks! Are you on Volcanocafe? Check it out, it gets silly sometimes but it's the best thing to a volcano hotline.
smokeybandit
Fri May 18, 2018 1:44 pm
but nothing like Eyjafjallajökull in terms of a high-traffic area. .
I will be very impressed if you didn't have to look up that spelling.
BN727227Ultra
Fri May 18, 2018 2:43 pm
Thanks, but no :-) Google, and CRTL-C CRTL-V is my friend!
