legacyins
Aer Lingus EI147 clips post while taxiing at SFO
Wed May 23, 2018 11:43 pm
EI 147 from Dublin was being towed into G-91 at SFO and the right wing had contact with a concrete post.
http://abc7news.com/travel/plane-wing-h ... e/3513867/
Reason: Updated title for clarity
laxtrii
Re: Aer Lingus aircraft mishap at SFO
Wed May 23, 2018 11:58 pm
G-91 is located in a very tight corner. Photos look like the damage is minimal. Even looks like the return flight is going to operate with a 2.5 hour delay.
andrewfarmer
Thu May 24, 2018 1:03 am
I once watched a 788 being pushed out from G91 which abuts the walkway between terminal and parking. The wingtip came inches from contacting the glass. Wing walker was watching it and stopped the tug just before contact. It took several back and forth rounds with the tug to straighten out and find the right angle to get the bird out of that tight spot. Usually I see AC A320s there due to the clearance. A 788 doesn't have a massive wingspan but that gate is definitely meant for smaller aircraft.
amax1977
Thu May 24, 2018 2:36 am
In these kind of cases who pays for the damage? The airport’s insurance?
Wingtips56
Thu May 24, 2018 2:41 am
I would guess not in this case. Doesn't look like the building ran into the airplane.
Worked for WestAir, Apollo Airways, Desert Pacific, Western, AirCal and American Airlines (Retired). Flight Memory: 181 airports, 92 airlines, 78 a/c types, 403 routes, 58 countries (by air), 6 continents. 1,119,414 passenger miles.
Home airport : CEC
Wingtips56
Thu May 24, 2018 2:43 am
Per the EI website, the departure just got pushed back another hour: ETD SFO at 21:30 local.
Home airport : CEC
LAXLHR
Thu May 24, 2018 2:54 am
The 788 wingspan is nearly as long as a 747-400, perhaps a 15ft difference or am I mistaken?
BA IB ET JM EA GK PA VS AA SN HP CO W7 WN NW DL UA AC US LH LX OS JL QF QR WY MH CX U2 EK 9W UK TP VY VN LO OK OZ UL SQ LA
707 727 L10 732-NG 741 742 743 744 752 753 762 763 772 773 787 DC8 DC9 DC10 M80 M11 100 AB3 310 318 319 320 321 330s 340s 350 380
questions
Thu May 24, 2018 3:04 am
Is G91 the gate next to the BART SFO station?
legacyins
Thu May 24, 2018 3:48 am
Yes.
As for fault, I would guess the tug operator with wing walker. I believe Swissport is their ground handling.
Eirules
Thu May 24, 2018 6:05 am
Flight was eventually cancelled, not sure if there was more damage than expected or as a precaution to check
Braybuddy
Thu May 24, 2018 6:43 am
'Bout time that airline had it's wings clipped anyway . . . :D
fraport
Thu May 24, 2018 6:46 am
The ground handler's insurance. The aircraft was being towed.
CarbHeatIn
Re: Aer Lingus EI147 clips post while taxiing at SFO
Thu May 24, 2018 12:57 pm
Thread title says the aircraft was taxiing, yet first post says it was being towed?
osupoke07
Thu May 24, 2018 1:09 pm
MD82, MD83, MD88, B717, B732, B733, B735, B737, B738, B739, B752, B763, B77W, CR2, CR7, CR9, A320, A321
prchan
Thu May 24, 2018 1:31 pm
from the picture it is possible to see the tug...of course the tug can have arrived after the incident, but would say it was being tugged.
SonaSounds
Thu May 24, 2018 3:27 pm
Winglet doesn't look like it took too much damage.
Overthecascades
Thu May 24, 2018 4:59 pm
"It happened as Flight 147 from Dublin was being towed to its arrival gate at SFO."
Why does the aircraft not taxi to the gate upon arrival? Due to the tightness around this particular gate?
Theseus
Thu May 24, 2018 5:08 pm
I just looked up gate G-91 on google maps, and it is amazingly tight indeed. Almost surprised they park A330s there.
Chasensfo
Thu May 24, 2018 5:26 pm
The LEFT gear was about 30 feet RIGHT of centerline when it hit. Plenty of room for an A330, 787, or 767...but you have to follow the yellow line. That is the whole point of a tow in to a tight spot. :)
TWA302
Thu May 24, 2018 6:29 pm
Wow! That tug driver really was off the line!
https://pbs.twimg.com/media/Dd6s856U0AEmWUy.jpg:large
Chasensfo
Thu May 24, 2018 6:34 pm
Indeed, very impressive. 777-200s are the largest aircraft certified for G91 right now, but in the 2000s, it was common to see 747-400s on the gate! No incidents, though it was a tight push with remote spots G103 and G104 occupied behind the terminal.
legacyins
Thu May 24, 2018 6:36 pm
The aircraft is currently at the United MOC.
JAmie2k9
Thu May 24, 2018 6:41 pm
Flying back tonight (hopefully).
twaconnie
Thu May 24, 2018 7:33 pm
Looks like a new ship.
airsmiles
Thu May 24, 2018 7:36 pm
Exactly one year old.
