InnsbruckFlyer
2 - 5 - 2 Configuration on a 777
Sun Jun 03, 2018 11:07 am
Hi All,
I was reading a trip report and saw this photo of an Air China 777's economy cabin, and as you can see, it's in a 2 - 5 - 2 configuration:
Are there any other airlines with this type of configuration? It seems awfully tight.
Greets from Innsbruck,
InnsbruckFlyer
Last flown aircraft: DH8D OE-LGN < DH8D OE-LGI < E195 OE-LWE < DH8D OE-LGI < A320 D-AIUR < A320 D-AIZM < B738 PH-HZJ < B737 PH-XRD < B772 N766AN < B738 N855NN < B788 N45905 < A319 N808UA < A320 N482UA < B752 N19117
george77300
Re: 2 - 5 - 2 Configuration on a 777
Sun Jun 03, 2018 11:12 am
InnsbruckFlyer wrote:
Hi All,
InnsbruckFlyer
Seats the same as a 3-3-3 config. Therefore better than most 777 that have 3-4-3. Also only one seat per row has to step over two people compared with 2 on the 3-3-3 config. So better for everyone except the one in the middle seat.
george77300
Sun Jun 03, 2018 11:13 am
Another topic with details.
viewtopic.php?t=536121
luckyone
Sun Jun 03, 2018 12:16 pm
DL definitely had this configuration on my flight from CDG-ATL in 2004. I believe UA also had this configuration originally on their 777s. It was a holdover from the days of the Trijets, which had the same configuration. The rationale being the rows of 5 made it easier for families traveling together to sit together. Also, the implementation of PTVs encourages 3-3-3 as it's my understanding that one box can supply three screens, and the rows of five required two boxes, resulting in four boxes per row instead of three. It may also be easier to have all of the seats in sets of 3 for purposes of having to swap them out--everything is the same as opposed to a set of 2, and a set of 5.
USAirALB
Sun Jun 03, 2018 12:42 pm
AA and UA both had that configuration on their 777s until the most recent refurbishment. DL did as well, but they swapped out their seats earlier around 2005 or so.
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 744ER, 752, 753, 762, 763ER, 772, 77E, 77W, 789, 319, 320, 321, 332, 333, 343, 359, 388
reffado
Sun Jun 03, 2018 1:09 pm
RG also had this on their UA-origin 777s.
Scanorama
Sun Jun 03, 2018 1:12 pm
CX had their 772 in 2-5-2 configuration originally as well. It was later changed to 3-3-3. The B777-300s (non-ER) have always been 3-3-3 I believe.
MIflyer12
Sun Jun 03, 2018 1:39 pm
The center seat of that center section of 5, on a route like ORD-FRA. Lovely.
frmrCapCadet
Sun Jun 03, 2018 1:43 pm
And the person in the center does have two ways to get out, in either case over two other persons.
Obzerva
Sun Jun 03, 2018 2:09 pm
MH also had this config.
gunnerman
Sun Jun 03, 2018 2:48 pm
Anyone who thinks that 2-5-2 tight should be aware that the majority of 777 deliveries are now 3-4-3. And look at CX: by the end of 2019, all of its 65 777s will have been converted from 3-3-3 to 3-4-3.
Newbiepilot
Sun Jun 03, 2018 3:07 pm
In the 1990s when load factors were usually in the 70s before revenue management systems were sophisticated to get load factors into the upper 80s, 2-5-2 was a popular configuration. The middle seat in the set of 5 was almost never used unless there was a larger family. Usually one of the middle seats per row was empty. This was a very comfortable configuration with an empty seat.
Nowadays revenue management systems can get load factors consistently in the 86-92% range in peak season. When you add the non rev load factor of 1-3% on top of that, 2-5-2 starts to be less desirable. 3-3-3 is more popular when all the seats are sold. In a group of 3, the aisle and window passengers tend to shift away from the middle seat and give up the armrests some. With 2-5-2 those three middle seats are brutal.
afcjets
Sun Jun 03, 2018 3:18 pm
Which is one of the many ways the orginal configuration was better. Only 1 out of 9 passengers on a full flight with 2x5x2 is two seats from the aisle, and they have two ways to get out, whereas on 3x3x3, twice as many passengers are two seats away from the aisle, with only one way out.
OA940
It's 9-abreast, so tight is a completely false idea.
A350/CSeries = bae
GE90man
Sun Jun 03, 2018 3:21 pm
I once flew on an AA 777-200 in a 2-5-2 config, back before the retrofits. Actually, some people prefer the 2-5-2 config over 3-3-3 due to the philosophy that there's only one person per row (middle seat) in 2-5-2 that needs to crawl over two people to get to the aisle, while there's 2 seats (two window seats) in 3-3-3 that require you to crawl over two people.
afcjets
Sun Jun 03, 2018 3:36 pm
While you're right it does make it easier for families, that is not why the DC10 and L1011 were 2x5x2. They originally were 2x2/2x2 where there was a console between the two pairs of seats in the center section, which they eventually replaced with another seat, beginning with AA I believe in 1978. Since the MD11 closely resembled the DC10, they went with the same configuration.
Feroze
Sun Jun 03, 2018 3:37 pm
My very first flight on a 777, in May 2000 from LHR to SFO with United Airlines, was configured 2-5-2 in Economy.
And guess where I was sat....!
RalXWB
Sun Jun 03, 2018 4:44 pm
First time in 2-5-2 which was definitely the last time with UA back in 2003 ORD-LHR in the most awful seat ever. #neveragain
gwrudolph
Sun Jun 03, 2018 4:48 pm
If you could snag a seat on one of the two sides, 2-5-2 was awesome! As others are saying, it doesn't much matter anyway because most carriers are moving toward 3-4-3 for 10 across
MartijnNL
Sun Jun 03, 2018 6:11 pm
Awfully tight? This is the best seat configuration in existence on the 777. Six out of nine passengers have either an aisle seat or a window seat. Only one out of nine passengers is more than one seat away from the aisle. Much better than today's 3-4-3 seating.
I am glad that the United Airlines 777's had this configuration when I flew them in 2000 and 2002.
airzona11
Sun Jun 03, 2018 6:32 pm
Flew UA/DL 777s the config. The 2 side was great. The middle section was not bad either. With the lower load factor, that middle seat was great to stretch out.
keesje
Sun Jun 03, 2018 6:54 pm
Ziyulu
Sun Jun 03, 2018 7:22 pm
Yes, the 2-5-2 seating on a 777 is much better than 3-4-3 on a 777 or 3-3-3 on a 787.
lugie
Sun Jun 03, 2018 7:40 pm
But with 3-3-3 there's a positive tradeoff to the drawback of having to climb over two people: A window. Even outside the "avgeek sphere" many people who sit by the window do so completely voluntarily, window seats are usually the first ones to be taken if you look at seat maps during online check in.
There are many reasons to prefer window seats even if you're not into aviation - a form of entertainment, the feeling of better awareness of the flight progress, less claustrophobia, opportunities for photography (whether those are iPhone pics for a snapchat story or professional images), being able to sleep better by leaning against the wall, etc etc
Since the most prevalent aircraft are 3-3 narrowbodies, most of the flying public doesn't know window seats as anything but being two seats away from the aisle so they will easily make that tradeoff aboard a 3-3-3 / 3-4-3 widebody.
Selling someone a middle seat (already bad in itself) sandwiched between 4 other pax is a considerably harder task.
Q400 E175 E190 CRJ7 CRJ9 CRJX MD88 A319 A320 A321 A332 A333 A359 B733 B73G B738 B739 B748 B764 B772 B77W B788 B789
FRA STR HAM TXL MUC ZRH ACE BRU BLL DUB MAN ARN MAD OPO LIS FNC AMS PHL RDU LGA CLT EWR ORD ATL SFO MDW IAD YYZ SJO PTY
jpetekyxmd80
Sun Jun 03, 2018 8:45 pm
Tight? Huh?? Practically a premium product by current standards
The Best Care in the Air, 1984-2009
Antarius
Sun Jun 03, 2018 8:48 pm
The biggest issue with 2-5-2 was requiring 2 different replacement seat pairs (a 2 and a 5 set) as well as requiring more underseat IFE boxes.
Then 3-4-3 came along and made the 9 across irrelevant.
I personally liked 2-5-2. Great for families of 4, great for couples and even solo travellers.
Militant Centrist
Let's all just use some common sense
mandargb
Tue Jun 05, 2018 5:21 am
KE had 2-5-2 also on their 777s.
They used it on SFO-ICN, definitely in late 2001 / early 2002.
I remember getting (to sleep) on full 5 seats for myself on one such flight.
I was the only assigned seat on those 5, they told me that at checkin, and nobody showed later also.
lebda
Tue Jun 05, 2018 5:27 am
2-5-2 was pretty standard up until recently. It's kinda a throwback from when L-1011s and DC-10s were popular, as both generally had the same seat config.
Denver Tower: Gulfstream 592, you’re cleared to 9,000 feet. For a vector to Hector, contact the sector director.
LAXLHR
Tue Jun 05, 2018 6:44 am
ORD-FRA 7 hours? Imagine hmmm ORD-HKG 15 hrs lol. or 3x4x3 seating.
Actually look at that pic and figure out where exactly were they able to cram in an extra seat. Already looked tight, amazingly sad!
BA IB ET JM EA GK PA VS AA SN HP CO WN NW DL UA AC US LH LX OS JL QF QR WY MH CX U2 EK 9W UK TP VY VN LO OK OZ UL SQ LA KL
707 727 L10 732-NG 741 742 743 744 752 753 762 763 772 773 787 DC8 DC9 DC10 M80 M11 100 AB3 310 318 319 320 321 330s 340s 350 380
TheFlyingDisk
Tue Jun 05, 2018 7:03 am
It may look tight, but it's probably because the seats aren't slimline but are thickly padded.
I FLY KLM+ALASKA+QATAR+MALAYSIA+AIRASIA+MALINDO
Max Q
Tue Jun 05, 2018 8:32 am
Great if you can snag the entire center row for your family or even yourself if traveling alone, serious sleeping room
Otherwise that’s a pretty miserable configuration, especially in the middle seat
One positive is that with this setup the total number of middle seats is the lowest possible
GGg
Someone83
Tue Jun 05, 2018 9:11 am
I prefered the 2-5-2 configuration as it opens up for 2-seaters, which is preferable unless you’re a group of 3 travelling together
directorguy
Tue Jun 05, 2018 9:12 am
At least no one got around to doing a 2-6-2 configuration...
oldannyboy
Tue Jun 05, 2018 9:25 am
I was never a big fan of this configuration...
Personally I have landed a good couple of times the dreaded middle seat on a chock-a-block aircraft on north-Atlantic red-eyes (one time with a particularly BIG lady next to me, who had gigantic arms overflowing the armrest and onto my shoulder..), and that pretty much sealed the deal for me for this configuration... Being a big water drinker (and thus a frequent lav visitor!) being sandwiched between a whole lot of 4 people is a great inconvenience. Just my two cents!
747-600X
Tue Jun 05, 2018 9:30 am
This is far better than 3-3-3.
In 3-3-3, two people (window seats) have to climb over TWO seats to get out to the aisle. In 2-5-2, only one person (middle of 5-bench) has to climb over two others to get out, and can choose which way to go. Everything else balances out between the two. So to me, 2-5-2 has always been more pleasant than 3-3-3.
afterburner33
Tue Jun 05, 2018 9:32 am
Whereas the one time I flew on a 777 with this configuration (AA ORD-LHR), I loved it because my wife and I could sit together by ourselves without some random stranger alongside us.
I have always found 3-3-3 to be quite annoying - when there was only two of us, and now that we are a family of 4. In some respects, we're now better off flying a 3-4-3 777 because we can have the center block of 4, and the reduced space isn't an issue because my kids don't take up much room.
Lufthansa
Tue Jun 05, 2018 10:05 am
The reason was PTV's. I control box does 3 seats. so 3-3-3 was most efficient although that isn't really a factor now most carriers are 3-4-3. 2-5-2 was actually a great configuration unless you ended up in the middle... but as previously mentioned these were usually the last to be assigned and its a hangover from DC-10 and L1011 days. I lucked out on MH once and got the entire 5 seats to myself. Easily enough space to stretch out and sleep. So in short ... there was no revenue advantage between 2-5-2 and 3-3-3 however there was a cost advantage.
muralir
Tue Jun 05, 2018 6:49 pm
Curious: Is there some intrinsic reason why a box can only control 3 PTVs? I'd think if 2-5-2 was commonplace (which it seems to have been), people would develop a single box to control 5 PTVs. Computing power is pretty cheap. Or were all the early boxes standardized to a max of 3 screens?
deltatim
Tue Jun 05, 2018 7:11 pm
Not bad to me... I used to love Delta's L-1011 coach configuration, which was 2-5-2. There's something nice about the two seats by the window - 2's company, three's a crowd.
aca36
Tue Jun 05, 2018 7:15 pm
All Nippon Airways uses 2-4-3 on some of their 77Ws.
neutronstar73
Tue Jun 05, 2018 7:58 pm
I'm just sick of this "it seems awfully tight" whenever a discussion comes up about the 777, especially is person making that claim doesn't know how to do math correctly. It's 9-abreast seating, but I guess some people' s bias automatically equates "777" with "horrible flying experience", even though the math doesn't back up that claim.
Tiresome.....I flew on several 2-5-2 777s and it was about as good as it gets, lest you compare it to the 2-3-2 767, which is great.
BA777300er
Tue Jun 05, 2018 8:56 pm
I personally have never been on a 2-5-2 777 but if you look at SeatGuru it says seat width is 18 inches for 2-5-2 and sometimes for 3-3-3 but for 3-4-3 seat width is reduced to only 17 inches.
On SQ 777-300 which is 3-3-3 the width is 19 inches so 9 seats across is not tight by economy standards.
YVRing
Wed Jun 06, 2018 12:25 am
That sounds awesome.
mdavies06
Wed Jun 06, 2018 1:18 am
keesje wrote:
17 years ago. You have been on a.net for a long time.
2175301
Wed Jun 06, 2018 2:19 am
I've sat in the center seat on 2-5-2 several times between Chicago and either San Francisco or Los Angeles, and back; and in almost all the other positions as well. I had no problem with the center seat.
Have a great day,
DL_Mech
Wed Jun 06, 2018 11:30 am
Check out the width of the armrests on this ex-DL L-1011.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
Mortyman
Wed Jun 06, 2018 11:36 am
Flew on a All Nippon Airlines Boeing 777-300 recently. It had 10 seats pr. row in economy in a 3-4-3 configuration. It was a domestic flight between Tokyo and Osaka
intermodal64
Wed Jun 06, 2018 2:32 pm
The 2-5-2 history goes way back to the DC-10 and L-1011. The center galley units and partitions were fixed components for a 2-4-2 configuration. When airlines wanted to go 9 across, the 2-5-2 was the easiest way to accommodate the fixed center partition components. In the original 9-across configurations, the center seat of the center 5-bank in the middle would fold down into a table. So, it was like keeping the 2-4-2 when flights were not completely full. As many have said on this post, flights are so full these days that the center seat was almost always used, making things really miserable for the three center seats of the 5-bank in the middle. That and in-seat IFE paved the way for the 3-3-3. Of course, with 3-4-3, we've transitioned into an era equivalent to "charter travel" back in the day.
LH707330
Wed Jun 06, 2018 2:35 pm
It's probably got less to do with the ability than the inventory management and certification. One of the reasons that the price of everything in aviation is the part number plus two zeroes is that it costs a lot to certify, and those costs then need to be spread over a fleet of (300 seats/plane * 1.5k planes = ~450k units) for the entire market. Figure there's a small handful of suppliers, each is looking at maybe 100k units. I'm sure the beancounters looked at the numbers.
If you get a half-empty plane, I still prefer 3-3-3, because there's more space to sleep. I lucked out recently on UA1 when some connecting pax missed the plane and I had my own 3-pack to myself.
