xxcr
Re: LH A340 damaged by pushback tug fire at FRA
Thu Aug 23, 2018 10:47 pm
So TK looses 2 planes in the past few months. LH just lost another plane to a fire......Is there a pattern i'm missing here?
DABYT
Sat Sep 15, 2018 7:32 pm
Any news on D-AIFA? Where at FRA is she parked? As she won’t return to service I wonder if part out and scrapping has begun.
sixfootscream
Sat Sep 15, 2018 7:38 pm
According to my friend she is parked at LH Technik all hidden between A/Cs parked there. I believe she will be scrapped.
ojjunior
Tue Oct 09, 2018 4:13 pm
Well, any updated news on D-AIFA?
Has the scrapping begun?
Pics?
frmrCapCadet
Tue Oct 09, 2018 6:54 pm
It appears the fire burned through the skin and into the fuselage. I can't imagine that it would only be minor damage. Anyone enlighten us otherwise?
Blotto
Tue Oct 09, 2018 7:02 pm
No minor damage. The aircraft is done. From what I hear they are waiting for the insurance to get their stuff done and then it will be scrapped.
N14AZ
Wed Feb 20, 2019 9:07 am
Scrapping has started:
Picture taken by Whisperjet, source: http://fraaviation.forumieren.de/t18881-d-aifa#83468
@ Moderators: I learnt from QF789 that thou shalt not post in threads that have been inactive for 6 months. The last post here is 4 months old so I hope it's okay to use this initial thread instead of opening a new one. If not, please delete...
DABYT
Wed Feb 20, 2019 11:15 am
Thanks for the update, N14AZ!
WIederling
Wed Feb 20, 2019 11:31 am
N14AZ wrote:
Taken down a peg or two :-)
and I suppose FraPort would like to see it vanish reasonably fast.
Someone urgently needed a piece of window belt ?
( or was that done to have easy access to unwieldy cabin monuments? )
Murphy is an optimist
N14AZ
Wed Feb 20, 2019 12:03 pm
I noticed the same thing.
Doubt it. If it was for better access they would have made a higher opening, I guess... but what I do know, haven't scrapped that many A340's in my life... ;-)
Welcome!
Blotto
Wed Feb 20, 2019 12:59 pm
The remainder of the A/C is located on LHT premises so Fraport doesn't care.
And they use it for funny stuff. There has just been a tank rescue training. You typically don't do that with A/C you still want to fly ;) Not sure though where the windows went
N14AZ
Wed Feb 20, 2019 1:18 pm
From the picture I would say the aircraft is stored behind LH's "butterfly hangars", correct? More or less this location, correct?
Blotto
Wed Feb 20, 2019 1:33 pm
yes, correct
danj555
Wed Feb 20, 2019 2:03 pm
I'd say the scrapping has finished!
No engines
No wheels
No interior
No flaps
Anything else?
Noshow
Wed Feb 20, 2019 2:05 pm
No vertical tailplane.
N14AZ
Wed Feb 20, 2019 2:43 pm
No engines
No wheels
No interior
No flaps
Anything else?
??? I consider scrapping as finished once it looks like this:
frmrCapCadet
Wed Feb 20, 2019 2:55 pm
I always appreciate updates on stories like this.
7673mech
Wed Feb 20, 2019 3:23 pm
That hole is to remove monuments and premium seats.
RRTrent
Wed Feb 20, 2019 3:44 pm
You can see it on Google Maps, behind the big hanger with the flared corners.
sassiciai
Wed Feb 20, 2019 5:04 pm
I would appreciate it if you could give some more detail about where the aircraft is, thanks!
I assume it is on the "south side" where all the LT buildings seem to be. On the left hand edge of the buildings is the A380 Maintenance hanger - can you "drive me" from there to the A340!
ei146
Wed Feb 20, 2019 5:19 pm
Here.
sassiciai
Wed Feb 20, 2019 9:03 pm
Well, that doesn't do it for me. I understood that Google Maps for FRA was so up-to-date that the burned A340 was visible (Post 222)
The link from ei146 does not show any A340, maybe it just shows the area as photographed some time ago, well before the burned aircraft was towed there. The aircraft in the linked Google Map show a couple of A330s and 2 A32x, no A340
hOMSaR
Wed Feb 20, 2019 9:10 pm
Weird. I see a STAR ALLIANCE painted A340, parked next to an A330, when I click that link.
I was raised by a cup of coffee.
N14AZ
Wed Feb 20, 2019 9:11 pm
Exactly, it just shows the location but it’s not an up-to-date picture.
Maybe it’s different from country to country but if I start google maps I can see D-AIFA.
PS.: it‘s not in the southern part of FRA but I am too tired to give you a better guidance right now... I drank what you have in your profile picture... :-)
Erebus
Wed Feb 20, 2019 10:33 pm
I am able to retrieve both versions, yours and the one with a 3D model of the burned aircraft. I think you might have to toggle a setting. Go to the menu option on the top left corner, and enable "Globe". A shot in the dark, see if that's your issue... :crossfingers:
stylo777
Wed Feb 20, 2019 11:26 pm
It's still there at the same spot as in googlemaps (saw the other day when passing the airport)
RRTrent
Thu Feb 21, 2019 9:12 am
Apologies, I don't know how to post a maps link, but several posts have noted the hanger its behind. once you see the A340 click to 3D mode and just move down to an almost side view of the aircraft, the scorch marks are clearly visible.
I understand you cant see any A340 when you lick the link, but others have noted they can, so maybe go to FRA manually on Maps and find the hanger beside the A gates. If not, maybe maps updates are location based? but I can definitely see it.
Harry765
Thu Feb 21, 2019 9:26 am
A Lufthansa Airbus A340 was damaged after a fire broke out on a truck towing the widebody jet at Germany's Frankfurt Airport on Monday.
Noshow
Thu Feb 21, 2019 9:33 am
You mean again or is this an old reporting?
OlafW
Thu Feb 21, 2019 10:48 am
There must be multiple versions of the views out there. While I do see an A340 in Star Alliance livery, it is absolutely intact. No scorch marks whatsoever.
WayexTDI
Thu Feb 21, 2019 12:37 pm
Are you talking about the same incident from 2018? Or a new one?
Eitilt
Thu Feb 21, 2019 12:43 pm
The damaged Star Alliance 340 is exactly where the google map location is.
I know because I drove past it on Monday.
desediez
Thu Feb 21, 2019 1:40 pm
No, not exactly, but nearly. Just move the google picture a bit to the right. AIFA is located exactly on the spot, where on the google image the A330 is parked.
What I know is that AIFA will be gone by the end of February.
A/C flown: 100,306,312,313,319,320,32A,A20N,321,333,342,343,346,359,351,388,703,721,722,731,732,733,734,735,738,
73H,741,742,743,744,74C,74D,74E,762,76W,772,77W,788,AR8,ARJ,CR2,CR7,CR9,D1C,D91,D93,D95,DH8,E90,F50,F70,
L15,M11,M81,M82,M83
happycrew
Fri Mar 08, 2019 10:06 pm
Its gone now. I drove past yesterday and all that was remaining, was a bit of the cockpit.
