FatCat
Re: LH A340 damaged by pushback tug fire at FRA
Mon Jun 11, 2018 3:09 pm
N14AZ wrote:
Aviation Herald now has a section for this accident: https://avherald.com/h?article=4b9bfba4&opt=0
A replacement A340-300 registration D-AIGP departed with a delay of two hours.
Wow, not bad.
Pünktlich ;)
Aeroplane flies high
Turns left, looks right
dcajet
Mon Jun 11, 2018 3:39 pm
I know, I know... BA did wonders with that 777 after the LAS fire. But this one don't look too good.
Continental767
Mon Jun 11, 2018 3:48 pm
[twoid][/twoid]
Yeah, that’s probably not going to buff out ;)
Indianapolis.
blooc350
Mon Jun 11, 2018 4:01 pm
Thats the same plane that does the daily SJC route--- wonder what they will be sending to SJC now
744lover
Re: LH A340 on fire in FRA now
Mon Jun 11, 2018 4:05 pm
juliuswong wrote:
deltadudejg wrote:
FatCat wrote:
However, JADEC tweeted that only minor damage. Assessment underway.
Btw, registration is D-AIFA
I doubt it will a minor damage. Probably all the section forward of L1/R1 will have to be replaced. If not melted, the aluminum might have lost its strength due to the heat. This not speaking, of course, of all electronics, cables, wires, etc.....
BR,
744lover
KLMatSJC
Mon Jun 11, 2018 4:08 pm
Wow, not bad.
And that's probably only because the inbound arrived at the scheduled departure time.
A318/19/20/21/21N A332/3 A343/5 A388 B712 B722 B732/3/4/7/8/9/9ER B744/4M B752/3 B762ER/3/3ER/4ER B77E/L/W B788 CRJ2/7/9 Q400 EMB-120 ERJ-135/140/145/145XR/175 DC-10-10 MD-82/83/88/90
Long Live the Tulip, Cactus, and Redwood
mjoelnir
Mon Jun 11, 2018 4:11 pm
Just take the next A340-300 out of storage.
smokeybandit
Mon Jun 11, 2018 4:17 pm
Seems a lot simpler just to write it off with you have a few spares just waiting around
PanHAM
Mon Jun 11, 2018 4:43 pm
they don't have -300s in storage, jut a few -600s.
There is still enough room for parting out and scrapping what cannot be used anymore on the siouth side of the runway system
Was Erlauben Erdogan!!!
InnsbruckFlyer
Sad to see that! One less aircraft in the LH fleet (at least for now). And yes, aircraft is confirmed as D-AIFA, with the name 'Dorsten'.
http://avherald.com/h?article=4b9bfba4&opt=0
InnsbruckFlyer
2019: A3 2x A320 | CL E195 | FB A319, E190 | LH A320, A321, A346, A359 | OS A320, B772, 3x DH8Q | UA A319
seahawk
Mon Jun 11, 2018 4:44 pm
That could bring an A346 back.
N415XJ
Mon Jun 11, 2018 4:51 pm
The raw version of the video from bild is embedded in this article:
https://sputniknews.com/europe/20180611 ... t-airport/
smokeybandit
Mon Jun 11, 2018 4:52 pm
InnsbruckFlyer
"The airline re-iterated: "das Cockpit wurde massiv durch Rauch beeinträchtigt" (the cockpit was massively affected by smoke) when smoke entered the aircraft."
After seeing the photos, I wouldn't think smoke damage would be their #1 concern.
WkndWanderer
Mon Jun 11, 2018 4:53 pm
columba wrote:
AIRT0M wrote:
placeholder wrote:
. They plan to put it back in service 'within days'.
To quote a former German Foreign Minister: "I am not convinced".
The reason why:
https://twitter.com/JacdecNew/status/10 ... 68/photo/1
See the hole in the third picture
Yeah, the scale of the two grown firefighters in gear next to the hole burned through the bottom of the plane shows how big it really is, "within days" would seem pretty optimistic.
ams747757
Mon Jun 11, 2018 4:55 pm
Ouch! Doesn't look so good. Thank goodness there were no pax on board. Do we know if the tug driver was injured at all?
I'm flying LH426 in a month or so- guess I know which aircraft reg. Won't be operating that flight.
How many of these A343/city line/*A's does LH need to operate its full schedule + spares? Hopefully losing one either temporarily or permanently doesn't impact the schedule too much but they only have a handful of routes for what is a smallish subfleet for this configuration. I guess they could always take a 346 out of storage and move a non city line 343 to help out?
richierich
To all the posters that reported this as "soot damage" or "minor" burns, please think before you post.
This fire, unfortunately, was clearly not minor and will clearly not "buff right out". While I am not an expert on aircraft repairs, I think we all know that anything affected the front of the aircraft is going to be a lot more complicated because of the expensive avionics and equipment all in one relatively confined space. Because the skin was burned through, I believe this plane is toast (pun intended.)
We can joke only because nobody was hurt or killed. However, this was a very expensive fire even considering the age of the aircraft. There will now be one less A343 gracing the skies, apparently.
None shall pass!!!!
airlinedork
Mon Jun 11, 2018 4:58 pm
Daily to SJC? I guess that's why it had just landed from ATL.
axiom
Mon Jun 11, 2018 5:04 pm
AFAIK LH is in the process of "mainlining" these CL 343 routes, in part by bringing on other aircraft. TPA is about to move to a higher J 343, for example. Perhaps this bigger process will be moved forward, and a 346 brought back in to the fold...
mjoelnir
Mon Jun 11, 2018 5:07 pm
Or a 340-300. Enough of them are stored.
lightsaber
Mon Jun 11, 2018 5:10 pm
744lover wrote:
juliuswong wrote:
BR,
744lover
A fire burned hole that close to an electronics compartment and all the cockpit wiring needs more than a few days.
For an 18 year old A343, probably not a write off, but I'm placing no bets.
Lightsaber
factsonly
Mon Jun 11, 2018 5:13 pm
'' The flames substantially damaged the aircraft, 10 people received minor injuries.''
http://www.avherald.com
BartSimpson
Mon Jun 11, 2018 5:14 pm
N14AZ wrote:
Wow, I never saw passengers or a group of visitors walking on the apron in that area of the airport (see at about 0:25). Not the best Timing, I guess..
I don't know how the situation is nowadays but when I worked at the Airport the incident area was my preferred route from office to car park. There are also offices in between the two hangars (you can see the building at about 0:14) So the group of people were more likely Lufthansa or other employees.
Curiousflyer
Mon Jun 11, 2018 5:18 pm
I am betting on a write-off.
readytotaxi
Mon Jun 11, 2018 6:02 pm
N14AZ wrote:
Reminds me a little bit of this jet...
New AirFrance test livery? :duck:
Growing older, but not up.
Revelation
Mon Jun 11, 2018 6:11 pm
Killjoy! :biggrin:
And, to be fair, one less airport tug.
People at AirportTugs.Net must be pretty upset.
Thanks for the dose of righteousness.
All the posts I saw and did had complete attribution.
It's up to the reader to decide if what they're reading is significant or not.
Aptivaboy
Mon Jun 11, 2018 6:13 pm
Classic! You win the interweb today.
Actually, it might just be repairable. I know a guy with a rad set of tools...
https://www.youtube.com/watch?v=A5cneCgNA9U
fortytwoeyes
Mon Jun 11, 2018 6:19 pm
As far as I can see there's not a single LH 343 stored. Looking further in LH group, Airfleets shows a few Swiss ones stored, but those all seem leased, so it's hard to say whether it would be viable to reactive one of those - and they might even have been scrapped already.
edit: Yep, those have all been scrapped
stratclub
Mon Jun 11, 2018 6:35 pm
seahawk wrote:
Looks to be mostly soot.
My thoughts exactly. You can that the white paint doesn't really look charred, just blackened from soot and the radome looks intact as well.
KICT
Mon Jun 11, 2018 6:44 pm
Every ex-LH A343 that went into "storage" was scrapped almost immediately or sold onward to places like Iran. Most if not all 300s that left the fleet were the plain jane -300, not the -300X that are still in use.
People are saying. Believe me.
lightsaber
Mon Jun 11, 2018 6:45 pm
I agree, ready to taxi won the interweb today.
Lightsaber
TC957
Mon Jun 11, 2018 6:46 pm
LH are about to take delivery of their 11th A350 at MUC so I'm sure one of the MUC-based A333's or A346's can be transferred to FRA to replace poor D-AIFA.
seahawk
Mon Jun 11, 2018 7:34 pm
richierich wrote:
To all the posters that reported this as "soot damage" or "minor" burns, please think before you post. .
It is not about thinking, it is about not having the same pictures at the time. The right side looked less damaged.
keesje
Mon Jun 11, 2018 7:57 pm
Looking at the intensity and proximity of the fire, the structure around the landing gear probably got a significant unscheduled head treatment, changing material properties & strenght. Fixing that would probably cost more than lease / reconfigure an A343/ A359, or have it in a maintenance hangar for 6 months. The rest value alone probably doesn't justify that.
Oeps, oversaw this picture, slow internet. Forget what I just wrote. A 100% write off.. :worried:
Armodeen
Mon Jun 11, 2018 8:00 pm
columba wrote:
The reason why:
Certainly looks like FRS staff peering in through a giant hole in the fuselage!
Edit: The pic above shows that that is exactly what it is! A sad end for this graceful airliner!
keesje
Mon Jun 11, 2018 8:04 pm
Was it a battery fire?
BobMUC
Mon Jun 11, 2018 8:20 pm
My bet would be an oil leak/fire at the truck. The intense of the fire looked more like coming from a liquid.
Dutchy
Mon Jun 11, 2018 8:22 pm
[twoid][/twoid]
Only needs some duck tape and a fresh paint job, can't be more than 2 hours of work. :lol:
IWMBH
Mon Jun 11, 2018 8:26 pm
AIRT0M wrote:
placeholder wrote:
Gonna be interesting to see, if it was in fact D-AIGV which was scheduled on LH482 to Tampa later on, what Bird will substitute for it.
I wouldnt hold my hopes up high to see her flying again, the Damage looks pretty substantial on the Nose section even though that Bird is fairly young with just over 18 Years.
According to LH the damaged plane was the D-AIFA and it was supposed to fly to PHL today. They plan to put it back in service 'within days'.
I find this hard to believe. If you see some of the pictures of the amount of damage,it will take at least months to repair this bird.
https://twitter.com/JacdecNew/status/10 ... dschade-op
Narfish641
Mon Jun 11, 2018 8:54 pm
Saw it this morning, feel bad for the 10 workers that had to inhale all that smoke. The video looks horrible too, huge hole in the landing gear and the avionics as well are badly damaged (According to The Aviation Herald).
Flew on:
SWA 737 738
Super80Fan
Mon Jun 11, 2018 8:56 pm
Had to go for the rare A340 didn't we? Couldn't take out a A320, 737, or A330?
RIP McDonnell Douglas
GE90man
Mon Jun 11, 2018 9:55 pm
Holey moly.
Asturias
Mon Jun 11, 2018 9:59 pm
Carlos01 wrote:
BobMUC wrote:
Seriously, anyone saying "only minor damage" after seeing that video should probably also go through an "assessment" like the plane.
I agree. The fire seems to have eaten through the fusalage, underneath the cockpit.It's pretty obvious in this video:
https://www.thesun.co.uk/news/6498786/f ... t-updated/
The ash, the heat, the water and foam has definitely caused intense local damage. That's not minor damage, nor is it a question of a "few days" in tech/ops to repair. This could take weeks or more to repair, if it will *ever* be repaired.
Tonight we fly
columba
Mon Jun 11, 2018 10:21 pm
[twoid][/twoid]
Well this is an Airbus A340 you are talking about not a Douglas Dc 9 ;-)
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
Mon Jun 11, 2018 11:13 pm
I think that is the end of the aircraft, the avionics bay is under the cockpit.
An idea of what’s in that space https://www.clipzui.com/video/z2i435z3d ... 41653.html
Wacker1000
Mon Jun 11, 2018 11:21 pm
juliuswong wrote:
However, JADEC tweeted that only minor damage. Assessment underway. https://twitter.com/JacdecNew/status/10 ... 1610240000
Most aviation professionals would not call a melted hole in the skin "minor".
kc135topboom
Tue Jun 12, 2018 12:29 am
The fire burned into the avionics bay, probably also took out all the wiring harnesses too. My guess she is going to be scrapped. She will not be worth much without avionics. Yeah the engines will be salvaged and the flight control surfaces, along with the generators and hydraulic parts. The engines won't be worth much. they only fit the A-340-200/-300.
As far as the actual scrapping, that can be done at any airport. They will bring in contractors who do that kind of work. I'm sure there are plenty of scrapping contractors around the EU who would bid on the work.
Narfish641
Tue Jun 12, 2018 12:48 am
If I have to take a good guess on the amount of A343 flying now, it's well under 90. But at least there will be spare engines for the rest of the CFM56 powered quad jets still flying around for different airlines.
Flew on:
SWA 737 738
lightsaber
Tue Jun 12, 2018 12:53 am
I believe the decision will be left to the insurance and LH.
There is some cost to scrap at FRA (vs. a profit flown out). I believe the damage is less than the insured residual value, so likely the insurance company will offer to repair. Will LH or will they negotiate for a transfer of funds? I don't know. It will depend on the damage. It will depend on LH's timeline for continued A343 operation. It will depend on how well LH calculates the economics.
We're in a widebody glut. It might be more economical to purchase a used A333?
Lightsaber
Bjm0517
Tue Jun 12, 2018 1:12 am
juliuswong wrote:
N14AZ wrote:
Bjm0517 wrote:
I hope Lufthansa will repair this bird, the A340 is such an amazing aircraft and I would hope to see this one go in such a negative way. :ashamed:
But if it does get scrapped, can that even happen at FRA? I mean they can store it but if they scrap it will it have to be repaired enough to fly to a scrapping-Capable airport? I hope it will not come to that.
I follow the "movements" in FRA since the beginning of the 1980ies but I cannot remember of a single jet that was scrapped in FRA.
I remember a LH-B742 that was transferred to HHN (less than 100km, give or take) just to be scrapped there: http://www.aviationpics.de/scrap/abyq/page_01.htm
Talking about....
juliuswong wrote:
The Singapore Airlines B777-212ER 9V-SQK suffered same fate last year. It was written off recently after in storage for more than seven months.
Has it been scrapped in Singapore?
Flew into SIN recently, she was stripped all title and logo, parked in front of SIAEC. Guess she is not going anywhere soon.
Such a sad ending to a mighty bird. 15 years old, and just got cabin refit last year before her fiery ending in Nov 2017.
It is a sad ending to such a mighty aircraft, I even saw this bird somewhere, it is one of my earliest memories, super sad to see her go :crying:
juliuswong
Tue Jun 12, 2018 1:30 am
744lover wrote:
juliuswong wrote:
BR,
744lover
With this image, I have to agree she is a toast! I will be surprised if she is fixed. The SQ B772ER was damaged to lesser extend (well, at least there is no hole on that 777), but she was written off by insurer. Tried uploading a close up picture here, but my office blocks all upload photo website.
- Life is a journey, travel it well -
