Airimages
Pilatus PC-24 lands on unpaved runway (Video)
Fri Jun 22, 2018 6:54 am
ap305
Re: Pilatus PC-24 lands on unpaved runway (Video)
Fri Jun 22, 2018 7:01 am
This aircraft could be the answer to the needs of the mines in northern Canada? It will carry less than the 732 though.
Racing, competing, is in my blood. It's part of me, it's part of my life; I've been doing it all my life. And it stands up before anything else- Ayrton Senna
CARST
Fri Jun 22, 2018 7:02 am
Awesome, thanks for sharing!
This airplane is gonna be the perfect plane for many air ambulances, outback and desert flying strips, as well as every drug lord and weapon smuggler in the world!
BlueSky1976
Fri Jun 22, 2018 7:11 am
I have to say this: PC-24 is absolutely THE MOST BEAUTIFUL business jet out there.
If I were a multibillionaire, I'd buy one without a second of hesitation.
Gulfstreams are for wussies.
Proudly avoiding 737 MAX since 18.11.2020.
WPvsMW
Fri Jun 22, 2018 7:32 am
I don't see any reverse thrust on the dirt strip landings... which make sense, and means the brakes are designed to dissipate all the kinetic and thermal energy. Swiss!!
TN486
Fri Jun 22, 2018 7:33 am
Pilatus are masters at this capability. I watched in suburban Melbourne Vic Aust many years ago the STOL capability of the "porter". (it landed on what I would call a hockey field, turned around and took of again). My memory is now vague but I believe there were some porters in the Defence Force. In the words of some, this new ac is a "game changer".
remember the t shirt "I own an airline"on the front - "qantas" on the back
flyingturtle
Fri Jun 22, 2018 8:05 am
Stunning video!
Porter / Turbo Porter - became the proverbial mountain aircraft
PC-7, -9 and -21 - became an air force trainer around the world, and the PC-7 was modified into the T-6 Texan II, for example
And now this... it even has a cargo door that accepts standard pallets.
David
Reading accident reports is what calms me down
ZaphodHarkonnen
Fri Jun 22, 2018 10:05 am
It will be very interesting to watch the life of this plane. Pilatus took what they were good at, looked for a niche that was unserved, and developed a plane aimed right at that market. And importantly appear to be delivering on time and budget.
I can see for those sorts of niche use cases the PC-24 is essentially the only game in town. Payload, speed, range, go anywhere. Perfect match of stuff.
BubbaYugga
Fri Jun 22, 2018 10:26 am
I noticed quite the time delay from deployment of the tiny outboard spoilers to the big lift dumpers.
Anyone familiar with the logic? MLG WOW + x seconds? NLG WOW? Combo?
Max Q
Fri Jun 22, 2018 10:37 am
Cool aircraft, interesting to see Pilatus went with double wheels on the main gear but a single wheel on the nose
I would think that single wheel could be an issue on really soft / wet ground
Looking at the video you can see they’re running a very low pressure on that nose wheel tire
Great it can operate into unimproved fields I just wonder how the owners will tolerate the inevitable rough wear and tear on their new multi million dollar jet
GGg
nmdrdh787
Fri Jun 22, 2018 1:56 pm
I'm excited for this as it could be a integral part of a project I am planning
sturmovik
Fri Jun 22, 2018 2:01 pm
Could it be manually deployed, at least in this case?
'What's it doing now?'
ELBOB
Fri Jun 22, 2018 9:23 pm
A 146-100 / -200 or the subsequent Avro RJ models would be much better suited and is unpaved-field certificated. And was picked by some airlines for that reason, such as TABA of Brazil. There was a kit that included mesh protection for the beacons and debris deflectors aft of the main gear. Low-pressure tyres fitted into the standard bays.
Or an An-148 if they wanted something new from the factory.
In terms of older jets, the Yak-40 and F.28 were also unpaved-capable; the latter did its testing in Iceland. As were the Tu-124 / 134 and believe it or not 154. And HS.125 business jet, certainly up to and including the -700.
What they all lacked was ... viral marketing.
flightsimer
Fri Jun 22, 2018 9:42 pm
I noticed the same thing and in other videos, it comes out much quicker which is leading me to thick these are being manually deployed here. In two other videos I watched, the main spoilers deployed within a second or two of the smaller spoilers.
Commercial / Airline Pilot
Max Q
Sat Jun 23, 2018 2:32 am
Activating spoilers after touchdown automatically through a weight on wheels switch works well on a normal runway
Bit challenging in this application with the rough field compressing and extending the oleos very rapidly
In the short time it takes to satisfy the logic to extend the spoilers the oleo can easily have re-extended to the point where inadequate weight is detected to activate them
Probably explains why manual activation was needed
GGg
Gemuser
Sat Jun 23, 2018 5:01 am
From MaxQ in Reply 10:
I doubt it will worry many of them, they seem to be mostly"remote area" operators. For example Australia's RFDS has ordered 4 for use in WA, given the immense size and underdevelopment of the state it will improve both response & evacuation times. They also operate around 30 PC-12's.
gemuser
rheinwaldner
Thu Jul 12, 2018 8:25 am
Another interesting detail about the performance of the PC-24:
In this moment a PC-24 on a test flight is flying at 45000 thousand feet altitude. Not sure how normal this is for this kind of aircraft:
https://www.flightradar24.com/HBVSA/1d18ab9e
Many things are difficult, all things are possible!
mjoelnir
Thu Jul 12, 2018 8:49 am
[url][/url]
It is quite normal for business jets to fly above the commercial airliners.
