texl1649 wrote:So it’s ultrafan vs LEAP/9x. I’m shocked rolls has the resources available short term to do this.
jagraham wrote:There is another thread which reports that GE and Safran were negotiating to increase the max thrust for CFM engines to 50000 lbs. So I vote for LEAP as opposed to 9x.
OTOH, what is Pratt going to do?
mffoda wrote:This is an interesting note in Jon's article...![]()
"Historically, picking a power plant has closely preceded the formal launch of the aircraft. Boeing made its pick of General Electric and Rolls-Royce engines for the 787 (then-7E7) just 20 days before All Nippon Airways placed the jet’s 2004 kickoff order."
PlanesNTrains wrote:mffoda wrote:This is an interesting note in Jon's article...![]()
The question then becomes, when will they pick the powerplant?
JayinKitsap wrote:texl1649 wrote:So it’s ultrafan vs LEAP/9x. I’m shocked rolls has the resources available short term to do this.
I suspect that B is concerned about this very thing.
texl1649 wrote:The basic LEAP core can’t do that though. His article references tech from both families, and while GE (and Boeing) would have an interest to brand them as one family, I’m guessing actual parts commonality would approach zero. Mechanic training for GE 797 engine and LEAP might be quite similar tho.
(CEO of GE Aviation David) Joyce said CFM will probably be the engine provider rather than GE, if Boeing selects the family.
“I see no reason at all why we wouldn’t make LEAP the baseline,” he said. “It will be bigger, but it will be something advancing not a full generation, but a half generation in technology from what LEAP is today.”
It will be “kind of” a clean-sheet engine, Joyce said. “We’ll be able to put as much technology as we feel is mature enough, advanced technology, brand new stuff.”
“It will be bigger,” Joyce told a JP Morgan investment conference on 14 March. “It’s advancing [on the Leap technology] not a full generation but a half-generation.”
“The probability is very, very high this will be a CFM engine,” Joyce says.
lightsaber wrote:Sadly, I think Boeing will decide which is less worse: RR or Pratt.
CFM has issues with the LEAP turbine, but that is interval on wing, not fuel burn nor dispatch reliability. It is easily monitored and the factories have already geared up to provide replacement parts.
CFM is pretty much certain (or at least GE) to be selected.
It is a question of who is the 2nd option and what hurdles they must leap to be selected.PlanesNTrains wrote:mffoda wrote:This is an interesting note in Jon's article...![]()
This is the most exciting time to engineer an engine. Many changes and improvements. Management decides if they want to risk new technology or not. It take a few months to optimize the concept for launch (including planned thrust growth margin).
By iterating aircraft/engine optimization, the overall airframe cuts fuel burn a few percent. The pylon will be optimized.
Now, far more goes on after engine selection, but first the opportunity has to be seen.
Lightsaber
Continental767 wrote:Looks like the 797 is coming soon. Very soon. Maybe even within a month, if it follows the 787 timeline. Exciting!
scouseflyer wrote:"OTOH, what is Pratt going to do?"
After the recent SNAFUs by Pratt will an OEM trust them to provide launch engines in the near future?
GoSharks wrote:Continental767 wrote:Looks like the 797 is coming soon. Very soon. Maybe even within a month, if it follows the 787 timeline. Exciting!
You don't pick winner(s) of an RFP the day they are due..
bigjku wrote:GoSharks wrote:Continental767 wrote:Looks like the 797 is coming soon. Very soon. Maybe even within a month, if it follows the 787 timeline. Exciting!
Yeah but Boeing has a ton of familiarity with the basic offerings they are going to see. The manufacturers will make their guarantees on performance, finances and specs which will be easily comparable in a matter of a few hours.
The only hard part is evaluating the technical risk with each proposal. But the basic architecture of each proposal is fairly well known. GE/CFM will offer a high temp exotic material but fairly conventional engine. Pratt will offer some GTF. RR is the only wildcard. Do they offer the full ultra fan or just the advanced?
You have likely already talked to airlines about their preferences. My take is that more airlines are loyal to RR than Pratt. I expect the RR to have more technical risk with their first geared fan and a new core but to win out on political merits over Pratt. I think CFM/GE is a sure thing.
texl1649 wrote:jagraham wrote:There is another thread which reports that GE and Safran were negotiating to increase the max thrust for CFM engines to 50000 lbs. So I vote for LEAP as opposed to 9x.
texl1649 wrote:What rational major carrier would want an all new ultrafan design in about 2026 at this point? I don’t think even BA or DL, let alone Korean or others would throw a big commitment that way.
texl1649 wrote:Oh, I realize, Revelation, that GE/SNECMA are expanding their contractual relationship with this new family, To 50or 55k, I should clarify my suspicion is it is, in fact, a new family. Sure, lots of LEAP stuff, but in reality a new core engine, with GE9x tech, and, curiously, not a GTF. so, same stage numbers and architecture as LEAP basically.
RJMAZ wrote:texl1649 wrote:jagraham wrote:There is another thread which reports that GE and Safran were negotiating to increase the max thrust for CFM engines to 50000 lbs. So I vote for LEAP as opposed to 9x.
The last few GE engines have pretty much been done by taking their best current core design and scaling it to the appropriate size and then adding a bit of new technology. This scaling of cores is now done in the virtual world speeding up development. The more new technology that is added the greater the risk. GE can easily strike a balance between risk and fuel burn targets to create an engine by the required operational date.
GE has this in the bag.
The GE9X fan is newer tech and a bit lighter at any given size. So you could effectively have a larger diameter fan providing more thrust with the same shaft horsepower. The LEAP core might only need to provide 10% more shaft power to create an engine with 30% more thrust. Bypass ratio could be as high as 13:1 setting a new record.
Supercharging a core with an additional front stage is pretty common practice. It increases overall frontal area giving higher flow and pressure ratio through the core. Increased heat is the obvious side effect but the LEAP core is reaching maturity. They might add some GE9x techology in the turbine section to handle the heat. This could easily add 25% more shaft power from the core creating an engine with 50% more thrust than the current LEAP.
The end result is an engine that probably shares few parts with the LEAP or GE9x but shares the mature technology of both.
Scaling the Pratt GTF is high risk. It needs a new larger core, Pratt has little experience scaling cores. It needs a new higher ratio gearbox.
Rolls royce advance is based off the 3 shaft trent design and is simply too large for the 797. Scaling it down would be inefficient. Derating the trentTen core and adding a smaller fan can not beat GE. Rolls would need a brand new core. The Rolls royce ultrafan is a cleansheet and very high risk option to meet the in service date. Boeing knows they arw struggling at the moment, even amateur enthusiasts can see Rolls is in trouble.
acjbbj wrote:Didn't GE say that they were calling it quits if they didn't get exclusivity?
imthedreamliner wrote:Fingers crossed for 797By the way, I think it is the perfect time to launch the program. Airbus is not at a position to counter this program due to the recent changes at the management level. Do they need to respond to 797 is another topic. Time will tell.
keesje wrote:imthedreamliner wrote:Fingers crossed for 797By the way, I think it is the perfect time to launch the program. Airbus is not at a position to counter this program due to the recent changes at the management level. Do they need to respond to 797 is another topic. Time will tell.
Airbus is in a very good position to counter & even pre emp this program. They have lots of resources, available technology and 2 existing maturing engines. If they want they do a small, light, cheap NMA, 3 years before Boeing NMA they will. And forget game changing, technological magic from either side. Airbus never has been shy, waiting for Boeing.
Taxi645 wrote:One can ask oneselve how long aviation will be able to avoid the consequences of the Paris agreement. Considering EIS will be somewhere between 2025-2027, playing it save with half-generation improvements might avoid technological risk but could very likely make itself very vulnerable to market/fuel use/regulatory risk.
1989worstyear wrote:Taxi645 wrote:One can ask oneselve how long aviation will be able to avoid the consequences of the Paris agreement. Considering EIS will be somewhere between 2025-2027, playing it save with half-generation improvements might avoid technological risk but could very likely make itself very vulnerable to market/fuel use/regulatory risk.
I'm glad someone else notices this on the site. A320 CEO is a good example of the current mindset - tweak engines, add LCD's and winglets and a 1988 variant magically becomes "state of the art" 25-30 years later. I guess I should upgrade the memory in my damn Apple IIe while I'm at it - and then tell my friends I have fast computer
scbriml wrote:1989worstyear wrote:Taxi645 wrote:One can ask oneselve how long aviation will be able to avoid the consequences of the Paris agreement. Considering EIS will be somewhere between 2025-2027, playing it save with half-generation improvements might avoid technological risk but could very likely make itself very vulnerable to market/fuel use/regulatory risk.
While selling by the thousand.
QXAS wrote:So with a 45K engine, what sort of fuselage does that indicate? Is the thrust required a clue for that or is it mostly inconsequential?
Revelation wrote:[(CEO of GE Aviation David) Joyce said CFM will probably be the engine provider rather than GE, if Boeing selects the family.
Ref: https://leehamnews.com/2018/03/22/ge-cf ... ng-on-nma/“It will be bigger,” Joyce told a JP Morgan investment conference on 14 March. “It’s advancing [on the Leap technology] not a full generation but a half-generation.”
So in essence it's going to be a bigger CFM LEAP with a "half generation" leap (tm) in technology.
jagraham wrote:Ultrafan is a GTF https://www.rolls-royce.com/media/our-s ... arbox.aspx. It also has a variable pitch fan. The new core is already being done in the Advance3 demonstrator. So the pieces are there, and should generate class leading efficiency; but will Boeing wait??? Or trust for that matter????? Ultrafan has a LOT of new toys in one toybox.
questions wrote:What do we know about the 797/NMA aircraft? From the link in the OP’s post:
- A pair of new small twin-aisle aircraft
- NMA-6X, is a 228-passenger medium-ranger with a 5,000 nautical mile endurance
- NMA-7X, seating in two classes for 267, touting a range 800 nautical miles shorter
How will it be different from the 788?
What will be the abreast seating configuration?
What is an ovoid hybrid fuselage?
What are 767-200 small twin boarding doors?
RJMAZ wrote:Cross section is still open for debate but I think it will be very similar to the 767. Most likely a foot wider to allow tight 8ab while keeping the 767's LD2 containers. Potentially a slightly reduced height cross section to use a brand new full width container.
parapente wrote:Considering the incredibly tight lead times put forward for this project it really can't be anything else than Cfm can it?
Boeing would be mad to select anybody else (and they are not mad).
And if I were Cfm I would demand exclusivity too.Cant see that Boeing has any option but to agree.
The 7x (I assume it would be built second) is actually quite a large aircaft that's going to need plenty of ooomph imho.
frigatebird wrote:Actually I think the 797 will have somewhat narrower cross section than the 767. 7 abreast Y with 17,5" only. The 787 is too wide for 8 abreast Y (according to the airlines) and too narrow for 9 abreast (according to the passengers). Same with the 777, too wide for 9 abreast and too narrow for 10 abreast. I don't think Boeing will make this mistake another time and make the fuselage wider (and heavier) than necessary, to compete with large narrowbodies like the A321LR.
RJMAZ wrote:Doubtful. 7ab at those seating values if two class would be nearing 767-400 length. That is getting structurally inefficient.
With a reduced height ovoid cross section the fuselage tube will be more suseptable to bending so optimal finenesd ratio will be less than normal. This points further to an 8ab cabin. It will look slightly stubby when viewed top down but it will look slender from the side due to the reduced height.
The big one is that 8ab is more efficient than 7ab in terms of aisle area. With 17.5" seats and aisles when going to 8ab you gain 14.5% extra seats in the width for only a 11.1% increase in width. That difference of 3.4% is pure efficiency. Its the main reason why the A330 beat the 767.
