Birdwatching
Why did KL602 return to LAX yesterday?
Sat Jul 14, 2018 4:46 pm
I've noticed that KL602, scheduled to fly LAX-AMS, made a U-turn over Colorado and returned to LAX, landing after 3:10h in the air. This seems strange to me. If it was anything urgent, they could have gone down in DEN, SLC or LAS. Does anybody know the background story here?
Here's the track. It was on a 747.
https://flightaware.com/live/flight/KLM ... /KLAX/KLAX
All the things you probably hate about travelling are warm reminders that I'm home
george77300
Re: Why did KL602 return to LAX yesterday?
Sat Jul 14, 2018 4:49 pm
Engine 3 failure. No emergency declared. I guess they chose LAX as best options for PAX and maintenance I guess.
LAXintl
Sat Jul 14, 2018 4:57 pm
Maintenance issue. (shutdown engine #3)
Birdwatching
Sat Jul 14, 2018 5:01 pm
Thanks for the quick responses! I assume they wouldn't have returned to LAX but landed someplace closer had this been on the 777 they also have on this route?
Antarius
Sat Jul 14, 2018 5:03 pm
Typically if the problem isn't an emergency, they will try to return to an airport that the airlines flies to. They have ground staff/support staff etc. to handle the issue there.
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
lavalampluva
Sat Jul 14, 2018 5:32 pm
Since it wasn’t a life threatening emergency they’ll fly to an airport which is staffed with KLM or Skyteam staff. Also since an engine will need to be repaired/replaced it they would fly to an airport with the proper mx crew.
Remind me to send a thank you note to Mr. Boeing.
Boof02671
Sat Jul 14, 2018 6:18 pm
I doubt KLM does their own maintenance in LAX, it’s either Delta or a vendor.
Just that LAX has better facilities to perform an engine change.
And they can always fly in their own mechanics.
As the engine and tooling must make its way to LAX.
lavalampluva
Sat Jul 14, 2018 6:31 pm
Well that’s what I meant. LAX is setup for 747 maintenance. DEN and SLC are not. They probably could have made it to MSP, but would probably have had the same issues.
DTWLAX
Sat Jul 14, 2018 6:47 pm
Looks like the inbound from AMS had some issues as well since it left AMS 2 hours late.
Made more sense to go back to LAX than any other airport since there are more options for accomodating passengers the next day on other flights like DL, KL and AF - not possible at SLC or DEN.
astaz
Sat Jul 14, 2018 6:49 pm
They were also probably significantly overweight for an immediate landing, so 90 or minutes of flight time buys them the opportunity to lose some fuel and get everything else together.
jsnww81
Sat Jul 14, 2018 6:55 pm
I saw the 747 sitting at the remote pads last night as I drove by on Pershing Drive, and wondered what was up. Good to know.
Bjm0517
Sat Jul 14, 2018 7:33 pm
Denver not as much, but SLC is a Delta hub, they could have sent a Delta 767 or something to AMS for those 744 pax, but then you have the issue of tools not being there to repair the 747 and no maitnince backs near by (LAX,ATL,etc)
Boof02671
Sat Jul 14, 2018 7:39 pm
Doesn’t work that way. Delta can’t operate a KL flight and a 764 doesn’t hold as much as a 747.
And there are slots etc to deal with.
keesje
Sat Jul 14, 2018 7:40 pm
I took KL604 later yesterday, saw it taxiing by and wondered about it..
Redbellyguppy
Sat Jul 14, 2018 9:03 pm
They buy everyone a hotel room if they divert somewhere. At LAX a good chunk of passengers just go home.
DTWLAX
Sun Jul 15, 2018 2:56 pm
DL is not going to put extra equipment to cover for a KLM flight. And the only flight to AMS from SLC is not going to accomodate all the KL passengers. That can be done at LAX which had 2 flights to AMS and 3 flights to CDG the next day.
Newbiepilot
Sun Jul 15, 2018 3:48 pm
KLM can probably lease tooling at LAX for an engine change at LAX. There are multiple MROs that can probably do the work such as Qantas if KLM doesn’t fly in their own team. I don’t know if KLM would fly in their own team or not. Existing 747 operators tend to cooperate quite a bit as the worldwide fleet shrinks.
Flanker7
Sun Jul 15, 2018 3:55 pm
Klm will most likely fly in some of there own tec crew to oversee the repairs
Flying blue only if possible
Boof02671
Sun Jul 15, 2018 4:03 pm
They won’t lease tooling, there are fly away engine change kits, no US based airline who has maintenance has 747 tooling anymore.
And I’d bet to say those kits have been shipped to LAX. They will need to lease a mini crane or hangar space.
I once took two flatbeds and a box truck to LAS from CLT, worked 20 years aircraft maintenance at US.
mmo
Sun Jul 15, 2018 4:05 pm
Of course, you do realize, a 747-400 or any transport category, can land at their MTOW. (Assumed the go around requirements are met for obstacle clearance) so if you land 1,000 kilos overweight or 100,000 kilos overweight an overweight landing inspection will be completed.
flyguy84
Sun Jul 15, 2018 5:24 pm
Yes. FARs require an immediate diversion to nearest suitable airport if you encounter a degraded engine. Of course a 747 has more than two engines so it’s not deemed an emergency.
SFO
Bjm0517
Mon Jul 16, 2018 1:04 am
Uhh, are you sure about that? DAL and KLM already codeshare on a lot of flights, I don’t think it would be an issue for DAL to help KLM out, especially with the seamlessness that they advertise with eachother
Nola
Mon Jul 16, 2018 2:37 am
It's beyond codeshare here. With the Transatlantic JV between DL/KLM/AF, they are essentially one airline. KL could easily put passengers on DL metal to get them to their final destinations. The issue would probably be whether there is sufficient capacity to handle all of the passengers.
IPFreely
Mon Jul 16, 2018 3:58 am
The same thing happened to a British Airways from Los Angeles to London back in 2005. They elected to continue as far as possible with three engines and ended up landing in Manchester:
https://en.wikipedia.org/wiki/British_A ... Flight_268
Bjm0517
Mon Jul 16, 2018 1:01 pm
Yeah, capacity is defiantly an issue, a 747 defiantly holds more than a 767 or A330
GlobalAirways
Mon Jul 16, 2018 7:04 pm
Don't they have spare parts up in Victorville, pretty close if so? Probably Qantas or United could do the repairs onsite? Maybe half the flyers could go home for the night if needed?
There is little difference in people, but that little difference makes a big difference. The little difference is attitude. The big difference is whether it is positive or negative. ~ W. Clement Stone
Newbiepilot
Mon Jul 16, 2018 7:40 pm
KLM chartering a Delta rescue flight is very unlikely. A rescue flight is very expensive and DL would not do that for free to help KLM out. There are also a sufficient number of flights that everyone could be reaccomodated within 36 hours. It is fairly easy rerouting people transatlantic.
On the other hand if KLM diverted somewhere incredibly remote and there were no options, they could ask to charter. That still is rare. Usually only smaller airlines charter rescue flights from other airlines.
Mon Jul 16, 2018 7:59 pm
Didnt DL operate a couple of rescue flights in the AF A380 incident?
Newbiepilot
Mon Jul 16, 2018 8:11 pm
Are you referring to the Goose Bay diversion? If so that makes sense. A diversion to SLC, DEN or LAX is less likely to require KL to charter a rescue flight from a partner. Delta could probably help with seats and in those circumstances KL will usually interline with anyone they can to get people home. You cant interline an A380 worth of people from goose bay
Boof02671
Mon Jul 16, 2018 11:16 pm
If QF or UA mechanic’s aren’t given training from KL, they aren’t allowed to touch the plane.
And KL would need to use an engine they own or lease due to specifics.
Boof02671
Mon Jul 16, 2018 11:17 pm
And you also forget DL just can’t pull a plane and crew into action quickly.
astaz
Fri Jul 20, 2018 12:15 am
I do realize that, but given the relatively non-urgent nature of losing an engine on a 747, it’s generally considered to be preferable to land below MLW when possible. Obviously the severity and how time critical the emergency is usually dictates this.
mmo
Fri Jul 20, 2018 6:44 am
Really? And how did you arrive at this conclusion? Just to point out a few things you might have missed in your initial 747-400, I assume you are a rated pilot on the 400 to make such a statement.
First of all, with the engine fail return, the aircraft isn't going anyplace for several hours. An overweight landing inspection on the 400 is a relatively straightforward inspection which starts in downloading the landing data from the CMC. If all is within limits, then it is just a simple visual inspection. Every airline I have worked for flying the 400 has always had the philosophy to get the aircraft on the ground at the earliest opportunity. If that means an overweight landing so be it.
Perhaps you could provide a reference or other evidence to support your statement of "it’s generally considered to be preferable to land below MLW when possible." with an engine out scenario.
astaz
Fri Jul 20, 2018 3:35 pm
So by your assessment the crew did a poor job by not immediately landing the aircraft at say DEN, SLC, LAS, PHX etc?
Obviously they felt the airplane was flying just fine, and felt that getting to LAX provided operational advantages, which I’m sure if they were worried about the aircraft itself, and it’s ability to fly, they would not have even been considering.
Here is an interesting article from Boeing on decision making when it comes to putting the aircraft down immediately, versus holding, or jettisoning fuel. Obviously at the end of the day it’s the Crew’s decision, to ensure a safe outcome.
https://www.boeing.com/commercial/aeromagazine/articles/qtr_3_07/article_03_1.html
777Mech
Fri Jul 20, 2018 6:27 pm
They can and they have before. Numerous times VS has set a bird down in Goose Bay/St. John's etc and DL has ferried an aircraft there to continue the flight.
Birdwatching
Fri Jul 20, 2018 8:32 pm
Thanks for all your comments, I didn't expect this thread to get 35 replies. I'm still wondering why they haven't continued to MSP or ORD, where they have their own staff too, and lots of onwards connections to get the pax home to AMS and beyond, and less distance from AMS to bring in technicians, tools and parts. But then someone wrote that they might save on accommodation cost since a good amount of passengers can go back home. But I can't imagine this outweighs the cost of bringing an engine to LAX vs ORD. Anyway, they made their decision to turn around very quickly. On flightaware it's 5 minutes from the moment the speed dropped (which I assume is the moment the engine shut down) to the time they commenced their very wide left turn.
mmo
Fri Jul 20, 2018 11:37 pm
First of all, you might want to review what I wrote. I didn't say anything about the crew's job performance. I was questioning your comments about "it’s generally considered to be preferable to land below MLW when possible." and questioned where you came up with that advice. If you think I did not agree with the crew's assessment, then you completely misread what I wrote. I was questioning your experience to make such broad stroke comments as if you had thousands of hours experience.
Boeing's article really doesn't give any advice, it merely points out the areas for consideration. My guess is with the air turnback of the KLM flight, it was probably close to MGW when it landed. The problem with such broad stroke advice you give is every situation is different. Look at the Swiss Air MD-11 incident. Did the crew make the right decision then? We can say with 20/20 hindsight probably not, but we weren't in the cockpit.
Personally, all things being equal, I am in the camp of get the aircraft on the ground safely as soon as possible. If I have already declared an emergency then I will land over weight, all things being equal. Overweight landings are practised in the sim and should not be a big deal. In this case, the "most logical" decision was to divert back to LAX. But SFO might have been closer. Again, dispatch will have their input but the Captain is the one making the decisions.
stratosphere
Sat Jul 21, 2018 12:24 am
But kind of surprised they didn't dump fuel if they were overweight of course it's the crews call you're right overweight landing is not a big deal but usually see it more in airplanes like the 757 which don't have fuel dump capability. Also was the Swiss Air MD-11 an incident? I thought it was an outright crash but iv'e been known to be wrong.
astaz
Sat Jul 21, 2018 12:38 am
I do have thousands of hours of experience, thank you for your assessment of my experience. I don’t feel that my comment was broad stroke, because in the event of a critical emergency I would happily land overweight every time. If I am over Colorado, and making the decision to go back to LA, and the ability to jettison fuel is available to me, I would much rather land under MLW than above it. Based on the fact they decided to go back to LA, they obviously didn’t feel getting the aircraft on the ground as quickly as possible was a necessity, or a diversion elsewhere would have been conducted. Given the time available to the Crew, why not attempt to make that landing underweight? That was my only point. If you have the time, and it is safe to do so, I still argue it is preferable to land below MLW, than above it, but if the nature of the emergency is time critical, I would land overweight all day long.
Flanker7
Sat Jul 21, 2018 9:18 am
Part reason to return to LAX is that there are two flights a day on there own flights and the Delta flights so getting stranded pax out makes it that bit easier. LAX has a lot crew available so getting crew home makes it that bit aswell.
