smolt
Insane heat wave digs a hole on RW22 Haneda Tokyo
Mon Jul 16, 2018 10:18 am
The insane heatwave going on these days finally digged a hole on runway 22 Haneda,Tokyo Japan. The hole was found on 0:30 at the noon, and the runway was closed for six hours. The runway was reportedly resumed but flight schedule mess is still continuing.
smolt
Re: Insane heat wave digs a hole on RW22 Haneda Tokyo
Mon Jul 16, 2018 10:34 am
This heatwave, which raises temperature as high as 40 centigrade, plus high humidity, is expected to last next ten days. So the same thing can happen anywhere in Japan,especially in the west and south. Also those travellers coming to Japan should pay enough attention to this hotness.
CARST
Mon Jul 16, 2018 10:48 am
Are there any photos?
When my airplane departed from HND four weeks ago very shortly into the take-off-roll we went through a massive hole, too and the nose-year nearly jumped off the ground. At least it felt like it. I was seated in 1K and thus nearly over the front gear. I thought to myself, wow, that runway is bad and needs to be resurfaced very soon. And that was before the heat wave. So yeah, if all HND runways were in that bad shape, then it is no wonder that a longer time of very high temperatures may damage a runway there which is already in a bad condition, especially in that time of the year when most airports see the highest number of movements...
(To clarify: we departed from rwy 36R or 05, but not from the affected 04/22. Doesn't change the point that their runways apparently need resurfacing.)
Faro
I don’t understand...what exactly is meant by a hole...runway surface irregularity, light concrete ablation or a hole developed on the topsoil adjacent to the runway paved surface?...
Faro
The chalice not my son
CARST
Mon Jul 16, 2018 11:06 am
Faro
The question is what material did they use for the upper surface of the runway? Is it concrete? Or tarmac?
Tarmac tends to melt under prolonged very high temperatures.
HND runway 05:
Heat damage to tarmac:
smolt
Mon Jul 16, 2018 5:28 pm
Reportedly the size of the hole is 30cm x 20cm and 10cm depth. They say the surface is flaked off. No more detail is reported. In Japan almost all runways surface is what we call asphalt, though perhaps this is not the exact term. To be correct that must be a mixture of asphalt and aggregate.
c933103
Mon Jul 16, 2018 6:31 pm
Faro
This is the hole Image
It's pointless to attempt winning internet debate. 求同存異. よく見て・よく聞いて・よく考える
Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan! Nyan!
Meow Meow Meow! Meow Meow Meow Meow!
trpmb6
Mon Jul 16, 2018 6:38 pm
That does not appear to be heat related damage. If the picture in the last post is indeed the hole cited by OP.
c933103
Mon Jul 16, 2018 7:48 pm
No official reason have been given to the formation of this hole, and report stated that a similar hole was formed on another runway of Haneda airport back in June.
DoctorVenkman
Mon Jul 16, 2018 8:42 pm
c933103 wrote:
Faro
I regularly drive by potholes 2-3 times bigger than that (and a fair amount deeper) in NYC. I've occasionally hit a few, too. While it's not something I'd want to do all the time, it has never significantly damaged my car.
With that in mind I can't imagine an aircraft with multiple bogies and much larger tires sustaining any sort of damage from a hole of that size. Of course, it's better to repair it, but it doesn't seem like there's much reason for alarm.
wn676
Mon Jul 16, 2018 11:39 pm
DoctorVenkman wrote:
c933103 wrote:
Faro
Spalling pavement poses a significant FOD risk. Something like this in a gate area would cause alarm.
Tiny, unreadable text leaves ample room for interpretation.
Samrnpage
Mon Jul 16, 2018 11:56 pm
The whole world seems to be under this heat wave, US, Japan, Europe
32andBelow
Tue Jul 17, 2018 12:16 am
How hot is 40?
AtomicGarden
Tue Jul 17, 2018 12:27 am
32andBelow wrote:
How hot is 40?
You mean in American temp? 104F
You killed a black astronaut, Cyril! That's like killing a unicorn!
kabq737
Tue Jul 17, 2018 12:35 am
32andBelow wrote:
How hot is 40?
About 105F.
Been on: 320, 321, 333, 733, 73G, 738, 739, 744, 752, 763, 764, 772, 789, C208, CR7, CR9, BE20, MD83, MD88, MD90, E70, E75, E90, TRIM
Flown: SEEKER, C150M C172N, C172R, C172S, C182RG, DA40, PA-46
402679
Tue Jul 17, 2018 12:48 am
There are still quite some snow down south in Argentina / Chile :P
32andBelow
Tue Jul 17, 2018 12:54 am
[twoid][/twoid]
AtomicGarden wrote:
32andBelow wrote:
How hot is 40?
Seems unreasonable that a runway would fail at that temp unless they use s totally different compound there.
m007j
Tue Jul 17, 2018 1:47 am
c933103 wrote:
Faro
Keep in mind the Imagine the kinetic energy involved. A rubber tire has just taken the shock of 187,000 tons (let's assume max landing weight for an A330, common plane in Asia) at around 160 mph and hits the jagged edge of that exposed second layer. All it takes is one weak tire, and boom! you've got a blown tire (maybe more depending on where it touches down) which can cascade from there. While I am intentionally sliding down the slippery slope the point is, one hole in the runway could be symptomatic of more or however infinitesimally small of a blown something or an engine ingesting loose asphalt, airports do not play around with it.
spacecadet
Tue Jul 17, 2018 3:32 am
Potholes are caused by changes in temperature, not by temperature itself.
I know potholes are not unheard-of on runways. That said, I'd have thought an airport like Haneda would have procedures and/or construction methods to avoid this.
CX Flyboy
Tue Jul 17, 2018 4:56 am
There has been a lot of rain in Japan. It is perhaps more likely that the hole came from that. Even one of the taxiways in HKG here has been breaking up because of the prolonged rain we have had this last week (Although it is finally gone...for now).
NearMiss
Tue Jul 17, 2018 5:46 am
I tell ya, it's not that cold down here actually, unless you go to the southern parts of Chile, like Coyhaique or Punta Arenas. Santiago's actually been quite unusually warm this Winter and not very rainy. Lowest temperature so far this year's been -3°C (about 27°F).
Back on topic, how dangerous can that pothole for big plane operations?
"There is an art, it says, or rather, a knack to flying. The knack lies in learning how to throw yourself at the ground and miss."
PW100
Tue Jul 17, 2018 4:14 pm
Wow. I can see how the shock of three Titanics will cause havoc to a runway . . . :-)
m007j
Tue Jul 17, 2018 5:21 pm
See this is what happens when you spend half your day with engineers and the other half with people who have never heard of the metric system before...
My mistake, that should read 187 tons, or around 374,000 lbs.
@PW100, I LOL'd at your tagline. Thanks for the laugh!
kjeld0d
Tue Jul 17, 2018 5:50 pm
I propose we rename this thread HOLEGATE
