Faro wrote:I don’t understand...what exactly is meant by a hole...runway surface irregularity, light concrete ablation or a hole developed on the topsoil adjacent to the runway paved surface?...
Faro
Faro
c933103 wrote:Faro wrote:I don’t understand...what exactly is meant by a hole...runway surface irregularity, light concrete ablation or a hole developed on the topsoil adjacent to the runway paved surface?...
Faro
This is the hole
DoctorVenkman wrote:c933103 wrote:Faro wrote:I don’t understand...what exactly is meant by a hole...runway surface irregularity, light concrete ablation or a hole developed on the topsoil adjacent to the runway paved surface?...
Faro
This is the hole
I regularly drive by potholes 2-3 times bigger than that (and a fair amount deeper) in NYC. I've occasionally hit a few, too. While it's not something I'd want to do all the time, it has never significantly damaged my car.
With that in mind I can't imagine an aircraft with multiple bogies and much larger tires sustaining any sort of damage from a hole of that size. Of course, it's better to repair it, but it doesn't seem like there's much reason for alarm.
32andBelow wrote:How hot is 40?
Samrnpage wrote:The whole world seems to be under this heat wave, US, Japan, Europe
AtomicGarden wrote:32andBelow wrote:How hot is 40?
You mean in American temp? 104F
Faro
This is the hole
geoshina wrote:Samrnpage wrote:The whole world seems to be under this heat wave, US, Japan, Europe
There are still quite some snow down south in Argentina / Chile
m007j wrote:Keep in mind the Imagine the kinetic energy involved. A rubber tire has just taken the shock of 187,000 tons (let's assume max landing weight for an A330, common plane in Asia) at around 160 mph and hits the jagged edge of that exposed second layer.
PW100 wrote:m007j wrote:Keep in mind the Imagine the kinetic energy involved. A rubber tire has just taken the shock of 187,000 tons (let's assume max landing weight for an A330, common plane in Asia) at around 160 mph and hits the jagged edge of that exposed second layer.
Wow. I can see how the shock of three Titanics will cause havoc to a runway . . .
