SyracuseAvGeek wrote:I've seen them use 900's on flights from SEA-EWR
flybynight wrote:SyracuseAvGeek wrote:I've seen them use 900's on flights from SEA-EWR
I should have made it more clear - AS seems to use more 800's than 900ER's.
KICT wrote:Do the 700s still make it out east?
FA9295 wrote:KICT wrote:Do the 700s still make it out east?
I've seen the -700s on PDX-AUS quite a bit as of recently. Also PDX-ORD every once in awhile.
usxguy wrote:I think that almost every flight to TPA, MCO, and FLL are 739ER or A321/A320 (LVX routes). And I believe that SEA-FLL is the longest AS flight in the system.
ericm2031 wrote:FA9295 wrote:KICT wrote:Do the 700s still make it out east?
I think he meant East Coast
flybynight wrote:On longer flights to east coast cities, it seems that AS uses a lot of 800's.
Is the range on the 900ER's so tight on those flight it is limiting, hence the use of 737-800's? Or is the 800 simple the most appropriate size?
YellowJ wrote:flybynight wrote:On longer flights to east coast cities, it seems that AS uses a lot of 800's.
Or perhaps they are matching capacity to demand. Considering the 900ER run SEA-FLL, which pushes block times of 7 hours, I doubt range is a issue.
NameOmitted wrote:ericm2031 wrote:FA9295 wrote:I've seen the -700s on PDX-AUS quite a bit as of recently. Also PDX-ORD every once in awhile.
Looking at it from Alaska, Texas is a small, East Coast state.
My point was that those are probably some of the longer -700 AS routes.
F9LASDEN wrote:usxguy wrote:I think that almost every flight to TPA, MCO, and FLL are 739ER or A321/A320 (LVX routes). And I believe that SEA-FLL is the longest AS flight in the system.
SEA-FLL is also the second-longest currently operating flight in the contiguous United States (title shared with NK) after AA's SEA-MIA route
TWA902fly wrote:F9LASDEN wrote:usxguy wrote:I think that almost every flight to TPA, MCO, and FLL are 739ER or A321/A320 (LVX routes). And I believe that SEA-FLL is the longest AS flight in the system.
SEA-FLL comes in at #8 longest in the AS system by mileage flown (not sure about time wise)...
ANC-KOA 2874 sm
ANC-ORD 2846 sm
ANC-OGG 2797 sm
ANC-HNL 2777 sm
ANC-LIH 2742 sm
BLI-KOA 2732 sm
LAX-SJO 2722 sm
SEA-FLL 2717 sm
'902
ANC-KOA 2874 sm
ANC-ORD 2846 sm
ANC-OGG 2797 sm
ANC-HNL 2777 sm
ANC-LIH 2742 sm
BLI-KOA 2732 sm
LAX-SJO 2722 sm
SEA-FLL 2717 sm
'902
AS doesn't operate ANC-LIH, so SEA-FLL is #7.
ANC-KOA 2874 sm
ANC-ORD 2846 sm
ANC-OGG 2797 sm
ANC-HNL 2777 sm
ANC-LIH 2742 sm
BLI-KOA 2732 sm
LAX-SJO 2722 sm
SEA-FLL 2717 sm
'902
It's seasonal.
FatCat wrote:I was looking at the differences between AS's -900 and -800, on seats arrangement.
What a strange configuration. 3 classes on -800 and some -900.
What Seatguru calls "Premium" is some sort of Business, right?
Never seen a 3 classes 738 here in EU, they are mostly sardine cans 189 full Economy, lol
RWA380 wrote:FatCat wrote:I was looking at the differences between AS's -900 and -800, on seats arrangement.
The idea is that the entire AS fleet, Airbus, Boeing & Embraer (Boeing South) will offer 3 distinctive cabins on all of their aircraft. Coach (with decent seat pitch). premium economy & First class. AS has a couple more 900ER's than 800's at this point & the field performance is not great on the 900ER, it's a slow ascent but the long take off runs are kind of fun.
The first 900ER for me, was on AS PDX-HNL, it was full of fuel (noted by the weight movement of the fuel as we cornered) it was certainly my longest roll on a 737 taking off towards the west, a long slow gradual ascent & by the time we hit the coastline, we were getting to cruising altitude, we were forward of the wing with an unobstructed view of the ocean for hours. 6h 20m PDX-HNL, slow ride!
EA CO AS wrote:Look for the 900ER to take over the majority of the pre-acquisition VX transcons; by January the transcons will be 70% Boeing, 30% Airbus.
vadodara wrote:EA CO AS wrote:Look for the 900ER to take over the majority of the pre-acquisition VX transcons; by January the transcons will be 70% Boeing, 30% Airbus.
Pretty strong statement! From op's perspective, any idea how the 737 stacks up against the A320?
FatCat wrote:RWA380 wrote:FatCat wrote:I was looking at the differences between AS's -900 and -800, on seats arrangement.
Thanks for your reply.
I also experienced a very long take off run, on one FR flight with the 738 completely packed of passengers, cargo and on a very hot and humid day. PSA-LPA last September. Also the climb was slow. Shortest T/O run ( apart from the departures from FLR ) in my experience was on an AZ MD82 back in 2008, LIN-CTA. MD80s had that attitude and being seated in the back didn't help but boy it was a sporty take off.
vadodara wrote:Pretty strong statement! From op's perspective, any idea how the 737 stacks up against the A320?
Go ahead .. tell some Texan redneck he's from the east! You gonna get shot!
seabosdca wrote:I think I've flown on -900ERs on every AS transcon route I've flown except for DCA. DCA is runway limited and a -900ER can't take off from there with a full load of passengers and fuel. I would love to know if the A321neo can do it, as DCA could desperately use more seats.
flybynight wrote:RWA380 wrote:FatCat wrote:I was looking at the differences between AS's -900 and -800, on seats arrangement.
How do feel the weight movement of the fuel? Curious if this is something new I can potentially be on the lookout for.
I can definitely tell if the flight is full for a long flight based on the amount of runway used. It is always interesting seeing AS 737's use up the same amount of runway as, say a 777. That's when you know you're looking at a loaded flight likely heading to maybe Boston or Hawaii.
But isnt' the range of the 800's still a little longer than the bigger 900ER's?
Years ago, when the -800 fleet was small, AS used to use the non-ER 900s on SEA-BOS and SEA-EWR. If weather was unfavorable there would be blocked seats and sometimes even IDBs on the westbound legs. I don't think I've ever seen blocked seats on a -900ER.
Flighty wrote:DCA transcon seems to be a case where A321 can do it (AA DCA-PHX and AS DCA-LAX) but B739 cannot do it.
ikolkyo wrote:RWA380 wrote:FatCat wrote:I was looking at the differences between AS's -900 and -800, on seats arrangement.
PDX-HNL is fighting against the wind over the ocean, so it's going to be a long ride at certain times of the year. Has nothing to do with the aircraft. Also "movement of the fuel" really dude? Come on.
