Judge1310 wrote:Wasn't this news from yesterday?
KLDC10 wrote:A little more information from the OP would be useful. Here is an article from FlightGlobal: https://www.flightglobal.com/news/artic ... lu-451730/
Summary:
September 5th 2018
Delta Flight 1418: ATL-MCO (Atlanta-Orlando)
Boeing 757-200 N668DN
For the record, this aircraft was delivered in June 1991
The engine was shut down in-flight, no one was injured and the aircraft returned safely to Atlanta. If it's any help, neither the year 1988, nor the year 1989 had anything to do with it...
TWA302 wrote:Judge1310 wrote:Wasn't this news from yesterday?
Yes, barely (2300 EDT). Since it hasn't been discussed why is that pertinent?
NWAROOSTER wrote:How close to retirement is this aircraft. Pratt & Whitney engines generally from my experience have a better record for containing containing debris. An example is the GE powered United DC-10 that had an uncontained engine failure of the number two engine and severed all the hydraulic lines. It tried to land at Souix City, Iowa and almost did. Northwest Airlines had a Pratt & Whitney powered DC-10 that had the number two engine, which was a JT9D-20, shortly after that disintegrate in flight but contained all the debris and landed safely at Denver, Colorado without any other damage. Pratt's engines were built stronger to with stand this type of engine failure.
deltal1011man wrote:NWAROOSTER wrote:How close to retirement is this aircraft. Pratt & Whitney engines generally from my experience have a better record for containing containing debris. An example is the GE powered United DC-10 that had an uncontained engine failure of the number two engine and severed all the hydraulic lines. It tried to land at Souix City, Iowa and almost did. Northwest Airlines had a Pratt & Whitney powered DC-10 that had the number two engine, which was a JT9D-20, shortly after that disintegrate in flight but contained all the debris and landed safely at Denver, Colorado without any other damage. Pratt's engines were built stronger to with stand this type of engine failure.
you do know that aircraft age has basically nothing to do with engine age right?
Narfish641 wrote:Glad everyone landed safely. Crazy incident, but crap happens.
flymco753 wrote:Are they going to pull a bird from the desert or are they just going to fix the powerplant and keep flying the frame?
Tedd wrote:NWAROOSTER wrote:How close to retirement is this aircraft. Pratt & Whitney engines generally from my experience have a better record for containing containing debris. An example is the GE powered United DC-10 that had an uncontained engine failure of the number two engine and severed all the hydraulic lines. It tried to land at Souix City, Iowa and almost did. Northwest Airlines had a Pratt & Whitney powered DC-10 that had the number two engine, which was a JT9D-20, shortly after that disintegrate in flight but contained all the debris and landed safely at Denver, Colorado without any other damage. Pratt's engines were built stronger to with stand this type of engine failure.
I don`t understand how you can suggest PW have a better record of containing debris than any other. All engine failures
are different with so many variables, these include, engine & aircraft speed, where in the engine the damage eminated,
etc, etc. While all engines are tested to contain fan blades ( the fan casings do a phenominal job btw ) there isn`t much that
can be done to contain certain failures behind the fan, & in instances of catastrophic failure that we`ve seen during the
recent past, it can put lives & the whole aircraft at risk depending in which direction the debris/shrapnel is flung.
All three of the major engine manufactures do a remarkable job of producing the safest powerplants possible, but you
can`t guarantee against mechanical failure in any of them.
wjcandee wrote:Just a point: they keep saying "uncontained" engine failure. If stuff comes out the tailpipe, it isn't "uncontained", it's just debris. Surprisingly, we haven't seen any "we're gonna die!!!" Twitter videos or photos out the window. This suggests, at least, that the description may be exaggerated, and we won't know until we see a photo or learn more complete info. The Flightglobal article talked about "on departure from ATL", which may be technically accurate but can be misread, as I did, to mean during the takeoff run, and now we find out they shut it down at FL180. It's possible that this was an engine issue requiring a precautionary shutdown, and it's likely that it was serious, given that DL said they would be changing the engine, but uncontained engine failure might be an overstatement here. Or not. It will be interesting to see.
KLDC10 wrote:The engine was shut down in-flight, no one was injured and the aircraft returned safely to Atlanta. If it's any help, neither the year 1988, nor the year 1989 had anything to do with it...
questions wrote:KLDC10 wrote:The engine was shut down in-flight, no one was injured and the aircraft returned safely to Atlanta. If it's any help, neither the year 1988, nor the year 1989 had anything to do with it...
What does this mean?
jeffrey0032j wrote:questions wrote:KLDC10 wrote:The engine was shut down in-flight, no one was injured and the aircraft returned safely to Atlanta. If it's any help, neither the year 1988, nor the year 1989 had anything to do with it...
This is a reference to a certain member with a weird obsession with how planes built 1988 and after are supposedly a lot better than planes built before. This member also has a weird obsession with calling 767s worst planes and A320 best planes in almost every post.
gokmengs wrote:Surprised this is not reported on avherald yet...
usdcaguy wrote:Is it just me, or are the engines on the 75's particularly prone to failure? Seems like DL has had a number of in-flight emergencies with its 757 engines. You have to wonder if DL is flying them a bit past their prime and should have ordered the A321s earlier.
bkflyguy wrote:usdcaguy wrote:Is it just me, or are the engines on the 75's particularly prone to failure? Seems like DL has had a number of in-flight emergencies with its 757 engines. You have to wonder if DL is flying them a bit past their prime and should have ordered the A321s earlier.
It's just you.
A.Net - The 757 is the greatest plane ever built. Boeing should restart the line and build more; Also A.Net. The 757 is so old and not safe, Delta should have ordered MAX or NEOs.......
CL350PilotSmith wrote:I’m a Challenger 350 driver and was a passenger on this flight. Definitely was not a flameout, rollback, or precautionary shutdown. I was in the window seat directly aft of the right wing. Climbing through FL180 there was a solid bang followed by flames and sparks exiting the number 2 engine. I did not assume it was an uncontained failure since there was no perceptible impact of engine part with the airframe, but I mentally prepared for a possible blown tire on landing. Given the explosive nature of the failure I would not be surprised if it was uncontained. The crew did a great job getting us back on the ground safely (longest 15 minutes in an airplane - especially when I observed more sparks some 5 minutes after shutdown). BTW - this flight was a line check for them. I assume they passed! Just wish I had videoed the event.
usdcaguy wrote:bkflyguy wrote:usdcaguy wrote:Is it just me, or are the engines on the 75's particularly prone to failure? Seems like DL has had a number of in-flight emergencies with its 757 engines. You have to wonder if DL is flying them a bit past their prime and should have ordered the A321s earlier.
It's just you.
The question isn't about safety measured in terms of fatalities but rather whether other carriers are having as many engine failures with other types.
bob75013 wrote:People keep referring to the "uncontained" engine failure, but I have seen no photo or reports of fuselage damage or engine damage that would equate to an "uncontained" failure --- just sayin...
jagraham wrote:Even before knowing the details of the failure, a few things need to be said . .
1) Engine shutdowns are rare.
Spacepope wrote:bob75013 wrote:People keep referring to the "uncontained" engine failure, but I have seen no photo or reports of fuselage damage or engine damage that would equate to an "uncontained" failure --- just sayin...
Uncontained can also refer to parts coming straight out the back of the engine, so lack of fuselage damage doesn't really tell you if it was contained or not.
