lightsaber wrote:Was anything changed in the engine for the enhanced A350? I'm not aware of anything. This could be a bird for all I know.
zeke wrote:lightsaber wrote:Was anything changed in the engine for the enhanced A350? I'm not aware of anything. This could be a bird for all I know.
Yes there is, the newer engines had some changes which reduces fuel burn a couple of percent.
I think the share price would have gone down even without this event, just like it will go up again.
LoganTheBogan wrote:Seems like such a silly article. How does an in-flight shutdown cause this much drama towards a company? The Trent XWB has been absolutely outstanding from EIS and has shown very few problems. That's not to say problems won't occur but it certainly doesn't explain why a simple unfortunate thing deserves this media drama.
WholaLottaLove wrote:A large drop in the share price would only make sense if this is due to a design problem. Isn't this more pointing towards a production issue given the fact that this engine was more or less brand new? (2-3 months old)
An Iberia Airbus A350-900, registration EC-MYX performing flight IB-6252 from New York JFK,NY (USA) to Madrid,SP (Spain) with 265 passengers and 11 crew, was enroute at FL410 about 70nm southeast of Halifax,NS (Canada) when the crew reported they had needed to shut the left hand engine (Trent XWB) down. The aircraft drifted down to FL250, turned around, the crew decided to return to New York's JFK Airport but when already cleare direct to New York Airport changed their mind to divert to Boston,MA (USA). The aircraft was recleared direct Boston, the crew advised they would be able to vacate the runway, no assistance was needed. The aircraft landed on Boston's runway 33L about 96 minutes after leaving FL410, vacated the runway and taxied to the apron with emergency services in trail.
Passengers reported the captain announced one of the engines had lost power and was shut down, they were diverting to Boston.
Passengers “knew something was up” when a smoke- and gaslike odor filled the cabin, Miller said. The crew did not mention the issue until “a bit later,” Miller wrote in a Twitter direct message early Wednesday.
uta999 wrote:I think RR need to sell that model to Boeing. Why is there such a problem with the 787 version vs the A350?
Aircellist wrote:Now that a BA 787 also had a diversion, how are the shares doing?
ikolkyo wrote:Aircellist wrote:Now that a BA 787 also had a diversion, how are the shares doing?
There was no engine failure.
Aircellist wrote:ikolkyo wrote:Aircellist wrote:Now that a BA 787 also had a diversion, how are the shares doing?
Fumes in the cockpit do not relate to the engines? Sorry for my ignorance…
uta999 wrote:Is the RR Trent XWB too big for the 787? I think RR need to sell that model to Boeing. Why is there such a problem with the 787 version vs the A350?
Ooooh so what? "A GEnx engine has a shutdown... GE is in big trouble now". My golly media gets on my nerves sometimes.
I'm sure the XWB will be free of any 1000 related issues. RR is good at what they do, just like any other engine manufacturer, and they'll get whatever needs sorting out done.
bigjku wrote:I don’t see any other explanation. Either RR got very lucky and swapped out the materials from the Trent 1000 that are responsible for the problem or they are just lying/hoping it doesn’t also occur on the derivative types. I would suspect the next 12-24 months will tell that tale. But if the XWB goes down with corrosion problems RR will need government money to remain viable IMHO.
bigjku wrote:uta999 wrote:Is the RR Trent XWB too big for the 787? I think RR need to sell that model to Boeing. Why is there such a problem with the 787 version vs the A350?
The XWB is newer, has much less in service time and the problems are durability based so I remain unconvinced that they know it isn’t a problem there too.
The timelines don’t work out for me.
The first reports of corrosion issues in the Trent’s were in 2016. The EASA and FAA restrictions occurred in April of this year. The package C engines had about 3 or so years of wingtime when that came down.
The XWB first ran in 2010, entered service in 2015. It wouldn’t be totally shocking if 3 or so years into things we start to see similar issues
Why? Because the idea that they made major materials changes that solved a corrosion problem they didn’t know they had yet given the above timeline doesn’t hold up.
If they did fix it they either got very lucky and basically fixed it by accident or they flat lied to regulators and airlines because they had a known problem, fixed it on their next engine and didn’t disclose to the airlines until engines were breaking in flight.
To me the more likely alternative given how ham fisted their response new to the breaking engines has been thus far is that they didn’t know jack squat until 2016-17. Otherwise they would have at least been buoidng up capacity to deal with their current disaster.
So unless they got really really lucky and just happened to fix a materials based defect for reasosns unrelated to the actual problem I would guess all the modern Trent engines have some level of corrosion issues buried within them.
Thats why shareholders are a bit skittish. If there is a problem on the XWB engine that means there is likely a problem on the Trent 7000 and the Ten. All of these engines predate the first known report of corossion issues.
RB211trent wrote:bigjku wrote:uta999 wrote:Is the RR Trent XWB too big for the 787? I think RR need to sell that model to Boeing. Why is there such a problem with the 787 version vs the A350?
Basically all you’ve just said is complete rubbish. Most of the problems associated with the T1000 issues at the moment have nothing to do with blade corrosion. You’ve obviously not even read the Ads as you don’t know their contents.
We shouldn’t compare the history of TXWB and T1000 by the number of years in service, rather we should compare their history over operating hours.
Roughly 40% of the 787 orders are equiped with the T1000, while all of the A350 orders are TXWB.
The blade corrosions issue was discovered in 2016, and so 400 787s were delivered by then in which 40% were T1000. This leaves us with 160 operational T1000 engines when the time the first cracking blade was discovered.
The Trent XWB is already past that number ( currently 200).
bigjku wrote:And BTW Airbus just dumped their head of sales from RR a day after the first inkling of an engine issue arose on the XWB.
Erebus wrote:bigjku wrote:And BTW Airbus just dumped their head of sales from RR a day after the first inkling of an engine issue arose on the XWB.
You're making things up. Airbus didn't "dump" him. His resignation was his own decision and Enders expressed regret for that. This has more to do with Airbus's top management issues than the incident with the XWB.
bigjku wrote:I grant it’s 100% speculation. But regulatory capture by the industry happened on the 787 and we all accept that right? Just suggesting we examine everyone’s motivations here before we accept corporate statements and regulatory silence that everything is “fine”.
RB211trent wrote:Most of the problems associated with the T1000 issues at the moment have nothing to do with blade corrosion.
Revelation wrote:RB211trent wrote:Most of the problems associated with the T1000 issues at the moment have nothing to do with blade corrosion.
Care to expand on what is publicly known about these other problems?
lowbank wrote:Guys the lead XWB engines have done 1500 cycles plus.
This event was after 50 cycles, no way on earth can that be a design issue. Logic dictates that.
I know lots of you guys are not Engineers. But seriously.
Balerit wrote:I remember reading somewhere that Airbus wanted a different coating on the blades and RR complied. Maybe Airbus engineers didn't trust the coating on the 1000.
lowbank wrote:Revelation wrote:RB211trent wrote:Most of the problems associated with the T1000 issues at the moment have nothing to do with blade corrosion.
I believe you are referring to turbine issues Revelation.
I think if you search compressor issue you may find the info you are looking for.
RB211trent wrote:lowbank wrote:Guys the lead XWB engines have done 1500 cycles plus.
Exactly, search compressor issues and you can get all the info you want. The ADs are accessible to anyone, and before anyone goes any further the compressor of the T1000 and XWB are not the same.
Dalmd88 wrote:RB211trent wrote:lowbank wrote:Guys the lead XWB engines have done 1500 cycles plus.
I think the Intermediate Compressors on The Trent 1000 and the XWB are very closely related. Rolls is concerned the blade cracking will occur in the XWB as the fleet ages. By then they should have a good fix from the 1000, but it will require an accelerated shop visit to fix the issue.
As for the IB A350 in BOS. I heard it was a auto rollback shutdown. The Trent family has lots of built in protections. If the engine sees certain faults it will auto shutdown to prevent damage. A vibe problem is one possible example. Delta shipped up the engine change kit this week in the event of an engine change. As of Friday I had not heard any updated info.
Bongodog1964 wrote:This all bears the signs of financial speculators making a short term gain at the expense of panicky investors, spread a rumour that RR have another mess on their hands, share prices immediately marked down and someone clears a short position they had on their books that was previously looking like a loss maker.
StTim wrote:WIederling wrote:Bongodog1964 wrote:This all bears the signs of financial speculators making a short term gain at the expense of panicky investors, spread a rumour that RR have another mess on their hands, share prices immediately marked down and someone clears a short position they had on their books that was previously looking like a loss maker.
In general GE seems to have the much more effective Astroturfer Corps.
Not only in the "sanitizing public appearance" but also in the "smear the competition" department.
Agree - Not sure it is just Astroturfer Corps or an inherent process of the American press etc to highlight non US company issues over and above their own. It seems to happen in many industries. I am not saying they do not publish issues that say Boeing or GE have - but they really go after an issue if it is PW, RR or Airbus etc.
