lightsaber
Re: Boeing Rolls out Static Test 777-9X
Wed Sep 19, 2018 12:37 am
na wrote:
blooc350 wrote:
What a beauty this will be in the SQ colors!
Rear 3/4 is the best angle for a long 777. Indeed good looking here in this rendering, overall it wont quite match the beauty and grandness of a 747-8.
Oh, that is lovely. The 744/748 was my current favorite, but that rendering changed my mind.
Wow!
Oh, I so want to know empty weight. That and cruise efficiency impact how many I think will sell.
Lightsaber
speedbird52
Wed Sep 19, 2018 1:14 am
I never thought I would say this but Boeing have managed to turn the 777 into a work of art
OldAeroGuy
Wed Sep 19, 2018 2:00 am
questions wrote:
When in commercial use, at what point will the wing extensions be placed in the downward position? At what point with they be return to “the upright and locked position”?
Tip extension will be initiated as the airplane crosses the hold line and enters the active runway.
Tip fold will be initiated as the airplane slows on the runway (less than 60kts?) and will be completed before entering the taxiways.
VirginFlyer
Wed Sep 19, 2018 2:04 am
OldAeroGuy wrote:
BREECH wrote:
OldAeroGuy wrote:
Ask me that when you see a tail-less airplane arrive at your gate!
To this brilliant mind "fully-assembled" means "all parts attached", not "uhm... we need to polish some logistics". And this little detail is important in this particular conversation for two reasons. One, the Daily Mail is a fascist outlet that has NEVER published one word of truth. And two, when Boeing rolled out 787 on 7/8/7 it was more of a Spruce Goose than the actual Spruce Goose. Only that one could actually fly. So how do we know this is not another exercise in plywood painting?
On a side note, shouldn't structural testing include the rudder?
Here's a link to a picture of the A380 in its static test rig. Note the lack of engines, horizontal tail and vertical tail.
https://i.stack.imgur.com/A3UPt.jpg
Both the A380 and the 777-9 were complete for structural test.
To further illustrate the point, here is the oldest of the 23,000 A380 photos in the A.net database showing a complete airframe:
Those who were around at the time will recall the great deal of wailing and gnashing of teeth about the apparent incomplete nature of this airframe which was to be used for static tests.
Interestingly when I searched for MSN 5000, it also gave me the A350 static test article, which is equally spartan:
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens. —Bahá'u'lláh
seabosdca
Wed Sep 19, 2018 3:33 am
The crew will lower them manually before starting the takeoff roll, but after clearing a point (to be determined on an airfield-by-airfield basis) where the span with tips extended will not cause clearance issues.
They will raise automatically upon landing.
travaz
Re: First fully assembled 777X photos are out
Wed Sep 19, 2018 4:09 am
BREECH wrote:
clrd4t8koff wrote:
The first fully assembled 777X jetliner has rolled off the Boeing production line at the manufacturer's Everett factory in Washington state:
https://www.dailymail.co.uk/travel/trav ... liner.html
Wow, can't wait to see this out of the hanger and flying! Look at those winglets!
Fully assembled... except for the tail and engines. Do they only hire people who are genetically unable to tell the truth? Would veritaphobic be the proper word?
What a total waste of 1's and 0's.
LAX772LR
Wed Sep 19, 2018 5:34 am
neutrino wrote:
vahancrazy wrote:
Are there any visible diffrences from classic 777 when flying?
Maybe you can recognize the 777-9 due to length and 4 exits but I expect the -8 to be similar enough to a -200.
The raked wingtips, for one, is the most discernible.
77Ls and 77Fs are -200s with raked wingtips, so take care to discern.
49Paralell wrote:
The A350 ULR's range is estimated to reach 17,960 Km, so it will come down strictly to economics as the 777X won't surpass it.
"surpass it" at what?
Range? --that's not an accurate statement. Boeing previously advertised a less-dense 778X at 9300nm without ACT. The proposal for QF hasn't been made public, but if it just gains the same that a tanked 77L offered, then that'd put it at nearly 9900nm and ahead of the A359ULR; and that's still calculated for 3class and 9abreast.
carlokiii
Wed Sep 19, 2018 6:42 am
Quick question... While the 777X will be categorized as a Code E plane at the gates, it's still Code F on the runway. Several airfields (HND and MNL come to mind) have limited A380 operations, such as runway-taxiway separation limitations that doesn't allow an A380 operating normally like a 777 would, ie. adjacent taxiway must be vacant when an A380 is active on the runway and v.v., or increased air traffic separations due to the wake turbulence of a Code F aircraft.
So wouldn't the 777X fall victim to the same operational constraints?
MON
Wed Sep 19, 2018 9:55 am
Matt6461, thanks for making me aware of the additional variables, particularly engine displacement change from centreline, that I was not aware of.
ZaphodHarkonnen
Wed Sep 19, 2018 10:22 am
I think that's a very likely chance for those sorts of airfields.
This is something each airfield will have to deal with when creating their specific plans and procedures.
Another thing to consider is that the B777X will be allowed to fly with passengers with the folding mechanism disabled. That means it will have to be treated as a Code F aircraft at the gate and when taxiing in that situation. So airfields will have to have plans and procedures in place to handle such occurrences.
SomebodyInTLS
Wed Sep 19, 2018 12:44 pm
That's a great illustration to put BREECH's mind at rest - all the red bits on there are *test interfaces* - so the massive great barge-board attached where the tail would normally be...? That has to be a solid block of e.g. steel so it can push, pull and twist tons and tons of load into the back of the aircraft.
"As with most things related to aircraft design, it's all about the trade-offs and much more nuanced than A.net likes to make out."
B764er
Wed Sep 19, 2018 1:34 pm
If Bristol had gotten hold of two GeNX engines from the future, the Brabazon would've been a pratical reality. It would've left the Comet in the dust.
B764er
Wed Sep 19, 2018 1:37 pm
Those 777x wings are huge! I wonder how a 10x or even an 11x would look like (if they happened, 10x being a posibility) We are on our way to the first 300ft Airliner.
BREECH
Wed Sep 19, 2018 1:49 pm
Also don't know why you're worried about what the Daily Mail says since you don't believe them in any case.
That's actually a good point.
Thank you for the photo. What a rig! I actually had to note the presence of fuselage before I noted the lack of tail. And I suppose that whole contraption moves to load the frame?
No friendship, love or respect unite people as much as shared hatred.
Sergey Dovlatov
Stitch
Wed Sep 19, 2018 1:56 pm
carlokiii wrote:
Quick question... While the 777X will be categorized as a Code E plane at the gates, it's still Code F on the runway. Several airfields (HND and MNL come to mind) have limited A380 operations, such as runway-taxiway separation limitations that doesn't allow an A380 operating normally like a 777 would, ie. adjacent taxiway must be vacant when an A380 is active on the runway and v.v., or increased air traffic separations due to the wake turbulence of a Code F aircraft. So wouldn't the 777X fall victim to the same operational constraints?
It will depend on what specific reasons the A380's operations are restricted. The 777X's span with wingtips extended is 8m less than the the A380's though I expect that is not enough to make a difference (since it would only be 4m per side). And Wake Turbulence is more an issue of Operating Weight and a 777X landing weight will be significantly lower than an A380's so air traffic separation will probably be the same as a 777-300ER.
OldAeroGuy
Wed Sep 19, 2018 2:22 pm
The white frame in the picture doesn't move.
The white bits below the fuselage and engine struts are bolted to the factory floor hold down these parts of the airframe.
The white bits above the wings and fuselage push down on the floor when the blue load harness pulls up on the wings and fuselage via load cells simulating air loads on the airframe.
AA777223
Wed Sep 19, 2018 5:14 pm
Something about thing wings, compared to the length (proportions) and the upturned bits in this pic remind me of an MD-11. I can't figure out why, but it just does.
https://pbs.twimg.com/media/Dm4kNuLWsAAKdrv.jpg
vs.
Maybe it's just me...
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
neutrino
Wed Sep 19, 2018 7:44 pm
lightsaber wrote:
278*10=2,780. A wee bit beyond the certification limit. ;)
Lightsaber
And at that number of bums, not even Ewoks can fit into that cabin, well maybe Porgs.
Potestatem obscuri lateris nescitis
BREECH
Wed Sep 19, 2018 9:12 pm
Do you happen to also know the (maximum) amplitude of the load cycles?
Sergey Dovlatov
dakota123
Wed Sep 19, 2018 9:28 pm
24 feet (!)
One of my favorite breaking things vids...
https://www.youtube.com/watch?v=Ai2HmvAXcU0
“And If I claim to be a wise man, well surely it means that I don’t know”
OldAeroGuy
Wed Sep 19, 2018 11:18 pm
dakota123 wrote:
24 feet (!)
Perhaps more deflection than 24ft for the 777-9 because:
1) Wing material is graphite composite rather than aluminum
2) 777-9 MTOW is 42% higher (775,000lb vs 545,000lb) so more load applied
3) 777-9 wing span is 18% greater (235.5ft vs 200ft)
lebda
Wed Sep 19, 2018 11:52 pm
Good Lord, that thing is a behemoth. I love it.
Denver Tower: Gulfstream 592, you’re cleared to 9,000 feet. For a vector to Hector, contact the sector director.
Prost
Thu Sep 20, 2018 1:16 am
When it turns on to the runway in some airports, and when it turns onto the taxiways in others.
SomebodyInTLS
Thu Sep 20, 2018 7:57 am
That's not an answerable question. Every point will have a different max load... also depending on load direction. And everything depends on the aircraft being tested and what it's designed for so it's not like there's a standard - even assuming anyone would divulge anything on an internet forum.
BirdBrain
Thu Sep 20, 2018 2:20 pm
I agree with you. I would like to think it would be part of the runway turning on/off checklist or with flaps extension/retraction, unless it requires some external help, which I doubt. If not, chances of forgetting to fold and running in to things is there. Can't be so much wear and tear by regularly folding and unfolding.
Stitch
Thu Sep 20, 2018 2:26 pm
BirdBrain wrote:
I would like to think it would be part of the runway turning on/off checklist or with flaps extension/retraction...
That is correct. The 777-9 ACAP details how the system works, including EICAS warnings/notifications and pre-takeoff and post-landing checklists and how the system operates in automatic and manual modes.
