enilria
OAG Changes 9/16/2018:3M Scales Back;KE to BOS;F9 Drops BOI-DEN;DL Drops MSP-PBI
Sun Sep 16, 2018 11:22 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: Sorry for the delay. OAG has not been updating Sunday morning reliably the last few weeks.
3M EYW-FLL DEC 4>3[5] JAN 4>3[5] FEB 4>3[5] MAR 4>3[5] APR 4>3[5] MAY 4>3[5] JUN 4>3[5]
3M EYW-MCO FEB 1.8>1.3[2] MAR 2>1.3[2] APR 2>1.3[2] MAY 2>1.3[2] JUN 2>1.3[2]
*3M EYW-RSW NOV 1.0>0.1[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
3M EYW-TPA NOV 3>2[2] DEC 3>2[3] JAN 3>2[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[3] MAY 3>2[3] JUN 3>2[3]
3M FLL-MCO NOV 3>1.1[3] DEC 3>1.0[3] JAN 3>1.0[3] FEB 3>1.0[3] MAR 3>1.0[3] APR 3>1.0[3] MAY 3>1.0[3] JUN 3>1.0[3]
3M FLL-MHH JAN 2>3[1.7]
3M FLL-TCB JAN 0.3>0.8[0.4]
3M FLL-TPA NOV 3>2[3] DEC 3>2[3] JAN 3>2[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[3] MAY 3>2[3] JUN 3>2[3]
*3M JAX-MHH FEB 0.3>0[0.2] MAR 0.4>0[0.5] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
*3M JAX-TPA NOV 1.6>0.1[2] DEC 1.5>0[3] JAN 1.6>0[3] FEB 1.6>0[2] MAR 1.5>0[1.5] APR 1.6>0[1.6] MAY 1.6>0[1.6] JUN 1.5>0[1.5]
*3M MCO-RSW NOV 1.0>0.1[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
*3M MCO-TLH NOV 0.7>0.1[0.6] DEC 0.7>0[0.5] JAN 0.7>0[0.8] FEB 0.7>0[0.8] MAR 0.7>0[0.7] APR 0.7>0[0.7] MAY 0.7>0[0.7] JUN 0.7>0[0.7]
3M MHH-PBI FEB 0.5>0.9[0.9]
3M MHH-TPA MAR 0.2>0.4[0.2] APR 0.1>0.4[0.1] MAY 0.1>0.4[0.1] JUN 0.2>0.4[0.2]
*3M PBI-TPA NOV 0.9>0.1[1.9] DEC 0.8>0[1.8] JAN 0.9>0[2] FEB 1.4>0[1.9] MAR 1.8>0[1.9] APR 1.9>0[1.9] MAY 1.9>0[1.9] JUN 1.8>0[1.9]
3M TLH-TPA NOV 1.7>0.9[1.7] DEC 1.7>0.8[1.7] JAN 1.7>0.9[1.7] FEB 1.7>0.9[2] MAR 1.7>0.8[2] APR 1.7>0.9[2] MAY 1.7>0.9[2] JUN 1.7>0.8[1.7]
4B DEN-TEX JAN 0.3>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
4M EZE-MIA DEC 1.6>1.2[1.6]
7H ANC-MCG OCT 0>0.3[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0]
9K ACK-HPN OCT 1.0>0.6[0.3]
9K HPN-MVY OCT 1.0>0.8[0.4]
AA AUA-PHL MAR 0.7>1.0[0.7]
AA BGR-DCA DEC 3>2[3]
AA BNA-PHL DEC 4>3[4]
AA BOI-ORD DEC 0>0.4[1.2]
AA BOI-PHX DEC 3>2[3]
AA BOS-DCA DEC 13>10[11] JAN 14>12[12]
AA BOS-LAX DEC 5>4[5]
AA BOS-LGA DEC 11>8[9] JAN 12>10[10]
AA BOS-ORD DEC 8>7[8]
AA BWI-JFK DEC 1.4>1.0[1.0]
AA CHS-PHL DEC 4>3[4]
AA CLT-HAV DEC 1.0>0.6[0.5]
AA CLT-PDX DEC 1.5>1.1[1.8]
AA CLT-POP MAR 1.0>0.3[0.8] APR 1.0>0.3[1.0]
AA CLT-UVF FEB 0.6>0.1[0.6] MAR 1.0>0.2[1.0] APR 1.0>0.1[1.0]
AA CUN-MIA JAN 6>5[6] FEB 6>5[6] MAR 6>5[6]
AA DCA-LGA DEC 10>8[8] JAN 11>10[9]
AA DCA-PBI DEC 1.5>2[2] JAN 1.0>1.4[2]
AA DCA-RSW DEC 0.4>1.0[1.7] JAN 1.0>1.5[2]
AA DCA-STL DEC 4>3[4]
AA DCA-YYZ DEC 3>1.8[1.7]
AA DFW-PBI DEC 1.8>2[2]
AA DFW-PIT DEC 4>3[3]
AA DFW-SAL DEC 0.4>0.7[0.5]
AA DTW-PHX DEC 1.7>2[3]
AA ELP-ORD DEC 1.9>2[3]
AA GRR-PHX APR 0.0>1.0[0]
AA HSV-ORD DEC 1.8>1.4[0.8]
AA IAH-PHL DEC 3>2[2]
AA JFK-LAX DEC 12>11[11]
AA JFK-ORD DEC 1.0>1.4[1.0]
AA LAS-PHL DEC 3>2[4]
AA LAX-MFR DEC 1.0>1.4[1.0]
AA LAX-OMA DEC 1.4>1.8[1.0]
AA LAX-RDM DEC 1.0>1.4[1.0]
AA LGA-MSP DEC 3>1.8[2]
AA LGA-ORD DEC 13>11[12] JAN 14>13[13]
AA LGA-PIT DEC 6>5[5]
AA LGA-ROA DEC 1.0>0.7[1.5]
AA LGA-STL DEC 4>3[3]
AA LGA-XNA DEC 1.7>1.3[1.5]
AA MCO-PHX DEC 2>3[3]
AA MIA-YUL DEC 1.4>1.0[1.5]
AA MSP-PHL DEC 3>1.9[1.8]
AA MYR-PHL DEC 1.8>1.0[1.5]
AA NAS-PHL JAN 0.7>1.0[0.8]
AA PHL-ROC DEC 5>4[5]
AA PHL-SEA DEC 1.4>1.0[1.5]
AA PHL-SLC DEC 0>0.4[0.5]
AA PHX-TUS DEC 6>7[8]
AC JAX-YYZ JAN 1.0>0.7[0.7]
AC PDX-YYC OCT 1.2>0.9[1.1]
AC TPA-YUL JAN 0.8>0.6[0.5]
*AF CDG-DFW APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0]
AM GDL-ORD JUN 1.0>1.5[1.9]
AM MEX-ORD JUN 2>3[3]
AM MEX-SFO JUN 2>3[2]
AS ANC-DUT JAN 2>4[4]
DL ABQ-ATL JUN 2>3[3]
DL ANC-MSP JUN 1.0>3[3]
DL ANC-SEA JUN 4>5[6]
DL ANC-SLC JUN 0>0.8[0.5]
DL ATL-DEN JUN 8>9[8]
DL ATL-GNV JUN 8>7[7]
DL ATL-JAC JUN 0>0.3[0.4]
DL ATL-LGA JUN 17>16[16]
DL ATL-MSN JUN 3>4[4]
DL ATL-MSY JUN 12>11[11]
DL ATL-OAK JUN 0>0.7[0.6]
DL ATL-PBI JUN 10>11[11]
DL ATL-PDX JUN 4>5[4]
DL ATL-PHF JUN 3>4[4]
DL ATL-PWM JUN 2>3[3]
DL ATL-SAN JUN 6>7[5]
DL ATL-SEA JUN 7>9[7]
DL ATL-SLC JUN 8>9[8]
DL BIL-MSP JUN 2>4[3]
DL BOI-MSP JUN 2.0>3[3]
DL BOS-LGA JUN 16>14[14]
DL BOS-PBI MAY 1.0>0.1[0] JUN 1.0>0.2[0.1]
DL BOS-SEA JAN 1.5>1.0[1.0]
DL BTV-JFK JUN 3>4[2.0]
DL BUF-MSP JUN 1.0>1.7[1.6]
DL BZN-MSP JUN 2>3[3]
DL CHA-DTW JUN 1.9>1.5[1.5]
DL CHO-LGA JUN 1.8>2[1.0]
DL CID-MSP JUN 3>4[4]
DL CLT-LGA JUN 8>7[7]
DL CVG-IAH JUN 1.9>1.5[1.5]
DL CVG-MCI JUN 1.9>1.5[1.5]
DL CVG-STL JUN 1.9>1.5[1.6]
DL CVG-YYZ JUN 1.9>1.5[1.5]
DL DAY-MSP JUN 3>4[3]
DL DCA-LGA JUN 12>10[10]
DL DEN-LGA JUN 2.0>3[2]
DL DTW-GRR JUN 6>7[6]
DL DTW-PLN JUN 2>4[3]
DL DTW-PVD MAR 3>4[3]
DL DTW-RSW JUN 3>2[2]
DL DTW-SAN JUN 3>4[3]
DL DTW-SEA JUN 4>6[5]
DL DTW-SFO JUN 4>5[4]
DL DTW-SNA JUN 0.7>0.9[0.9]
DL DTW-TVC JUN 4>5[5]
DL EWR-SLC JUN 1.0>1.6[1.3]
DL FAI-SEA MAY 2>1.0[1.0]
DL GEG-MSP JUN 2>3[3]
DL HNL-MSP JAN 1.0>0.7[0.9] FEB 1.0>0.7[0.9]
DL IAH-LGA JUN 6>5[5]
DL IND-JFK JUN 2>3[3]
DL IND-RDU JUN 1.9>1.5[1.5]
DL INL-MSP JUN 2>1.2[1.9]
DL JFK-PDX JUN 2.0>3[3]
DL JFK-SAV APR 2>3[2] MAY 2>3[2] JUN 2>3[2]
DL JFK-SEA JUN 4>5[5]
DL JFK-YVR JUN 0>0.6[0.5]
DL LAX-SEA JUN 8>9[9]
DL LGA-ORD JUN 15>13[12]
DL LIH-SEA FEB 0.9>0.7[0.9]
DL MLI-MSP JUN 1.0>1.8[1.5]
DL MSO-SLC JUN 3>4[3]
DL MSP-OKC JUN 2.0>3[3]
*DL MSP-PBI JAN 0.3>0.0[0.3] FEB 0.3>0[0.4] MAR 0.4>0[0.4]
DL MSP-PHX JUN 6>5[6]
DL MSP-PSC JUN 1.0>1.8[1.7]
DL MSP-RAP JUN 4>5[5]
DL MSP-RSW JUN 2>1.2[1.2]
DL MSP-SBN JUN 2.0>3[3]
DL MSP-SJC JUN 1.9>3[3]
DL MSP-SMF JUN 2.0>3[2]
DL MSP-TVC JUN 0>3[1.9]
DL MSP-XNA JUN 1.9>1.5[1.6]
DL OGG-SLC FEB 0.9>0.6[0.6]
DL OKC-SLC JUN 2.0>3[2]
DL RAP-SLC JUN 1.0>1.8[1.0]
DL SEA-SJC JUN 4>5[5]
DL SEA-YVR JUN 5>7[6]
DL SLC-YYC JUN 1.0>1.8[1.8]
DY BCN-OAK APR 0>0.4[0.7] MAY 0>0.4[0.7] JUN 0>0.4[0.7]
F9 ABQ-DEN NOV 0.6>0.3[0.9] DEC 0.6>0[1.5] JAN 0.5>0[1.1] FEB 0.3>0[0.9]
F9 ATL-AUS DEC 0.4>0.1[0.6] JAN 0.4>0[0.6] FEB 0.2>0[0.6]
*F9 BOI-DEN DEC 0.3>0[0] JAN 0.3>0[0]
F9 GRR-MCO DEC 0.7>1.0[0.4] JAN 0.7>1.0[0.9]
F9 JAX-LAS NOV 0.8>0.6[0]
GV ATT-BET OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>1.3[0] JAN 0>1.3[0] FEB 0>1.3[0] MAR 0>1.3[0] APR 0>1.3[0] MAY 0>1.3[0] JUN 0>1.3[0]
GV ATT-KUK OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>1.3[0] JAN 0>1.3[0] FEB 0>1.3[0] MAR 0>1.3[0] APR 0>1.3[0] MAY 0>1.3[0] JUN 0>1.3[0]
GV BET-NUP OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>1.3[0] JAN 0>1.3[0] FEB 0>1.3[0] MAR 0>1.3[0] APR 0>1.3[0] MAY 0>1.3[0] JUN 0>1.3[0]
GV KUK-NUP OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>1.3[0] JAN 0>1.3[0] FEB 0>1.3[0] MAR 0>1.3[0] APR 0>1.3[0] MAY 0>1.3[0] JUN 0>1.3[0]
HA KOA-LAX JAN 0.5>1.0[0.2]
IB BCN-BOS APR 0>0.4[0.3] MAY 0>0.5[0.3] JUN 0>0.4[0.3]
*IB BCN-SFO APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
*IG MIA-MXP APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0.4]
JJ GRU-MCO JAN 1.0>1.3[1.8]
*KE BOS-ICN APR 0>0.5[0] MAY 0>0.7[0] JUN 0>0.7[0]
KS AKN-ANC NOV 1.5>1.8[1.0]
KS AKN-DLG NOV 0.5>0.2[0.9] DEC 0.5>0.2[0.9]
KS ANC-CDB NOV 0.8>0.4[0.6] DEC 0.8>0.5[0.5]
KS ANC-DLG NOV 2>1.8[1.7] DEC 2>1.9[1.5]
KS ANC-SDP NOV 0.8>0.4[0.6] DEC 0.8>0.5[0.5]
*LF CEC-OAK DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0]
*LF LAS-SBA OCT 0>0.3[0] NOV 0>0.7[0] DEC 0>0.7[0] JAN 0>0.7[0] FEB 0>0.7[0]
*LF OAK-SBA OCT 0>0.5[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0]
*NK CLO-FLL DEC 0>0.4[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0]
SY PDX-PHX JAN 0.6>0.3[0] FEB 0.6>0.1[0]
*SY PDX-RNO DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.3>0[0]
TA MGA-MIA NOV 1.0>0.6[1.0]
TJ ACK-HPN OCT 0.5>0.9[0.7] NOV 0.5>0.9[0.4]
TJ ACK-TEB OCT 0.5>0.8[0.8] NOV 0.5>0.8[0.4]
UA ABE-ORD FEB 3>1.9[2]
UA ABQ-IAH FEB 4>5[3]
UA ABQ-ORD JAN 1.2>2[1.2]
UA ALB-IAD JAN 3>2[2] FEB 3>2[2]
UA ALB-ORD FEB 4>3[3]
Probably filing error
*UA ANC-ORD MAY 1.0>3[1.0] JUN 1.0>3[1.8]
UA ATL-EWR FEB 8>7[7]
UA AVP-ORD JAN 3>2[1.0] FEB 3>1.9[1.0]
UA BDL-ORD FEB 4>3[3]
UA BFL-SFO FEB 1.5>1.0[1.0]
UA BNA-EWR FEB 6>5[4]
UA BNA-SFO FEB 1.9>3[1.0] MAR 1.8>3[1.8] APR 1.9>3[1.9] MAY 1.9>3[2] JUN 1.8>3[2]
UA BOS-DEN FEB 5>4[3]
UA BOS-EWR FEB 10>9[10]
UA BOS-ORD FEB 7>6[7]
UA BUF-ORD FEB 4>3[3]
UA BUR-DEN FEB 3>1.9[2]
UA BWI-ORD FEB 4>3[3]
UA BWI-SFO FEB 1.4>0.9[1.0]
UA CAE-ORD FEB 2>3[1.9]
UA CLE-FLL JAN 0.7>1.0[0.4]
UA CLE-IAH FEB 6>5[5]
UA CLE-RSW JAN 0.7>1.0[0.3]
UA CMH-EWR FEB 7>5[5]
UA CRW-ORD FEB 1.5>0.9[1.0]
UA CVG-IAD FEB 4>3[3]
UA DAY-EWR FEB 2>1.4[1.9]
UA DEN-EUG FEB 3>2[2]
UA DEN-FLL FEB 1.5>2[1.5] MAR 1.0>1.2[2]
UA DEN-GEG FEB 3>2[1.9]
UA DEN-GTF FEB 3>2[2]
UA DEN-IAD FEB 7>5[5]
UA DEN-LAX FEB 7>6[7]
UA DEN-MEM FEB 1.9>2[2.0]
UA DEN-MSN FEB 1.9>2[2.0]
UA DEN-ONT FEB 1.4>1.0[1.9]
UA DEN-ORD FEB 10>9[8]
UA DEN-RAP FEB 5>4[3]
UA DEN-RDM FEB 3>2[1.0]
UA DEN-SAF FEB 3>2[2]
UA DEN-SFO FEB 10>8[9]
UA DEN-TPA FEB 2>3[2]
UA DEN-YVR FEB 3>2[1.9]
UA DEN-YWG FEB 1.5>1.0[1.0]
UA DFW-IAD FEB 3>1.9[2]
UA DLH-ORD FEB 3>2[3]
UA DSM-IAH FEB 1.9>2[2.0]
UA EWR-EYW FEB 2>3[1.5]
UA EWR-GRR FEB 3>1.9[2]
UA EWR-LAX FEB 10>9[10]
UA EWR-PBI FEB 6>7[8]
UA EWR-PIT JAN 8>7[7] FEB 9>8[7]
UA EWR-RSW FEB 4>5[4]
UA EWR-SEA FEB 2>1.8[3]
UA EWR-SLC FEB 1.0>1.5[1.0] MAR 1.0>1.2[1.0]
UA EWR-TYS FEB 1.5>0.9[1.8]
UA EWR-YHZ FEB 3>2[2]
UA GRR-IAH FEB 1.0>1.5[1.0]
UA GRR-ORD JAN 7>6[6]
UA IAD-LAX FEB 7>5[5] MAR 9>8[6]
UA IAD-MCI FEB 3>1.9[1.9]
UA IAD-MSP FEB 1.5>1.0[1.5]
UA IAD-PVD FEB 3>2[1.5]
UA IAD-ROA JAN 3>2[2] FEB 3>2[2]
UA IAD-SEA FEB 3>1.9[1.9]
UA IAD-SFO FEB 8>7[7]
UA IAD-TYS FEB 4>3[2.0]
UA IAD-YUL FEB 3>2[1.5]
UA IAH-LAS FEB 7>6[5]
UA IAH-LAX FEB 10>8[10]
UA IAH-LFT JAN 5>6[5] FEB 5>7[6]
UA IAH-LIT FEB 5>6[5]
UA IAH-MLU FEB 2>1.9[1.9]
UA IAH-MOB FEB 5>6[5]
UA IAH-ORF FEB 1.5>1.9[1.0] MAR 1.0>1.2[1.0]
UA IAH-PDX FEB 3>2[1.9]
UA IAH-PSP FEB 2>3[2]
UA IAH-RIC FEB 1.5>1.1[1.0]
UA IAH-RSW JAN 2>3[1.8] FEB 2>3[1.9]
UA IAH-SEA FEB 5>4[4]
UA IAH-SFO JAN 8>9[8]
UA IAH-SJC FEB 1.5>1.0[1.0]
UA IAH-SLC FEB 4>5[4]
UA IAH-TUL JAN 6>7[6] FEB 6>8[7]
UA IAH-TUS JAN 3>4[3] FEB 3>4[3]
UA ILM-ORD FEB 1.5>1.0[0]
UA IND-SFO JAN 1.9>1.2[1.2] FEB 1.9>1.0[1.0]
UA LAX-ORD FEB 10>9[9]
UA MCO-ORD FEB 6>7[6]
UA MCO-SFO FEB 3>2[2]
UA MIA-ORD FEB 3>2[2]
UA OMA-ORD FEB 5>4[4]
UA ORD-PDX JAN 3>2[3] FEB 3>2[2]
UA ORD-PNS FEB 1.0>1.5[0.5] MAR 1.0>1.2[1.7]
UA ORD-PSP FEB 1.5>2[1.0] MAR 1.0>1.2[1.0]
UA ORD-PWM FEB 3>2[1.0]
UA ORD-ROA FEB 3>1.9[2]
UA ORD-SEA FEB 4>3[3]
UA ORD-SFO FEB 12>9[8] MAR 14>13[9]
UA ORD-SJC JAN 1.7>1.0[2.0] FEB 1.9>0.9[2]
UA ORD-SRQ FEB 1.5>2[1.5] MAR 1.0>1.2[2]
UA ORD-YVR FEB 1.5>1.0[1.0]
UA ORD-YWG JAN 3>1.9[2]
UA ORD-YYZ FEB 6>5[4]
UA PDX-SFO FEB 8>7[7]
UA RDD-SFO JAN 4>3[3] FEB 4>3[3]
UA RDU-SFO FEB 1.5>1.9[1.4] MAR 1.0>1.2[1.9]
UA SEA-SFO FEB 9>8[8]
UA SFO-SMF JAN 6>4[5]
UA SFO-STL JAN 1.9>1.2[1.9] FEB 1.9>1.0[1.8]
*UX JFK-MAD JAN 0.7>0.3[0.3] FEB 0.6>0[0] MAR 0.6>0[0.4]
WN DEN-LGB JAN 0.1>0.3[0.3]
WN HOU-SLC NOV 0.2>0.9[0.3]
WN LAS-LGB JAN 0.8>3[0.8]
WN LGB-SMF JAN 2>4[2]
WN OAK-SLC NOV 2>3[3]
WW BWI-KEF MAY 0>1.0[1.3] JUN 0>1.0[1.6]
dfdubflyer
Re: OAG Changes 9/16/2018:3M Scales Back;KE to BOS;F9 Drops BOI-DEN;DL Drops MSP-PBI
Sun Sep 16, 2018 11:28 pm
I was getting worried about you enilria! thanks as always for the OAG update :)
iflykpdx
Sun Sep 16, 2018 11:33 pm
Yay! Thank you.
Airport Management - UND
usairways85
Sun Sep 16, 2018 11:46 pm
The AA PHL reductions are more evidence that AA is completely slashing the PHL schedule around Thanksgiving and Christmas (schedules cut by 50-75%). Though, on 12/24 the lone PHL-LAS flight is a 763
11725Flyer
Sun Sep 16, 2018 11:55 pm
Whew! I was wondering if you were going to post today. As usual, thanks very much for putting this together!
klm617
Mon Sep 17, 2018 12:04 am
Holy cow DTW-PLN from 2 to 4 that's a schocker.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
NWADTWE16
Mon Sep 17, 2018 12:05 am
Nice adds for DTW, whats up with the Air Europa Cancellation, anyone know? Isn't that imperative to get people to their network?
I haven't been everywhere, but it's on my list!
lavalampluva
DTW did quite well with this update. A majority of the routes were beefed up.
Remind me to send a thank you note to Mr. Boeing.
mtnwest1979
Mon Sep 17, 2018 12:06 am
I am really amazed F9 lasted this long in BOI. Shocked they even restarted the routeeto begin with.
Riddle: Which lasts longer, a start-up airline or a start-up football league?
UALFAson
Mon Sep 17, 2018 12:22 am
THREE flights a day on a route they didn't even serve a couple of years ago?! This is nuts. So is pricing on the route. VX was practically giving seats away before the merger. Then UA went to 2x daily and it seemed like United dropped fares to get butts in the seats. Now AS seems to be pricing higher than UA did the last few itineraries I have looked at. For New Year's, for example, AS was coming in at almost twice what UA was charging.
"We hope you've enjoyed flying with us as much as we've enjoyed taking you for a ride."
TropicalSky
Mon Sep 17, 2018 12:46 am
Interesting that Delta is jumping into the pool on JFK-YVR....that's a busy route
LHUSA
Mon Sep 17, 2018 12:47 am
Per United.com, UA is indeed going 3 daily on ORDANC. Wow!
klm617
Mon Sep 17, 2018 12:58 am
This might be to link up with WS
klm617
Mon Sep 17, 2018 12:59 am
I wish DTW could get back their ANC flight
FA9295
Well, they pushed AS out of SFO-IND, now it's time to move on to the next route! :stirthepot:
tphuang
Mon Sep 17, 2018 1:00 am
DL is definitely already on JFK-YVR. Nothing new here.
Dominion301
Mon Sep 17, 2018 1:06 am
Going to 7x on YVR-SEA next June. I think they’re already on YVR-JFK seasonally. Might be starting the season a few days earlier next summer.
For 3M, those are some pretty significant cuts. It looks like they’re exiting RSW.
FA9295
No surprise here. This route didn't seem all that realistic on a Boeing 737 anyway...
Dominion301
Mon Sep 17, 2018 1:10 am
An MSP airline attempts to break out into the PNW. Even if their head honcho in Network Planning is an ex-ASer, wouldn’t it make more sense to start your non-MSP expansion closer to home, like in say MKE?
joeblow10
Mon Sep 17, 2018 1:14 am
And all are redeyes leaving within 90 minutes of each other.... would be kind of shocked to see all 3 stick by the time next summer rolls around but who knows.
Interesting that DL brought back daytime ANC-MSP service this year, would've figured if UA is going 3x daily it would've done the same to ORD
MO11
Mon Sep 17, 2018 1:25 am
Many airlines have significant cutbacks beginning the Tuesday or Wednesday after Thanksgiving, until the week before Christmas (around 12/19).
miaami
Mon Sep 17, 2018 1:31 am
AA is upguaging one MIA-ORD-MIA flight to 77W from 12/19/18 to 01/04/19.
MIA-ORD 09:45 12:06 77W
ORD-MIA 13:32 17:35 77W
chepos
Mon Sep 17, 2018 1:34 am
In past years Thanksgiving day the afternoon are no ops (at least in PHX and I believe PHL), and no TA departures that evening (out of PHL).
Fly the Flag!!!!
enilria
Mon Sep 17, 2018 1:35 am
Thanks for the kind words everyone. Yeah, it’s always a depressing Sunday when I grab the schedules and the file is exactly the same size as the prior week as was the case today. I guess somebody was asleep at the switch.
I’m shocked ANC-ORD 3x is Real and all red eyes. That’s nuts.
stl07
Mon Sep 17, 2018 1:39 am
To be fair, they did launch STL, BNA, and Madison
Interesting how every thread is spammed with "bring back paid membership, there are too many spammers"
Chugach
Mon Sep 17, 2018 1:46 am
DL’s had a daytime ANC-MSP going back to the NW days; right now it’s seasonal since they started flying ANC-SEA again a few years ago.
Chugach
Mon Sep 17, 2018 1:48 am
Assuming it actually sticks, I wonder if AS will blink on their second daily ANC-ORD.
joeblow10
Mon Sep 17, 2018 1:52 am
Continuing on ANC... Looking at UA’s capacity next summer, looks like they’ve obviously significantly shifted focus to ORD connections at the expense of DEN and SFO.
IIRC DEN had up to 3x (2 redeye, 1 daytime) daily to ANC this summer and SFO up to 2x on peak days. Both appear to be reduced to 1x daily next year.
Combine that with the fact they run FAI only out of ORD and I guess it’s clear their Alaska flight strategy is clearly centered on Chicago and East Coast traffic. Guess it makes sense, I’d much rather connect from East Coast-ORD-ANC than fly 4-6 hours to Seattle only to do 3-4 more.
piedmontf284000
Mon Sep 17, 2018 2:18 am
It will be interesting to see how AS responds. They typically have two daily in summer. That would be 5 total! It could also be an attempt to keep AA off the route.
Btw, we are on your schedule Enrilia, so don't fret it. Thanks for all the weekly updates.
Or UA could just use a larger aircraft. I suppose though they don't have many to spare in summer.
Some nice adds out of GRR.
Wonder if this has more to do with pilot shortages then anything else
EvanWSFO
Mon Sep 17, 2018 2:49 am
Which all are likely to fail. There's only so many ULCC business out there. 99% of pax in Nashville has ever heard of them. If they last until 2019 I'll be shocked.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
EvanWSFO
Mon Sep 17, 2018 2:52 am
It seems 3M cannot get it together. I suspect they will be a footnote in a long list of airline failures.
admanager
Mon Sep 17, 2018 3:08 am
Some significant adds to SEA for the summer compared to what was previously for sale, although in some cases it just brings things back to last years numbers.. (there were some small decreases in BOS, FAI, BOI and LIH.
cjmoeser
Mon Sep 17, 2018 3:27 am
That flight has usually been full, no matter the day. They were doing well on that route.
jetmatt777
Mon Sep 17, 2018 3:41 am
Obviously they were doing well since they dropped the route. Full flights don’t always mean profitable, especially when Frontier is selling $2-20 fares out of DEN.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
LAXBUR
Mon Sep 17, 2018 4:02 am
UA does BOI-DEN 4-5x per day and WN 2x per day. F9 two or three times a week just didn’t make sense on a route with decent daily service.
hiflyeras
Mon Sep 17, 2018 4:20 am
I was waiting for the BZN QX ticket counter to open and saw maybe 40 people check in right next door at F9 on a Sunday. Meanwhile my QX flight to SEA was sold out. I wondered how much longer F9 would last.
Aloha717200
Mon Sep 17, 2018 5:23 am
I'm honestly surprised about F9. Flights were full to nearly full most of the time. #1 complaint I kept hearing next door was the airline constantly losing people's luggage through DEN. #2 complaint was several cancelled flights and massive delays at least once a week. Lots of pissed off folks at the F9 ticket counter in BOI.
compensateme
Mon Sep 17, 2018 5:32 am
Doesn’t really matter; NK and F9 aren’t necessarily competing for the same types of passengers as the legacies, which is why both can be very successful on routes they’re slaughtered frequency wise (ORD-LAX, for example).
Obviously, F9 wasn’t generating the revenue necessary to continue service.
We don’t care what your next flight is.
bluefltspecial
Mon Sep 17, 2018 6:18 am
This was an interesting one. At one point Delta was operating this with a daily morning CR7, then it went back to a CRJ 4-5 days a week, and now it's twice daily.
I went for a peek and now it's loading in July as 3 daily. I had heard the yield was high, maybe they are trying to add connectivity to other cities via LGA. I know US/PDT used to operate this up to 4x on some days with a Dash. Interesting, regardless,
And thank you as always Enilria, I have always enjoyed letting my inner avgeek out reading these.
Save a horse, ride a Fly-boy....
enilria
Mon Sep 17, 2018 10:18 am
Several of those are flat with last year, but yes a few.
So for June they are only up 1 rt. They will scale back May later.
clrd4t8koff
Mon Sep 17, 2018 11:19 am
When will KE finally put the new BOS-ICN on sale. Wasn’t this announced over a month ago?
adamh8297
Re: OAG Changes 9/16/2018: lol3M Scales Back;KE to BOS;F9 Drops BOI-DEN;DL Drops MSP-PBI
Mon Sep 17, 2018 11:34 am
It's loaded in Amadeus so I would think very soon. I'd be shocked if it doesn't go on sale this week.
Has anyone heard of the UP BOS-NAS launch that was reported in this thread a few weeks back?
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
evank516
Mon Sep 17, 2018 1:25 pm
JFK-YVR is an existing seasonal route that DL has been on for the past couple of years in the summer. Nothing new.
FATFlyer
Mon Sep 17, 2018 3:46 pm
The cruise industry is adding a lot of capacity to Alaska itineraries in 2019. UA is likely looking to route that traffic thru ORD.
In 2019, Princess will move the Royal Princess to Alaska routes and have its largest total Alaska passenger capacity in the 50 years it has cruised that area. Royal Caribbean will add the 5,000-passenger Ovation of the Seas to Alaska service. Celebrity in 2019 is replacing the Infinity in Alaska with the larger Eclipse. There are also other capacity adds from other lines for 2019.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
Flighty
Mon Sep 17, 2018 4:01 pm
Where does Delta fit into this equation? Haven't they done 5x 757 MSP-ANC In the past...
How many daily scheduled passenger flights link ANC with the rest of USA? I think 3x ORD is right in line and probably not the frist time it has been done, but any thoughts appreciated.
F9LASDEN
Mon Sep 17, 2018 4:53 pm
BZN is a market that F9 has been in consistently since even before the transition to ULCC. They’ve even added a frequency recently, going from 3x weekly to 4x weekly, and they’re running through the winter this year after it being summer seasonal for the last several years. Given they’ve recently extended it to year round, added frequencies, and have kept the route through the last several turbulent years of network changes for F9, it appears that DEN-BZN is performing decently for them.
Spirit of the West...A Whole Different Animal...Low Fares Done Right
F9LASDEN
Mon Sep 17, 2018 4:56 pm
ABQ and BOI look like the first two of the 21 routes F9 added from DEN that were added as part of the 85 route mega-expansion last summer to be cut.
hiflyeras
Mon Sep 17, 2018 7:51 pm
Goodie! There should be some great cruise fares available out of SEA with so much capacity! ;-)
jasoncrh
Mon Sep 17, 2018 8:48 pm
Is Air Europa completely dropping JFK?
Aloha717200
Mon Sep 17, 2018 10:02 pm
Word around BOI today is that F9 will be back in the spring, BOI is seasonal. Not sure how much truth there is to that rumor.
