janders wrote:Yes posted and discussed about 2 weeks ago.
aemoreira1981 wrote:janders wrote:Yes posted and discussed about 2 weeks ago.
It was a rumor though. Likely routes I see at the start would be EWR-FRA and EWR-TLV (PM EWR arrival).
CONTACREW wrote:aemoreira1981 wrote:janders wrote:Yes posted and discussed about 2 weeks ago.
It wasn't a rumor. It was from the internal employee site that had a NDA at the bottom of the article so it was removed.
CarlosSi wrote:A little shocked at first, since EWR isnt much of a 787 hub, although with its range and size it seems optimal for “short” transatlantic flights, but we all knew that.
aemoreira1981 wrote:CarlosSi wrote:A little shocked at first, since EWR isnt much of a 787 hub, although with its range and size it seems optimal for “short” transatlantic flights, but we all knew that.
I could also see the 787-9 out of Newark for all flights to Asia other than NRT. Once the B77Es go 10 abreast in Y, they’re unlikely to make it to any India and Far East destinations without major payload restrictions. Each would likely also do transcontinental services to rotate between EWR and the California hubs.
Blockplus wrote:The 10 could replace all the 777-200 out of iah. Would be a great plane there too.
dmstorm22 wrote:aemoreira1981 wrote:CarlosSi wrote:A little shocked at first, since EWR isnt much of a 787 hub, although with its range and size it seems optimal for “short” transatlantic flights, but we all knew that.
The EWR-BOM/DEL routes could be upped to 77Ws at some point to - that was the initial plan before Kirby took over.
The 78J makes complete sense for EWR for its EU routes.
avi8tir wrote:Will the -10's be getting the new Polaris seats or the PMCO BizFirst product?
hz747300 wrote:Any chance they'll send the bird to HKG?
anrec80 wrote:aemoreira1981 wrote:janders wrote:Yes posted and discussed about 2 weeks ago.
Does 787-10 have legs to TLV? It's a perfect plane for Europe-East Coast routes, but not beyond that.
Block wrote:Are there any more orders for the -8 or -9? If not will a base be closed and EWR would be replacing it?
airzona11 wrote:7810 will be a money making machine from EWR.
gsg013 wrote:Lets think what transatlantic routes are 777 out of EWR
EWR-CDG
EWR-FRA (777W)
EWR-DUB
EWR-LHR
EWR-BRU 2X
EWR-BCN
I believe all of these could and should be candidates for the 787-10 when it comes to Newark. There are probably a few other planes that are currently 767-400ER or 767-300 that may be able to move over to 787-10 at some point.
Bricktop wrote:EWR-CDG is a 757 or a 767 at different times of the year. A 78X is overkill there.
adambrau wrote:Bricktop wrote:EWR-CDG is a 757 or a 767 at different times of the year. A 78X is overkill there.
The earlier departure to CDG is currently a 772.
EWR-CDG
EWR-FRA (777W)
EWR-DUB
EWR-LHR
EWR-BRU 2X
EWR-BCN
EWR-CDG
EWR-FRA (777W)
EWR-DUB
EWR-LHR
EWR-BRU 2X
EWR-BCN
drdisque wrote:Is there a seat map for the 787-10? If it ends up being less premium than the Polaris 777-200ER then it may make sense to put it on routes like EWR-MXP/FCO if it's more premium heavy I can see it doing LHR and BRU.
IAHWorldflyer wrote:I don't want to be pendantic, but I do not think there is currently a 787 base at IAH of any kind. That base was moved to IAD last year.
Currently the only 787 operations from IAH is a 789 that runs IAH-SYD in a W pattern with LAX. I don't work for UA, but I assume those crews are either LAX or SFO based.
iahcsr wrote:drdisque wrote:Is there a seat map for the 787-10? If it ends up being less premium than the Polaris 777-200ER then it may make sense to put it on routes like EWR-MXP/FCO if it's more premium heavy I can see it doing LHR and BRU.
I have a pic but don’t know how to put it here from iPad .. configuration is 44/21/253
anrec80 wrote:hz747300 wrote:Any chance they'll send the bird to HKG?
Not 10 - no range. Maybe 789.
