n471wn
First 717 Being Scrapped
Mon Sep 24, 2018 4:57 pm
It appears that Turkmenistan is sending a 2005 built (#55186) to EGPB to be scrapped which would be the first 717 (other than the prototype) to be scrapped. Very odd that neither Delta nor Hawaiian would not be interested in a late model 717 with few hours and cycles.
777Mech
Re: First 717 Being Scrapped
Mon Sep 24, 2018 4:59 pm
Delta has purchased the Turk 717 assets and will be parting them out creating a spares pool.
burnsie28
Mon Sep 24, 2018 6:22 pm
From my understanding there are many questionable issues with the Turk 717s that would possibly prevent it from being put into service. Wasn't there some corrosion questions before?
Yflyer
Mon Sep 24, 2018 6:52 pm
Someone can correct me if I'm wrong, but from what I remember the issue with the Turk 717s is that the paperwork on them is incomplete. So even if they were in perfection condition (which is rather unlikely) if they can't prove that all the required maintenance was done on them then they can't legally be put into service. I assume that doesn't prevent them from being purchased for parts, though.
airportugal310
Mon Sep 24, 2018 7:09 pm
Indeed, DMS (Delta Material Services) has been shopping around 717 parts as of late
“They bought their tickets, they knew what they were getting into. I say, let 'em crash.”
lightsaber
Mon Sep 24, 2018 7:17 pm
I'm surprised it took this long to part these examples. The condition of the aircraft and paper was rumored poor for a long time.
It would be cheaper for DL to buy more A220-100 than fly these. As everyone has noted, these are parts donors.
Lightsaber
Winter is coming.
tomaheath
Mon Sep 24, 2018 7:43 pm
Parton my ignorance but don’t a lot of the airframe parts and engines need paperwork for last maintenance and hours flown?
MartijnNL
Mon Sep 24, 2018 7:51 pm
Flightradar24 showed EZ-A106 fly from Minsk (Belarus) to Cotswold Airport (Kemble, U.K.) yesterday. It was almost four hours in the air.
n471wn
Mon Sep 24, 2018 8:42 pm
Not a bad “death flight”—-4 hours!
KICT
Mon Sep 24, 2018 8:50 pm
The questionable parts will be inducted into repair as required and re-certified.
People are saying. Believe me.
Dalmd88
Mon Sep 24, 2018 8:51 pm
A lot of the harvested components will go through a shop visit before they see an airplane again. That will make them serviceable. For the entire airframe that is hard to do to make sure it is airworthy from a records standpoint. For the airframe I suspect the doors and flight control surfaces will be saved. Most of the wing and fuselage structure will be scrapped. Any structural part that has been drilled, will not be able to be reused on another plane.
B757Forever
Mon Sep 24, 2018 8:54 pm
Many of the parts DL is after (cowlings, fairings, gear doors, flight controls etc) can be used after a detailed visual inspection or an inspection per the CMM. Other parts (components such as valves, actuators etc) can be routed through a shop for a full overhaul. Some parts (engine internals, some landing gear parts) are unusable without full records.
The Rolls Royce Dart. Noise = Shaft Horsepower.
wjcandee
Mon Sep 24, 2018 8:58 pm
I remember from several years ago in discussions regarding the DC10 that many parts at Douglas were custom-drilled and therefore not easily-transferable from one aircraft to another. I'm a little hazy on this. Anyone understand what I'm saying, and is that correct? Was this handled differently on the 717 (being a Douglas product and all)?
tomaheath
Mon Sep 24, 2018 9:16 pm
Thank you for the info.
lightsaber
Mon Sep 24, 2018 9:31 pm
I'll rephrase, there is an approved rebuild/repair process for most parts. Some of the most expensive parts are in the engine and if the FADAQ can be read, cycle life will be determined.
Gear, valves, ans actuators will be rebuilt as will the engines as that is the only way to be safe. Note: I projected, it is possible the engines are never re-assembled too.
It should be possible to determine life for items never replaced. Anything with ambiguous use gets rebuilt or scrapped. There is no middle ground.
Lightsaber
Winter is coming.
kitplane01
Mon Sep 24, 2018 9:32 pm
Can you explain more about this please?
lightsaber
Mon Sep 24, 2018 9:36 pm
The DC-10s had many match fit parts. There are far fewer such parts on the 717 outside of the structure. The basic structure is doomed. It is the piece parts (windows, actuators, engines/nacelles and removable surfaces). About half the value is the engines. But hey, need a fuel level meter? Have we got a bargain on a rebuilt unit... Spare landing gear in the rebuild pipeline is always a plus.
Millions of dollars of aluminum will become beercan. :spit:
Lightsaber
Winter is coming.
Dalmd88
Mon Sep 24, 2018 10:14 pm
Same is true for Boeing and at least the older Airbus. Once a structural part like a frame or stringer is installed in an airplane it can not be removed and installed in another. The holes for the fasteners, weather they are hilocks, or rivets do not line up. All of these parts were hand drilled during production and while the spacing looks even, it is not once you try to mate used parts together. I've seen brand new parts from Boeing and Douglas that had factory pilot holes in them that would not line up with the existing factory holes in the mating part.
Another matter is corrosion. Once you start really digging in an older airframe you will find the grey dust. It just is not worth the effort to try and harvest these parts. The raw stock to make these parts is pretty cheap.
777Mech
Tue Sep 25, 2018 12:39 am
From what I hear DMS is particularly after the landing gear sets. The main gear is different from from -88s and 90s, and IIRC the main gear on the 717 is the same as on a DC-9-3, and that tooling is long gone, so now DL is having to do some repair development to get to overhaul these components.
The nose gear is the same across all DC-9/MD80 series.
MassAppeal
Tue Sep 25, 2018 12:50 am
How long does the average scrapped plane "feed" a fleet before another needs to be sacrificed?
B757Forever
Tue Sep 25, 2018 1:01 am
That's not quite how it works. A list of parts to be harvested is developed, those parts are pulled and warehoused, the rest gets scrapped. The parts are then pulled from storage as needed.
wrongwayup
A set of landing gear is the third most valuable component set on the aircraft, but it's a distant third to #s 1 & 2 - the engines - which are an order of magnitude more valuable! Depends on maintennace condition of course - time since overhaul on the gear versus time since overhaul and LLP lives remaining in the engines.
777Mech
Tue Sep 25, 2018 2:39 am
Right. This was especially true for the MD-90 program, and the 717 is following right in its footsteps. The only difference is DL is overhauling the 715 and they aren't really hurting for parts on that engine.
This leaves me to suspect the OEM for the landing gear isn't delivering what DL wants in regards to overhauling the gear. Who the OEM is? I dont have a clue.
danipawa
Fri Oct 05, 2018 11:15 pm
Boeing 717-200 55187 5147 EZ-A107 Turkmenistan Airlines ferried 03oct18 KRW-ADB-EGBP after storage, for part-out & scrap
Spacepope
Fri Oct 05, 2018 11:26 pm
Since this is A.net, it should be pointed out the airframe referred to in the original post was actually the SECOND 717 scrapped, as the prototype was broken up at Long Beach way back in 2005.
RobK
Fri Oct 05, 2018 11:44 pm
...which was already stated in the opening post, had you bothered to read the thread first. :roll:
QANTAS747-438
Fri Oct 05, 2018 11:51 pm
How much can an airline benefit from using one frame as a scrap pool? There are only so much of each thing: 2 inboard flaps, 1 tail jackscrew, etc
81819
Sat Oct 06, 2018 12:13 am
I think it gives an airline a parts pool. For instance a refurb if a part may take six weeks. Having a parts pool means parts Froman aeroplane re simply swapped out with a part from the parts pool. The part removed from the plane is sent out for refurb and than added back into the parts pool. Delta would look at their 717 maintenance schedule, the parts required and their cost and evaluate that against the cost of scraping aeroplanes and stocking the refurbed parts.
Antarius
Sat Oct 06, 2018 12:28 am
I see what you did there 8-)
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
SEPilot
Sat Oct 06, 2018 1:40 am
777Mech wrote:
wrongwayup wrote:
I suspect that the OEM is Goodrich Aerospace. In 1987-1988 I was in charge of designing a family of three grinding machines for Cleveland Pneumatics, which at that time was manufacturing all the landing gear for Boeing and McDonnell-Douglas. The smallest was strictly for military planes, as it was too small for airliners. The second was the first one designed, and the test strut for it was the MD-80 main gear. The largest was over 30 feet long, and the test strut for it was the 747 nose gear (which at the time was the longest strut they made. But I believe it was long enough for the 777 struts, even though they had not been conceived at this time). Cleveland Pneumatic was later acquired by Goodrich. The machines that were originally in Cleveland (they bought two sets of the smaller two machines, one set going to Tullahoma, TN) including the largest one went to their plant in Oakville, Ontario after they closed the Cleveland plant. I saw one of the machines being overhauled about three years ago; they are still being used. Seeing how difficult it is to change suppliers for major components like landing gear I suspect that Goodrich supplied them for the 717.
Just an aside; before they got the machines I designed they took between 7 and 9 hours to grind a MD-80 strut. When they got these machines they did it in about 30 minutes.
stratclub
Sat Oct 06, 2018 2:17 am
What happens with parts is they are sent to overhaul, are essentially zero timed and are sold with an FAA 8130-3 AIRWORTHINESS APPROVAL TAG from an FAA approved Repair Station as a certified and airworthy part. Having history records on the part isn't really a requirement. If you were to sell engines in an as removed condition, you would need meticulous records on them to have any chance of hanging them on a wing without an overhaul shop visit and an 8130-30 form.
danipawa
Mon Oct 15, 2018 10:46 pm
another one:
Boeing 717-200 55153 5072 EZ-A101 Turkmenistan Airlines ferried 12oct18 KRW-ADB-EGBP after storage, for part-out & scrap
bennett123
Sat Dec 22, 2018 5:16 pm
Kemble has EZ-A101, EZ-A102, EZ-A106 and EZ-A107.
What has happened to EZ-A103, EZ-A104 and EZ-A105.
Where they scrapped in Turkmenistan?.
CarlosSi
Sat Dec 22, 2018 7:44 pm
Knew it had to be Turkmenistan; maybe it was the relatively small fleet size? They’re better as parts if it means the rest of the 717 fleet can fly reliably with parts available, rather than spreading parts out thin.
citationjet
Sat Dec 22, 2018 7:49 pm
I believe that this was pointed out in the OP.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
aviatorcraig
Sat Dec 22, 2018 8:31 pm
The question here is WHY are these birds missing vital details in their documentation?
If Turkmenistan has operated these aircraft from day one, why have they not taken care of their investment. Would they not be more valuable as flying, ready to go passenger carrying aircraft instead of parts donors? I can't understand why they have not kept better records.
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
WPvsMW
Sat Dec 22, 2018 8:53 pm
Why? It's a -stan. The land of very elastic regulations... and inspections.
United_fan
I feel old,I toured EZ-A105 before it was delivered in LGB in 2004.
"Suspicion is a matter of opinion"
jagraham
Sat Dec 22, 2018 9:17 pm
:checkmark:
:checkmark:
smartplane
Sat Dec 22, 2018 9:57 pm
The 717 used market, and parts too, is underpinned by one operator - DL.
DL buys parts strategically, while others tend to buy as needed.
DL is today the equivalent of what Kelowna was for the CV580 in the 60's, 70's and 80's, except they are not keen to sell complete aircraft, and parts are not cheap.
Boeing did a dis-service to 717 operators by selling most parts to DL.
Owner wouldn't take DL's price for the complete aircraft, but they will end up taking DL's price for most of the parts.
Spacepope
Sat Dec 22, 2018 11:44 pm
Which RobK already pointed out 2 months ago, but thanks for the timely help dude.
juliuswong
Wed Apr 03, 2019 5:37 am
- Life is a journey, travel it well -
bennett123
Wed Apr 03, 2019 8:27 am
All four are still at Kemble @ Mid March.
Of the four, 106 is the furthest progressed, and now lacks outer wings and undercarriage.
