enilria
OAG Changes 9/30/2018:AC Drops YYZ-MDT/ROC/SYR;DL Adds BOS-LIS, Drops SGU-SLC;F9 Drops CHS-ORD;UA Drops SGU-DEN/LAX
Sun Sep 30, 2018 1:41 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
AA ACK-DCA JUN 0>0.7[0.6] JUL 0>1.6[1.7]
AA BOI-DFW JUN 1.0>1.8[1.8] JUL 1.0>2[1.9]
AA CLT-SXM MAR 2.0>1.1[0] APR 2.0>1.1[0] MAY 2>1.1[0]
AA DCA-MVY JUN 0>0.5[0.4] JUL 0>1.4[1.3]
AA DFW-ONT MAY 5>6[5] JUN 5>6[6] JUL 5>6[6]
AA DFW-RSW JUN 3>4[2] JUL 3>4[3]
Earlier start
AA GRR-PHX DEC 0>0.4[0]
AA MIA-SAP FEB 2>1.5[2] MAR 2>1.0[2]
AA MIA-STT MAR 1.5>1.0[1.0] APR 1.6>1.0[1.0] MAY 1.6>1.0[1.0]
AA MIA-SXM MAR 1.9>1.0[1.0] APR 2>1.0[1.0] MAY 2>1.0[1.0]
AA MIA-TGU FEB 1.6>1.1[1.6] MAR 2>1.2[2]
AA ORD-SMF MAR 0.9>0[0.8]
**AC MDT-YYZ NOV 3>0[2] DEC 3>0[2] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3] MAY 4>0[4] JUN 4>0[4] JUL 4>0[4]
**AC ROC-YYZ NOV 3>0[3] DEC 3>0[3] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3] MAY 4>0[4] JUN 4>0[4] JUL 4>0[4]
**AC SYR-YYZ NOV 3>0[3] DEC 3>0[3] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3] MAY 4>0[4] JUN 4>0[4] JUL 4>0[4]
AD FLL-REC APR 0.4>0.2[0] MAY 0.4>0.1[0.2]
AD FLL-VCP APR 1.3>1.0[1.5] MAY 1.4>1.0[1.4]
AS ABQ-SAN JAN 1.0>0.6[1.0]
*AS ELP-SAN FEB 0>0.4[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
*AS ELP-SEA FEB 0>0.4[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
DI LGW-MCO APR 0.6>0.8[0.5] MAY 0.5>0.9[0.6] JUN 0.6>0.9[0.6] JUL 0.5>0.8[0.8]
DL ANC-MSP FEB 0.9>0.6[0.8]
DL APN-PLN MAY 1.0>0.7[0.7] JUN 1.0>0.7[0.7] JUL 1.0>0.7[0.7]
DL ATL-BTV JUL 1.0>1.8[1.7]
DL ATL-COS MAR 1.0>0.7[0.9]
DL ATL-GRB MAR 2.0>1.0[1.0]
DL ATW-DTW APR 3>4[3]
DL ATW-MSP APR 3>4[4] MAY 3>4[3]
DL AUS-MSP FEB 2>1.9[2]
DL BHM-LGA JUL 4>3[1.6]
*DL BOS-LIS MAY 0>0.3[0] JUN 0>1.0[0] JUL 0>1.0[0]
DL BTV-JFK JUN 4>3[2.0] JUL 4>3[1.8]
DL BWI-RDU JAN 1.9>1.5[1.6] FEB 2>1.5[1.7]
DL CDC-SLC JUN 2>3[1.7] JUL 2>3[1.7]
DL CHO-LGA JUN 2>1.8[1.0] JUL 3>1.8[1.0]
Now seasonal? odd...
*DL COD-SLC MAR 1.9>0[1.0] APR 2>0[1.0] MAY 2>0.3[1.0] JUN 3>1.3[1.2] JUL 3>1.3[1.3]
DL DTW-EWR JUN 5>6[7] JUL 5>6[7]
*DL DTW-HNL JUL 0>0.7[0]
DL DTW-HSV JAN 0.9>0.7[0.6]
DL DTW-JAX MAR 2.0>1.0[1.0]
*DL DTW-LHR MAY 1.4>1.9[1.4] JUN 1.4>2[1.4] JUL 1.4>2[1.5]
DL DTW-MQT MAR 1.8>1.0[1.8] APR 1.9>1.0[1.9]
DL DTW-PLN JUN 4>3[3]
DL DTW-SCE JAN 3>2[3] FEB 3>2[3]
DL DTW-SWF JAN 1.9>1.1[1.9] FEB 1.9>1.0[1.9]
DL DTW-TVC JAN 4>3[4] FEB 4>3[4]
DL IMT-MSP DEC 0.7>1.0[1.0] JAN 1.0>0.5[1.0] FEB 1.0>0.5[1.0]
DL INL-MSP DEC 1.0>1.7[1.7] JAN 1.7>0.9[1.7] FEB 1.7>0.9[1.7] MAR 2>1.5[1.7]
DL JAX-LGA MAY 4>3[3] JUN 4>3[3] JUL 4>3[4]
DL JFK-TXL APR 0.5>0[0]
DL JFK-YYZ JUN 3>4[4] JUL 3>4[4]
DL LGA-ORD JAN 12>11[11] FEB 13>12[11]
DL LGA-ROC JUL 4>3[4]
DL LGA-SYR JUL 4>3[3]
DL LGA-TYS JAN 1.8>1.3[0.8] FEB 1.8>1.3[0.8]
*DL LHR-PDX JUN 0.6>1.0[0.6] JUL 0.6>1.0[0.5]
DL LSE-MSP JAN 3>2[2] FEB 3>2[2] MAR 3>2[3] APR 3>2[3] MAY 3>2[3] JUN 3>2[3] JUL 3>2[3]
DL LWS-SLC MAR 1.6>3[1.8] APR 1.6>3[1.9] MAY 2>3[1.8] JUN 2>3[1.8] JUL 2>3[1.9]
DL MLI-MSP MAR 1.8>1.0[1.7]
DL MSP-YUL FEB 1.0>0.8[0.8]
DL MSP-YYC JUN 2>3[2] JUL 2>3[2]
DL MSY-SLC FEB 1.0>0.8[1.0]
There's something odd about all the SGU service that OO dropped. Is it real?
*DL SGU-SLC JUN 4>0[4] JUL 4>0[3]
DL SLC-WYS MAY 0>0.3[0.5] JUL 0>1.9[2]
*F9 CHS-ORD DEC 0.3>0.0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0]
F9 DEN-FSD JAN 0.5>0.3[0]
F9 DEN-MCI JAN 0.7>0.5[1.0]
F9 DEN-OKC JAN 0.5>0.3[1.0]
F9 DEN-SMF JAN 0.5>0.3[0]
F9 DEN-TUL JAN 0.7>0.5[0]
F9 MIA-ORD JAN 1.0>0.7[1.0]
FI DFW-KEF MAY 0.9>0.6[0.0] JUN 1.1>0.6[0.6]
FI KEF-MCI JUN 1.0>0.6[0.4] JUL 1.0>0.6[0.4]
FI KEF-SEA MAY 2>1.5[2.0] JUN 3>2[2] JUL 3>2[2]
G7 CVG-STL NOV 0.9>0.4[0.7] DEC 0.8>0.4[0.4] JAN 0.9>0.4[0.8] FEB 0.9>0.4[0.8] MAR 0.8>0.4[0.8] APR 0.9>0.4[0.9] MAY 0.9>0.4[0.9] JUN 0.8>0.4[0.8] JUL 0.9>0.4[0.9]
*KL AMS-LAS JUN 0>0.3[0] JUL 0>0.4[0]
KS ANC-SNP NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.6] FEB 0.4>0[0.4] MAR 0.5>0[0.5] APR 0.4>0[0.4] MAY 0.4>0[0.5] JUN 0.5>0[0.5] JUL 0.4>0[0.3]
KS SNP-STG NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.3] MAR 0.3>0[0.3] APR 0.3>0[0.3] MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.2]
*LF LAS-PGA NOV 0>0.3[0] DEC 0>0.4[0]
*LF PGA-PHX NOV 0.2>1.3[0] DEC 0>1.2[0] JAN 0>0.3[0]
*LH DUS-EWR DEC 0.7>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.8>0[0.8] APR 0.8>0[0.9] MAY 0.9>0[0.8] JUN 0.9>0[0.9] JUL 0.8>0[0.8]
MW HNL-JHM NOV 7>8[8] DEC 7>8[8] JAN 7>8[8]
*MW HNL-LUP NOV 0>0.9[0] DEC 0>0.9[0] JAN 0>0.9[0]
MW HNL-OGG NOV 3>4[0] DEC 3>4[0] JAN 3>4[3]
MW KOA-OGG NOV 12>13[12] DEC 12>13[13] JAN 12>13[14]
MW LUP-MKK NOV 0.4>0.9[0] DEC 0.4>0.9[0] JAN 0.4>0.9[0]
MW MKK-OGG NOV 10>11[10] DEC 10>11[10] JAN 10>11[9]
SY MSP-PHX DEC 1.6>2.0[1.9]
*UA DEN-SGU JUN 2>0[2] JUL 2>0[1.8]
UA EWR-MBJ MAR 1.6>2[1.3]
UA EWR-SFO MAR 14>13[12]
UA EWR-YYZ MAR 3>4[4] APR 3>4[4] MAY 3>4[4] JUN 3>4[4] JUL 3>4[4]
UA IAH-SAL JAN 2>3[2]
*UA LAX-SGU JUN 1.0>0[1.0] JUL 1.0>0[1.0]
UA ORD-RAP APR 1.0>0.1[0.3]
NOTE: June was only loaded as a partial month, so basically JUN is not usable below...
WN ABQ-AUS APR 0.1>0.4[0.6] MAY 0>0.4[0.5]
WN ABQ-BWI APR 0.3>1.0[1.7] MAY 0>1.0[1.8] JUN 0>0.3[2]
WN ABQ-DAL APR 1.1>5[5] JUN 0>1.2[5]
WN ABQ-DEN APR 0.7>3[3] JUN 0>0.7[3]
WN ABQ-HOU APR 0.7>3[3] JUN 0>0.7[3]
WN ABQ-LAS APR 0.9>4[4] JUN 0>0.9[4]
WN ABQ-LAX APR 0.5>2[2] JUN 0>0.5[2]
WN ABQ-MCI APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN ABQ-MDW APR 0.3>1.8[2] JUN 0>0.5[2]
WN ABQ-OAK APR 0.4>2[2] JUN 0>0.6[3]
WN ABQ-PHX APR 1.1>5[6] MAY 0>5[6] JUN 0>1.3[6]
WN ABQ-SAN APR 0.4>1.9[1.9] JUN 0>0.5[2.0]
WN ALB-BWI APR 1.1>5[6] MAY 0>5[6] JUN 0>1.3[6]
WN ALB-DEN APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN ALB-FLL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN ALB-MCO APR 0.5>2[2] JUN 0>0.5[1.3]
WN ALB-MDW APR 0.5>2[2] MAY 0>2[2.0] JUN 0>0.5[2]
WN ALB-TPA APR 0.3>1.1[1.3] JUN 0>0.3[1.0]
WN AMA-DAL APR 0.9>4[4] JUN 0>0.9[4]
WN AMA-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN ATL-AUS APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-BNA APR 1.0>4[0] MAY 0>4[0] JUN 0>1.1[0]
WN ATL-BOS APR 0.5>2[3] MAY 0>2[3] JUN 0>0.5[3]
WN ATL-BWI APR 1.5>6[6] JUN 0>1.5[6]
WN ATL-CLE APR 0.4>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.5[1.8]
WN ATL-CMH APR 0.6>3[3] JUN 0>0.7[3]
WN ATL-CUN APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN ATL-DAL APR 1.1>5[5] JUN 0>1.3[5]
WN ATL-DCA APR 0.9>4[4] JUN 0>1.1[4]
WN ATL-DEN APR 0.9>4[4] JUN 0>1.0[5]
WN ATL-DTW APR 0.5>3[3] JUN 0>0.7[3]
WN ATL-FLL APR 1.2>5[5] JUN 0>1.3[5]
WN ATL-GSP APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-HOU APR 1.4>6[6] JUN 0>1.4[6]
WN ATL-IAD APR 0.4>3[1.9] MAY 0>3[1.8] JUN 0>0.7[1.8]
WN ATL-IND APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-JAX APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-LAS APR 0.9>4[4] JUN 0>1.0[4]
WN ATL-LAX APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-LGA APR 1.2>5[5] JUN 0>1.3[5]
WN ATL-MCI APR 0.9>4[4] JUN 0>0.9[4]
WN ATL-MCO APR 1.4>6[6] JUN 0>1.5[6]
WN ATL-MDW APR 1.4>6[6] JUN 0>1.5[6]
WN ATL-MKE APR 0.4>2.0[2.0] JUN 0>0.5[1.9]
WN ATL-MSP APR 0.5>2[2] JUN 0>0.5[1.9]
WN ATL-MSY APR 0.9>4[4] JUN 0>1.0[4]
WN ATL-OAK APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN ATL-PBI APR 0.5>1.9[2] MAY 0>1.9[2.0] JUN 0>0.5[1.9]
WN ATL-PHL APR 0.5>3[3] JUN 0>0.7[3]
WN ATL-PHX APR 0.5>2[2.0] JUN 0>0.5[1.9]
WN ATL-PIT APR 0.5>2[1.8] MAY 0>3[1.9] JUN 0>0.7[1.9]
WN ATL-PUJ APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN ATL-RDU APR 0.6>3[3] JUN 0>0.7[3]
WN ATL-RIC APR 0.7>3[3] JUN 0>0.7[3]
WN ATL-RSW APR 0.7>2[2] JUN 0>0.5[1.8]
WN ATL-SAN APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN ATL-SAT APR 0.4>1.9[1.9] JUN 0>0.5[2.0]
WN ATL-STL APR 0.9>4[4] JUN 0>1.0[4]
WN ATL-TPA APR 1.4>6[6] JUN 0>1.5[6]
WN AUA-BWI APR 0.3>0.8[0.8] JUN 0>0.2[1.1]
WN AUA-FLL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN AUS-BNA APR 0.5>3[2] MAY 0>3[2] JUN 0>0.8[3]
WN AUS-BOS APR 0.2>1.0[1.2] JUN 0>0.3[1.0]
WN AUS-BWI APR 0.5>2[1.9] MAY 0>3[1.9] JUN 0>0.6[2]
WN AUS-CUN APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN AUS-DAL APR 2>10[10] MAY 0>9[10] JUN 0>2[9]
WN AUS-DCA APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN AUS-DEN APR 1.1>5[5] JUN 0>1.3[5]
WN AUS-ELP APR 0.5>3[2] JUN 0>0.7[3]
WN AUS-EWR APR 0.2>1.7[1.7] JUN 0>0.5[1.8]
WN AUS-FLL APR 0.4>1.3[1.8] MAY 0>1.1[1.9] JUN 0>0.3[2.0]
WN AUS-HOU APR 1.2>5[5] JUN 0>1.4[5]
WN AUS-HRL APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN AUS-LAS APR 0.7>4[3] MAY 0>4[3] JUN 0>1.0[3]
WN AUS-LAX APR 0.6>3[3] JUN 0>0.7[3]
WN AUS-LBB APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN AUS-MCI APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN AUS-MCO APR 0.5>2[2] JUN 0>0.5[2]
WN AUS-MDW APR 0.7>3[3] JUN 0>0.8[3]
WN AUS-MSY APR 0.5>3[2] MAY 0>3[1.9] JUN 0>0.7[1.8]
WN AUS-OAK APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN AUS-PHX APR 0.9>4[4] JUN 0>1.0[4]
WN AUS-SAN APR 0.6>3[3] JUN 0>0.6[3]
WN AUS-SFO APR 0.2>0.9[0.8] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN AUS-SJC APR 0.4>2[1.9] MAY 0>2[1.9] JUN 0>0.6[1.8]
WN AUS-SMF APR 0.2>1.0[0.8] JUN 0>0.3[1.0]
WN AUS-STL APR 0.4>2.0[1.9] JUN 0>0.5[1.8]
WN AUS-TPA APR 0.4>1.3[1.3] JUN 0>0.3[1.1]
WN BDL-BWI APR 1.5>7[7] MAY 0>7[8] JUN 0>1.9[7]
WN BDL-DEN APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BDL-FLL APR 0.3>1.1[1.1] JUN 0>0.3[1.0]
WN BDL-MCO APR 0.8>3[3] JUN 0>0.9[2]
WN BDL-MDW APR 0.4>3[2] JUN 0>0.7[3]
WN BDL-RSW APR 0.2>1.1[1.5] MAY 0>1.1[1.2] JUN 0>0.3[0.2]
WN BDL-STL APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN BDL-TPA APR 0.5>3[3] JUN 0>0.7[1.9]
WN BHM-BWI APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN BHM-DAL APR 0.5>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[1.8]
WN BHM-HOU APR 0.4>1.9[1.9] JUN 0>0.5[2.0]
WN BHM-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BHM-MCO APR 0.5>2[2] JUN 0>0.5[2]
WN BHM-MDW APR 0.5>1.9[1.9] JUN 0>0.5[2.0]
WN BHM-TPA APR 0.4>1.9[1.7] MAY 0>1.8[1.7] JUN 0>0.5[1.8]
WN BNA-BOS APR 0.5>3[3] JUN 0>0.7[3]
WN BNA-BWI APR 1.3>6[6] JUN 0>1.5[6]
WN BNA-CHS APR 0.3>1.2[1.6] MAY 0>1.2[1.8] JUN 0>0.4[1.4]
WN BNA-CLE APR 0.5>3[3] JUN 0>0.7[3]
WN BNA-CLT APR 0.4>1.9[1.1] MAY 0>1.8[1.1] JUN 0>0.5[1.1]
WN BNA-CMH APR 0.5>2[2] JUN 0>0.5[2]
WN BNA-DAL APR 1.1>5[4] MAY 0>5[4] JUN 0>1.3[4]
WN BNA-DCA APR 0.9>4[3] MAY 0>4[3] JUN 0>1.0[3]
WN BNA-DEN APR 1.1>5[5] JUN 0>1.4[5]
WN BNA-DTW APR 0.4>2.0[2] JUN 0>0.5[2]
WN BNA-ECP APR 0.5>2[2] MAY 0>2[3] JUN 0>0.6[2]
WN BNA-EWR APR 0.6>3[0] MAY 0>3[0] JUN 0>0.7[0]
WN BNA-FLL APR 1.2>4[3] MAY 0>4[3] JUN 0>1.0[3]
WN BNA-HOU APR 0.9>4[4] JUN 0>1.0[4]
WN BNA-JAX APR 0.7>3[3] JUN 0>0.7[3]
WN BNA-LAS APR 0.7>3[4] MAY 0>3[4] JUN 0>0.8[4]
WN BNA-LAX APR 0.6>3[3] JUN 0>0.7[3]
WN BNA-LGA APR 0.7>3[3] JUN 0>0.8[3]
WN BNA-MCI APR 0.7>4[4] JUN 0>1.0[4]
WN BNA-MCO APR 1.4>5[5] JUN 0>1.4[5]
WN BNA-MDW APR 1.4>7[7] JUN 0>1.8[7]
WN BNA-MKE APR 0.5>2[2] JUN 0>0.5[2]
WN BNA-MSP APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BNA-MSY APR 0.9>3[3] JUN 0>0.8[3]
WN BNA-OAK APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BNA-PHL APR 0.6>3[2] MAY 0>3[2] JUN 0>0.7[2]
WN BNA-PHX APR 0.7>4[3] MAY 0>4[3] JUN 0>1.0[3]
WN BNA-PIT APR 0.4>2.0[1.7] JUN 0>0.5[1.3]
WN BNA-PNS APR 0.5>2[2] JUN 0>0.5[2]
WN BNA-RDU APR 0.7>3[4] MAY 0>3[4] JUN 0>0.8[3]
WN BNA-SAN APR 0.5>1.9[1.2] JUN 0>0.5[2]
WN BNA-SAT APR 0.5>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[2.0]
WN BNA-STL APR 0.7>3[3] JUN 0>0.7[3]
WN BNA-TPA APR 1.1>4[4] JUN 0>1.1[4]
WN BOI-DEN APR 0.5>2[2] JUN 0>0.5[2]
WN BOI-GEG APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN BOI-LAS APR 0.5>1.9[1.9] JUN 0>0.5[2.0]
WN BOI-OAK APR 0.5>2[2] MAY 0>2.0[2] JUN 0>0.5[2]
WN BOI-PHX APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BOI-SAN APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BOI-SJC APR 0.2>0.9[0.8] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN BOI-SMF APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BOS-BWI APR 1.8>9[9] JUN 0>3[9]
WN BOS-CMH APR 0.2>1.5[1.5] JUN 0>0.4[1.8]
WN BOS-DAL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BOS-DEN APR 0.4>3[3] JUN 0>0.7[3]
WN BOS-HOU APR 0.2>1.0[1.1] MAY 0>1.0[1.1] JUN 0>0.3[1.7]
WN BOS-IND APR 0.2>1.5[1.4] MAY 0>1.7[1.6] JUN 0>0.4[1.7]
WN BOS-MCI APR 0.2>1.0[1.5] MAY 0>1.0[1.7] JUN 0>0.3[1.9]
WN BOS-MDW APR 0.7>4[4] JUN 0>1.1[6]
WN BOS-MKE APR 0.2>1.0[1.5] MAY 0>1.0[1.7] JUN 0>0.3[1.7]
WN BOS-STL APR 0.7>3[3] JUN 0>0.7[3]
WN BUF-BWI APR 1.1>5[5] JUN 0>1.5[5]
WN BUF-FLL APR 0.4>1.3[1.3] JUN 0>0.3[1.0]
WN BUF-LAS APR 0.4>1.9[1.8] JUN 0>0.5[1.9]
WN BUF-MCO APR 1.0>4[4] JUN 0>0.9[2]
WN BUF-MDW APR 0.4>3[3] JUN 0>0.8[4]
WN BUF-PHX APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN BUF-TPA APR 0.6>2[2] JUN 0>0.5[1.3]
WN BUR-DAL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BUR-DEN APR 0.4>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[3]
WN BUR-HOU APR 0.2>0.9[0] MAY 0>0.9[0] JUN 0>0.2[0]
WN BUR-LAS APR 2>9[9] JUN 0>2[10]
WN BUR-MDW APR 0.2>0.9[0] MAY 0>0.9[0] JUN 0>0.2[0]
WN BUR-OAK APR 3>11[11] JUN 0>3[11]
WN BUR-PDX APR 0.2>0.9[0.9] JUN 0>0.2[1.0]
WN BUR-PHX APR 1.4>6[6] JUN 0>1.5[5]
WN BUR-SFO APR 1.0>5[4] MAY 0>5[4] JUN 0>1.1[4]
WN BUR-SJC APR 2>9[8] JUN 0>2[8]
WN BUR-SLC APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BUR-SMF APR 1.9>8[8] JUN 0>2[8]
WN BWI-CHS APR 0.7>3[3] JUN 0>0.9[4]
WN BWI-CLE APR 0.7>3[3] JUN 0>0.7[3]
WN BWI-CLT APR 0.6>3[3] JUN 0>0.7[3]
WN BWI-CMH APR 0.9>4[4] JUN 0>0.9[4]
WN BWI-CUN APR 0.5>2[2] JUN 0>0.6[2]
WN BWI-CVG APR 0.7>3[3] JUN 0>0.8[3]
WN BWI-DAL APR 0.9>4[4] JUN 0>1.0[4]
WN BWI-DEN APR 1.1>5[4] MAY 0>5[4] JUN 0>1.2[6]
WN BWI-DTW APR 0.4>3[3] JUN 0>0.7[3]
WN BWI-ECP APR 0.1>0.9[1.1] JUN 0>0.3[1.2]
WN BWI-FLL APR 2>10[9] JUN 0>3[9]
WN BWI-GRR APR 0.2>0.9[0.9] JUN 0>0.2[1.0]
WN BWI-HOU APR 0.7>4[3] MAY 0>4[3] JUN 0>0.9[4]
WN BWI-IND APR 0.6>3[3] JUN 0>0.7[3]
WN BWI-ISP APR 1.0>5[5] JUN 0>1.2[5]
WN BWI-JAX APR 0.9>4[4] JUN 0>1.0[4]
WN BWI-LAS APR 1.0>5[6] MAY 0>5[6] JUN 0>1.3[6]
WN BWI-LAX APR 0.8>3[3] JUN 0>0.7[3]
WN BWI-MBJ APR 0.5>2[1.3] MAY 0>2[1.3] JUN 0>0.5[2]
WN BWI-MCI APR 0.5>3[3] JUN 0>0.7[3]
WN BWI-MCO APR 2>10[10] JUN 0>3[10]
WN BWI-MDW APR 1.4>7[7] JUN 0>1.7[7]
WN BWI-MEM APR 0.2>1.7[1.7] MAY 0>1.9[1.8] JUN 0>0.5[1.8]
WN BWI-MHT APR 1.1>6[6] JUN 0>1.5[6]
WN BWI-MKE APR 0.6>3[3] JUN 0>0.6[3]
WN BWI-MSP APR 0.4>1.9[1.9] MAY 0>1.8[1.9] JUN 0>0.5[2.0]
WN BWI-MSY APR 0.8>3[3] JUN 0>0.8[3]
WN BWI-OAK APR 0.2>1.0[1.0] JUN 0>0.3[1.7]
WN BWI-OKC APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BWI-ORF APR 0.9>5[5] JUN 0>1.2[5]
WN BWI-PBI APR 1.2>3[3] JUN 0>0.8[2]
WN BWI-PHX APR 0.7>3[3] JUN 0>0.8[3]
WN BWI-PIT APR 0.4>3[3] JUN 0>0.7[3]
WN BWI-PUJ APR 0.3>1.3[1.3] JUN 0>0.4[2]
WN BWI-PVD APR 1.2>6[7] MAY 0>7[8] JUN 0>1.8[8]
WN BWI-PWM APR 0.7>3[3] JUN 0>0.8[4]
WN BWI-RDU APR 1.3>6[6] MAY 0>6[7] JUN 0>1.6[7]
WN BWI-ROC APR 0.7>3[3] JUN 0>0.8[3]
WN BWI-RSW APR 1.2>5[5] JUN 0>1.2[4]
WN BWI-SAN APR 0.7>3[3] JUN 0>0.8[3]
WN BWI-SAT APR 0.7>3[3] JUN 0>0.7[3]
WN BWI-SDF APR 0.6>3[3] JUN 0>0.9[4]
WN BWI-SJC APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN BWI-SJU APR 0.3>1.1[1.1] JUN 0>0.3[1.1]
WN BWI-SLC APR 0.2>1.0[1.0] JUN 0>0.3[1.7]
WN BWI-SMF APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BWI-STL APR 0.9>4[4] JUN 0>1.0[4]
WN BWI-TPA APR 1.9>8[8] MAY 0>8[7] JUN 0>2[7]
WN BZE-FLL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN BZE-HOU APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN CHS-DAL APR 0.2>1.0[0.3] MAY 0>1.0[0.3] JUN 0>0.3[0.4]
WN CHS-HOU APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN CHS-MDW APR 0.4>2.0[2.0] JUN 0>0.5[2]
WN CLE-DEN APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN CLE-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN CLE-MDW APR 1.0>4[4] JUN 0>1.1[5]
WN CLE-MKE APR 0.4>1.6[1.9] MAY 0>1.6[1.9] JUN 0>0.4[1.8]
WN CLE-PHX APR 0.5>1.4[1.9] MAY 0>1.1[1.9] JUN 0>0.3[1.2]
WN CLE-STL APR 0.4>2.0[1.9] MAY 0>2.0[1.8] JUN 0>0.5[2]
WN CLT-DAL APR 0.2>1.0[1.2] MAY 0>1.0[1.1] JUN 0>0.3[1.0]
WN CLT-HOU APR 0.2>1.0[1.0] JUN 0>0.3[1.6]
WN CLT-MDW APR 0.5>3[2] MAY 0>3[2] JUN 0>0.7[2]
WN CMH-DAL APR 0.3>1.1[1.2] JUN 0>0.3[1.0]
WN CMH-DCA APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN CMH-DEN APR 0.3>1.1[1.1] JUN 0>0.3[2.0]
WN CMH-FLL APR 0.3>1.1[1.1] JUN 0>0.3[1.0]
WN CMH-HOU APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN CMH-LAS APR 0.5>2[2] JUN 0>0.6[2]
WN CMH-MCO APR 1.1>4[4] JUN 0>1.0[4]
WN CMH-MDW APR 1.2>5[5] JUN 0>1.3[5]
WN CMH-PHX APR 0.3>1.1[1.1] JUN 0>0.3[1.6]
WN CMH-RSW APR 0.8>1.6[1.5] MAY 0>1.1[1.0] JUN 0>0.3[1.3]
WN CMH-STL APR 0.4>3[1.9] MAY 0>3[1.9] JUN 0>0.7[1.8]
WN CMH-TPA APR 0.8>2[2] JUN 0>0.6[2]
WN CRP-HOU APR 0.9>4[4] JUN 0>1.0[4]
WN CUN-DEN APR 0.3>1.2[1.3] JUN 0>0.4[1.3]
WN CUN-FLL APR 0.5>2[3] MAY 0>2[3] JUN 0>0.5[3]
WN CUN-HOU APR 0.5>2[2] JUN 0>0.6[2]
WN CUN-LAX APR 0.1>0.3[1.0] MAY 0>0.3[1.0]
WN CUN-MDW APR 0.7>2[2] JUN 0>0.6[2]
WN CUN-STL APR 0.2>1.0[0.3] MAY 0>1.0[0.1] JUN 0>0.3[0.2]
WN CVG-DEN APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN CVG-MDW APR 1.1>5[5] JUN 0>1.2[5]
WN DAL-DCA APR 1.1>5[4] MAY 0>5[4] JUN 0>1.3[4]
WN DAL-DEN APR 1.6>7[7] JUN 0>1.8[7]
WN DAL-DTW APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-ECP APR 0.5>2[1.3] MAY 0>2[1.4] JUN 0>0.5[1.5]
WN DAL-ELP APR 0.9>4[4] JUN 0>1.0[4]
WN DAL-FLL APR 0.7>3[2] MAY 0>3[2] JUN 0>0.8[2]
WN DAL-HOU APR 4>19[19] JUN 0>5[19]
WN DAL-IND APR 0.3>1.1[1.2] JUN 0>0.3[1.3]
WN DAL-LAS APR 1.2>5[5] JUN 0>1.3[5]
WN DAL-LAX APR 1.1>5[4] MAY 0>5[4] JUN 0>1.2[4]
WN DAL-LBB APR 1.1>5[5] JUN 0>1.2[5]
WN DAL-LGA APR 1.1>5[4] MAY 0>5[4] JUN 0>1.2[4]
WN DAL-LIT APR 0.7>3[3] JUN 0>0.7[3]
WN DAL-MAF APR 1.0>4[4] JUN 0>1.1[5]
WN DAL-MCI APR 1.4>6[6] JUN 0>1.5[6]
WN DAL-MCO APR 1.1>4[4] MAY 0>4[3] JUN 0>1.1[4]
WN DAL-MDW APR 1.5>7[7] JUN 0>1.7[7]
WN DAL-MEM APR 0.7>3[1.5] MAY 0>3[1.2] JUN 0>0.7[1.3]
WN DAL-MKE APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DAL-MSP APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0.1]
WN DAL-MSY APR 1.6>7[7] JUN 0>1.8[7]
WN DAL-OAK APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN DAL-OKC APR 0.7>3[3] JUN 0>0.7[3]
WN DAL-OMA APR 0.3>1.3[1.2] MAY 0>1.2[1.1] JUN 0>0.4[1.0]
WN DAL-ONT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-PDX APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-PHL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-PHX APR 1.4>6[6] JUN 0>1.5[6]
WN DAL-PIT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-PNS APR 0>0.8[0] MAY 0>1.0[0] JUN 0>0.3[0.5]
WN DAL-RDU APR 0.2>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.3[1.0]
WN DAL-SAN APR 0.9>4[4] JUN 0>0.9[4]
WN DAL-SAT APR 2>10[10] JUN 0>2[9]
WN DAL-SDF APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DAL-SEA APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-SFO APR 0.4>1.9[2] MAY 0>1.9[2] JUN 0>0.5[2]
WN DAL-SJC APR 0.4>1.7[1.7] MAY 0>1.7[1.8] JUN 0>0.4[1.8]
WN DAL-SLC APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-SMF APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN DAL-SNA APR 0.2>0.9[0.9] JUN 0>0.2[0.8]
WN DAL-STL APR 1.3>6[6] JUN 0>1.5[6]
WN DAL-TPA APR 0.8>3[2] MAY 0>3[2] JUN 0>0.8[2]
WN DAL-TUL APR 0.9>4[4] JUN 0>1.0[4]
WN DCA-FLL APR 0.5>2[2] JUN 0>0.6[2]
WN DCA-HOU APR 0.7>3[3] JUN 0>0.8[3]
WN DCA-MCI APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN DCA-MCO APR 0.5>2[2] JUN 0>0.6[2]
WN DCA-MDW APR 1.4>6[6] JUN 0>1.6[6]
WN DCA-MKE APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN DCA-MSY APR 0.5>2[2] JUN 0>0.5[2]
WN DCA-OKC APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DCA-OMA APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DCA-PVD APR 0.5>2[2] JUN 0>0.5[2]
WN DCA-STL APR 0.9>4[4] JUN 0>1.0[4]
WN DCA-TPA APR 0.5>2[2] JUN 0>0.6[2]
WN DEN-DTW APR 0.4>1.7[1.9] MAY 0>1.7[1.9] JUN 0>0.4[1.9]
WN DEN-ELP APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DEN-EWR APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN DEN-FLL APR 0.7>1.6[1.6] JUN 0>0.3[1.4]
WN DEN-GEG APR 0.5>2[2] JUN 0>0.5[2]
WN DEN-GRR APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DEN-HOU APR 1.4>6[5] MAY 0>6[5] JUN 0>1.5[6]
WN DEN-IAD APR 0.6>3[3] JUN 0>0.7[3]
WN DEN-IND APR 0.7>4[4] JUN 0>0.9[4]
WN DEN-JAX APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN DEN-LAS APR 2>10[9] JUN 0>3[9]
WN DEN-LAX APR 1.6>7[8] MAY 0>7[8] JUN 0>1.8[8]
WN DEN-LBB APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DEN-LGA APR 0.7>3[2] MAY 0>3[2] JUN 0>0.7[3]
WN DEN-MCI APR 1.3>6[6] JUN 0>1.5[7]
WN DEN-MCO APR 1.0>3[4] MAY 0>3[4] JUN 0>0.9[4]
WN DEN-MDW APR 2>9[9] JUN 0>2[9]
WN DEN-MEM APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN DEN-MKE APR 0.8>4[4] JUN 0>0.9[4]
WN DEN-MSP APR 0.9>4[5] JUN 0>1.2[5]
WN DEN-MSY APR 0.5>3[2] MAY 0>3[2] JUN 0>0.7[2]
WN DEN-OAK APR 1.1>5[5] JUN 0>1.2[5]
WN DEN-OKC APR 0.6>3[3] JUN 0>0.7[3]
WN DEN-OMA APR 0.7>3[3] JUN 0>0.8[3]
WN DEN-ONT APR 0.5>1.9[1.9] JUN 0>0.5[2.0]
WN DEN-PDX APR 0.9>4[4] MAY 0>5[4] JUN 0>1.2[4]
WN DEN-PHL APR 0.5>2[1.9] MAY 0>3[1.9] JUN 0>0.6[2]
WN DEN-PHX APR 3>12[11] MAY 0>12[11] JUN 0>3[10]
WN DEN-PIT APR 0.3>1.0[1.0] JUN 0>0.3[1.6]
WN DEN-PVR APR 0.3>1.1[1.0] JUN 0>0.3[1.0]
WN DEN-RDU APR 0.5>2[2] JUN 0>0.5[2]
WN DEN-RNO APR 0.5>1.9[1.9] JUN 0>0.5[2]
WN DEN-SAN APR 1.4>6[6] JUN 0>1.6[6]
WN DEN-SAT APR 0.7>3[3] JUN 0>0.7[3]
WN DEN-SDF APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN DEN-SEA APR 0.5>3[4] MAY 0>3[4] JUN 0>0.8[5]
WN DEN-SFO APR 0.7>4[4] JUN 0>1.0[5]
WN DEN-SJC APR 0.7>3[4] JUN 0>0.9[4]
WN DEN-SJD APR 0.3>1.3[1.3] JUN 0>0.4[1.2]
WN DEN-SLC APR 1.3>6[6] JUN 0>1.4[6]
WN DEN-SMF APR 0.9>4[4] JUN 0>1.0[5]
WN DEN-SNA APR 1.1>5[5] JUN 0>1.2[5]
WN DEN-STL APR 1.1>5[5] JUN 0>1.3[5]
WN DEN-TPA APR 0.8>3[3] JUN 0>0.8[3]
WN DEN-TUL APR 0.4>1.9[1.9] JUN 0>0.5[2.0]
WN DEN-TUS APR 0.7>2[2] JUN 0>0.5[2]
WN DSM-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DSM-PHX DEC 0.5>1.0[0] JAN 0.1>0.3[0.2]
WN DSM-STL APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN DTW-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN DTW-MDW APR 0.8>4[5] JUN 0>1.2[4]
WN DTW-PHX APR 0.3>1.0[1.7] MAY 0>1.0[1.7] JUN 0>0.3[1.8]
WN DTW-STL APR 0.4>1.9[1.8] JUN 0>0.5[1.9]
WN ECP-HOU APR 0.2>1.1[1.1] JUN 0>0.3[1.2]
WN ECP-STL APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN ELP-HOU APR 0.7>3[3] JUN 0>0.7[3]
WN ELP-LAS APR 0.5>2[2] JUN 0>0.6[2]
WN ELP-LAX APR 0.3>1.6[1.9] MAY 0>1.7[1.9] JUN 0>0.4[2.0]
WN ELP-PHX APR 0.5>3[3] MAY 0>3[4] JUN 0>0.7[4]
WN ELP-SAT APR 0.4>1.9[2] MAY 0>1.9[3] JUN 0>0.5[3]
WN EWR-MDW APR 1.2>5[5] JUN 0>1.4[5]
WN EWR-OAK APR 0.2>0.7[0.8] MAY 0>0.7[1.0]
WN EWR-PHX APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN EWR-SAN APR 0.2>0.7[0.8] MAY 0>0.7[1.0]
WN EWR-STL APR 0.4>2.0[2] JUN 0>0.5[2]
WN FLL-GCM APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-HAV APR 0.7>3[2] MAY 0>3[2] JUN 0>0.8[2]
WN FLL-HOU APR 0.7>3[2] MAY 0>3[2] JUN 0>0.8[3]
WN FLL-IND APR 0.5>1.3[1.5] JUN 0>0.3[1.1]
WN FLL-ISP APR 0.4>1.3[1.3] JUN 0>0.3[1.0]
WN FLL-JAX APR 0.7>3[2] JUN 0>0.7[3]
WN FLL-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-MBJ APR 0.5>2[2] JUN 0>0.5[2]
WN FLL-MCI APR 0.5>1.4[1.3] JUN 0>0.3[1.0]
WN FLL-MCO APR 1.1>5[5] JUN 0>1.2[5]
WN FLL-MDW APR 1.2>4[4] JUN 0>1.0[4]
WN FLL-MSY APR 0.5>3[3] JUN 0>0.7[2]
WN FLL-NAS APR 0.5>2[2] JUN 0>0.5[2]
WN FLL-PHL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-PHX APR 0.3>1.0[1.1] MAY 0>1.0[1.1] JUN 0>0.3[1.0]
WN FLL-PIT APR 0.5>1.3[1.3] JUN 0>0.3[1.7]
WN FLL-PLS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-PUJ APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-PVD APR 0.5>1.4[2] JUN 0>0.4[1.0]
WN FLL-RDU APR 0.3>1.1[1.2] JUN 0>0.3[1.2]
WN FLL-SAT APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN FLL-SJO APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN FLL-SJU APR 0.3>1.0[1.5] MAY 0>1.0[1.5] JUN 0>0.3[1.6]
WN FLL-STL APR 0.8>2[1.6] MAY 0>2[1.9] JUN 0>0.6[2]
WN FLL-TPA APR 1.1>5[5] JUN 0>1.2[5]
WN GEG-LAS APR 0.5>2[2] JUN 0>0.5[2]
WN GEG-OAK APR 0.5>2[2] MAY 0>2.0[2] JUN 0>0.5[2]
WN GEG-PHX APR 0.2>1.0[1.2] JUN 0>0.3[1.0]
WN GEG-SJC APR 0.2>0.9[0.8] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN GEG-SMF APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN GRR-MDW APR 0.7>3[3] JUN 0>0.7[3]
WN HAV-TPA APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-HRL APR 1.1>5[5] JUN 0>1.2[5]
WN HOU-IND APR 0.5>1.9[1.9] JUN 0>0.5[2.0]
WN HOU-JAX APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN HOU-LAS APR 1.2>5[5] JUN 0>1.3[5]
WN HOU-LAX APR 1.2>5[5] JUN 0>1.3[5]
WN HOU-LGA APR 0.7>3[3] JUN 0>0.7[3]
WN HOU-LIR APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-MAF APR 0.7>3[3] JUN 0>0.7[3]
WN HOU-MBJ APR 0.2>0.8[1.0] MAY 0>0.7[1.0] JUN 0>0.2[1.1]
WN HOU-MCI APR 0.6>3[3] JUN 0>0.7[3]
WN HOU-MCO APR 1.0>4[4] JUN 0>1.1[5]
WN HOU-MDW APR 1.6>6[6] JUN 0>1.6[6]
WN HOU-MEM APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN HOU-MEX APR 0.9>4[4] JUN 0>1.1[4]
WN HOU-MKE APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-MSY APR 2>9[9] JUN 0>2[9]
WN HOU-OAK APR 0.5>1.9[1.9] JUN 0>0.5[2.0]
WN HOU-OKC APR 0.8>4[4] JUN 0>1.0[4]
WN HOU-OMA APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN HOU-PHX APR 1.1>5[5] JUN 0>1.2[5]
WN HOU-PIT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-PNS APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-PVR APR 0.3>1.0[1.0] JUN 0>0.3[1.2]
WN HOU-RDU APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-SAN APR 0.5>2[2] JUN 0>0.5[2]
WN HOU-SAT APR 1.2>5[5] JUN 0>1.4[5]
WN HOU-SDF APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN HOU-SJC APR 0.2>1.0[0.8] JUN 0>0.3[1.0]
WN HOU-SJD APR 0.3>1.2[1.2] JUN 0>0.3[1.3]
WN HOU-SJO APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN HOU-SLC DEC 0.3>1.0[0.5] JAN 0.1>0.3[0.2]
WN HOU-SNA APR 0.2>1.0[1.0] JUN 0>0.3[1.7]
WN HOU-STL APR 0.9>4[4] JUN 0>1.0[4]
WN HOU-TPA APR 0.7>3[3] JUN 0>0.7[3]
WN HOU-TUL APR 0.7>3[3] JUN 0>0.7[3]
WN ICT-LAS APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN ICT-PHX APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN ICT-STL APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN IND-LAS APR 0.7>3[3] JUN 0>0.8[3]
WN IND-LAX APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN IND-MCI APR 0.4>1.7[1.8] MAY 0>1.7[1.9] JUN 0>0.4[1.7]
WN IND-MCO APR 1.1>4[4] JUN 0>1.0[4]
WN IND-MDW APR 0.4>1.7[1.7] JUN 0>0.4[1.7]
WN IND-OAK APR 0.2>0.9[0] MAY 0>0.9[0] JUN 0>0.2[0]
WN IND-PHX APR 0.5>2[2] JUN 0>0.5[2]
WN IND-RSW APR 1.0>2[1.8] MAY 0>1.4[1.2] JUN 0>0.5[1.4]
WN IND-TPA APR 0.8>3[3] JUN 0>0.8[3]
WN ISP-MCO APR 0.7>3[4] MAY 0>3[4] JUN 0>0.8[3]
WN ISP-PBI APR 0.5>2[2] JUN 0>0.5[1.9]
WN ISP-TPA APR 0.4>1.2[1.7] MAY 0>1.0[1.7] JUN 0>0.3[1.5]
WN JAX-MDW APR 0.2>1.0[1.1] MAY 0>1.0[1.1] JUN 0>0.3[1.1]
WN LAS-LAX APR 2>10[10] JUN 0>3[10]
WN LAS-LBB APR 0.2>1.0[1.1] MAY 0>1.0[1.1] JUN 0>0.3[1.1]
WN LAS-LGB FEB 0.3>3[0.7] APR 0.1>0.3[0.6] MAY 0>0.3[0.5]
WN LAS-LIT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN LAS-MAF APR 0.3>1.1[1.1] JUN 0>0.3[1.1]
WN LAS-MCI APR 1.0>4[4] JUN 0>1.0[4]
WN LAS-MCO APR 0.5>2[2] MAY 0>2[2.0] JUN 0>0.5[2]
WN LAS-MDW APR 2>9[9] JUN 0>2[9]
WN LAS-MKE APR 0.7>3[3] JUN 0>0.7[3]
WN LAS-MSY APR 0.4>2.0[2] JUN 0>0.5[2]
WN LAS-OAK APR 2.0>9[8] MAY 0>9[8] JUN 0>2[8]
WN LAS-OKC APR 0.5>2[2] MAY 0>2[2.0] JUN 0>0.5[1.9]
WN LAS-OMA APR 0.7>3[3] JUN 0>0.7[3]
WN LAS-ONT APR 0.9>4[4] JUN 0>1.0[4]
WN LAS-PDX APR 0.9>4[4] JUN 0>1.1[4]
WN LAS-PHX APR 2>11[10] JUN 0>3[10]
WN LAS-PIT APR 0.4>1.9[1.9] JUN 0>0.5[2]
WN LAS-RDU APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN LAS-RNO APR 2>10[9] MAY 0>10[9] JUN 0>3[9]
WN LAS-SAN APR 2>10[10] JUN 0>3[10]
WN LAS-SAT APR 0.9>4[4] JUN 0>0.9[4]
WN LAS-SDF APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN LAS-SEA APR 0.7>3[3] JUN 0>0.8[3]
WN LAS-SFO APR 1.2>6[6] JUN 0>1.6[6]
WN LAS-SJC APR 2>9[9] JUN 0>2[8]
WN LAS-SLC APR 1.1>5[5] JUN 0>1.2[5]
WN LAS-SMF APR 1.8>8[7] JUN 0>1.9[8]
WN LAS-SNA APR 1.3>6[6] JUN 0>1.5[6]
WN LAS-STL APR 0.9>4[4] JUN 0>1.1[4]
WN LAS-TPA APR 0.5>1.9[1.9] JUN 0>0.5[1.9]
WN LAS-TUL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN LAS-TUS APR 0.7>3[3] JUN 0>0.8[3]
WN LAX-MCI APR 0.7>3[3] JUN 0>0.7[3]
WN LAX-MDW APR 1.2>6[6] JUN 0>1.5[6]
WN LAX-MKE APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN LAX-MSY APR 0.6>3[2] MAY 0>3[2] JUN 0>0.6[2]
WN LAX-OAK APR 3>12[12] JUN 0>3[12]
WN LAX-OMA APR 0.2>0.8[0] MAY 0>0.9[0] JUN 0>0.2[0.8]
WN LAX-PDX APR 0.6>2[1.9] MAY 0>2[1.9] JUN 0>0.6[1.8]
WN LAX-PHX APR 2.0>8[8] JUN 0>2[8]
WN LAX-PIT APR 0.2>0.9[0.9] JUN 0>0.2[1.0]
WN LAX-PVR APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN LAX-RNO APR 0.7>3[3] JUN 0>0.7[3]
WN LAX-SAT APR 0.4>1.9[2] MAY 0>1.9[2.0] JUN 0>0.5[2]
WN LAX-SFO APR 1.9>9[9] JUN 0>2[9]
WN LAX-SJC APR 2>10[10] JUN 0>3[10]
WN LAX-SJD APR 0.2>1.0[1.8] MAY 0>1.0[2] JUN 0>0.3[1.2]
WN LAX-SLC APR 0.7>3[3] JUN 0>0.7[3]
WN LAX-SMF APR 1.9>8[8] JUN 0>2[8]
WN LAX-STL APR 0.7>3[3] JUN 0>0.7[3]
WN LAX-TPA APR 0.2>0.7[0] MAY 0>0.7[0]
WN LAX-TUS APR 0.7>3[3] JUN 0>0.7[3]
WN LGA-MCI APR 0.4>1.9[1.0] MAY 0>1.9[1.0] JUN 0>0.5[1.0]
WN LGA-MDW APR 1.4>6[6] JUN 0>1.5[6]
WN LGA-MKE APR 0.4>1.7[1.9] MAY 0>1.7[1.9] JUN 0>0.4[1.8]
WN LGA-MSY APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN LGA-STL APR 0.7>3[3] JUN 0>0.7[3]
WN LGA-TPA APR 0.4>1.7[2] MAY 0>1.7[2] JUN 0>0.4[2]
WN LGB-OAK APR 0.9>4[4] JUN 0>1.0[4]
WN LGB-SMF FEB 2>4[2] APR 0.5>2[2] JUN 0>0.5[2]
WN LIT-PHX APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN LIT-STL APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
WN MBJ-MCO APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN MBJ-MDW APR 0.3>0.8[0.8] JUN 0>0.2[1.0]
WN MCI-MCO APR 0.8>2[3] MAY 0>2[3] JUN 0>0.6[4]
WN MCI-MDW APR 1.6>7[8] MAY 0>7[8] JUN 0>1.9[8]
WN MCI-MKE APR 0.4>1.7[1.7] JUN 0>0.4[1.7]
WN MCI-MSP APR 0.4>1.7[1.7] JUN 0>0.4[1.7]
WN MCI-MSY APR 0.2>1.1[1.2] JUN 0>0.3[1.1]
WN MCI-OAK APR 0.2>0.8[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.7]
WN MCI-PHX APR 1.2>4[4] JUN 0>0.8[3]
WN MCI-RDU APR 0.2>1.0[0.7] MAY 0>1.0[0.9] JUN 0>0.3[0.8]
WN MCI-SAN APR 0.5>1.9[1.9] JUN 0>0.5[1.8]
WN MCI-SAT APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN MCI-STL APR 0.8>4[4] JUN 0>0.9[4]
WN MCI-TPA DEC 1.0>1.3[1.0] APR 0.5>1.5[1.5] MAY 0>1.2[1.3] JUN 0>0.4[1.9]
WN MCO-MDW APR 2>8[8] JUN 0>2[8]
WN MCO-MEM APR 0.5>1.4[1.4] JUN 0>0.3[1.3]
WN MCO-MHT APR 0.5>3[4] MAY 0>2[3] JUN 0>0.7[1.4]
WN MCO-MKE APR 1.1>4[4] JUN 0>0.9[3]
WN MCO-MSY APR 0.9>4[4] MAY 0>5[4] JUN 0>1.2[4]
WN MCO-OAK APR 0.2>0.8[0.1] MAY 0>0.7[0.1]
WN MCO-ORF APR 0.2>1.2[1.8] MAY 0>1.2[2.0] JUN 0>0.3[1.4]
WN MCO-PHL APR 0.7>3[3] JUN 0>0.9[3]
WN MCO-PHX APR 0.3>1.3[1.9] MAY 0>1.3[2] JUN 0>0.4[1.6]
WN MCO-PIT APR 1.2>4[4] JUN 0>1.1[4]
WN MCO-PVD APR 1.0>4[5] JUN 0>1.2[4]
WN MCO-RDU APR 0.7>3[3] JUN 0>0.8[2]
WN MCO-ROC APR 0.3>1.0[1.2] JUN 0>0.3[1.0]
WN MCO-SAN APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN MCO-SAT APR 0.5>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[2]
WN MCO-SDF APR 0.3>1.1[1.0] MAY 0>1.1[1.0] JUN 0>0.3[1.5]
WN MCO-SJC APR 0.2>0.8[0] MAY 0>0.7[0.8]
WN MCO-SJU APR 0.6>2[2] JUN 0>0.5[3]
WN MCO-SMF APR 0.2>0.8[0] MAY 0>0.7[0.8]
WN MCO-STL APR 1.2>4[4] MAY 0>5[4] JUN 0>1.3[5]
WN MDW-MEM APR 0.5>1.9[1.9] JUN 0>0.5[1.8]
WN MDW-MHT APR 0.2>2[3] JUN 0>0.7[3]
WN MDW-MSP APR 1.5>7[6] JUN 0>1.6[7]
WN MDW-MSY APR 0.7>4[3] JUN 0>1.0[3]
WN MDW-OAK APR 0.5>3[3] JUN 0>0.7[4]
WN MDW-OKC APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN MDW-OMA APR 0.9>5[5] MAY 0>5[6] JUN 0>1.3[6]
WN MDW-ONT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN MDW-ORF APR 0.3>1.1[1.9] MAY 0>1.1[1.9] JUN 0>0.3[2]
WN MDW-PDX APR 0.4>1.7[1.7] JUN 0>0.4[3]
WN MDW-PHL APR 1.3>6[6] JUN 0>1.4[6]
WN MDW-PHX APR 2>8[8] MAY 0>7[8] JUN 0>1.9[7]
WN MDW-PIT APR 1.0>4[4] JUN 0>1.1[5]
WN MDW-PUJ APR 0.3>0.7[0.7] MAY 0>0.5[0.6]
WN MDW-PVD APR 0.4>3[3] JUN 0>0.7[3]
WN MDW-RDU APR 0.7>4[4] JUN 0>0.9[4]
WN MDW-RNO APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN MDW-RSW APR 1.4>5[5] JUN 0>1.1[3]
WN MDW-SAN APR 0.9>4[4] JUN 0>1.0[4]
WN MDW-SAT APR 0.5>2[2] JUN 0>0.5[3]
WN MDW-SDF APR 0.7>3[3] JUN 0>0.9[4]
WN MDW-SEA APR 0.4>3[3] JUN 0>0.7[4]
WN MDW-SFO APR 0.5>2[2] MAY 0>2[2.0] JUN 0>0.5[3]
WN MDW-SJC APR 0.2>1.6[1.5] JUN 0>0.4[1.7]
WN MDW-SJD APR 0.1>0.6[0] MAY 0>0.5[0]
WN MDW-SJU APR 0.1>0.4[0.2] MAY 0>0.4[0.1]
WN MDW-SLC APR 0.5>2[2] MAY 0>2.0[2] JUN 0>0.5[2]
WN MDW-SMF APR 0.2>1.0[1.0] JUN 0>0.3[1.8]
WN MDW-STL APR 1.5>7[7] JUN 0>1.8[7]
WN MDW-TPA APR 1.5>5[5] JUN 0>1.3[5]
WN MDW-TUS APR 0.3>1.0[1.0] JUN 0>0.3[1.0]
WN MEM-TPA APR 0.3>1.0[1.0] JUN 0>0.3[1.1]
WN MHT-TPA APR 0.3>1.9[2.0] JUN 0>0.6[1.4]
WN MKE-PHX APR 1.0>3[3] JUN 0>0.7[2]
WN MKE-STL APR 0.4>1.9[1.8] JUN 0>0.5[1.8]
WN MKE-TPA APR 0.7>1.6[1.5] MAY 0>1.1[1.0] JUN 0>0.3[1.0]
WN MSP-OAK APR 0.2>0.9[0] MAY 0>0.9[0] JUN 0>0.2[0]
WN MSP-PHX APR 0.7>1.7[2] MAY 0>1.2[2] JUN 0>0.4[2]
WN MSP-STL APR 0.5>3[3] JUN 0>0.7[3]
WN MSY-OAK APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN MSY-PHX APR 0.3>1.3[1.4] MAY 0>1.2[1.9] JUN 0>0.3[1.3]
WN MSY-SAN APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN MSY-SAT APR 0.3>1.0[1.0] JUN 0>0.3[1.1]
WN MSY-SMF DEC 0.3>1.0[0] JAN 0.1>0.3[0]
WN MSY-STL APR 0.5>2[1.9] MAY 0>2.0[1.9] JUN 0>0.5[2]
WN MSY-TPA APR 0.8>3[4] JUN 0>0.7[3]
WN OAK-ONT APR 1.4>7[7] JUN 0>1.8[7]
WN OAK-PDX APR 1.4>6[6] MAY 0>6[5] JUN 0>1.5[6]
WN OAK-PHX APR 1.4>6[6] JUN 0>1.5[5]
WN OAK-PVR APR 0.2>0.6[1.0] MAY 0>0.5[1.0]
WN OAK-RNO APR 0.6>2[3] MAY 0>1.9[3] JUN 0>0.5[2]
WN OAK-SAN APR 3>11[11] JUN 0>3[11]
WN OAK-SAT APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0>0.3[0]
WN OAK-SEA APR 1.4>6[5] MAY 0>6[5] JUN 0>1.5[6]
WN OAK-SJD APR 0.1>0.7[1.0] MAY 0>0.7[1.0] JUN 0>0.2[1.0]
WN OAK-SLC DEC 2>3[3] APR 0.6>3[3] JUN 0>0.7[3]
WN OAK-SNA APR 1.7>7[7] JUN 0>1.8[7]
WN OAK-STL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN OKC-PHX APR 0.5>2[2.0] JUN 0>0.5[2]
WN OKC-STL APR 0.4>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[2.0]
WN OMA-PHX APR 0.9>2[2] JUN 0>0.5[1.4]
WN OMA-STL APR 0.7>3[3] JUN 0>0.7[3]
WN ONT-PDX APR 0.2>0.9[1.0] MAY 0>0.9[1.0] JUN 0>0.2[1.0]
WN ONT-PHX APR 1.3>6[6] MAY 0>6[7] JUN 0>1.6[6]
WN ONT-SJC APR 0.9>5[5] JUN 0>1.2[4]
WN ONT-SMF APR 1.3>6[6] MAY 0>6[7] JUN 0>1.6[6]
WN PDX-PHX APR 0.8>3[3] JUN 0>0.8[4]
WN PDX-SAN APR 0.6>3[3] JUN 0>0.6[3]
WN PDX-SJC APR 1.5>6[5] MAY 0>6[5] JUN 0>1.4[5]
WN PDX-SMF APR 1.1>5[5] JUN 0>1.2[5]
WN PDX-STL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN PHL-PHX APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN PHL-STL APR 0.6>3[2] MAY 0>3[2.0] JUN 0>0.7[2]
WN PHL-TPA APR 0.5>3[2] MAY 0>3[2.0] JUN 0>0.7[1.5]
WN PHX-PIT APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN PHX-RDU APR 0.2>0.4[1.1] MAY 0>0.3[1.1]
WN PHX-RNO APR 0.5>1.9[1.9] MAY 0>1.9[1.8] JUN 0>0.5[2.0]
WN PHX-SAN APR 2>10[9] JUN 0>2[10]
WN PHX-SAT APR 0.7>3[3] JUN 0>0.7[3]
WN PHX-SDF APR 0.2>1.0[1.0] JUN 0>0.3[1.1]
WN PHX-SEA APR 0.9>4[4] JUN 0>1.0[4]
WN PHX-SFO APR 1.3>5[5] JUN 0>1.4[5]
WN PHX-SJC APR 1.5>6[5] MAY 0>6[5] JUN 0>1.5[5]
WN PHX-SLC APR 1.3>6[5] JUN 0>1.4[6]
WN PHX-SMF APR 1.4>6[5] MAY 0>6[5] JUN 0>1.4[5]
WN PHX-SNA APR 1.5>6[6] JUN 0>1.6[7]
WN PHX-STL APR 0.9>4[4] JUN 0>1.0[3]
WN PHX-TPA APR 0.3>1.0[1.7] MAY 0>1.0[1.8] JUN 0>0.3[2.0]
WN PHX-TUL APR 0.5>1.3[1.4] JUN 0>0.3[1.8]
WN PIT-RSW APR 0.5>1.3[1.3] JUN 0>0.3[1.2]
WN PIT-STL APR 0.2>1.1[1.1] JUN 0>0.3[1.1]
WN PIT-TPA APR 0.7>2[3] MAY 0>2[3] JUN 0>0.6[2]
WN PVD-TPA APR 0.5>1.9[3] MAY 0>1.9[2.0] JUN 0>0.5[1.5]
WN RDU-STL APR 0.3>1.9[1.8] MAY 0>2[2.0] JUN 0>0.6[2]
WN RDU-TPA APR 0.5>2[2] JUN 0>0.6[2]
WN RNO-SAN APR 0.5>2[2] JUN 0>0.5[2]
WN RNO-SJC APR 0.4>1.7[1.0] MAY 0>1.7[1.0] JUN 0>0.4[1.0]
WN ROC-TPA APR 0.3>1.0[1.2] JUN 0>0.3[0.7]
WN RSW-STL APR 0.6>1.8[1.6] JUN 0>0.6[2]
WN SAN-SAT APR 0.4>1.9[2.0] MAY 0>1.9[2.0] JUN 0>0.5[2]
WN SAN-SEA APR 0.5>2[2] MAY 0>2.0[1.9] JUN 0>0.5[2]
WN SAN-SFO APR 1.8>8[8] JUN 0>1.9[8]
WN SAN-SJC APR 3>11[11] JUN 0>3[11]
WN SAN-SJD APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SAN-SLC APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SAN-SMF DEC 10>11[11] APR 2>11[11] MAY 0>11[10] JUN 0>3[11]
WN SAN-STL APR 0.5>2[2] MAY 0>2[2.0] JUN 0>0.5[2]
WN SAN-TPA APR 0.2>0.8[1.0] MAY 0>0.7[1.0]
WN SAN-TUS APR 0.5>1.9[1.9] JUN 0>0.5[1.8]
WN SAT-STL APR 0.5>2[2] JUN 0>0.5[2.0]
WN SAT-TPA APR 0.3>1.0[1.0] JUN 0>0.3[1.1]
WN SDF-TPA APR 0.3>1.1[1.1] JUN 0>0.3[1.3]
WN SEA-SJC APR 0.9>4[4] JUN 0>1.1[4]
WN SEA-SMF APR 1.0>4[5] MAY 0>4[5] JUN 0>1.1[5]
WN SEA-STL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SFO-STL APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SJC-SLC APR 0.4>1.8[1.7] JUN 0>0.4[1.7]
WN SJC-SNA APR 3>11[8] MAY 0>11[8] JUN 0>3[8]
WN SJC-STL APR 0.2>1.0[0.8] JUN 0>0.3[1.0]
WN SJC-TUS APR 0.2>0.9[0] MAY 0>0.9[0] JUN 0>0.2[0]
WN SJD-SNA APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SLC-SMF APR 0.2>1.0[1.0] JUN 0>0.3[1.0]
WN SMF-SNA APR 1.5>6[6] JUN 0>1.6[6]
WN SMF-STL APR 0.2>1.0[0.8] JUN 0>0.3[1.0]
WN STL-TPA APR 0.8>2[2] JUN 0>0.6[2]
WN STL-TUL APR 0.4>1.9[1.9] JUN 0>0.5[1.8]
X4 GST-JNU JAN 0>1.9[3] FEB 0>2[3] MAR 0>2[3] APR 0>3[4] MAY 0>0.3[5]
X4 HNH-JNU MAY 0.5>0[0] JUN 2>0[0] JUL 2>0[0]
X4 HNS-JNU MAY 0.3>0[0] JUN 1.0>0[0] JUL 1.0>0[0]
X4 JNU-PEC MAY 0.2>0[0] JUN 0.8>0[0] JUL 0.8>0[0.0]
X4 JNU-SGY MAY 0.3>0[0] JUN 1.0>0[0] JUL 1.0>0[0]
ridgid727
Re: OAG Changes 9/30/2018:AC Drops YYZ-MDT/ROC/SYR;DL Adds BOS-LIS, Drops SGU-SLC;F9 Drops CHS-ORD;UA Drops SGU-DEN/LAX
Sun Sep 30, 2018 1:44 pm
The reason all the SGU service is dropped at that time, is because the airport will be closed for aprox 4 months, to redo runway problems. Issues from the original contractor that built the airport.
TropicalSky
Sun Sep 30, 2018 1:50 pm
Thanks for the hard work ENILRIA.....interesting to see DL JFK-TXL axed,is this a seasonal cut?
enilria wrote:
FAQ
HOW DO I READ IT?
CHARTERS?
Earlier start
RJNUT
Sun Sep 30, 2018 2:06 pm
Also appears DL has bumped capacity slightly at CDC as a bit of a reliever service.
chrisnh
Sun Sep 30, 2018 2:20 pm
DL is to BOS what AA is to PHL.
ridgid727
Sun Sep 30, 2018 2:23 pm
I wonder what the increase in capacity at CDC will do to future EAS service there?
enilria
Sun Sep 30, 2018 2:25 pm
THANKS!
I believe that's just April and it didn't operate the prior April so it's kinda moot.
WOW. Sounds like a lawsuit.
Balloonchaser
Sun Sep 30, 2018 2:30 pm
WN BWI-ISP APR 1.0>5[5] JUN 0>1.2[5].....
I sure hope that there is a mistake there
flyfresno
Sun Sep 30, 2018 2:31 pm
enilria wrote:
THANKS!
I would be shocked to see this service end completely! Thanks for the heads up!
nkops
Sun Sep 30, 2018 2:40 pm
Turn left heading 080 contact departure
flyguy84
Sun Sep 30, 2018 2:44 pm
Yep. Temporary closure at SGU. Service will resume when airport re-opens.
SFO
klm617
Sun Sep 30, 2018 2:52 pm
Interesting to see PDX-LHR go daily.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
TW870
Sun Sep 30, 2018 3:07 pm
As I read it it just brings the JFK-TXL start date in line with what it was last year - which was in May. This just means that the flights that had been for sale for the second half of April are no longer for sale. I assume that JFK-TXL will still operate on the 767-300ER from May to September. Enilria, is this correct?
phllax
Sun Sep 30, 2018 3:09 pm
A lot of the frequencies appear to be misfiled, especially BUR-LAS. No way they drop to 2 dailies.
dbo861
Sun Sep 30, 2018 3:12 pm
This is a small increase but DSM-PHX is now daily through January 6. The daily flight was originally supposed to end December 15 but now it goes through the holidays. It'll be nice to have 4 daily WN flights at DSM..if only for 2 months.
Aliqiout
Sun Sep 30, 2018 3:15 pm
See the explanation in the OP. June numbers for WN are unusable.
ZuluTime
Sun Sep 30, 2018 3:17 pm
With DTW-LHR moving up to double daily and PDX-LHR going daily, that's an extra slot every day at LHR. One of the VS afternoon spares currently leased out, now to cover PDX?
mtnwest1979
Sun Sep 30, 2018 3:28 pm
With Contour adding the LAS route to their PHX offerings from Page,AZ; one could theoretically go CEC-OAK-SBA-LAS-PGA-PHX if times worked out lol. I assume the add will be for a/c rotation....
Riddle: Which lasts longer, a start-up airline or a start-up football league?
MO11
Sun Sep 30, 2018 3:36 pm
Nothing.
klm617
Sun Sep 30, 2018 3:37 pm
It seems LIS-ATL is ending so there is a 767 there. Hope they move one DTW-LHR to VS
SANFan
Sun Sep 30, 2018 3:40 pm
April is not accurate either on the WN redcap - it is also a partial month. The extension is valid from Apr 8 thru Jun 8.
bb
routeplanner
Sun Sep 30, 2018 3:44 pm
MO11 wrote:
Nothing.
Wouldn't be so sure about that. There is a group that is calling CDC before the Feds as they are 50 miles from SGU and receiving EAS benefits. They are claiming the loopholes for a major service airport are not viable here. It won't be long till that is scrapped.
enilria
Sun Sep 30, 2018 4:17 pm
What's the mistake?
bb
It's accurate...not misfiled. This exact situation is described in the FAQ and I noted it as well at the top of the WN section.
enilria wrote:
FAQ
NEW CHANGE-...If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out.
For example, WN PHX-SAN APR 2>10[9] JUN 0>2[10]
They had one week of APR filed which averaged to 2 RTs in April, now they have the full month filed. They did not file all of June so now it's showing the same effect.
EvanWSFO
Sun Sep 30, 2018 4:54 pm
Say what? What does that mean?
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
slcdeltarumd11
Sun Sep 30, 2018 5:03 pm
St George is a warm place, it's more Las Vegas weather than salt lake City. I am surprised they cant start April 1 to be done earlier. That goes into prime summer, bummer for the area. Tourism is a major source of Ibcome for alot or that area. Fortunately LAS and Cedar City are pretty close and all Interstate so I guess there are good alternatives avaialable.
Prost
Sun Sep 30, 2018 5:53 pm
The article itself says:
The project’s April-August schedule was chosen to coincide with the time of year when flights in and out of St. George are less frequently booked.
panamair
Sun Sep 30, 2018 6:09 pm
Yes, JFK-TXL will now restart for S19 in May 2019 just like it did back in S18. It will still be on the 225-seat 763ER (76Z). The season is running till end of October this year (not Sept) though.
777Mech
Sun Sep 30, 2018 6:13 pm
Wrong. ATL-LIS is seasonal. Not ending completely. VS doesn't have the frames to add flights.
clrd4t8koff
Sun Sep 30, 2018 6:44 pm
BOS-LIS is summer seasonal also and it’s loaded, so why isn’t ATL-LIS? Looks like BOS is replacing ATL for DL.
Victorville
Sun Sep 30, 2018 10:05 pm
Didn't realize ATL-LIS wasn't coming back. Just checked and it's not loaded. What was the equipment on the route?
BOS-LIS is 752 so a net reduction in seats.
airlinedork
Sun Sep 30, 2018 10:39 pm
Um yeah.... seriously confused by that claim.
airlinedork
Sun Sep 30, 2018 10:41 pm
Yeah I'd like to know where this slot came from too.
mercure1
Sun Sep 30, 2018 11:14 pm
Yep!
https://onemileatatime.com/st-george-airport-closing/
mercure f-wtcc
MO11
Sun Sep 30, 2018 11:24 pm
routeplanner wrote:
MO11 wrote:
Nothing.
Cedar City qualifies for EAS subsidy since it was served by a certificated carrier on deregulation day. Its subsidy falls well within the ever-tightening rules. If Congress changes the law, then fine.
kavok
Sun Sep 30, 2018 11:29 pm
JFK-LIS carries all the NYC O/D, and BOS now connects everyone else. As far as European destinations go, BOS is in a better geographic position than ATL to connect pax (albeit ATL has a lot more connections to draw from).
But BOS opens up the Midwest, which previously had to connect in JFK... which as congested and delay prone as JFK is, no one wants to connect there if they can avoid it. So switching to BOS-LIS makes LIS much more desirable for Midwest markets on DL.
compensateme
Mon Oct 01, 2018 12:14 am
Connections through ATL can be just as competitive as those through BOS (time wise), especially Westbound... and of course ATL has oodles more feed.
The big clue here is the use of a domestic 757 on BOS, which speaks volumes for the type of traffic DL was attracting. Similar capacity as the 763, whose premium cabin can be better utilized elsewhere.
We don’t care what your next flight is.
MSPNWA
Mon Oct 01, 2018 12:15 am
Trading D1 ATL-LIS for BOS-LIS on a domestic 757 (with TAP already going for the low yield crowd) is a curious adjustment.
compensateme
Mon Oct 01, 2018 12:24 am
DL’s published some sub-$600 fares (Basic Economy) from BOS next summer, with domestic first class (Premim Select) going for $2k. No thanks!
airlinedork
Mon Oct 01, 2018 12:32 am
BOS connects everyone else? No. BOS doesn't have half the connections JFK has. JFK is for O&D and connections.
DL is starting BOSLIS b/c BOS has a huge Portuguese population, far greater than NYC:
Rank State Population of Portuguese Americans
1California 346,172
2 Massachusetts 296,449
3 Rhode Island 96,433
4 New Jersey 76,952
5 Florida 69,147
6 New York 50,657
7 Connecticut 49,167
8 Hawaii 48,634
There's a reason why TAP Air Portugal flies to 3 US cities, and one of them is BOS.
tphuang
Mon Oct 01, 2018 12:33 am
If you check the OTP numbers, BOS really isn't much better. For example in August, both are at 73%. In July, BOS at 76% and JFK at 74%. In June, BOS and JFK both at 78%. This is about DL trying to build up its BOS operation. Without providing some feed at BOS, they would have to fill with pure O&D, which they would have to compete with the much stronger TP on this route.
Rdh3e
Mon Oct 01, 2018 1:06 am
enilria wrote:
FAQ
They lost the EAS contact for Winter service to UA so it makes sense they don't want to compete against a subsidized competitor. Same way UA didn't fly the Winter when OO had the contract via SLC.
This is actually just a trimming of the season as they had previously removed October through February.
Victorville
Mon Oct 01, 2018 12:11 pm
I wonder if they will shift more low-yielding European routes like this to BOS where they can be operated with the domestic 757, where that airplane wouldn't have the range from ATL/DTW, but leave premium traffic connecting over JFK/ATL/DTW.
AviationGeek78
Mon Oct 01, 2018 1:03 pm
That is quite right on all fronts. Good catch.
incitatus
Mon Oct 01, 2018 2:13 pm
Yes, they are "close". All it takes for DL to close the difference is to pave over all of East Boston and build another 30 or 40 gates.
I do not consume Murdoch products including the Wall Street Journal
MIflyer12
Mon Oct 01, 2018 2:46 pm
I don't think they could get very far with that. BOS doesn't have the destination set nor frequencies to play connecting hub the way ATL/DTW/MSP do for Delta... without that 30-gate expansion mentioned above!
