bakestar wrote:Morning all,
Thankfully all was well, but does this seem a little exessive by the crew? Or was it in real danger?
Major roads around the airport were also closed
https://www.theage.com.au/national/nsw/ ... 507n5.html
ABpositive wrote:When a mayday call is made, does it mandate an investigation from the safety agencies, e.g. CASA in this instance?
CaptainKoror wrote:I believe that the use of "mayday" is an ICAO standard when declaring any kind of emergency.
"There's an international standard that requires that, once you get down to your fuel reserve in a flight, you have to declare what is called a 'fuel mayday'," Mr Gibson said.
"What that tells air traffic control and aircraft in the area is that you need priority to come in. It doesn't mean you're running out of fuel; you've still got plenty of fuel left, but it's a precaution to say: 'I'm down to my reserve and I need to come in as quickly as can be arranged.' "
jumbojet wrote:article mentioned the plane, a Boeing 787-900, only had 180 passengers on board. A rather light load don't you think?
Revelation wrote:Routine stuff:"There's an international standard that requires that, once you get down to your fuel reserve in a flight, you have to declare what is called a 'fuel mayday'," Mr Gibson said.
Utah744 wrote:Wonder when they realized they were running way over their projected fuel burn. It is hard to believe it all of a sudden happened the last hour before landing. If they overflew Fiji (NAN) with it's 11,500' runway they may have some explaining to do. No one wants to make an extra stop but you've got to follow the regs.
KICT wrote:Please let the flight crew fly the aircraft. Next thread.
qf789 wrote:jumbojet wrote:article mentioned the plane, a Boeing 787-900, only had 180 passengers on board. A rather light load don't you think?
Firstly there is no such thing as a 787-900, its a 787-9 secondly the latest reports suggest that there were 239 passengers on board.
https://www.news.com.au/travel/travel-u ... d9a1c947ac
Also let me make it quite clear if you are coming on this thread to turn it into your usual DL nonsense, think again, take it elsewhere preferably where no one else has to read it
highflier92660 wrote:This is a bit of a mystery because UAL 839 blocked the flight in 14:23 which is faster than a majority of the that flight's recent trips between LAX and SYD. They only taxied for 10 minutes at LAX so fuel wasn't burned-up on the ground. The flight is well within the capability of the Boeing 787-9. This leaves questions surrounding why it was dispatched with insufficient fuel. Some people are going to do some explaining.
Newbiepilot wrote:The American LAX-SYD flight diverted to HNL after already passing Hawaii. There were remnants of a hurricane off the coast of California so i wonder if that caused extra headwinds that were unforseen.
The united flight did something unusual. Step climbs are normal as fuel burns off, but at one point they were flying at 40,500ft. I assume that was to optimize fuel burn. That makes me wonder if they knew they were extremely tight on fuel but thought they could make it until descent.
Whatsaptudo wrote:A mayday should only be declared if the crew believe the aircraft will land with less than the Final Reserve fuel. for the sake of United and the crew, i hope that's what was showing on the gauges when they got to the gate. A mayday is a very serious thing to do. Let's not be flippant. According to the media in Australia, United is now saying it was a mechanical issue. I'd bet the Fuel on board at the gate was too high to run with the fuel argument. And as others have said, if it was that critical, they should have diverted long before they got to Sydney. Maybe they just didn't want to get in line?
qf789 wrote:ABpositive wrote:When a mayday call is made, does it mandate an investigation from the safety agencies, e.g. CASA in this instance?
CASA is the Australian equivalent of the FAA, the investigating of this incident would be left up to the ATSB
N766UA wrote:CaptainKoror wrote:I believe that the use of "mayday" is an ICAO standard when declaring any kind of emergency.
Technically, I suppose, but actually stating “mayday” implies iminent peril. I’ve declared several emergencies, and never once did I say the word “mayday.”
To most pilots and controllers in the US, saying “mayday” means I’m in peril. For fuel, we say “declaring emergency fuel.” For all other emergencies, we say “declaring an emergency.” You say mayday when your circumstances are so egregious they don’t permit you to explain further. That said, perhaps overseas it’s a more universal term.
jumbojet wrote:qf789 wrote:jumbojet wrote:article mentioned the plane, a Boeing 787-900, only had 180 passengers on board. A rather light load don't you think?
I didnt mention anything about Delta and my bad, 787-9 not 900. Long day at the office, Point being, if, as the article suggested there was only 180 folks on-board, then wouldnt that particluar aircraft be able to fly LAX-SYD without having fuel issues? Was it an operational mixup?
CriticalPoint wrote:N766UA wrote:CaptainKoror wrote:I believe that the use of "mayday" is an ICAO standard when declaring any kind of emergency.
International pilots only say MAYDAY because it’s recognized world wide declaring an emergency in China will get you no where. Every time I have a problem I say MAYDAY no matter where I am in the world because it gets the point across that I have a problem.
DeltaB717 wrote:I've just listened to the recordings from liveatc - info is a bit patchy due to the quality of the recording (because of the distance UA839 was from YSSY when it declared - it was still at 410 and 135nm from YWLM). However, YMML issued a SIGMET about 10-15 minutes before the first time the 'issue' with UA839 was raised in the recording (at which point UA839 is offered YWLM, hence my earlier reference to its position relative to YWLM). Reading between the lines, one would assume YMML was the planned alternate for UA839 and the crew / UA Ops elected not to nominate another alternate, and instead declare mayday and continue for YSSY. Going on through the recording, UA839 is offered (several times) options including track shortening and a Runway 25 landing, but declines each and every offer - so the situation can't have been critical, and the declaration therefore most likely purely procedural.
As an aside, QF829 followed UA839 onto Runway 16R and was asked if they could accept a little more track lengthening, to which they replied in the affirmative, stating "we have the fuel."
Reference to United saying there was a mechanical issue could also indicate a fault, the result of which being that the system was unable to draw from some portion of the remaining fuel and therefore, technically, the reserves start to be burnt.
