enilria
OAG Changes 10/7/2018:AA +CLTRAP,+DFW-HRL/EYW, Drops CLTTUS,CZMMIA;AI Drops EWRLHR;B6 +BOSPSP;DE Drops AUS;DL +DTWLSE
Sun Oct 07, 2018 12:52 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
Beechcraft
*4P PVD-YHU NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.7[0] FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.7[0]
*7Q EYW-MLB NOV 0.3>0[0] DEC 0.3>0[0]
AA ABE-PHL JAN 4>2.0[2] FEB 4>3[2.0]
AA ABQ-DFW JAN 8>7[7]
AA ABQ-ORD JAN 2>1.5[1.9]
*AA AGS-DFW MAR 0>0.9[0] APR 0>1.0[0.3] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA ALB-PHL JAN 6>5[5]
AA AMA-DFW JAN 7>6[6]
AA ATL-CLT JAN 9>8[8]
AA ATL-JFK FEB 0>0.3[0]
AA ATL-ORD JAN 5>4[6]
AA ATL-PHL JAN 6>5[6]
AA AUS-ORD JAN 4>3[3]
AA AVL-CLT JAN 7>6[5]
AA AVP-PHL JAN 4>3[3]
AA AZO-ORD JAN 3>2[2.0]
AA BDL-LAX JAN 1.0>0.1[0.1] FEB 1.0>0.5[0.4]
AA BDL-PHL JAN 6>4[5] FEB 6>5[5]
*AA BFL-DFW MAR 0>0.9[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
*AA BGI-CLT JUN 0.1>0.8[0.1] JUL 0.1>1.0[0.1]
AA BGI-MIA JUN 2>3[2] JUL 2>3[2]
AA BGR-DCA JAN 3>1.6[3]
AA BGR-PHL JAN 5>4[4]
AA BHM-ORD JAN 2>1.5[1.6]
AA BHM-PHL JAN 3>2.0[0.9]
AA BJX-DFW JUN 2>3[2] JUL 2>3[2.0]
AA BMI-ORD JAN 3>1.9[1.9]
AA BNA-CLT JAN 7>8[7]
AA BNA-LAX JAN 2>1.3[1.2] MAR 2>3[2.0] APR 2>3[2.0] MAY 2>3[2] JUN 2>3[2] JUL 2>3[2]
AA BNA-ORD JAN 8>7[8]
AA BNA-PHL JAN 5>4[5] FEB 6>5[5]
AA BOI-DFW JAN 1.1>2.0[1.0] FEB 1.0>1.5[1.0]
AA BOI-PHX JAN 4>2[3] FEB 4>3[4]
AA BOS-DFW JAN 7>5[6] FEB 7>6[6]
AA BOS-JFK JAN 5>4[2.0]
AA BOS-LAX JAN 6>4[5] FEB 6>5[5]
AA BOS-ORD JAN 10>6[7] FEB 10>8[7]
AA BOS-PHX JAN 4>3[4]
AA BRO-DFW JAN 4>3[3]
AA BTV-PHL JAN 5>4[5]
AA BUR-DFW APR 0>1.9[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
AA BUR-PHX JAN 4>3[3]
AA BWI-DFW JAN 4>3[3]
AA BWI-JFK JAN 1.8>1.0[1.0] FEB 2>1.5[1.0]
AA BWI-ORD JAN 5>4[4]
AA CAK-ORD JAN 3>1.7[1.9]
AA CHO-PHL JAN 1.9>1.1[1.8] FEB 2>1.5[1.8]
AA CHS-DFW JAN 3>2[2]
AA CHS-PHL JAN 5>3[3] FEB 5>4[3]
AA CLE-DFW JAN 5>3[3]
AA CLE-JFK JAN 2>3[1.0]
AA CLT-DTW JAN 7>6[6]
AA CLT-GRR JAN 2>3[2]
AA CLT-GSP JAN 8>9[7]
*AA CLT-HAV NOV 1.0>0.1[1.0] DEC 0.6>0[0.5]
AA CLT-IAD JAN 8>7[6]
AA CLT-MBJ MAY 4>3[4]
AA CLT-MYR JAN 9>8[7]
AA CLT-PBI JAN 4>5[5]
AA CLT-PDX JAN 1.8>0.9[1.2] FEB 2>1.5[1.0]
AA CLT-PHF JAN 6>5[5]
AA CLT-PNS JAN 5>4[3]
AA CLT-PVD JAN 5>4[4]
**AA CLT-RAP JUN 0>0.8[0.3] JUL 0>1.0[0.3]
AA CLT-RSW JAN 4>5[5]
AA CLT-SAV JAN 9>8[8]
AA CLT-SDF JAN 8>7[6]
**AA CLT-TUS FEB 1.0>0.4[0.5] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0.9] JUL 1.0>0[0.9]
AA CMH-DFW JAN 5>3[3]
AA CMH-PHL JAN 7>5[5] FEB 7>6[6]
AA COU-DFW JAN 3>2[2]
AA COU-ORD JAN 3>1.7[1.9]
AA CRP-DFW JAN 7>6[6]
AA CRW-DCA FEB 1.9>1.4[1.7] MAR 1.8>1.0[1.7] APR 1.9>1.0[1.8] MAY 1.9>1.0[1.8] JUN 1.8>1.0[1.8] JUL 1.9>1.0[1.8]
AA CUU-DFW JUN 2>3[2] JUL 2>3[2]
AA CVG-DCA JAN 3>1.9[3]
AA CVG-DFW JAN 5>4[4]
AA CVG-PHL JAN 6>5[5]
**AA CZM-MIA APR 0.9>0.0[0.9] MAY 0.8>0[0.8] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
AA DAY-ORD JAN 5>4[4]
*AA DCA-OKC FEB 0>0.5[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA DCA-PBI JAN 1.4>2[2] FEB 1.0>1.5[3]
AA DCA-PHL JAN 3>4[3]
AA DCA-RSW JAN 1.5>2[2] FEB 1.0>1.5[2]
AA DEN-PHL JAN 1.2>0.9[1.5]
*AA DFW-DGO JUN 0>0.8[0] JUL 0>1.0[0]
AA DFW-EWR JAN 5>4[4]
**AA DFW-EYW JUN 0>0.8[0.1] JUL 0>1.0[0.1]
*AA DFW-FLG APR 0>1.9[0] MAY 0>2[0] JUN 0>2[0.1] JUL 0>2[0.1]
AA DFW-GDL JUN 2>3[2] JUL 2>3[2]
*AA DFW-GNV MAR 0>0.9[0] APR 0>2.0[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
AA DFW-GPT JAN 3>2[2]
AA DFW-GRI JAN 2>3[1.9]
AA DFW-GRK JAN 7>5[5] FEB 7>6[5]
AA DFW-GRR JAN 2>3[3]
**AA DFW-HRL MAR 0>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0]
AA DFW-IAD JAN 4>3[3]
AA DFW-IAH JAN 10>9[8]
AA DFW-JFK JAN 4>3[1.1]
AA DFW-LGA JAN 12>11[10]
AA DFW-MKE JAN 4>3[3]
AA DFW-MLU JAN 3>2[2]
*AA DFW-MRY APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA DFW-MSP JAN 6>5[5]
AA DFW-MSY JAN 8>7[7]
AA DFW-ORD JAN 13>12[12]
AA DFW-PDX JAN 4>3[3]
AA DFW-PIT JAN 5>3[3] FEB 5>4[3]
AA DFW-PNS JAN 5>4[4]
AA DFW-PVR JUN 3>4[3] JUL 3>4[3]
AA DFW-QRO JUN 2>3[2] JUL 2>3[2]
AA DFW-RDU JAN 6>5[5]
AA DFW-RIC JAN 3>2[2]
AA DFW-SAN JAN 9>8[8]
*AA DFW-SAP JUN 0>0.5[0] JUL 0>0.6[0]
AA DFW-SAV JAN 3>1.7[2] FEB 3>2[2]
AA DFW-SEA JAN 9>6[7] FEB 9>8[7]
AA DFW-SLP JUN 2>3[2] JUL 2>3[2]
AA DFW-SMF JAN 5>4[4]
*AA DFW-TGU JUN 0>0.4[0] JUL 0>0.4[0]
AA DFW-TXK JAN 4>3[3]
AA DFW-VPS JAN 5>4[4]
*AA DFW-YUM MAR 0>0.9[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA DTW-LGA JAN 4>5[6]
AA DTW-PHL JAN 6>5[5]
AA DTW-PHX JAN 2>3[3]
AA ELP-ORD JAN 2>1.3[1.5] FEB 2>1.5[1.0]
AA EVV-ORD JAN 3>2[1.9]
AA EWR-ORD JAN 6>5[5]
AA EWR-PHX JAN 4>3[3]
AA EYW-MIA MAR 4>5[4]
AA FAT-LAX JAN 4>5[3]
AA FLL-ORD JAN 3>2[3]
AA FNT-ORD JAN 4>3[3]
AA FSD-ORD JAN 3>2[2]
AA GRR-PHL JAN 3>2[2]
AA GSP-PHL JAN 3>2[2]
AA HSV-ORD JAN 1.8>0.9[0.9] FEB 2>1.5[0.9]
AA HVN-PHL JAN 3>2[3]
AA IAH-PHL JAN 4>2.0[3] FEB 4>3[3]
AA ILM-PHL JAN 3>1.8[1.6] FEB 3>2[1.6]
AA IND-LAX JAN 2>0.9[0.6] FEB 2>1.4[0.7]
AA IND-LGA JAN 3>2.0[2] FEB 3>2.0[3] MAR 3>2[3] APR 3>2[3] MAY 3>2[3] JUN 3>2[3] JUL 3>2[3]
AA IPT-PHL JAN 3>1.1[2] FEB 3>2[2]
AA ISP-PHL JAN 3>2[3]
AA JFK-ORD JAN 1.1>1.9[1.0] FEB 1.0>1.4[1.0]
AA JFK-PHX JAN 5>4[4]
AA JFK-SAT FEB 0>0.5[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA LAS-PHL JAN 4>2.0[3] FEB 4>3[3]
AA LAX-MCO JAN 4>3[3]
AA LAX-OMA JAN 1.2>2[0.7] FEB 1.0>2[0.9] MAR 1.0>2[1.0] APR 1.0>2[0.9] MAY 1.0>2[0.8] JUN 1.0>2[1.0] JUL 1.0>2[1.0]
AA LAX-ORD JAN 10>9[9]
AA LAX-PDX JAN 3>4[3]
AA LAX-PHL JAN 6>5[6]
AA LAX-RDM JAN 1.2>1.7[1.0] FEB 1.0>1.3[1.0]
AA LAX-RDU JAN 1.8>0.8[0.8] FEB 1.7>1.2[0.7]
AA LAX-RNO JAN 4>5[4]
AA LAX-SAT JAN 2>3[2] FEB 2>3[2] MAR 2>3[2] APR 2>3[2] MAY 2>3[2] JUN 2>3[2] JUL 2>3[2]
AA LAX-SFO JAN 11>10[12]
*AA LAX-TUL APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA LEX-PHL JAN 3>2[2]
AA LGA-MSP JAN 2>1.6[2]
AA LGA-PBI JAN 1.2>0.9[1.0]
AA LGA-PHL JAN 2>3[3]
AA LGA-RIC JAN 3>4[3]
AA LGA-SDF FEB 3>2[1.7] MAR 3>1.7[1.7] APR 3>1.7[2] MAY 3>1.7[3] JUN 3>1.7[3] JUL 3>1.7[3]
AA LGA-STL JAN 4>3[3]
*AA LGA-TYS FEB 0>1.1[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
AA MCI-PHL JAN 3>2[2]
AA MCO-MIA JAN 7>9[7] FEB 7>9[7] MAR 7>9[7]
AA MDT-PHL JAN 6>4[5]
AA MEM-ORD JAN 4>3[3]
AA MEM-PHL JAN 3>2.0[2]
AA MHT-PHL JAN 6>5[5]
AA MIA-RSW JAN 1.5>2[0.3]
*AA MIA-SCU MAY 0>0.9[0] JUN 0>1.0[0] JUL 0>1.0[0]
AA MIA-SDQ JUN 4>5[4] JUL 4>5[4]
AA MIA-TLH JAN 3>4[4]
AA MIA-UVF JUN 1.0>1.8[1.0] JUL 1.0>2[1.0]
AA MKE-PHL JAN 5>4[4]
AA MSP-PHL JAN 4>3[1.9]
AA MSP-PHX JAN 4>3[3]
AA MSY-ORD JAN 1.8>3[1.7] FEB 1.9>2[1.8]
AA MYR-PHL JAN 3>1.0[0.5] FEB 3>2[0.5]
AA OAK-PHX JAN 4>3[3]
AA ORD-PDX JAN 2>1.1[1.2] FEB 3>1.8[1.0]
AA ORD-PHL JAN 9>8[7]
AA ORD-PIA JAN 3>2[2]
AA ORD-PIT JAN 6>5[5]
AA ORD-RDU JAN 4>2[3]
AA ORD-RIC JAN 4>3[3]
AA ORD-SAN JAN 4>3[3]
AA ORD-SEA JAN 5>3[3] FEB 5>4[3]
AA ORD-SFO JAN 6>5[5] FEB 6>5[5]
AA ORD-SNA JAN 4>3[2]
AA ORD-TUS JAN 3>2[2]
AA ORD-TYS JAN 3>2.0[2]
AA PHF-PHL JAN 3>2[2]
AA PHL-PHX JAN 7>6[6]
AA PHL-PVD JAN 6>4[6] FEB 6>5[6]
AA PHL-PWM JAN 6>5[5]
AA PHL-RDU JAN 6>5[6]
AA PHL-RIC JAN 7>5[6]
AA PHL-ROC JAN 6>4[5] FEB 6>5[5]
AA PHL-RSW JAN 3>2[4]
AA PHL-SAV JAN 3>2[0.9]
AA PHL-SBY JAN 4>3[3]
AA PHL-SCE JAN 5>4[4]
AA PHL-SDF JAN 4>2[1.9] FEB 4>3[1.9]
AA PHL-SEA JAN 1.0>0.6[1.1] FEB 1.0>0.8[1.0]
AA PHL-SLC JAN 0.2>1.0[1.0] FEB 0>0.5[1.0]
AA PHL-STL JAN 5>3[4] FEB 5>4[4]
AA PHL-SWF JAN 3>2[3]
AA PHL-SYR JAN 5>4[5]
AA PHL-TYS JAN 3>2[1.9]
AA PHL-YUL JAN 5>3[3] FEB 5>4[4]
AA PHL-YYZ JAN 5>4[5]
AA PHX-SBA JAN 5>4[4]
AA PHX-TUS JAN 6>8[8]
*AI EWR-LHR NOV 0.5>0.2[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.5] FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4]
AN HHR-MYF NOV 0>0.2[0] DEC 0>0.2[0]
AN HHR-OAK NOV 0>1.6[0] DEC 0>1.5[0.7] JAN 0>0.3[0.2]
AN HHR-SQL NOV 0>1.6[0] DEC 0>1.6[0] JAN 0>0.3[0]
AN MYF-SBA NOV 0>0.5[0] DEC 0>0.5[0]
AN OAK-SBA NOV 0>1.6[0] DEC 0>1.5[0] JAN 0>0.3[0]
AN OAK-TKF NOV 0>0.4[0] DEC 0>0.4[0]
AN SBA-SQL NOV 0>1.3[0] DEC 0>1.2[0] JAN 0>0.2[0]
AN SQL-TKF NOV 0>0.9[0] DEC 0>0.9[0]
AS JFK-SEA APR 2>3[1.0] MAY 2>3[1.0]
AS LAS-SEA JAN 9>8[7]
AS LAX-LTO MAR 0.8>1.0[0.7] APR 0.7>1.0[0.7]
AS LAX-MZT MAR 0.8>1.0[0.8] APR 0.7>1.0[0.7]
AS LAX-SEA FEB 14>15[11]
AS LAX-ZIH APR 1.0>0.7[0.6]
AS PDX-SEA FEB 23>24[23]
AS SAN-SJD MAR 1.5>1.2[1.7] APR 1.6>1.1[1.9] MAY 1.6>1.1[1.9]
AS SEA-SFO JAN 15>14[10]
AS SEA-SJC JAN 10>8[7]
AS SFO-SJD MAR 1.6>1.2[0] APR 1.7>1.1[0.3] MAY 1.7>1.1[1.6]
AS SJC-SJD MAR 0.8>1.0[0.9] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0]
*B6 BOS-PSP MAR 0>0.3[0] APR 0>0.3[0]
BW FLL-POS MAY 1.0>0.8[0.5]
*DE AUS-FRA JUN 0.3>0[0.3] JUL 0.3>0[0.4]
*DE FRA-PDX MAY 0.3>0[0.3]
DL ATL-CAE MAR 7>8[8]
DL ATL-GPT MAR 4>5[4] APR 4>5[4] MAY 4>5[4]
*DL ATL-LIS MAY 0.3>0[0.3] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
DL ATL-TYS MAR 8>9[8]
DL BUR-LAS JAN 0>0.3[0.4]
DL CHS-DTW APR 1.9>3[1.9] MAY 1.9>3[1.8] JUN 2.0>3[2.0] JUL 2>3[2]
DL CVG-IAH MAR 1.5>0.8[0.8]
DL DTW-FLL MAR 5>6[6]
NK reaction
*DL DTW-JAX DEC 1.0>1.3[1.0] JAN 1.0>1.9[1.0] FEB 1.0>1.9[1.0] MAR 1.0>2[1.0]
*DL DTW-LSE MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
DL DTW-MKE MAR 5>6[6]
DL DTW-TVC JAN 3>4[4] FEB 3>4[4]
DL IMT-MSP JAN 0.5>1.0[1.0] FEB 0.5>1.0[1.0]
DL INL-MSP JAN 0.9>1.7[1.7] FEB 0.9>1.7[1.7]
DL LGA-MYR JUL 0>0.3[0.4]
DL LGA-TVC JUN 0>0.4[0.5] JUL 0>0.5[0.9]
DL MSP-RIC JUL 1.8>3[1.7]
F9 MCO-ORD DEC 1.0>1.3[1.2] JAN 1.0>1.3[1.0] FEB 1.0>1.3[1.0]
FI DEN-KEF MAY 1.5>1.0[0.9] JUN 2>1.0[1.3] JUL 2>1.0[1.3]
FI DFW-KEF JUL 1.2>0.6[0.6]
FI KEF-PDX MAY 0.8>0.5[0.5] JUN 1.5>0.7[0.8]
G7 CVG-STL NOV 0.4>0.9[0.7] DEC 0.4>0.8[0.4] JAN 0.4>0.9[0.8] FEB 0.4>0.9[0.8] MAR 0.4>0.8[0.8] APR 0.4>0.9[0.9] MAY 0.4>0.9[0.9] JUN 0.4>0.8[0.8] JUL 0.4>0.9[0.9]
GV DUT-STG NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0] FEB 0>0.2[0] MAR 0>0.2[0] APR 0>0.2[0] MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0]
GV SNP-STG NOV 0>0.7[0] DEC 0>0.6[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.7[0] APR 0>0.6[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.6[0]
HA AKL-HNL MAY 0.7>0.4[0.6] JUN 0.7>0.5[0.7]
HU BOS-PEK NOV 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
KS ANC-SNP NOV 0>0.4[0.3] DEC 0>0.4[0.3] JAN 0>0.5[0.6] JUN 0>0.4[0.5] JUL 0>0.4[0.3]
*LF MCN-TPA JAN 0>0.3[0] FEB 0>0.3[0]
*LH AUS-FRA MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0]
*LH FRA-SJC NOV 0.6>0[0] DEC 0.5>0[0] JAN 0.6>0[0] FEB 0.4>0[0] MAR 0.7>0[0.1] APR 0.7>0[0.7] MAY 0.7>0[0.7] JUN 0.7>0[0.7] JUL 0.7>0[0.7]
Just a month
LH MIA-MUC APR 1.0>0[1.0]
LH MUC-ORD APR 1.4>1.9[1.0] MAY 1.4>1.8[1.0] JUN 1.4>1.9[1.0] JUL 1.4>1.8[1.5]
PD IAD-YTZ JAN 3>2[3] FEB 2>1.7[2]
PD MDW-YTZ JAN 4>3[4]
PF BOS-BRU JUN 0.5>0[0] JUL 0.6>0[0]
PF BOS-FRA JUL 0.3>0[0]
PF BOS-TXL JUN 0.4>0[0] JUL 0.6>0[0]
PF BRU-EWR MAY 0.7>0[0] JUN 1.0>0[0] JUL 1.0>0[0]
PF BRU-IAD JUN 0.4>0[0] JUL 0.4>0[0]
PF CDG-EWR NOV 0.7>0[0] DEC 0.8>0[0] JAN 0.8>0[0] FEB 1.0>0[0] MAR 0.9>0[0]
PF EWR-MAD JUL 0.5>0[0]
PF EWR-STN NOV 0.6>0[0] DEC 0.8>0[0] JAN 0.8>0[0] FEB 1.0>0[0] MAR 1.0>0[0]
PF FRA-JFK JUN 0.5>0[0] JUL 1.0>0[0]
PF IAD-STN NOV 0.4>0[0] DEC 0.5>0[0] JAN 0.5>0[0] FEB 0.6>0[0] MAR 0.6>0[0]
PF JFK-TXL JUN 0.8>0[0] JUL 1.0>0[0]
SE CDG-MIA JUL 0.4>0.7[0.4]
SY DFW-LAS DEC 0.6>0.9[0] JAN 0.5>0.8[0] FEB 0.6>0.9[0] MAR 0.6>0.9[0]
*SY DFW-PUJ DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0]
UA ABQ-DEN MAR 5>4[4] APR 5>4[4] MAY 5>4[5]
UA ASE-IAH APR 0>0.2[0.8]
UA ASE-LAX APR 1.0>0.2[1.1] MAY 1.0>0[0]
UA ASE-ORD APR 1.0>0.3[1.3] MAY 1.0>0[0]
UA AUS-SFO JUN 4>5[5] JUL 4>5[4]
UA BOI-DEN MAR 5>4[4] APR 5>4[4] MAY 5>4[4]
UA BOI-SFO JUN 4>5[5] JUL 4>5[5]
UA BUR-DEN MAR 3>2[2] APR 3>2[3] MAY 3>2[3]
UA BUR-SFO JUN 5>6[5] JUL 5>6[4]
UA BWI-DEN JUN 2>3[2] JUL 2>3[2]
*UA BZN-LAX APR 0>1.0[0.1] MAY 0>1.0[0]
UA BZN-SFO JUN 1.9>0.7[1.7] JUL 2>1.1[2]
UA CHS-IAH FEB 2>1.9[1.5]
UA CLE-DEN MAR 4>3[3] APR 4>3[3] MAY 4>3[3]
UA COD-DEN JUN 2>3[3] JUL 2>3[3]
UA CPR-DEN JUN 4>5[4] JUL 4>5[4]
UA DEN-EUG MAR 3>2.0[2.0] APR 3>2[2] MAY 3>2[2.0]
UA DEN-EWR JUN 7>9[8] JUL 7>9[8]
UA DEN-FAT APR 4>3[4] MAY 4>3[4]
UA DEN-FCA JUL 4>3[4]
UA DEN-FLL MAR 1.2>2[2] APR 1.0>2[1.9] MAY 1.0>2[2.0] JUN 1.0>2[1.9] JUL 1.0>2[1.7]
UA DEN-GCC MAY 2>1.9[2] JUN 2>1.8[3] JUL 2>1.9[2]
UA DEN-GEG MAR 3>2[2.0] APR 3>2[2] MAY 3>2[2]
UA DEN-GTF MAR 3>2[2] APR 3>2[2] MAY 3>2[2]
UA DEN-IAD MAR 7>6[6] APR 8>6[6] MAY 8>7[6]
UA DEN-IAH MAR 11>10[10] APR 11>10[10] MAY 11>10[10]
UA DEN-MAF JUN 3>4[3] JUL 3>4[3]
UA DEN-MCI APR 6>5[5] MAY 6>5[5] JUN 6>5[6] JUL 6>5[6]
UA DEN-MCO JUN 3>4[4] JUL 3>4[4]
UA DEN-MEM MAR 2>3[2] APR 1.9>3[2] MAY 1.9>3[2] JUN 1.8>3[2] JUL 1.9>3[2]
UA DEN-MFR MAR 3>2[2]
UA DEN-MKE JUN 2>3[1.9] JUL 2>3[1.9]
UA DEN-MOT JUN 2>3[2] JUL 2>3[2.0]
UA DEN-MSN MAR 2>3[2] APR 1.9>3[1.9] MAY 1.9>3[1.8] JUN 1.9>3[1.8] JUL 1.9>3[1.8]
UA DEN-MSO APR 4>3[3] MAY 4>3[3]
UA DEN-MSY MAR 2>3[2] APR 2>3[2] MAY 2>3[2] JUN 2>3[2] JUL 2>3[2]
UA DEN-MTJ APR 2>3[3]
UA DEN-OKC APR 5>4[5] MAY 5>4[5]
UA DEN-ORD MAR 11>10[9] APR 12>11[10] MAY 12>11[11] JUL 12>13[12]
UA DEN-PHL MAR 3>2[2] APR 3>2[2] MAY 3>2[2]
UA DEN-PHX MAR 5>6[6] APR 5>6[5] MAY 5>6[5] JUN 5>6[4] JUL 5>6[4]
UA DEN-PIT JUN 2>3[1.9] JUL 2>3[2.0]
UA DEN-PSP JUN 4>3[3] JUL 4>3[3]
UA DEN-RAP MAR 6>4[3] APR 7>4[4] MAY 7>4[5]
UA DEN-RDM MAR 3>2[1.0] APR 3>2[1.7] MAY 3>2[2]
UA DEN-SBA APR 4>3[3] MAY 4>3[3]
UA DEN-SEA JUL 5>6[6]
UA DEN-SFO MAR 11>9[9] APR 11>10[9] MAY 11>10[9]
UA DEN-SGF JUN 3>4[4] JUL 3>4[4]
UA DEN-SGU MAR 2>3[2] APR 2>3[2] MAY 1.8>3[2.0]
UA DEN-SJC APR 4>3[4] MAY 4>3[4]
UA DEN-TPA MAR 2>3[3] JUN 1.8>3[2] JUL 1.9>3[1.9]
UA DEN-TUL JUL 4>5[4]
UA DEN-XNA MAR 1.9>3[1.6] APR 1.8>3[1.9] MAY 1.8>3[2] JUN 1.8>3[2] JUL 1.8>3[2]
UA DEN-YVR MAR 3>2[2.0] APR 3>2[1.9] MAY 3>2[2]
UA DEN-YWG MAR 1.8>1.0[1.0] APR 2>1.0[1.0] MAY 2>1.0[1.0]
UA DEN-YYC APR 4>3[3] MAY 4>3[3]
UA EUG-SFO JUN 5>4[5] JUL 5>4[5]
UA EWR-MTJ FEB 0.3>0.6[0.2] MAR 0.3>1.0[0.3]
UA EWR-SBN MAR 0.8>0.0[1.0]
UA FAY-IAD JAN 1.8>1.3[2.0]
UA FCA-LAX JUN 0.8>0.5[0.8]
UA FCA-SFO JUN 0.9>0.6[0.9]
UA GEG-SFO JUN 2>3[2] JUL 2>3[2.0]
UA JAC-LAX JUN 0.8>0.5[0.8]
UA MCI-SFO JUN 3>2[1.8] JUL 3>2[1.7]
UA MFR-SFO JUN 4>5[5] JUL 4>5[5]
UA MSO-SFO JUN 0>0.8[0.9] JUL 0>1.0[1.1]
UA PHL-SFO JUN 3>2[2.0] JUL 3>2[2]
UA PIT-SFO JUN 1.0>1.8[1.8] JUL 1.0>2[2.0]
UA PSP-SFO JUN 5>3[3] JUL 5>3[3]
UA RDD-SFO JUN 4>3[4] JUL 4>3[3]
UA RDM-SFO JUN 3>5[5] JUL 3>5[5]
UA RDU-SFO JUN 1.0>1.8[2.0] JUL 1.0>2[2.0]
UA RNO-SFO JUN 5>4[4] JUL 5>4[4]
UA SAN-SFO JUN 9>10[10] JUL 9>10[10]
UA SBA-SFO JUN 6>5[6] JUL 6>5[6]
UA SBP-SFO JUN 3>4[4] JUL 3>4[4]
UA SFO-TPA JUN 1.0>1.8[1.0] JUL 1.0>2[1.0]
UA SFO-TUS JUN 2>3[2] JUL 2>3[2]
UA SFO-YVR JUN 4>5[5] JUL 4>5[5]
VC AUS-TUL JUL 0.4>0.9[0.9]
*VC CAE-SFB DEC 0>0.5[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.6[0] APR 0>0.6[0] MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.6[0]
VC CLT-SFB JAN 0.5>0.3[0.3] FEB 0.6>0.3[0.3] MAR 0.6>0.2[0.3] APR 0.5>0.2[0.4] MAY 0.6>0.2[0.5] JUN 0.6>0.2[0.6] JUL 0.5>0.2[0.5]
VC MGM-SFB DEC 0.6>0.3[0] JAN 0.5>0.3[0] FEB 0.6>0.3[0] MAR 0.6>0.3[0] APR 0.6>0.3[0] MAY 0.6>0.3[0.3] JUN 0.6>0.3[0.6] JUL 0.5>0.3[0.6]
*VC SFB-TLH DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0]
WS PHX-YYC MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0]
WS SFO-YYC MAY 0.9>1.4[0.9] JUN 1.0>2[1.0] JUL 1.0>2[1.0]
*WW KEF-SFO NOV 0.3>0.0[0.2] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.4>0[0.5]
YK MOB-OSS NOV 1.0>0[0] DEC 1.0>0[0]
Bigant0408
Re: OAG Changes 10/7/2018:AA +CLTRAP,+DFW-HRL/EYW, Drops CLTTUS,CZMMIA;AI Drops EWRLHR;B6 +BOSPSP;DE Drops AUS;DL +DTWLS
Sun Oct 07, 2018 1:23 pm
I think we all saw Condor dropping the Austin route at some point.
The man who sleeps on the floor doesn’t fall out of bed
usairways85
Sun Oct 07, 2018 1:34 pm
A lot of AA PHL cuts in January. Some just a carry over from last year, some not. Not all that surprising. But I still don't understand less than daily flights on PHL-DEN/SEA.
enilria
Sun Oct 07, 2018 1:36 pm
I feel bad for Condor. They are being used as R&D by the other carriers.
I expect more cuts to fund all the new routes.
usairways85
Sun Oct 07, 2018 1:43 pm
I think it will be more of a total shift in aircraft utilization, which is already starting to happen. PHL-DTW, BNA, RDU, PVD, PIT, STL, MSP, MCI, BDL all see more 319 and larger aircraft when a few years ago these were all 175 and smaller. Less flights with bigger aircraft creates slack with the CR7, CR9, 175 fleet to fund the new routes. I can't say where the 319/320s are coming from though.
klm617
Sun Oct 07, 2018 2:06 pm
Except those in AUS who stated that DE was not leaving and would operate the route along side of LH.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
klm617
Sun Oct 07, 2018 2:08 pm
Maybe they could do DTW-MUC twice weekly in the summer
TYSflyer
Sun Oct 07, 2018 2:13 pm
Kind of hate seeing the loss in frequency on DCA-CRW. It appears to be a permanent drop to daily service. I guess the route recently changed to CRJ-200 couldn’t sustain the frequency previously operated by the Dash.
jb1087xna
Sun Oct 07, 2018 2:15 pm
Thanks as always!
I'm not a normal UA flier, but that's a decent frequency to probably the best positioned western hub that XNA has access to. (DL doesn't fly to SLC and AA doesn't fly to PHX) If only they'd get rid of the 50 seaters on the route... but that's for another thread.
Bigant0408
Sun Oct 07, 2018 2:16 pm
I don’t blame them for thinking that way. But as I mentioned in another thread I had a feeling it would be San Diego all over again. Now I wonder if DE plans to create another USA route not served by LH.
khowaga
Sun Oct 07, 2018 2:29 pm
The port (AUS) had announced that DE was returning in 2019, and the LH announcement didn’t include the news that DE would withdraw (and the airport’s usually hyperactive web team didn’t update the info), so there was a bit of confusion. This seems to clear it up!
LovePrunesAnet
Sun Oct 07, 2018 3:04 pm
Its probably something to do with Condor being scared of that new AUS Delta skyporch lol
enilria
Sun Oct 07, 2018 3:13 pm
jb1087xna wrote:
Thanks as always!
LOL
Didn't DE re-add MSY? Not sure I see LH there in the future.
enilria
Sun Oct 07, 2018 3:15 pm
To me this was a big surprise. Particularly with other Caribbean islands still depleted from past hurricanes. I realize it will probably be seasonal, but amazing it can't support yearround into the biggest Latin hub...not even on weekends!
Dominion301
Sun Oct 07, 2018 3:22 pm
While some of those frequency drops are no doubt offset by aircraft upgauges, no doubt the cuts are nothing more than appeasing Wall Street who get paranoid whenever ASM growth exceeds 2% with any of the US3.
Thanks as always for enilria for appeasing our weekly Sunday addiction.
Condor stopped the short-lived MUC long-haul flying after the summer 2017 season.
PSAatSAN4Ever
Sun Oct 07, 2018 3:25 pm
It was my belief when both Condor and Edelweiss Air began service to SAN that this was the LH group's test run of service, seeing the level of premium demand to gauge whether Germany-San Diego flights could be operated profitably. Indeed they can, and against the draw of British Airways to LHR. Austin has apparently passed that same test; however, perhaps SJC has not.
The flight is loaded and available for booking, including a first class cabin:
BFL 0600 DFW 1120 AA 5806 CR9
DFW 1900 BFL 2010 AA 5950 CR9
I remember AA having trouble in the winter months with this schedule in the 1990's at BFL because of the Tule fog that can envelope the San Joaquin valley. I would have guessed that SBA would have had this schedule and BFL would have had SBA's schedule (late morning departure, turning quickly and departing for an early evening arrival), but I guess this is what the numbers dictate.
Now if BFL could just get some intra-California service besides SFO (come on Horizon!!) and I could fly to BFL (oh how I miss ExpressJet!), I'd REALLY be happy!
pdt2f
Sun Oct 07, 2018 3:29 pm
They’d be welcome here at BNA.
“The sky peoclaims God’s glory - the vault of heaven, the Hand of Him who made it.”
BNA based.
Bigant0408
Sun Oct 07, 2018 3:36 pm
I can picture BNA as a potential route. Especially since only BA serves it.
TUSDawg23
Sun Oct 07, 2018 3:53 pm
CLT-TUS going away next year is unfortunate, but not unexpected. I just don't think AA could get enough connecting traffic from TUS flowing to CLT when they have DFW and ORD to fill that void. So far AA has failed to make JFK and now CLT work from TUS. I'd love to see DL or B6 offer a seasonal JFK route, but it's just tough to make anything east of the Mississippi work for TUS that isn't ATL or CHI.
enilria
Sun Oct 07, 2018 3:58 pm
This flight has a one year SCASD grant behind it.
n2dru
Sun Oct 07, 2018 4:30 pm
American starting ATLJFK hmm. They are already on the LGA route. Now JFK. Up against DL and B6. Should be interesting. ATL NYC is a large market though.
Adipocere
Sun Oct 07, 2018 4:34 pm
More cuts from PHX, with at least BOI and BUR increasing to DFW at the same time....
hoya
Sun Oct 07, 2018 4:37 pm
For UA at DEN, many of the flight times have changed too. Is this the launch of the DEN rebank that has been mentioned in many articles about UA? This article mentions a launch in February 2019. https://www.usatoday.com/story/travel/f ... 796251002/
Hoya Saxa!!
N292UX
Sun Oct 07, 2018 4:48 pm
CLT-TUS started this year and is dropped now. Isn't the first time a new route for AA has lasted less than a year. JFK-DEN barely made it 3 months before being cut.
WaywardMemphian
Sun Oct 07, 2018 4:54 pm
jb1087xna wrote:
Thanks as always!
United already flies SFO/XNA
AA has XNA/LAX plus all the DFW connections.
So many people I know in NWA simply drive to Tulsa for O&D to DEN due to the low fares between United, Southwest and Frontier there.
Does United anticipate F9 coming into XNA?
Also there is this:
Answer to Southwest?
If they had the A220 in house, I think SFO/MEM would be great for them.
CIDFlyer
Sun Oct 07, 2018 5:14 pm
DFW - HRL is a good add, surprised it took this long. They didn’t serve BRO either until the past few years and that’s up to CR7 service now. It’s probably come at the expense of MFE though used to be all mainline but now RJs
DL LSE-DTW a good add as well going east
Runway28L
Sun Oct 07, 2018 5:17 pm
Not only a lot of frequency reductions for AA at PHL, but quite a few capacity downgrades as well. Skimming through AA's site, quite a few routes that gained more mainline this past year (STL, PIT, DTW, MSP, PVD) are losing a lot of mainline capacity/flights in January and replaced with smaller equipment including CRJs.
LAX772LR
Sun Oct 07, 2018 5:26 pm
Of course they did, their traffic was 23% higher this year compared to last (their inbounds were averaging 91% in Y and sold out in J) with higher fares, and they carried an average of 105,000lbs cargo per month compared to zero, last time. They've found nothing but success in that market.
Uh-huh, just like you didn't see BA "wasting" an LHR slot on MSY.... a route where they're now routinely charging $2000+ for 2wk advanced purchase in standard-Y, on an only 8hr flight during the low season, and filling it.
Predictions aren't your strong suit. ;)
USAirALB
Sun Oct 07, 2018 5:37 pm
This is actually the second time CLT-TUS has been cut. US tried the route when they first merged with HP with a similar schedule and it lasted for around the same duration.
CLT-ABQ also failed. I’m surprised that both routes failed, given the strength of AA in New Mexico and Arizona. ATL seems to support both flights but I guess DL doesnt really have DFW like AA does.
Unrelated, but I noticed that CLT-SJC has a longer season than last year, so I wonder if that route will eventually go year round.
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 744, 752, 753, 762, 772, 77E, 77W, 789, 319, 320, 321, 332, 333, 343, 359, 388
joeblow10
Sun Oct 07, 2018 5:45 pm
TUS-CLT was also not helped by being a redeye. Probably a decent route for Eastbound connections but a much smaller market when you factor in the overnight aspect
flyPIT
Sun Oct 07, 2018 6:07 pm
MSY was not loaded until AUS got axed, and is showing *only* 1x weekly for 3 months in S19.
Hardly "filling it" with a 69% LF. Aug stats from the MSY thread:
BA: 64.2% full outbound (MSY-LHR) 2883 pax/4494 seats
73.5% full inbound (LHR-MSY) 3305 pax/4494 seats
68.9% full combined 6188 pax/8988 seats
FLYi
ericm2031
Sun Oct 07, 2018 6:18 pm
Interesting to see so many United Express changes so far out, not sure if there’s much to read into that or not.
FATFlyer
Sun Oct 07, 2018 6:20 pm
The March start date will be after the Tule fog season, it is very rare to have dense fog days at BFL from March to late October (maybe only a couple of days during that time of year).
We will see if there is a winter schedule change to try to avoid fog during the November to late February season (December and January are usually the worse months).
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
klm617
Sun Oct 07, 2018 6:25 pm
wedgetail737 wrote:
What airline is "AN"?
Ansett
FATFlyer
Sun Oct 07, 2018 6:29 pm
AN is now assigned to Advanced Air, LLC out of Hawthorne (not Ansett). They are operating flights for Surf Air.
https://www.surfair.com/us/surf-air-x-advanced-air/
When I don't recognize a code or question if it was reassigned I use the IATA code search.
https://www.iata.org/publications/Pages/code-search.aspx
DanDun
Sun Oct 07, 2018 6:34 pm
The AA flights from JFK-ATL will only run Feb 1-4, two flights a day on the A321T. I’m guessing these are super bowl adds. Interesting marketing idea.
LAX772LR
DE is 2xwk on Mondays and Thursdays for S19.
That, and they announced earlier this year than they did last year, nothing atypical about that.
flyPIT wrote:
Aug stats
That's August. Inbounds already bounced back to the high80s in September based on Airport's stats, not including nonrevs.
jb1087xna
Sun Oct 07, 2018 6:40 pm
WaywardMemphian wrote:
jb1087xna wrote:
Thanks as always!
Also there is this:
Oh I realize SFO and LAX from UA and AA respectively. I just bucket SFO to serve any WM traffic since our dot-com office is out there. And LAX on AA is just once a day as well, and in the afternoon.
It appears UA is pulling up the first DEN flight of the day to 7:15, which means that could potentially be the fastest option to get to various cities out west other than SFO and LAX.
flyPIT
Sun Oct 07, 2018 6:42 pm
I'm simply looking at their website. Showing 1x weekly on Mondays.
FLYi
teneriffe77
Sun Oct 07, 2018 6:54 pm
I think some of the PHL reductions may be temporary as January tends to be low month for travel and some routes get reduced due to low demand and aircraft maintenance schedules
EvanWSFO
Sun Oct 07, 2018 7:02 pm
I suspect they will. The ? is will they add before the permanent FIS is in place? If BA goes daily next summer, it might get a little tight in the temporary facility as TATL flights tend to arrive/depart within to be scheduled closely.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
AirFiero
Correct. SJC-CLT started out June through mid August a few years ago. Now it starts in May and runs well into October.
Someone posted the PDEW numbers, and they dropped off a lot in the winter. Are we sure CLT - TUS isn't a seasonal drop only?
n2dru
Sun Oct 07, 2018 7:24 pm
Didn't think about that. You are right, it is an interesting marketing idea. They already have several flights a day from LGA. Wonder if they would upgauge any of those during the same timeframe?
LAX772LR
Sun Oct 07, 2018 7:27 pm
Random example: Thursday, June 6, 2019.
They've also informed their ground handler that they'll be returning 2Wk, and that was back in early August.
Again, this is typical DE.... they announced last year on Oct 10 that they were returning to MSY, but flights still weren't bookable for another two weeks, and only Sundays were bookable at first. No idea why they do that, but it seems to be the rule with them, not the exception.
baje427
Sun Oct 07, 2018 7:38 pm
I am interested to see how these increased frequencies on the MIA and CLT to BGI will go that is a significant capacity increase.
SunsetLimited
Sun Oct 07, 2018 7:48 pm
DE’s MSY service for ‘19 is twice-weekly from June 6 through at least September 23.
Not sure why the PIT fans are so up in arms about a route that touches an airport almost 1,000 miles away. Strange...
Spread hope like fire.
LAX772LR
Sun Oct 07, 2018 7:56 pm
Or why people keep assuming that MSY's nearly 3yr-old DE service has anything to do with AUS, other than perhaps seizing the opportunity for better timings.
TWA1985
Sun Oct 07, 2018 7:59 pm
I’m seeing a lot of AA reductions at ORD. Is this due to upgauging or what?
Be Young. Be Wild. Be Free.
flyPIT
Sun Oct 07, 2018 8:01 pm
"Up in arms?" Whatever, as if MSY fans don't comment on air service in other cities. As for DE I'll trust their website over anything else for now.
FLYi
