sibibom wrote:Technically ATR is part-owned by Airbus.
And what is now Bombardier was owned by Boeing in the 1990s
32andBelow wrote:Ok well this is an aviation website not USA Today. People here should know they turboprops are jets engines.
Matt6461 wrote:aeromoe wrote:Matt6461 wrote:Additional drawbacks of high wing:
-Requires T-tail, which is structurally inefficient.
Umm...no it doesn't. Ever seen the AN-124 and AN-225?
I stand corrected. Thank you.
A more accurate statement would be there must some mechanism - either elevation of the Hstab or enlargement - that accounts for greater wing-Hstab interference with a high wing.
The most common mechanism is the T-tail.
An-124/225 appears to place the Hstab higher than, or at least level with, the wing by curving the rear fuselage upwards and reducing taper on the north end of the fuselage y axis. That's not a free adjustment. It's still paying an Hstab price for the high wing, just not in the currency of T-tail.
32andBelow wrote:afterburner wrote:N766UA wrote:
Of course they are. They’re just not turbojets...
Turboprop and turboshaft are gas turbine engines, just like turbojet and turbofan. However, the majority of people don't know (or don't care) about what type of engine inside an engine cowling. When there is a propeller attached to it, it isn't a jet engine to them.
Kent350787 wrote:sibibom wrote:Technically ATR is part-owned by Airbus.
caflyboy wrote:Did anybody read the question? The question was about Boeing and Airbus. The poster didn't say Antonov or BAE or Bombardier, Dornier, ATR,LET etc. I believe he asked Boeng and Airbus...
citationjet wrote:AtomicGarden wrote:So we can all agree that high wing commercial jets exist but none is large or particularly succesful.
Yes, and also that no high wing commercial jets are made by Airbus and Boeing, which was the question originally asked by the OP.
citationjet wrote:rutankrd wrote:Suppose we ignore the following
BAE 146 SERIES
BAE RJX SERIES
DORNIER 328JET
ANTONOV 148
ANTONOV 158
ANTONOV 72
ANTONOV 74
BAADE 152 abject failure admittedly
None of the above are/were high wing then ?
Read the OP. He is asking why Airbus and Boeing don’t build high wing commercial jets. None of your examples are Airbus or Boeing products.
citationjet wrote:sibibom wrote:well do ATRs and Bombardiers count?sholmes wrote:I would say no: the question is on "commercial jets".
More specifically, the OP's question was why doesn't Airbus and Boeing not build commercial jets with the wings on top. Last I knew, ATRs and Bombardiers were not built by Airbus or Boeing.
citationjet wrote:bennett123 wrote:How about the BAE 146TheFlyingDisk wrote:Or the Dornier 328 Jet. Or the An-72/74vhtje wrote:Whatchu talkin' 'bout, Willis?
The thread title didn't specify manufacturer, but the OP's question was: why Airbus and Boeing never make an airplane with the wing on top?
Sure, there are examples of high wing commercial jets, but none of these were built by Airbus or Boeing.
SomebodyInTLS wrote:32andBelow wrote:afterburner wrote:Turboprop and turboshaft are gas turbine engines, just like turbojet and turbofan. However, the majority of people don't know (or don't care) about what type of engine inside an engine cowling. When there is a propeller attached to it, it isn't a jet engine to them.
Being pedantic, no they're not. The thrust is not the result of a jet exhaust, it's the result of the attached propellor.
As mentioned, they both use TURBINES at the core, but a (turbo)jet engine - unsurprisingly - uses the JET for thrust, while a turboprop uses the PROP for thrust.
And being even more pedantic, no modern aircraft uses jet engines!!! They use turbofans. where the FAN provides most of the thrust...
Clipper101 wrote:It is due to Stability & Control issues that characterize high wing profiles in contrast to low wings:
High wings are more stable at low speeds, less stables at high speeds contrary to low wings which are less stable at low speeds & more stable at high speeds.
ZKNCI wrote:On the positive side, the lifting surface is uninterrupted…
keesje wrote:Many disadvantages, but aerodynamical it's better.
One un-interupted, high aspect ratio lift surface.
aerolimani wrote:keesje wrote:Many disadvantages, but aerodynamical it's better.
That's a nice image and all, but I fail to see how the top of the fuselage is acting as a lifting surface, given the absence of leading edge, trailing edge, and underside, all of which are required for an aerofoil to function. Unless the high wing is on struts, raised above the fuselage like an old biplane/triplane, then its lifting ability is still being interrupted by the fuselage.
A few commercial jets have however been built with wings on the top, as also recalled in some posts above.
keesje wrote:aerolimani wrote:keesje wrote:Many disadvantages, but aerodynamical it's better.
The body is also generating lift, specially under angles (of attack).
http://freeware.aerosoft.com/forum/scre ... 667e5e.jpg
aerolimani wrote:keesje wrote:aerolimani wrote:That's a nice image and all, but I fail to see how the top of the fuselage is acting as a lifting surface, given the absence of leading edge, trailing edge, and underside, all of which are required for an aerofoil to function. Unless the high wing is on struts, raised above the fuselage like an old biplane/triplane, then its lifting ability is still being interrupted by the fuselage.
I really don't think that bump between the wings is doing anything to generate lift. It's just there because the structure that most efficiently supports the wings is passing through. If that part of the fuselage is aerodynamically important to lift-generation, then why is there no deicing boot up there?
As I said, an effective aerofoil functions as a complete and specific shape. Simply continuing the top profile of the aerofoil over the top of the fuselage does not magically turn the fuselage into a lift-generating device. At very best, it will make for some smoother airflow over wing roots, allowing more of the wing to effectively generate lift. That area itself, however, is not doing anything to lift the plane into the air.
A fuselage definitely contributes to the lift. It isn’t anywhere near as effective as a wing, but it would be incorrect to say it produces zero lift. Any 3 dimensional object travelling through the air at an angle of attack will generate lift, but it won’t do it nearly as effectively as an aerofoil.
V/F
aerolimani wrote:VirginFlyer wrote:aerolimani wrote:I really don't think that bump between the wings is doing anything to generate lift. It's just there because the structure that most efficiently supports the wings is passing through. If that part of the fuselage is aerodynamically important to lift-generation, then why is there no deicing boot up there?
V/F
Indeed. Just as one can feel the effect of AOA when you stick your arm out the window of a moving vehicle. As to airpoanes, increased lift from increased AOA comes from increased pressure underneath the entire aircraft; wings and fuselage. And that is doing more to lift the plane than any little bump in the top of the fuselage between the wings of a high wing.
Both surfaces of a wing are generating lift. The reason the top surface is kept so meticulously clean is because the low pressure above, which the shape of the wing creates, is very easily disrupted. It’s why spoilers work. The high pressure created below the wing is much more robust.
I’ll believe that the continuation of the wing profile over the top of the aircraft is is helping to keep the aerodynamics as clean as possible for the top of the wings. I won’t believe that it’s turning the two separate wings into one gigantic lift-generating surface. More importantly, I don’t believe it’s offering any particular advantage over a low wing, as far as aerodynamics are concerned.
keesje wrote:aerolimani wrote:VirginFlyer wrote:A fuselage definitely contributes to the lift. It isn’t anywhere near as effective as a wing, but it would be incorrect to say it produces zero lift. Any 3 dimensional object travelling through the air at an angle of attack will generate lift, but it won’t do it nearly as effectively as an aerofoil.
V/F
Hi, I think the lift contribution of the underpressure over a typical airfoil is much bigger than the contribution of overpressure under the wing.
https://www.physicsforums.com/threads/pressure-and-lift-around-a-wing.944142/page-7
A low wing has many advantages, optimal lift is not one of them.
northstardc4m wrote:Kent350787 wrote:sibibom wrote:Technically ATR is part-owned by Airbus.
Only deHavilland Canada was owned by Boeing (Canada) for a few years jointly with the Ontario Government... and it was sold to Bombardier who already owned Canadair, but Boeing never owned Bombardier.
NameOmitted wrote:As fan diameter increases, might we see an engine protruding essentially straight ahead of the wing with much of the fan above the wing, or an engine mounted on a pylon extending above the wing thereby providing more space (along with a new maintenance challenge)?
