enilria
OAG Changes 10/14/2018: HUGE UA Change, Numerous Routes Added and Dropped
Sun Oct 14, 2018 10:43 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: The data update was delayed for some unknown reason. So better late than never.
3F CGA-HYL NOV 2>0[2] DEC 2>0[2] JAN 2>0[2] FEB 2>0[2] MAR 2>0[2] APR 2>0[2] MAY 2>0[2] JUN 2>0[2] JUL 2>0[2]
3F CGA-KTN NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9] FEB 0.9>0[0.9] MAR 0.8>0[0.9] APR 0.9>0[0.8] MAY 0.9>0[0.9] JUN 0.8>0[0.9] JUL 0.9>0[0.8]
3F HYL-KTN NOV 2>0[2] DEC 2>0[2] JAN 2>0[2] FEB 2>0[2] MAR 2>0[2] APR 2>0[2] MAY 2>0[2] JUN 2>0[2] JUL 2>0[2]
3F KTB-KTN NOV 3>0.9[3] DEC 3>0.8[3] JAN 3>0.9[3] FEB 3>0.9[3] MAR 3>0.8[3] APR 3>0.9[3] MAY 3>0.9[3] JUN 3>0.8[3] JUL 3>0.9[3]
3F KTN-MTM NOV 3>1.7[3] DEC 3>1.7[3] JAN 3>1.7[3] FEB 3>1.7[3] MAR 3>1.7[3] APR 3>1.7[3] MAY 3>1.7[3] JUN 3>1.7[3] JUL 3>1.7[3]
4B BWI-JST NOV 0>1.7[0] DEC 0>1.7[0] JAN 0>1.7[0] FEB 0>1.7[0] MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0]
4B JST-PIT NOV 0>3[0] DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0]
4O GDL-SAT DEC 0.3>0.5[0.4]
9X FKL-PIT MAR 0>0.3[3] APR 0>0.4[3]
9X LNS-PIT MAR 0>0.3[2] APR 0>0.4[2]
A7 CEN-CSL NOV 0>0.4[0]
A7 CSL-CSL NOV 0>0.2[0] DEC 0>0.2[0]
A7 CSL-CUL NOV 0>0.4[0] DEC 0>0.4[0]
A7 CSL-HMO NOV 0>0.6[0] DEC 0>0.5[0]
A7 CSL-LAP NOV 0>0.6[0]
A7 CSL-LMM NOV 0>0.7[0]
A7 CSL-MZT NOV 0>0.6[0] DEC 0>0.4[0]
A7 CSL-PVR NOV 0>0.4[0] DEC 0>0.4[0]
AA AVP-CLT MAR 3>4[3] APR 3>4[4]
*AA BGR-ORD JUN 0.1>0.8[0.1] JUL 0.1>1.0[0.1]
AA BOI-DFW FEB 1.5>2[1.0] MAR 1.0>2[1.0]
AA BOI-ORD APR 1.0>0[0.7]
AA BUF-CLT MAR 3>4[3] APR 3>4[3]
AA CLT-GCM FEB 1.8>2[1.6] MAR 2>3[2] APR 2.0>3[2]
AA CLT-GRR MAR 2>3[2.0] APR 2>3[2.0]
AA CLT-HAV JAN 0.8>0[0.8] FEB 1.0>0.5[1.0]
AA CLT-JAN MAR 4>3[3]
AA CLT-NAS APR 2>3[2] MAY 2>3[2]
AA CLT-PBI FEB 5>6[6] MAR 4>6[6] APR 4>6[6]
AA CLT-SRQ MAR 4>5[5] APR 4>5[4]
AA COS-ORD FEB 1.0>1.5[1.9]
AA CUN-ORD APR 2>1.2[2] MAY 1.9>1.0[1.9]
AA CUN-PHX APR 1.9>1.0[1.9] MAY 2>1.0[2]
AA DFW-GCM APR 1.0>0.3[0.3] MAY 1.0>0.3[0.3]
AA DFW-MRY FEB 0>0.3[0]
AA LGA-PBI APR 0.0>1.3[0.1]
AA OKC-PHX FEB 1.0>1.5[0] MAR 1.0>2[0]
AA ORD-SAV MAY 0>0.9[0]
AA ORD-SMF APR 1.0>0[0.7]
AA ORD-YVR JAN 0.9>0.6[0]
AZ FCO-LAX FEB 0.4>0.1[0]
They didn't load their schedule for all of June, so ignore June.
B6 ABQ-JFK MAY 0>0.8[1.0] JUN 0>0.4[1.0]
B6 ACK-BOS MAY 0>0.2[0.3]
B6 ACK-JFK MAY 0>1.4[0.9] JUN 0>0.8[3]
B6 ALB-FLL JUN 0>0.4[1.0]
B6 ALB-MCO JUN 0>0.4[1.0]
B6 ANC-SEA MAY 0>0.3[0.2] JUN 0>0.4[1.0]
B6 ANU-JFK MAY 0>0.4[0.5]
B6 ATL-BOS JUN 0>1.9[5]
B6 ATL-FLL JUN 0>0.8[2]
B6 ATL-JFK JUN 0>0.8[2]
B6 ATL-MCO JUN 0>0.4[1.0]
B6 AUA-BOS FEB 2>3[2] MAR 2>3[2] APR 2>3[2] JUN 0>0.5[1.3]
B6 AUA-FLL JUN 0>0.4[1.0]
B6 AUA-JFK JAN 1.7>2[1.7] MAY 0>1.3[1.1] JUN 0>0.5[1.6]
B6 AUS-BOS JUN 0>0.4[1.0]
B6 AUS-FLL JUN 0>0.4[1.0]
B6 AUS-JFK JUN 0>0.8[2]
B6 AUS-LGB JUN 0>0.4[1.6]
B6 AUS-MCO JUN 0>0.4[1.0]
B6 BDA-BOS JUN 0>0.4[1.0]
B6 BDA-JFK MAY 0>1.0[1.5] JUN 0>0.4[2]
B6 BDL-DCA JUN 0>0.7[1.9]
B6 BDL-FLL MAY 0>1.9[2] JUN 0>0.4[2]
B6 BDL-MCO FEB 2>3[2] MAR 2>3[2] APR 2>3[2] MAY 0>3[2] JUN 0>0.8[2]
B6 BDL-PBI JAN 1.0>1.8[1.0] FEB 1.0>1.5[1.0] JUN 0>0.4[1.0]
B6 BDL-SJU JUN 0>0.4[1.0]
B6 BDL-TPA JUN 0>0.4[1.0]
B6 BGI-BOS MAY 0>0.3[0.1]
B6 BGI-FLL JUN 0>0.4[1.0]
B6 BGI-JFK MAY 0>2[1.7] JUN 0>0.9[2.0]
B6 BNA-BOS JUN 0>0.8[2]
B6 BNA-FLL JUN 0>0.4[1.0]
B6 BOG-FLL JAN 1.2>1.6[1.1] JUN 0>0.4[1.0]
B6 BOG-MCO MAY 0>1.0[0.5] JUN 0>0.4[0.9]
B6 BOS-BUF APR 4>3[4] MAY 0>4[5] JUN 0>1.8[5]
B6 BOS-BUR MAY 0>1.0[0] JUN 0>0.4[0]
B6 BOS-BWI JUN 0>2[6]
B6 BOS-CHS MAY 0>3[2] JUN 0>1.1[2]
B6 BOS-CLE JUN 0>1.3[3]
B6 BOS-CLT MAY 0>2[1.9] JUN 0>0.9[1.9]
B6 BOS-CUN MAY 0>0.9[1.1]
B6 BOS-DCA JUN 0>4[9]
B6 BOS-DEN JUN 0>0.7[1.9]
B6 BOS-DFW JUN 0>0.7[1.8]
B6 BOS-DTW JUN 0>1.2[3]
B6 BOS-EWR JUN 0>2[5]
B6 BOS-FLL JUN 0>2[5]
B6 BOS-HOU JUN 0>0.4[1.0]
B6 BOS-IAD JAN 3>0.6[3] FEB 2>0[2] MAR 3>0[3] APR 3>0[3]
B6 BOS-JAX JUN 0>1.1[3]
B6 BOS-JFK MAR 7>6[7] APR 7>5[7] MAY 0>6[7] JUN 0>2[6]
B6 BOS-LAS MAY 0>4[3] JUN 0>1.5[3]
B6 BOS-LAX JUN 0>1.6[4]
B6 BOS-LGA JUN 0>2[5]
B6 BOS-LGB MAY 0>1.6[1.0] JUN 0>0.6[1.0]
B6 BOS-MCO MAY 0>7[5] JUN 0>2[5]
B6 BOS-MEX MAY 0>1.0[0] JUN 0>0.4[0]
B6 BOS-MSP JUN 0>1.1[3]
B6 BOS-MSY JUN 0>0.8[1.5]
B6 BOS-NAS MAR 1.2>2[1.1] APR 1.1>2[1.0]
B6 BOS-ORD MAY 0>4[3] JUN 0>1.7[4]
B6 BOS-PAP MAY 0>0.3[0.2]
B6 BOS-PBI FEB 5>7[6] MAR 6>7[7] APR 6>7[7] MAY 0>4[5] JUN 0>1.6[4]
B6 BOS-PHL MAR 5>6[5] APR 5>6[5] MAY 0>7[5] JUN 0>3[6]
B6 BOS-PHX JUN 0>0.4[1.0]
B6 BOS-PIT JUN 0>2[6]
B6 BOS-PUJ FEB 0.9>1.1[0.8] MAR 0.6>1.2[0.6] APR 0.5>1.1[0.9] MAY 0>1.0[0.9] JUN 0>0.4[0.7]
B6 BOS-RDU MAY 0>6[5] JUN 0>2[5]
B6 BOS-RIC JUN 0>1.5[4]
B6 BOS-ROC JAN 0>0.8[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>0.4[0]
B6 BOS-RSW MAY 0>4[5] JUN 0>1.5[4]
B6 BOS-SAN MAY 0>2[3] JUN 0>0.8[3]
B6 BOS-SAV MAY 0>1.7[1.1] JUN 0>0.7[1.1]
B6 BOS-SDQ MAY 0>1.4[1.0] JUN 0>0.8[1.0]
B6 BOS-SEA MAY 0>1.9[2] JUN 0>0.7[3]
B6 BOS-SFO JUN 0>1.9[5]
B6 BOS-SJC MAY 0>1.0[0.9] JUN 0>0.4[1.0]
B6 BOS-SJU MAY 0>1.5[1.0] JUN 0>0.6[1.3]
B6 BOS-SLC JUN 0>0.4[1.0]
B6 BOS-SMF MAY 0>0.4[0.6] JUN 0>0.3[0.9]
B6 BOS-SRQ JAN 1.0>1.7[1.0] FEB 1.1>1.5[1.1]
B6 BOS-STI JAN 1.0>1.8[0.9] FEB 1.0>1.4[0.8] JUN 0>0.4[1.1]
B6 BOS-SYR JUN 0>0.4[1.0]
B6 BOS-TPA FEB 4>5[4] MAR 4>5[4] APR 4>5[4] JUN 0>1.6[3]
B6 BQN-FLL MAY 0>0.4[0.5] JUN 0>0.2[0.5]
B6 BQN-JFK MAY 0>0.7[0.5] JUN 0>0.4[0.8]
B6 BQN-MCO JAN 0.5>0.8[0.5] MAY 0>0.8[1.0] JUN 0>0.4[1.0]
B6 BTV-JFK JUN 0>1.2[3]
B6 BUF-FLL JUN 0>0.4[1.0]
B6 BUF-JFK JUN 0>2[6]
B6 BUF-LAX JUN 0>0.4[1.0]
B6 BUF-MCO JUN 0>0.4[1.0]
B6 BUR-JFK MAY 0>1.9[1.0] JUN 0>0.7[1.0]
B6 BWI-FLL JAN 1.2>0.5[2] FEB 1.5>0[2] MAR 2>0[2] APR 2>0[2]
B6 BWI-MCO JAN 0.7>0.2[1.0] FEB 0.9>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
B6 CHS-DCA MAY 0>2[3] JUN 0>0.8[3]
B6 CHS-FLL JUN 0>0.4[1.0]
B6 CHS-JFK JUN 0>1.3[3]
B6 CLE-FLL JUN 0>0.4[1.0]
B6 CLT-JFK JUN 0>0.8[2]
B6 CMW-FLL JUN 0>0.4[1.0]
B6 CTG-FLL JUN 0>0.4[1.0]
B6 CTG-JFK MAY 0>0.6[0.4] JUN 0>0.2[0.5]
B6 CUN-FLL MAY 0>1.0[1.3] JUN 0>0.4[2]
B6 CUN-JFK FEB 2.0>1.5[2] MAY 0>3[2] JUN 0>1.1[2]
B6 CUN-MCO MAY 0>1.0[1.3] JUN 0>0.4[1.2]
B6 CUR-JFK MAY 0>0.3[0.4]
B6 DAB-JFK JAN 1.0>0.2[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
B6 DCA-FLL JUN 0>2[5]
B6 DCA-JAX JUN 0>0.8[2]
B6 DCA-MCO JUN 0>1.4[4]
B6 DCA-PBI JUN 0>0.4[1.0]
B6 DCA-RSW MAY 0>2[1.0] JUN 0>0.8[1.0]
B6 DCA-SJU JUN 0>0.2[0.5]
B6 DEN-JFK MAY 0>1.9[1.0] JUN 0>0.7[1.5]
B6 DTW-FLL JAN 1.0>0.2[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
B6 EWR-FLL MAY 0>3[4] JUN 0>1.1[4]
B6 EWR-MCO MAY 0>5[6] JUN 0>1.8[6]
B6 EWR-PBI MAY 0>2[3] JUN 0>0.8[3]
B6 EWR-RSW MAY 0>2[3] JUN 0>0.8[2]
B6 EWR-SDQ JUN 0>0.4[1.0]
B6 EWR-SJU JUN 0>0.4[1.0]
B6 EWR-STI JUN 0>0.4[1.0]
B6 EWR-TPA JUN 0>0.8[2]
B6 FLL-GCM MAY 0>1.0[0] JUN 0>0.4[0]
B6 FLL-HAV MAY 0>3[1.9] JUN 0>1.1[1.8]
B6 FLL-HOG JUN 0>0.4[1.0]
B6 FLL-HPN MAY 0>1.9[2] JUN 0>0.7[2]
B6 FLL-JAX JUN 0>1.2[3]
B6 FLL-JFK JUN 0>3[6]
B6 FLL-KIN JUN 0>0.8[3]
B6 FLL-LAS JUN 0>0.4[1.0]
B6 FLL-LAX MAY 0>3[2] JUN 0>1.2[2]
B6 FLL-LGA JUN 0>1.9[5]
B6 FLL-LGB JAN 1.0>0.2[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
B6 FLL-LIM JUN 0>0.4[1.0]
B6 FLL-MBJ MAY 0>1.0[1.3] JUN 0>0.4[2]
B6 FLL-MDE JUN 0>0.4[1.0]
B6 FLL-MEX JUN 0>0.8[2]
B6 FLL-MSY JUN 0>0.4[1.0]
B6 FLL-NAS JUN 0>1.8[3]
B6 FLL-ORD JUN 0>0.4[1.0]
B6 FLL-ORH JUN 0>0.4[1.0]
B6 FLL-PAP JUN 0>0.8[3]
B6 FLL-PHL MAY 0>1.0[2] JUN 0>0.4[1.4]
B6 FLL-PHX FEB 0>0.5[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>0.4[0]
B6 FLL-PIT JAN 1.0>0.2[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
B6 FLL-PLS JUN 0>0.4[1.0]
B6 FLL-POS JUN 0>0.4[1.0]
B6 FLL-PUJ MAY 0>1.4[1.0] JUN 0>0.8[1.0]
B6 FLL-PVD JUN 0>0.4[1.0]
B6 FLL-RDU JUN 0>0.8[2]
B6 FLL-RIC JUN 0>0.8[2]
B6 FLL-SAN MAY 0>0.6[1.0] JUN 0>0.2[1.0]
B6 FLL-SDQ JAN 1.5>2[1.3] FEB 1.0>1.5[1.0] MAY 0>2[1.0] JUN 0>0.8[1.2]
B6 FLL-SFO JUN 0>0.8[2]
B6 FLL-SJO JUN 0>0.4[1.0]
B6 FLL-SJU JUN 0>1.0[3]
B6 FLL-SLC JUN 0>0.4[1.0]
B6 FLL-SNU JUN 0>0.4[1.0]
B6 FLL-STI MAY 0>1.0[0] JUN 0>0.4[0.6]
B6 FLL-SWF JUN 0>0.4[1.0]
B6 FLL-SXM FEB 0>0.5[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>0.4[0]
B6 FLL-UIO JUN 0>0.4[1.0]
B6 GCM-JFK JUN 0>0.3[0.7]
B6 GND-JFK JUN 0>0.3[0.9]
B6 HAV-JFK JUN 0>0.4[1.0]
B6 HAV-MCO JUN 0>0.4[1.0]
B6 HOU-JFK JUN 0>0.4[1.0]
B6 HPN-MCO JUN 0>1.2[4]
B6 HPN-PBI FEB 4>5[4] MAR 4>5[4] APR 4>5[4] JUN 0>1.2[3]
B6 HPN-RSW JUN 0>0.4[1.0]
B6 HPN-TPA JUN 0>0.4[1.0]
B6 IAD-JFK JAN 3>0.5[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3]
B6 JAX-JFK JUN 0>1.2[3]
B6 JFK-KIN MAY 0>3[2] JUN 0>1.2[3]
B6 JFK-LAS JUN 0>1.5[4]
B6 JFK-LAX MAY 0>11[10] JUN 0>4[9]
B6 JFK-LGB MAY 0>1.9[2] JUN 0>0.7[2]
B6 JFK-MBJ MAY 0>1.0[1.3] JUN 0>0.4[1.7]
B6 JFK-MCO MAY 0>8[7] JUN 0>3[7]
B6 JFK-MEX MAY 0>1.0[0] JUN 0>0.4[0]
B6 JFK-MSY MAY 0>4[3] JUN 0>1.4[2]
B6 JFK-NAS FEB 1.5>2[1.5] MAR 2>3[2] APR 2>3[2] MAY 0>1.7[1.3] JUN 0>0.7[1.6]
B6 JFK-OAK MAY 0>0.7[0.9] JUN 0>0.2[1.0]
B6 JFK-ONT MAY 0>1.0[0] JUN 0>0.4[0]
B6 JFK-ORD MAY 0>2[4] JUN 0>0.8[3]
B6 JFK-ORH JUN 0>0.4[1.0]
B6 JFK-PAP MAY 0>2[1.0] JUN 0>0.8[1.6]
B6 JFK-PBI JUN 0>1.6[3]
B6 JFK-PDX JUN 0>0.4[1.0]
B6 JFK-PHX JUN 0>0.4[1.0]
B6 JFK-PLS MAY 0>0.9[1.3] JUN 0>0.3[1.1]
B6 JFK-POP JUN 0>0.4[1.0]
B6 JFK-POS JUN 0>0.4[1.0]
B6 JFK-PSE MAY 0>0.3[0.5]
B6 JFK-PSP MAY 0>0.5[0.0]
B6 JFK-PUJ MAY 0>3[2] JUN 0>0.8[2]
B6 JFK-PWM JAN 3>0.7[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3]
B6 JFK-RDU MAY 0>2[3] JUN 0>0.8[3]
B6 JFK-RNO MAY 0>0.6[0.7] JUN 0>0.2[0.9]
B6 JFK-ROC MAY 0>2[3] JUN 0>0.8[3]
B6 JFK-RSW JUN 0>0.8[2]
B6 JFK-SAN MAY 0>1.9[2] JUN 0>0.7[2]
B6 JFK-SAV JUN 0>0.8[2]
B6 JFK-SDQ MAY 0>5[4] JUN 0>2[5]
B6 JFK-SEA MAY 0>1.9[2.0] JUN 0>0.7[1.9]
B6 JFK-SFO JUN 0>2[6]
B6 JFK-SJC JUN 0>0.4[1.0]
B6 JFK-SJU MAY 0>3[2] JUN 0>1.0[3]
B6 JFK-SLC MAY 0>2[1.0] JUN 0>0.8[1.0]
B6 JFK-SMF JUN 0>0.4[1.0]
B6 JFK-SRQ JUN 0>0.4[1.0]
B6 JFK-STI MAY 0>6[4] JUN 0>2[5]
B6 JFK-SXM MAY 0>1.1[1.0] JUN 0>0.5[1.0]
B6 JFK-SYR JUN 0>0.8[2]
B6 JFK-TPA JAN 2>3[3] FEB 3>4[4] MAR 4>5[4] APR 4>5[4] JUN 0>1.2[3]
B6 JFK-UVF MAY 0>1.1[1.0] JUN 0>0.5[1.0]
B6 LAS-LGB MAY 0>3[6] JUN 0>1.2[5]
B6 LAX-MCO JUN 0>0.4[1.0]
B6 LGA-MCO JUN 0>1.6[4]
B6 LGA-PBI JUN 0>1.2[3]
B6 LGB-OAK MAY 0>2[4] JUN 0>0.8[4]
B6 LGB-PDX MAY 0>1.0[2] JUN 0>0.4[2]
B6 LGB-RNO JUN 0>0.4[1.0]
B6 LGB-SEA MAY 0>1.0[2.0] JUN 0>0.4[2]
B6 LGB-SFO MAY 0>2[4] JUN 0>0.8[5]
B6 LGB-SJC MAY 0>2[4] JUN 0>0.8[4]
B6 LGB-SLC MAY 0>3[4] JUN 0>1.2[3]
B6 LGB-SMF MAY 0>2[3] JUN 0>0.8[2]
B6 MBJ-MCO JUN 0>0.4[1.0]
B6 MCO-MEX JUN 0>0.8[2]
B6 MCO-NAS MAY 0>0.7[0.8] JUN 0>0.3[1.0]
B6 MCO-ORH JUN 0>0.4[1.0]
B6 MCO-PAP MAY 0>0.7[1.0] JUN 0>0.3[1.0]
B6 MCO-PSE MAY 0>1.0[0.5] JUN 0>0.4[0.8]
B6 MCO-PVD MAY 0>1.0[2] JUN 0>0.4[2]
B6 MCO-RIC JUN 0>0.8[2]
B6 MCO-SDQ JUN 0>0.4[1.0]
B6 MCO-SJO JUN 0>0.4[1.0]
B6 MCO-SJU MAY 0>2[3] JUN 0>0.9[3]
B6 MCO-SLC JUN 0>0.4[1.0]
B6 MCO-SWF JUN 0>0.4[1.0]
B6 MCO-SYR JUN 0>0.4[1.0]
B6 PBI-PVD FEB 0>0.5[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>0.4[0]
B6 SJU-TPA MAY 0>1.0[0.5] JUN 0>0.4[1.0]
*BA BNA-LHR MAY 0.7>1.0[0.6] JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7]
DL ATL-LAX JUL 13>14[13]
DL ATL-SFO JUN 9>8[7]
DL BOS-PBI APR 1.0>0.7[1.0]
DL BOS-RSW APR 1.1>0.8[0.5]
DL JAC-SLC MAY 2>3[2]
DL LAX-OGG JUN 2>3[3] JUL 2>3[3]
DL LGA-OMA MAY 1.9>3[1.7] JUN 1.8>3[1.8] JUL 1.8>3[1.7]
F9 MCO-ORD MAR 1.0>1.3[1.0] APR 1.0>1.3[1.0]
FI KEF-PDX JUL 1.7>0.9[0.8]
HU PEK-SEA DEC 0.8>0.6[0.8]
I4 JNU-KLW NOV 0.5>1.0[0] DEC 0.5>1.0[0] JAN 0.5>1.0[0] FEB 0.5>1.0[0] MAR 0.5>1.0[0] APR 0.5>1.0[0] MAY 0.5>1.0[0] JUN 0.5>1.0[0.5] JUL 0.5>1.0[0.5]
I4 JNU-KTN NOV 1.5>0.5[0] DEC 1.5>0.5[0] JAN 1.5>0.5[0] FEB 1.5>0.5[0] MAR 1.5>0.5[0] APR 1.5>0.5[0] MAY 1.5>0.5[0] JUN 1.5>0.5[1.5] JUL 1.5>0.5[1.5]
I4 JNU-PSG NOV 0.5>1.0[0] DEC 0.5>1.0[0] JAN 0.5>1.0[0] FEB 0.5>1.0[0] MAR 0.5>1.0[0] APR 0.5>1.0[0] MAY 0.5>1.0[0] JUN 0.5>1.0[0.5] JUL 0.5>1.0[0.5]
KQ JFK-NBO NOV 1.0>0.7[0]
KX GCM-JFK JAN 0.7>1.0[0.7] FEB 0.7>1.0[0.7]
LY EWR-TLV APR 0.8>1.4[1.1]
NK FLL-IAG JAN 1.0>0.7[1.0]
NK FLL-PBG JAN 1.0>0.7[1.0]
SE CDG-MIA JUL 0.7>0.4[0.4]
*UA ABQ-LAX MAR 0.8>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.8] JUL 1.0>0[2]
*UA ACV-DEN JUN 0>0.8[0] JUL 0>1.0[0]
*UA ANC-EWR JUN 0.1>0.4[0.1] JUL 0.1>1.0[0.1]
*UA AVL-EWR FEB 0.9>0.4[0.9] MAR 1.0>0[1.0] APR 1.0>0[1.1] MAY 1.0>0[1.0]
*UA AVL-IAD FEB 0>1.1[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
UA BZN-IAH JUL 0.3>1.0[0.3]
UA BZN-LAX JUL 1.3>2[1.3]
*UA CHS-DEN JUN 0>0.8[0] JUL 0>1.0[0]
*UA CMH-SFO JUN 0>0.8[0] JUL 0>1.0[0]
*UA CRW-IAD JAN 1.7>0.2[1.9] FEB 1.9>0[1.9] MAR 2>0[2] APR 2>0[2] MAY 2>0[2] JUN 2>0[1.9] JUL 2>0[1.7]
UA CRW-ORD APR 1.9>3[1.6] MAY 1.9>3[1.8] JUN 1.8>3[2.0] JUL 1.9>3[2.0]
UA DAY-EWR JAN 1.9>1.2[1.9] FEB 1.4>1.0[1.9] MAR 1.8>1.0[2.0] APR 2>1.0[2.0] MAY 2>1.0[1.8] JUN 2>1.0[1.8] JUL 2>1.0[1.8]
**UA DFW-LAX APR 3>0[3] MAY 3>0[3] JUN 3>0[3] JUL 3>0[3]
*UA ELM-EWR APR 2>0[1.5] MAY 2>0[2] JUN 2>0[2] JUL 2>0[2]
*UA ELM-IAD APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
*UA EUG-LAX APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
*UA EWR-HAM MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
*UA EWR-LEX FEB 0.9>0.4[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
UA EWR-MCI APR 3>4[3] MAY 3>4[3] JUN 3>4[3] JUL 3>4[3]
*UA EWR-MHT MAR 2>3[3] APR 2>0[3] MAY 2>0[3] JUN 2>0[2] JUL 2>0[3]
UA EWR-OMA APR 1.9>3[1.9] MAY 1.9>3[2] JUN 1.8>3[1.9] JUL 1.9>3[1.9]
*UA EWR-PNS JUN 0>0.8[0] JUL 0>1.0[0]
UA EWR-RIC APR 5>6[5] MAY 5>6[5] JUN 5>6[6] JUL 5>6[6]
*UA EWR-SBN APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0]
UA EWR-STL APR 5>6[5] MAY 5>6[5] JUN 4>5[5] JUL 5>6[5]
UA EWR-TYS MAR 1.6>0.9[1.9] APR 1.9>0.9[2.0] MAY 1.9>0.9[2] JUN 1.8>0.8[1.8] JUL 1.9>0.9[1.7]
UA FAY-IAD JAN 1.3>1.7[2.0]
*UA HHH-IAD APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
*UA HHH-ORD APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0]
*UA IAD-LEX FEB 0>1.1[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0]
*UA IAD-MHT APR 0>3[0] MAY 0>3[0] JUN 0>3[0] JUL 0>3[0]
*UA IAD-PHL JAN 4>0.8[4] FEB 4>0[4] MAR 4>0[4] APR 4>0[4] MAY 4>0[4] JUN 4>0[4] JUL 4>0[4]
UA IAH-RNO FEB 0.3>0.7[0.6]
*UA LAX-MSN APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
*UA LAX-PSC APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0]
*UA LAX-SUN JUN 0>0.4[0] JUL 0>1.0[0]
UA RDD-SFO MAR 4>3[3] APR 4>3[3] MAY 4>3[3]
WN BUR-SJC FEB 8>9[8] MAY 8>9[8]
WN ELP-SAN JAN 0.1>0.9[0] FEB 0.1>1.1[0] MAR 0.2>1.2[0.1] APR 0.1>1.1[0.2] MAY 0.1>1.1[0.1] JUN 0.0>0.3[0.1]
WN LAX-SJC FEB 10>11[10]
WN RNO-SJC APR 1.7>2[1.0] MAY 1.7>2[1.0]
WN SAN-SJC JAN 11>12[11] FEB 11>12[11] MAR 11>12[11] APR 11>12[11] MAY 11>12[11]
WN SAN-SMF JAN 11>12[11] FEB 10>12[10] MAR 10>11[10]
WW EWR-KEF MAY 1.0>1.8[1.1] JUN 1.0>2[1.8] JUL 1.0>2[1.8]
WW KEF-MCO APR 0>0.4[0]
WW KEF-SFO MAY 0.1>0.7[0.8] JUN 0>0.7[1.0] JUL 0>0.7[1.0]
WW KEF-STL JAN 0.4>0.1[0] FEB 0.4>0[0] MAR 0.4>0[0]
X4 GST-JNU NOV 0>2[0] DEC 0.1>1.9[3] JAN 1.9>0[3] FEB 2>0[3] MAR 2>0[3] APR 3>0[4] MAY 0.3>0[5]
SANFan
Re: OAG Changes: HUGE UA Change, Numerous Routes Added and Dropped
Sun Oct 14, 2018 10:46 pm
My Sunday is now complete! Thank you Enilria.
Now to see what's new...
bb
SESGDL
Sun Oct 14, 2018 10:47 pm
Wow, I’m shocked that UA is dropping DFW-LAX.
Jeremy
SgtBarone
Sun Oct 14, 2018 10:52 pm
Congrats to CMH for landing daily service to SFO!
AGP ATL BCN BNA BOS CLE CLT DCA DEN FLG FLL FRA IAD IAH JAX LAS LAX LGB MAD MCI MDW MKE MUC PHX RDU RSW SEA SJU SLC SNA TPA
PlanesNTrains
Sun Oct 14, 2018 10:54 pm
The title is different this time - almost missed it.
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
Runway28L
Yet another huge blow for MHT. :(
mandargb
Sun Oct 14, 2018 10:57 pm
Good to see B6 building up at SJC, OAK and SFO.
PlanesNTrains
Sun Oct 14, 2018 11:01 pm
I don’t think B6 is building up, I think they are actually slashing service in some of these cities. It’s just that now the schedule is being extended or otherwise finalized and so it shows (for example) 0>2(4). That’s a decrease from 4 to 2 daily in the yoy comparison.
-Dave
32andBelow
Sun Oct 14, 2018 11:03 pm
Wow increasing ANC-EWR next summer. Route just do well. Long flight on a 757
sagechan
Sun Oct 14, 2018 11:05 pm
CRW - Washington, DC is taking a hit, AA dropped 1 of 2 in Feb to DCA and now UA discontinuing service to IAD enterily.
717, 733, 734, 738, 739, 744, 752, 763, 772, 77W, 789, A319, A320, A321, A332, A333, A359, MD88, CRJ, CR7, CR9, DH1, DH2, DH3, S340, ER4, E170, E175, E190/CO, NW, US, AC, NH, AA, UA, DL, WN, WS, SK, VY, LA, QF, AR, AV, MH, KA, AS
hOMSaR
Sun Oct 14, 2018 11:06 pm
The flights are being shifted to IAD. As with many of the other regional flights moving to IAD, UA has decided they’d rather focus the EWR capacity on O&D, and run connections through IAD, since they have more room to do stuff at the latter.
I was raised by a cup of coffee.
enilria
Re: OAG Changes 10/14/2018: HUGE UA Change, Numerous Routes Added and Dropped
Sun Oct 14, 2018 11:08 pm
bb
Yes, I was getting worried it wouldn't update today!
A lot!
Jeremy
Yeah, that was a big surprise.
Thanks. Originally I was trying to stuff alll the UA route changes into the title, but I gave up and didn't add that back. FIXED.
Funny it goes from +1 to 0
Yup
SANFan
Sun Oct 14, 2018 11:09 pm
Interesting... looks like WN found an extra 737 sitting around SAN not doing anything! I knew about SAN-ELP going daily but was wondering where the airplane for the flight had come from. Looks like a day of flying to the extended Bay area and back is the answer! Nice!
bb
jetmatt777
Sun Oct 14, 2018 11:12 pm
We were about to call the authorities for a wellness check on you!
Thanks for the update as always.
I’m very surprised UA is pulling out of LAX-DFW.
AVLAirlineFreq
Sun Oct 14, 2018 11:16 pm
Wow, really surprised about this. CO/UA has flown AVL-EWR for almost 20 years, and it went mainline nearly 2 years ago. I'm guessing G4 will look at making AVL-EWR daily.
dbo861
Sun Oct 14, 2018 11:19 pm
bb
WN must realize Hawaii isn't going to happen as soon as they'd hoped and this is capacity they set aside for Hawaii that can be put to use elsewhere while they wait for FAA approval.
adamh8297
But the biggest blow is for HAM who appears to have just lost their only Transatlantic link.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
Chugach
Sun Oct 14, 2018 11:22 pm
Throwback to the CO days. Good to see.
SATexan
Sun Oct 14, 2018 11:30 pm
Filing error or is B6 really drawing down in AUS??
lowfareair
Sun Oct 14, 2018 11:34 pm
Ugh, with IAD-PHL ending, it's becoming even harder now for TATL flying out of PHL on Star Alliance. I think it's down to LH to FRA or AC via YUL/YYZ.
jb1087xna
Sun Oct 14, 2018 11:35 pm
Thanks as always!
Enilria noted to ignore June for B6 because of incomplete data. If that's the case, I wouldn't read into it yet.
spongenotbob
Sun Oct 14, 2018 11:39 pm
Hilton Head, wow - 3 new UA flights a day on certain days! That is a big surprise.
Thanks Enilria... finally got my Sunday reading :smile:
RJNUT
the results of the HHH runway extension at work with the UA adds to IAD and ORD! Will DL add ATL or LGA this coming summer?
travaz
Sun Oct 14, 2018 11:46 pm
Interesting add for B6 non stop PHX FLL. It's a red eye turn. That makes WN and B6 the only carriers with NS to FLL from PHX. The B6 flight leaves at 11:59 PM and the WN flight leaves at 11:50 AM. I wonder if B6 sees an opportunity here? They have only had the BOS and JFK flight forever. Why this add?
Edit for clarity
SANFan
Sun Oct 14, 2018 11:47 pm
bb
OTOH, I was thinking that, noting that these are new flights added between SAN and SJC & SMF in the dead of winter, as well as remembering that SAN, SJC & SMF are supposedly 3 of the 4 Hawaiian gateways, perhaps these new adds in those markets somehow will allow the etops airplanes to be moved around among the gateways. Since all aircraft flying between SAN, SJC and SMF are already 'spoken for' (read: sked with turns already) maybe WN needs some free-standing flights to use to move, say, an etops arrival from HNL at SJC down to SAN to make a return flight to OGG.
I don't know if anyone can follow my reasoning but it seems possible to me... That subfleet of etops 738s is going to have to have the ability to be fed into the network at some point for mx. So I can see that maybe WN wanted some flexibility to move them around on the coast a bit between the gateways. Just a theory...
bb
Bigant0408
Sun Oct 14, 2018 11:54 pm
Going to Newark isn’t in the cards for Star Alliance service? I am shocked this service ended but guess LF weren’t great
The man who sleeps on the floor doesn’t fall out of bed
SANFan
Sun Oct 14, 2018 11:57 pm
Another thought regarding all those intra-CA adds by WN. We also need to remember that WN, like AS, has to be holding back airplanes for the expected PAE start-up, possibly in early '19. Maybe something has happened to those plans and WN now finds itself with a couple of planes available... and is pressing them into service.
WN has both Hawaii and Everett (PAE) routes hanging over their corporate head, waiting on the FAA for approval. It's got to be driving the network planners nuts to want to save the planes for all these new routes once they get approved, versus getting them in service NOW and generating revenue for the carrier...
bb
jplatts
Mon Oct 15, 2018 12:01 am
Jeremy
AA has hubs at both DFW and LAX, and AA is also the dominant carrier at both DFW and LAX. LAX also already has nonstop service to Dallas on DL, WN, AS, and NK in addition to AA and UA.
WN also has focus cities at both DAL and LAX, with DAL also being the home base for WN and LAX being the largest WN West Coast focus city.
boscmh
Mon Oct 15, 2018 12:06 am
Fantastic to see UA finally jump onto CMH-SFO!
lowfareair
EWR is a bit away from PHL, although people do use it when the price/timing make sense vs PHL for flights. They have Amtrak via 30th Street, but it isn't the best for making connections and the UA codeshare know the trains don't work for other Star carriers.
flyguy84
Mon Oct 15, 2018 12:16 am
No surprise here really... United continues to move connecting traffic over IAD instead of EWR.
SFO
jfklganyc
Mon Oct 15, 2018 12:25 am
Re FLL PHX
I think this is an attempt to round out their western stations.
You are starting to see a lot of 1 daily FLL Western flying. That’s a good thing...if it works
enilria
Mon Oct 15, 2018 12:29 am
Nope. It's just that the time the update is available to me has become more random.
bb
Probably
jb1087xna wrote:
Thanks as always!
Yup. June is a partial month. You'd need to divide by how many ever days they filed to correct it. Too much of a pain for me.
Yeah one of the Easter Eggs in this mega-change.
bb
Yeah, could also be that
Big boom for IAD nobody expected
capejet
Mon Oct 15, 2018 12:30 am
UA is adding 2 nonstops LAX-EUG, AA flies 2 a day already so that will double the service. Is the market that big?
Rdh3e
Mon Oct 15, 2018 12:43 am
Doing a dummy booking it appears there is also weekeend EWR service. That would be 4 additional flights per day on Saturday.
enilria
Mon Oct 15, 2018 12:47 am
Nope
klm617
Interesting that WOW Air has now canceled STL service. From March on there are no flights loaded from KEF to CLE, CVG, DFW and STL.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
DeltaRules
Mon Oct 15, 2018 12:53 am
FINALLY!
It totally blew my mind that they'd added everything in the region, including routes with DL competition, but no CMH. Better late than never, though.
A310/319/320/321/333, ARJ, BN2, B717/722/73S/733/734/735/73G/738/739/744/757/753/767/763/764/777, CR1/2/7/9, DH6, 328, EM2/ERJ/E70/E75/E90, F28/100, J31, L10/12/15, DC9/D93/D94/D95/M80/M88/M90/D10, SF3, SST
STT757
EWR-PNS is an old CO route from the '80s and '90s, it operated with a stop at JAX.
Bigant0408
Mon Oct 15, 2018 12:56 am
Oh yea I live in Philly so I’m aware about the distance and all. I just wasn’t sure if you were a loyal FF for Star alliance figure Newark would make it easier in sense. Only good thing I can say is at least LH increase capacity starting end of March 19 with 747 being used. I agreed overall traveling to Newark and JFK is quite a distance and costly
tphuang
really interesting, a lot of shifting to IAD going on there. I'm not convinced this will necessarily work out beneficial for UA.
FlyPNS1
Mon Oct 15, 2018 12:57 am
With UA cutting many of the thinner routes to EWR and shifting them to IAD, I was surprised to see EWR-PNS get added. I guess UA would rather have the New York -PNS market to themselves versus flying IAD-PNS where they'd be competing against AA flying DCA-PNS. At least UA was smart and is using a E170 for EWR-PNS, not a ERJ.
I will say IAD-AVL should have been added a long time ago. Lots of people in DC area go to AVL, so the lack of service there was always odd. Slightly surprised they want to launch IAD-HHH, when they haven't even historically done IAD-MYR which is a bigger market.
Chasensfo
Mon Oct 15, 2018 1:04 am
Same time lat year jetBlue had 2-4x daily on JFK/BOS/SFO/LGB from SFO, this is actually a sharp decline for jetBlue. They had built up a nice little SFO operation, busy at times. It was actually common to have 4-5 jetBlue aircraft here in the summer.
MIflyer12
Mon Oct 15, 2018 1:18 am
bb
Yeh, but it's not a lot of aircraft in the context of a fleet of 743.
cheapgreek
Mon Oct 15, 2018 1:33 am
I'm hoping for UA to begin HVN-IAD flights off its 5600 foot runway.
mikeyp224
What's going on with JetBlue? They are dropping most of the routes to San Diego down to less than daily in June? This can't be right, can it?
jasoncrh
Mon Oct 15, 2018 1:34 am
Clearly you didn't read Enilria's disclaimer. He said that B6 hadn't loaded all their June flights yet, so the numbers for June are not accurate.
The way his template works is that it loads all the flights for the month and divides by the days of the month. They haven't loaded all the flights, but are still dividing by the same number of days, so it looks like there are way fewer flights this coming June than there were the past June.
There is no massive decrease.
Chasensfo
Mon Oct 15, 2018 1:38 am
Ah OK, that makes a lot more sense. There is so much info there I usually just read the flight schedule, not the disclaimer as it usually doesn't vary much.
TYSflyer
Mon Oct 15, 2018 1:54 am
Thanks Enilria. I would like to know how many times I refreshed throughout the day patiently waiting haha! The most surprising of the UA adds to me is MSN-LAX. That is now 2 links to the west coast from UA there. MSN has been on a tear there lately with new service!
TYSflyer
Mon Oct 15, 2018 2:04 am
In my opinion this is a win for AVL. The lack of a direct D.C. connection was a huge hole at AVL. They also appear to be focusing on IAD to the south as evidenced by recently changing CHA from EWR to IAD and the HHH add among others. The seat count will be about the same just to IAD and G4 might be better able to grow the AVL-EWR not having the competition. Curious what your thoughts are? I’m sure it stings a little losing the mainline flight though. Btw UA also dropped the mainline TYS-EWR. I guess they are no longer fearful of G4.
