enilria
OAG Changes 10/28/2018:F9 Drops GSP-LAS/MCO,SAT-CVG/RDU,PIT-MCO/SAN,AUS-SJC,BNA-TTN,MCI-RDU;UA Adds FAI-SFO
Sun Oct 28, 2018 1:31 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*". This comparison is versus the corrected version posted downthread last week.
NOTE: Back on schedule today. Hopefully a good sign for the future!
4B DFW-VCT NOV 0>0.5[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
4B IAH-VCT NOV 0>1.1[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
4B MCE-OAK NOV 0>1.1[1.7] DEC 0>1.2[1.7]
4O GDL-LAS DEC 0.6>1.0[0.7]
7H ANC-MCG JUL 0.0>0.5[0]
7H BET-VAK JUL 1.3>0.9[0.9]
7H EEK-KWN JUL 1.8>1.4[1.3]
7H FAI-GAL JUL 1.9>2[2]
7H FAI-RBY JUL 1.1>0.6[0.6]
7H GAL-KAL JUL 0.7>1.0[1.0]
7H GAL-NUL JUL 0.7>1.0[1.0]
7H GAL-RBY JUL 1.1>0.6[0.6]
7H HPB-SCM JUL 1.3>0.9[0.9]
7H KAL-NUL JUL 0.7>1.0[1.0]
7H KTS-OME JUL 0.0>0.9[0]
7H KTS-TLA JUL 0.9>0[0.9]
7H KWN-TOG JUL 0.8>0[0]
7H OME-TLA JUL 0.9>0[0.9]
A7 CEN-CSL NOV 0.4>0[0]
A7 CSL-CSL NOV 0.2>0[0] DEC 0.2>0[0]
A7 CSL-CUL NOV 0.4>0[0] DEC 0.4>0[0]
A7 CSL-HMO NOV 0.6>0[0] DEC 0.5>0[0]
A7 CSL-LAP NOV 0.6>0[0]
A7 CSL-LMM NOV 0.7>0[0]
A7 CSL-MZT NOV 0.6>0[0] DEC 0.4>0[0]
A7 CSL-PVR NOV 0.4>0[0] DEC 0.4>0[0]
AA ABQ-ORD JAN 1.5>2[1.9] FEB 1.7>2[1.9]
AA AUS-ORD JAN 3>4[3]
AA DFW-EGE APR 1.0>0.1[1.1] MAY 1.0>0[1.0]
AA DFW-FAT APR 1.9>2[1.9] MAY 1.9>2[2] JUN 1.8>2[3] JUL 1.9>2[3]
AA DFW-JAC JUN 1.0>1.8[1.8] JUL 1.0>2[2]
AA DFW-LAX MAY 13>15[13] JUN 13>15[13] JUL 13>15[13]
AA DFW-RNO APR 2>3[2]
AA DFW-SAF APR 3>4[3] MAY 3>4[3] JUN 3>4[3] JUL 3>4[3]
AA DFW-SHV JUN 5>6[5] JUL 5>6[5]
AA KOA-LAX APR 1.5>1.1[1.6]
AA KOA-PHX APR 1.0>0.6[0.6]
AA LAX-LIH APR 1.6>1.2[1.6]
AA MSP-ORD JAN 6>7[6]
AA ORD-TPA JAN 3>4[3]
But net zero...
*AC RDU-YUL JUN 0>0.9[0] JUL 0>1.0[0]
AC RDU-YYZ MAY 4>3[4] JUN 4>3[4] JUL 4>3[4]
AD CNF-MCO FEB 0.4>0.2[0.5]
AD MCO-REC FEB 0.4>0.2[0.6]
*AI BOM-JFK DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.5[0] APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0] JUL 0>0.4[0]
AM IAD-MEX DEC 0.9>0.1[1.0] JAN 0.2>0[0.8]
AM LAS-MEX APR 1.0>1.3[1.8] MAY 1.0>1.3[1.7] JUN 1.0>1.3[2] JUL 1.0>1.3[2]
AM MCO-MEX APR 1.0>1.3[2.0] MAY 1.0>1.3[1.8] JUN 1.0>1.3[2] JUL 1.0>1.3[2]
AS PHX-SFO MAR 1.7>1.3[2.0]
AS SAN-SJC MAR 2>4[3]
AS SEA-STL MAR 1.0>1.4[1.7] APR 1.0>2[2] MAY 1.0>2[1.9] JUN 1.6>2[1.7]
B6 BOS-PSP MAR 0.3>0.6[0] APR 0.3>0.6[0]
*B6 FLL-GYE MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>0.4[0]
DL ATL-SEA JUN 9>8[7]
*DL CHS-MSP JUN 0>0.4[0] JUL 0>1.0[0]
*DL CMH-SLC JUN 0>0.5[0] JUL 0>1.0[0]
DL CVG-MCI JUL 1.3>1.0[1.2]
DL DTW-MQT MAR 1.0>1.9[1.8] APR 1.0>1.7[1.9]
*DL DTW-SMF JUN 0>0.5[0] JUL 0>1.0[0]
DL IAD-JFK APR 3>4[3] MAY 3>4[3] JUN 3>4[3] JUL 3>4[3]
That's kinda surprising.
*DL IAD-SEA JUN 1.0>1.4[0.8] JUL 1.0>2.0[1.0]
DL JAC-SLC JUN 3>4[3] JUL 3>4[3]
DL MCO-SEA JUN 1.0>1.2[1.0]
It appears F9 dropped a bunch of routes...
F9 ATL-DEN DEC 1.3>1.0[1.3]
F9 AUS-CMH JAN 0.3>0.0[0]
F9 AUS-MSY JAN 0.3>0.1[0.4]
F9 AUS-ONT JAN 0.3>0.1[0.4]
F9 AUS-RDU JAN 0.5>0.1[0.4] FEB 0.6>0.3[0.4]
*F9 AUS-SJC JAN 0.3>0.0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0.3]
*F9 BNA-TTN JAN 0.3>0.1[0] FEB 0.3>0[0]
F9 CHS-PHL JAN 0.3>0.1[0]
F9 CLT-PHL JAN 1.0>0.6[0.6]
*F9 CVG-SAT JAN 0.5>0.1[0] FEB 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0.3]
F9 DEN-GEG JAN 0.3>0.0[0]
F9 DEN-MSY DEC 0.9>0.7[1.0]
*F9 GSP-LAS JAN 0.3>0.1[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0]
*F9 GSP-MCO JAN 0.3>0.1[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0]
F9 IAH-RDU JAN 0.3>0.0[0]
F9 ISP-MCO DEC 1.4>1.1[2.0]
F9 LAS-MEM JAN 0.3>0.1[0.6]
F9 LAS-RDU JAN 1.0>0.6[1.0]
*F9 MCI-RDU JAN 0.3>0.1[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0.4]
F9 MCO-MSY JAN 0.7>0.1[1.0] FEB 0.7>0.4[1.0]
*F9 MCO-PIT JAN 0.3>0.0[0.4] FEB 0.3>0[0.4] MAR 0.3>0[0.4] APR 0.3>0[0.1]
F9 MCO-SAN DEC 1.0>0.5[1.0] JAN 1.0>0.4[1.0] FEB 1.0>0.7[1.0]
F9 MSY-SAT JAN 0.4>0.1[0.6] FEB 0.4>0.2[0.6]
F9 ONT-SAT JAN 0.3>0.0[0.6]
*F9 PIT-SAN JAN 0.3>0.0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0]
*F9 RDU-SAT JAN 0.5>0.1[0] FEB 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0.2]
F9 SAN-SAT JAN 0.4>0.1[0.6] FEB 0.4>0.2[0.6]
Temporary seasonal suspension. Appears they also did it last year, so nobody freak out plz.
FI KEF-MSP JAN 0.5>0.1[0.2] FEB 0.6>0[0] MAR 0.7>0.5[0.5]
IB MAD-SFO APR 0>0.3[0.1]
KS AKN-ANC FEB 1.0>1.9[1.0] MAR 1.0>1.9[2] JUN 2>5[5] JUL 2>6[8]
KS AKN-DLG FEB 1.0>0.1[1.0] MAR 1.0>0.1[0]
KS ANC-CDB MAR 0.7>0.4[0.7] APR 0.9>0.4[0.8] MAY 0.9>0.4[0.9] JUN 0.8>0.4[1.1] JUL 0.9>0.4[0.7]
KS ANC-DLG APR 3>2[3] MAY 3>2[3] JUN 3>2[3] JUL 3>2[3]
KS ANC-SDP MAR 0.7>0.4[0.7] APR 0.9>0.4[0.8] MAY 0.9>0.4[0.9] JUN 0.8>0.4[0.9] JUL 0.9>0.4[0.7]
KS CDB-SDP MAR 0.1>0.4[0.1] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0.2]
*LF BKW-CLT DEC 0>1.4[0] JAN 0>1.7[0] FEB 0>1.7[0] MAR 0>1.7[0]
*LF BKW-PKB DEC 0>1.4[0] JAN 0>1.7[0] FEB 0>1.7[0] MAR 0>1.7[0]
The ME3 used to fly everything daily. I think that's slowly coming to an end.
QR DOH-MIA APR 1.0>0.7[1.0] MAY 1.0>0.7[1.0] JUN 1.0>0.7[1.0] JUL 1.0>0.7[1.0]
TJ ACK-HPN MAY 0>1.7[1.8] JUN 0>1.6[1.9] JUL 0>4[5]
TJ ACK-TEB APR 0>0.3[0.4] MAY 0>1.5[1.7] JUN 0>1.5[1.8] JUL 0>4[5]
TJ HPN-MVY JUN 0>1.1[1.2] JUL 0>1.8[2]
TJ MVY-TEB JUL 0>1.3[1.6]
UA ABE-ORD MAR 3>2[2.0]
UA ABQ-ORD MAR 1.8>1.1[1.0]
UA AUS-EWR MAR 3>4[4]
UA AVP-ORD MAR 3>1.9[1.0]
UA BFL-SFO MAR 1.6>1.0[1.0]
UA BNA-EWR MAR 7>5[4]
UA BTV-ORD MAR 3>2[2]
UA BUF-ORD MAR 5>3[3]
UA CAE-ORD MAR 2>3[2]
UA CMH-EWR MAR 7>6[5]
UA CWA-ORD MAR 3>1.9[2]
UA DAY-EWR JAN 1.2>1.9[1.9] FEB 1.0>1.4[1.9]
This was announced a few weeks ago
*UA DEN-FAI JUN 0>0.5[0] JUL 0>0.6[0]
UA DSM-IAH MAR 2>3[2]
UA EWR-EYW MAR 2>3[2]
UA EWR-GRR MAR 4>2[1.9]
UA EWR-MKE MAR 4>2[3]
UA EWR-ORF MAR 6>4[4]
UA EWR-PWM MAR 5>3[4]
UA EWR-RSW MAR 4>6[5]
UA EWR-SLC MAR 1.2>2.0[1.0]
UA EWR-SRQ MAR 2>3[1.0]
UA EWR-YHZ MAR 3>2[2]
UA EWR-YQB MAR 2>3[2]
Don't think this route has ever been flown before
**UA FAI-SFO JUN 0>0.4[0] JUL 0>0.4[0]
UA GRR-IAH MAR 1.2>1.7[1.0]
UA IAD-LAX MAR 8>7[6]
UA IAD-MCI MAR 3>2[1.8]
UA IAD-MDT JAN 3>1.9[4]
UA IAD-MSY MAR 2>3[3]
UA IAD-PVD MAR 4>3[2]
UA IAD-PWM MAR 4>2[1.0]
UA IAD-ROA MAR 3>2[1.9]
UA IAD-SFO MAR 8>7[7]
UA IAD-TYS MAR 4>3[3]
UA IAH-LAS MAR 7>6[6]
UA IAH-LAX MAR 11>10[10]
UA IAH-LBB MAR 3>4[3]
UA IAH-MLU MAR 3>1.9[2.0]
UA IAH-ORF MAR 1.2>1.9[1.0]
UA IAH-PDX MAR 3>2[2.0]
UA IAH-PSP MAR 2>3[2]
UA IAH-RIC MAR 1.8>1.0[1.0]
UA IAH-RNO MAR 0.5>1.0[1.0]
UA IAH-RSW MAR 2>3[2]
UA IAH-SEA MAR 5>4[4]
UA IAH-TUS MAR 3>4[3]
UA IAH-VPS MAR 2>3[3]
UA ILM-ORD MAR 1.8>1.0[0]
UA LAX-ORD MAR 11>9[9]
UA LAX-SBA MAR 4>3[4]
UA MCI-SFO MAR 3>2[3]
UA MCO-ORD MAR 6>8[8]
UA MSY-SFO MAR 1.0>1.7[1.8]
UA OKC-ORD MAR 4>3[2]
UA ORD-PNS MAR 1.2>2.0[1.7]
UA ORD-PSP MAR 1.2>2.0[1.0]
UA ORD-PWM MAR 3>2[1.7]
UA ORD-RSW MAR 2>4[4]
UA ORD-SEA MAR 4>3[3]
UA ORD-SFO MAR 13>10[9]
UA ORD-SGF MAR 3>4[3]
UA ORD-SRQ MAR 1.3>2[2]
UA ORD-TPA MAR 3>4[4]
UA ORD-TVC APR 3>1.9[3] MAY 3>2.0[3] JUN 3>1.9[5] JUL 3>1.9[5]
UA ORD-YVR MAR 1.8>1.0[1.7]
UA ORD-YYZ MAR 6>5[5]
UA PDX-SFO MAR 8>7[7]
UA RDU-SFO MAR 1.2>1.9[1.9]
UA SEA-SFO MAR 9>8[8]
UA SFO-TUS MAR 2>4[4] APR 2>4[4] MAY 2>3[4]
UP BIM-MIA NOV 0.6>0.2[0] DEC 0.6>0[0] APR 0.3>0[0] MAY 0.6>0[0.5] JUN 0.6>0[0.6] JUL 0.5>0[0.5]
*VVC MIA-SMR DEC 0>0.2[0] JAN 0>0.4[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0]
WN AUS-SJC JAN 1.9>2[1.9] FEB 1.8>2[1.8]
WN CHS-MDW JAN 1.8>1.3[1.0]
WN LAS-LGB MAR 0.3>3[0.6]
WN LGB-SMF MAR 2>4[2]
WN MDW-PVD JAN 2>1.5[2]
WN RNO-SAN JAN 2>3[2] FEB 2>3[2]
WN SJU-TPA JAN 0.6>1.0[0.7]
I don't know what to make of XE. This stuff is truly new?
XE BUR-LAS DEC 0>5[3] JAN 0>5[3]
XE BUR-OAK DEC 0>4[0] JAN 0>4[3]
*XE LAS-OAK NOV 0.7>1.3[0] DEC 0>2[0] JAN 0>3[0]
*XE LAS-SNA DEC 0>3[0] JAN 0>3[0]
*XE MMH-SNA DEC 0>0.3[0] JAN 0>0.5[0]
XE OAK-RNO NOV 0.8>0[0]
*XE OAK-SNA DEC 0>0.8[0] JAN 0>0.9[0]
TWAGuy
Re: OAG Changes 10/28/2018:F9 Drops GSP-LAS/MCO,SAT-CVG/RDU,PIT-MCO/SAN,AUS-SJC,BNA-TTN,MCI-RDU;UA Adds FAI-SFO
Sun Oct 28, 2018 1:49 pm
enilria wrote:
But net zero...
Hardly net zero...RDU-YYZ goes from 4 CRJs to 3 E175s so capacity increases 18%. With the new RDU-YUL frequency overall AC capacity at RDU increases 44% year over year...
enilria
Sun Oct 28, 2018 1:55 pm
TWAGuy wrote:
enilria wrote:
But net zero...
On departures it is net zero. This report does not document changes in seats.
TropicalSky
Sun Oct 28, 2018 1:56 pm
So great full for your hard work Enirlia,this week I can enjoy reading it with coffee lol
What's so surprising regarding Delta going 2x on IAD-SEA?
I'm surprised that AM is stopping MEX-IAD....thought they would keep it even if just for political ties
TWAGuy
Sun Oct 28, 2018 2:02 pm
enilria wrote:
TWAGuy wrote:
enilria wrote:
But net zero...
Sorry, couldn't resist :)
lavalampluva
Sun Oct 28, 2018 2:05 pm
XE = JetSuite X
Remind me to send a thank you note to Mr. Boeing.
SteveXC500
Sun Oct 28, 2018 2:06 pm
Icelandair does pull back at MSP, as noted, the difference this year will be a 737 MAX 8 instead of the 752.
enilria
Sun Oct 28, 2018 2:11 pm
IAD transcon is notoriously difficult. For example, B6 just left IAD completely. Also, IAD is a pretty weak market for DL and they are not #1 at DCA either. Plus, SEA while a hub is not a mega-hub and they are not even #1 in the market. PLUS, the Asia connects are circuitous over SEA. So, couple that all together and I find it surprising.
lavalampluva wrote:
XE = JetSuite X
Yeah, but I don't follow them. Those routes that appear to be new I feel like I saw them add before. Have they not a been flown before?
With EI entering the market it is probably healthier for them to be flying the MAX than the 757.
joeblow10
Sun Oct 28, 2018 2:21 pm
Two biased observations b/c they affect my travels:
Looks like AA is pulling out of Vail entirely during the summer. That sucks - they had been running at least once a day thru DFW for the past decade or more. Now it’s UAX via DEN or drive.
Also, continued expansion for destinations out of FAI on UA. But didn’t they announce DEN was going to be daily? Maybe I misread that - but I guess they’ve decided to split service and alternate between DEN/SFO with a daily to ORD
flyboy7974
Sun Oct 28, 2018 2:32 pm
Trying to think back, when did VX/AS start PHXSFO?
pmanni1
Sun Oct 28, 2018 2:41 pm
Glad to see competition from WN has not hurt this route.
simpv
Sun Oct 28, 2018 2:45 pm
Wow, who saw SFO-FAI coming? I assume it would be a seasonal add, in addition to DEN.
PlanesNTrains
Sun Oct 28, 2018 2:46 pm
Perhaps DL IAD-SEA is in anticipation of Amazon opening a second hq in DC?
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
PlanesNTrains
Sun Oct 28, 2018 2:47 pm
I think they flew it last year for spring training.
-Dave
MIflyer12
Sun Oct 28, 2018 3:04 pm
There's not a lot of non-stop capacity on SEA-WAS (looking at 6/3/19):
3x UA SEA-IAD
1x AS SEA-BWI
1x AS SEA-IAD
2x AS SEA-DCA
1x DL SEA-IAD
Maybe there doesn't need to be.
AS doesn't have redeyes in the market - odd, given other eastern markets for AS. DL's sole flight is timed to compete with a UA redeye A320. Maybe the add is a daytime flight?
jplatts
Sun Oct 28, 2018 3:13 pm
3x UA SEA-IAD
1x AS SEA-BWI
1x AS SEA-IAD
2x AS SEA-DCA
1x DL SEA-IAD
In addition to UA, AS, and DL, WN also has seasonal SEA-BWI nonstop service.
717atOGG
Sun Oct 28, 2018 3:17 pm
3x UA SEA-IAD
1x AS SEA-BWI
1x AS SEA-IAD
2x AS SEA-DCA
1x DL SEA-IAD
The add is a daytime flight. It's scheduled as follows:
Leave SEA 9:45 am, arrive IAD 5:45 pm
Leave IAD 6:45 pm, arrive SEA 9:27 pm
And not to nitpick or anything, but NK and WN also seasonally serve SEA-BWI, with WN doing a daytime flight and NK doing a redeye.
A320/321, A332, 712, 73G/8/9ER, 744, 752/3, E145, E175
usairways85
Sun Oct 28, 2018 3:22 pm
3x UA SEA-IAD
1x AS SEA-BWI
1x AS SEA-IAD
2x AS SEA-DCA
1x DL SEA-IAD
With the WN/NK seasonal adds mentioned, ~10x daily is not a lot of capacity on SEA-WAS?
jb1087xna
Sun Oct 28, 2018 3:24 pm
Thanks Enilria!
Yup, daytime flight in both directions.
enilria
Sun Oct 28, 2018 3:45 pm
jb1087xna wrote:
Thanks Enilria!
3x UA SEA-IAD
1x AS SEA-BWI
1x AS SEA-IAD
2x AS SEA-DCA
1x DL SEA-IAD
I haven't run the numbers, but I wouldn't be surprised if there's more transcon service from BWI than IAD if you remove UA from IAD. I know on the surface that seems like an unfair comparison, but IAD is considered the primary transcon airport for WAS in most people's minds so superficially you would think it would be important for all the large airlines to play in the IAD market transcons, but it just hasn't gone that way. JFK-transcon is massively more competitive. DCA is a factor, of course, since LGA doesn't have long-haul.
Rdh3e
Sun Oct 28, 2018 3:46 pm
The AA EGE cuts are only April and May. It's a still bookable nonstop in summer.
yellowtail
Sun Oct 28, 2018 3:58 pm
With consistent sub $700 round trip Y fares to the Indian subcontinent from Miami they are clearly struggling with yields. Probably and attempt to fix that.
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
Rdh3e
Sun Oct 28, 2018 4:05 pm
That is indeed as you noted a totally unfair comparison. The reason your comparison doesn't work is that UA having such a large presence in IAD transcon likely discourages others from flying the routes, for instance it's probably why AS doesn't fly SAN-IAD.
I ran this against the current July 2019 schedule (with July 2018 for WN/NK) for routes over 2,200mi (basically to exclude LAS).
BWI…WN…12
BWI…AS…5
BWI…NK…4
BWI…UA…3
DCA…AS…5
DCA…AA…2
DCA…UA…1
DCA…DL…1
IAD…UA…27
IAD…AS…6
IAD…AA…2
IAD…DL…2
klm617
Sun Oct 28, 2018 4:06 pm
WOW GRR has really been hitting it out of the park lately first AA and now UA adds more to both EWR and IAH.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
EvanWSFO
Sun Oct 28, 2018 4:07 pm
F9 is notorious for abandoning routes. Many of them probably shouldn't have been started. It's not helping then win over pax who are already leery of using them.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
klm617
Sun Oct 28, 2018 4:08 pm
But QR has the benefit of AA feed just like at PHL and they still can't make a go of it.
admanager
Sun Oct 28, 2018 4:09 pm
You've heard the same rumors I have then.
Rdh3e
Sun Oct 28, 2018 4:10 pm
What meaningful feed is there beyond MIA that wouldn't be better connected over PHL?
Just look at this, even TPA is better over PHL than MIA.
http://www.gcmap.com/mapui?P=TPA-DOH,+T ... PA-PHL-DOH
SgtBarone
Sun Oct 28, 2018 4:35 pm
Thanks for your hard work, Enilria. Look forward to this every Sunday.
AGP ATL BCN BNA BOS CLE CLT DCA DEN FLG FLL FRA IAD IAH JAX LAS LAX LGB MAD MCI MCO MDW MKE MUC PHX RDU RSW SEA SJU SLC SNA TPA
jplatts
Sun Oct 28, 2018 4:40 pm
In addition to the discontinuation of F9 CVG-SAT nonstop service, I am also not currently seeing any F9 nonstops to ATL, AUS, DFW, JAX, LAX, MSP, LGA, PHL, RDU, and SJC out of CVG in April 2019, even though F9 has already extended its flight schedule through April 29, 2019.
There is likely going to be more demand for WN service out of CVG in Summer 2019 than was the case in the past with F9 significantly cutting back at CVG in 2019, and I think that WN will probably be announcing a few more nonstop routes out of CVG in the 11/15/18 schedule extension with demand for WN service out of CVG expected to be greater than it was in the past.
SANFan
Sun Oct 28, 2018 4:41 pm
This is yet another bunch of adds to skeds that have already been announced/released. Seems to be a recent trend from WN.
Just another great appreciation for the great OAG threads! These sorts of unexpected sked changes from WN would be, IMO, almost impossible to find otherwise unless they were just stumbled upon.
Of course the suspicious side of me thinks that WN must be expecting that someone **cough cough - AS?** is getting ready to announce, for example, SAN-RNO service...
bb
phxa340
I have been on this flight when it is probably 100+ Boeing employees. Wouldn’t be surprised if Boeing travel fills both of these flights 50%+ most days minus weekends.
Bobloblaw
Sun Oct 28, 2018 4:50 pm
Really??? You ask what points can be connected over MIA that cannot be connected over PHL? Even the duplicate caribbean/latin destinations from PHL misconnect from DOH.
No one cares if PHL is 150 miles less than MIA to DOH from TPA. No one books an 8000 mile flight based on 150 miles less circuity. Using that logic all YYZ-SYD traffic should flow over LAX and none over YVR.
MIA gives QR access to latin america that PHL cannot.
SANFan
Sun Oct 28, 2018 4:51 pm
Oh my, a bunch of out-of-the-blue Frontier drops! Such an unexpected shock!
Exactly the reason I keep track of all new F9 service in pencil with a big eraser... But that's ok, that just means soon there'll be another round of strange and wonderful adds to the F9 route map that will again make people jump up and down with excitement. (Until those too are cancelled.) Quite an operation, F9.
New slogan? "Frontier -- Fly With Us Now, But Don't Plan Ahead!"
bb
Bobloblaw
Sun Oct 28, 2018 4:52 pm
UA is down 2 to GRR from EWR from 4 to 2...but are the 2 now mainline?
klm617
Sun Oct 28, 2018 5:01 pm
All of South America, The Caribbean and Mexico.
stl07
Sun Oct 28, 2018 5:07 pm
but double customs/immigration
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
gwrudolph
Sun Oct 28, 2018 5:08 pm
bb
I can't imagine how much time/resource they spend setting up stations and routes, then cutting them and/or pulling out?!?!?! Securing space, securing and signing contracts with FBOs, signage/branding, securing crew hotel agreements, etc, etc, etc.
usairways85
Sun Oct 28, 2018 5:09 pm
And AA just said they had a tough quarter for Latin America traffic out of MIA. So it wouldn't be surprising if QR also got pinched a bit if they are banking on Latin America-MIA-DOH-beyond traffic.
klm617
Sun Oct 28, 2018 5:10 pm
Yes you're right I was looking at the 2 vs 1.9 last year IDK how that 4 got in there as it is only operating 2 nonstop now.
yellowtail
Alas, it does not seem to be enough
Bigant0408
Sun Oct 28, 2018 5:11 pm
F9 never fails when it comes to huge route drops and add ons. You rarely hear Spirit drop routes left and right but I guess Frontier knows what they are doing. As for QR I’m surprised but the frequency reduction to MIA. I wonder if it’s signs to come for other routes minus JFK
The man who sleeps on the floor doesn’t fall out of bed
MAH4546
Sun Oct 28, 2018 5:12 pm
Nope. QR and AA ended their partnership, despite both being in OW.
Miami has a lot of capacity to the region - Qatar, Emirates, Turkish, El Al, and, starting in April, Royal Air Maroc, and it all came quickly. No doubt fares are hurting.
a.
Rdh3e
Sun Oct 28, 2018 5:14 pm
Which is why I said "meaningful". Just because STT now connects TO DOH doesn't mean anyone would actually use it. The MIA link is largely superfluous for connectivity so unless it survives in MIA-DOH local plus MIA-DOH-India it's basically worthless. That is why it's being day of weeked, it doesn't have the utility it needs.
B752OS
Sun Oct 28, 2018 5:16 pm
Did a good amount of traffic connect through MIA on AA with the DOH-MIA flights? People flying SCL-MIA-DOH for example.
Bigant0408
Sun Oct 28, 2018 5:18 pm
Excellent point about the other other airlines you mentioned. They can only lower the fares but so much
MAH4546
Sun Oct 28, 2018 5:23 pm
There's certainly some, but the route survives on MIA local traffic now as AA and QR no longer partner.
a.
SANFan
Sun Oct 28, 2018 5:52 pm
I will say that as far as SAN is concerned, we have a lot more nonstop capacity to BWI than IAD: in peak season, WN, AS & NK operate ~5 dailies to BWI, whereas only UA flies to IAD, 3x daily. Other cx, WN the most recent, have attempted IAD service but quickly dropped it. (And WN dropping SAN routes is rare.)
It has to be noted that SAN is the largest major western market (outside the perimeter) without a nonstop to DCA and who knows if or when that problem will be resolved...
I can only conclude that flyers between SAN and DC much prefer Baltimore -- so long as our choice remains either BWI or IAD. Not a huge surprise.
bb
tphuang
Sun Oct 28, 2018 6:23 pm
Thanks again enilria
I think this is just them going to twice daily for the peak summer season. They do add capacity in the summer time. This is just to improve their schedule on this route, I would imagine. They are certainly willing to loose plenty of money on new routes out of SEA.
lavalampluva wrote:
XE = JetSuite X
yes, I think this was all announced about 4 weeks ago. Huge surge in flights to LAS. Huge surge out of SNA. It seems like they are doing the best out of those LA basin to LAS routes. OAK is getting quite a few adds too. MMH is restarting from both BUR and SNA.
http://aviationtribune.com/airlines/nor ... d-flights/
On some day, they run 7 flights a day from BUR to LAS.
asuflyer05
Sun Oct 28, 2018 6:34 pm
The opening of HQ2 is a long way off. My guess is there's plenty of demand from the significant Boeing and Amazon presence in the Dulles Tech Corridor.
Edit: Forgot to add my thanks to enilria for putting this together week in and week out. One of the best reads on A.net these days. Thanks again!
