kalvado
Re: Lion Air 737MAX8 Crashed Jakarta to Pangkal Pinang
Fri Nov 30, 2018 3:28 pm
keesje wrote:
Southwest is adding new angle of attack indicators to its 737 max fleet
https://theaircurrent.com/aviation-safety/southwest-airlines-is-adding-new-angle-of-attack-indicators-to-its-737-max-fleet/
A clear signal from the largest 737 MAX operator / customer.
Can be just a knee jerk reaction. Is that actually meaningful information, or pilots are now tasked with supervising automation which already supervises them?
dragon6172
Fri Nov 30, 2018 4:08 pm
WIederling wrote:
dragon6172 wrote:
scbriml wrote:
For just a few seconds until it kicks in again (assuming conditions that caused it to activate are still present), no?
No, the authority is always there. Yes, MCAS will attempt to trim nose down 5 seconds after pilot trim input (assuming conditions requiring its use exist), but the authority for pilots to override it is always available.
so you have to kick it in the shins every 5..10 seconds.
That is kind of a Tamagotchi design ( feed me, go potty, warm my belly, comb my hair, feed me, ..).
terrible.
Or you could just turn off the electric trim using the cutout switches and not have to worry about it.
Phrogs Phorever
wingman
Fri Nov 30, 2018 4:10 pm
terrible.
Or you just turn it off when it's not working properly. The last pilots did that Step 1 but these guys went your Tamagotchi route instead.
Isn't this what 99% of modern "piloting" is all about, making sure the plane is doing what it's supposed to by constantly monitoring all those large, shiny displays? The 737 system needs to be fixed and it will be, probably something as easy as what SW is doing. And Boeing is going to be on the hook, rightly so, for missing a crucial piece of operation that led to this accident. But there's plenty of other stuff to focus on here too. Not sure I understand your comment. The prior pilots turned it off and hand flew the plane to safety, these guys didn't know how to do that (Boeing's potentially massive liability), or just didn't connect the dots so apparently obvious to the prior crew. Bad sensors or syestems, correct responses, basic flying skills..lots of accidents have happened in this general category that should not have. Outside of actual piloting for 10-25 minutes on a 1 hour or 19 hour flight, the main job is to supervise the systems and understand when they depart from "helpful" to "lethal".
PlanesNTrains
Fri Nov 30, 2018 4:22 pm
terrible.
I’m not sure it’s all that simple (so to speak). I’m at a loss as to how this got through the certification process let alone Boeing’s own in-house analysis? They designed a system poorly then didn’t provide clear communication on what it is, how it works, and what to do when it inevitably is fed erroneous data. Instead they designed a system that fights the pilots who are now trying to troubleshoot with one hand tied behind their back - and with nearly 200 lives in their hands. That’s not just libelous, it’s borderline criminal, particularly if an investigation brings out emails and memos showing what they knew and when they knew it.
I’m not doubting a fix can be made or that Boeing will “pay the price”, but whatever price they pay will be cold comfort to the families of those who died on this plane.
I’m not accusing or absolving any other party. I have no idea what ultimately will be found in this investigation. I do know, though, that these pilots were setup to fail, and no amount of “That’s their job - to figure these things out” will change that for me. I dare anyone to willingly be put in their shoes and potentially face their maker to prove that point.
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
wingman
Fri Nov 30, 2018 4:50 pm
PlanesNTrains wrote:
terrible.
I agree with what you're saying but would honestly be shocked and very upset of Boeing is discovered to have designed a poor system knowingly and then worked to cover that up to their customers. If they did do so then billions will get paid and execs may go to prison (again, rightly so). While it's no consolidation to the victims and their families I sincerely hope that Boeing thought the emergency response (hit switch and hand fly to nearest airport) was well known/intuitive. The prior crew knowing it would be testament to that. Passing the incident details to the next crew would've saved 189 lives, and somewhere along the way both incidents should have led to a global directive and proper fix without the lives lost.
SEPilot
Fri Nov 30, 2018 5:04 pm
The root cause of the problem appears to be inaccurate AOA readings being fed to the MCAS computer. Here is a relatively simple fix that should prevent that. Part of the problem is that the AOA sensors, by design, do not give meaningful readings while the plane is stationary. That is easy to fix. Put a light spring or counterbalance load on the control vanes so that when the plane is stationary the AOA indicator reads 0. Measure the input at the MCAS for the AOA and if it is not zero, you know before takeoff. And if it radically departs from zero during the takeoff run you know you have a problem and what to do about it.
WIederling
Fri Nov 30, 2018 5:08 pm
If the airflow "feel" tab is broken off the AoA will stay at zero. Every one happy as a camper :-)
Seem to be lots of duhh simple solutions around that are patently wrong.
Murphy is an optimist
SEPilot
Fri Nov 30, 2018 5:16 pm
If it stays zero the pilot will also know it is wrong. As soon as the plane reaches significant speed it should change; AOA is almost never zero in flight, and it isn’t on the takeoff run even before rotation.
PixelFlight
Fri Nov 30, 2018 5:34 pm
terrible.
If you are so confident that MCAS can be "just turn off" and "not have to worry about it", why the FAA required his addition in the first place ?
Safety is not just a game where you can simply replace a bad designed protection by an reduced envelope !
:stirthepot: 737-8 MAX: "For all speeds higher than 220 Kts and trim set at a value of 2.5 units, the difficulity level of turning the manual trim wheel was level A (trim wheel not movable)." :stirthepot:
ikramerica
Fri Nov 30, 2018 5:35 pm
While this is way of course now, I think the roadblock people are running into is the same one auto designers face: if the automobile were a new invention today using available technology today, the controls may look nothing like what they do now. Other than driverless vehicles, cars have steering wheels and foot pedals because long ago it made the most sense to manually operate the systems. (Early autos had tillers and hand brakes and throttle levers).
Aircraft designs apply modern technology to ancient paradigms and the results aren’t always what we expect. And certainly if we were to start from scratch, controls would be very different, even more so than a side stick. Even the aircraft itself might look very different. But it can’t be done because of pushback by pilots, airlines, regulators, passengers, airports etc.
And so we end up with the problem of an aircraft that would be too expensive to replace with a clean sheet but needs voodoo to keep it stable.
par13del
Fri Nov 30, 2018 5:37 pm
I am hoping the CVR is found so that we can understand why when they identified that flying with flaps down minimized the trim issues, they continued to raise them.
The FDR unfortunately, does not tell the full story.
kalvado
Fri Nov 30, 2018 5:40 pm
And do we end up with the problem of an aircraft that would be too expensive to replace with a clean sheet but needs voodoo to keep it stable.
I don't really think there are any fundamentally new paradigms available. If they were there, we would see those in military pretty quick. But I can think only about HUD as a new element - and it is making the way into civilian products.
Until cerebral interfaces are reliable enough, hands and feet used to control things are pretty much the only option as hand movement are the most precise ones. That doesn't leave too much room for something truly new...
hivue
Fri Nov 30, 2018 5:51 pm
The prior crew were no aeronautical geniuses themselves as they continued flight to destination in a non-airworthy airplane.
smartplane
PixelFlight wrote:
dragon6172 wrote:
PixelFlight wrote:
The problem is that the MCAS is not a optional automatic system. The MCAS is actually a required protection system with authority over the pilot due to the greater instability of the 373MAX compared to the previous 737 families.
Pilot always has authority over MCAS, as has been discussed here several times, pilot trimming using the yoke trim switches stops MCAS trim inputs.
It that case the MCAS is not longer a protection system. Always the same conflict: is MCAS is not a required protection authority, then the 737MAX is less safe than it predecessors as it have a reduced flight envelop that require extra training to flight without or against MCAS. Enough dead already.
Was it ever a 'protection system? Surely it's primary purpose is to replicate, within boundaries, the flying characteristics of earlier 737's to protect 'grandfathering'.
If it was a protection system, there would have been more emphasis on training, documentation, data sources, fail-safe, and multiple visual and audible warnings a pilot had turned it off, if in fact they could.
What data did Boeing have following each of the last four flights? What errors were they seeing? Did they provide any solicited or unsolicited advice to the airline? Owners (including leasors) are under the impression the MAX is similar to the A320 family, and even 787, when it comes to monitoring condition and / or how it's being flown.
gzm
Fri Nov 30, 2018 5:52 pm
Trin wrote:
So I have a question, after reading everything that is up to date on this incident. It is more a human-related question than a design-related question, but nonetheless....
WHY would an airplane with such sensor discrepancies be allowed to (be able to) take off?
I will repeat what I posted weeks ago: This airplane was in NO WAY airworthy and the fact that it was cleared for service on the incident date (or previous two flights) is just astounding.
Being a former gate agent myself,I agree with you.We both see the human point of view. But the experts here say that the plane was fit to fly.However,it is one thing to say that the pilot,having accepted to fly the plane,has full responsibility -which speaks volumes and I won't elaborate- and another thing to have to face the anguish, complaints and what else from the relatives needlessly.There is obviously a lot to learn from this accident.
Now,about what the prior flight crew did or did not communicate to the next,I have only this to say: The pilot upon arrival communicates the technical issues to the ground mechanic who is assigned to the specific arrival/departure turn-around,so to speak.I have seen them discuss issues in a calm, understanding, professional manner despite an air of displeasure on the captain's part. So,the previous pilot does not see the next one,perhaps only rarely. So how did the mechanics react? They arranged for a colleague of theirs to fly as NoSeat in the cockpit to act as a witness and try to learn from it. It remains to be seen if and how negatively he influenced their reactions...
smartplane
Fri Nov 30, 2018 5:57 pm
For an aircraft designed and first delivered in the 21st century, the airline should have comprehensive status reporting on the aircraft even before it lands, including deviations from profiles for the route being flown. The flight crew contribution should be to elaborate on symptoms and in-flight workarounds in response to questions from the techs.
dragon6172
Fri Nov 30, 2018 6:06 pm
Who said the FAA required it?
Phrogs Phorever
LDRA
Fri Nov 30, 2018 6:07 pm
I have a hunch it might be both.
737NG already has a tendency to pitch up at high AoA without control column input at high thrust setting. There is already a function in STS to trim nose down on detected stall on 737NG. So the margin to satisfy Part 25.203a is already small on 737NG. Max with its aero changes, could very well bust Part25.203a without MCAS
Even if MCAS is allowed to be turned off, the pilot training for Max specific high AoA flight characteristics is not there. So somewhere there is a fail to properly certificate
PixelFlight
Fri Nov 30, 2018 6:08 pm
The failure mode of the JT610 left AoA sensor is still unknown (to the public at least). AoA reading while the plane is stationary (or taxiing) is really not a problem at all. Sensors have to be validated, by voting between multiple of then, or by predictive filters, because any sensor can fail in any evil way, no matter what. Single sensor input algorithm that actuate a critical control surface must be prohibited on commercial aircraft as soon as possible. More I think about this, more I am shocked about how this design could still be certified to fly today.
Take some time reading documentation about the lasts AFDX avionic designs and you will certainly get a feeling about the gigantic gaps between the B737MAX design and the A380, B787, or A350 designs. I mean, almost no peoples (outside aircraft industry) realize how dramatically different those designs are.
PixelFlight
Fri Nov 30, 2018 6:18 pm
https://theaircurrent.com/aviation-safe ... cas-jt610/
“Boeing quietly added a new system [MCAS] to compensate for some unique aircraft handling characteristics during it’s (sic) Part 25 certification”
WIederling
Fri Nov 30, 2018 6:31 pm
FAA requires an airframe stable in pitch up. i.e. taking the nose down must be possible in all flight regimes.
The higher placed and larger drag source that represents the engine(cowlings) will at some point create/amplify pitch up moment.
FAA requirement of "no positive feedback in pitching up" was "solved" by Boeing via introducing MCAS
that must limit pitch up at all times to a value smaller than where the positive feedback into pitch(up) sets in.
It does not fix the basic issue the new aerodynamics create instead it tries to limit attitude to save values.
Afaics the MCAS is stuckoed on as a quick and dirty job.
Not telling then is either due time constraints or the underlying mechanics do not lend themselves to being made public.
PixelFlight
Fri Nov 30, 2018 6:32 pm
This is exactly what all operators and pilots are now asking for !
There impression are totally false: the obsolete avionic of a B737MAX is nothing like the AFDX avionic of a B787, really not. Even a A320 avionic is still far advanced compared to a B737, with for example triple sensors redundancy and well defined protection laws.
dakota123
Fri Nov 30, 2018 6:33 pm
"Boeing quietly" are Mr. Ostrower's words, just to be clear.
“And If I claim to be a wise man, well surely it means that I don’t know”
PixelFlight
Fri Nov 30, 2018 6:37 pm
Not only Mr. Ostrower's words, as many operators and pilots have publicly said that there did not know about the MCAS before the EAD.
dakota123
Fri Nov 30, 2018 6:40 pm
And yet:
(Apologies, Wikipedia): On 5 November 2014, Lufthansa Flight 1829, an Airbus A321 was flying from Bilbao to Munich when the aircraft, while on autopilot, lowered the nose into a descent reaching 4000 fpm. The uncommanded pitch-down was caused by two angle of attack sensors that were jammed in their positions, causing the fly by wire protection to believe the aircraft entered a stall while it climbed through FL310. The Alpha Protection activated, forcing the aircraft to pitch down, which could not be corrected even by full stick input. The crew disconnected the related Air Data Units and were able to recover the aircraft."
Not an A vs B, point is simply "the best laid plans of mice and men oft go awry" even with redundancy.
PixelFlight
Fri Nov 30, 2018 7:10 pm
And yet:
Just a small difference regarding the probability:
B737: a single AoA failure can generate a uncommanded pitch-down
A320: two AoA failures can generate a uncommanded pitch-down.
A predictive filter would have rejected 1, 2 or even 3 failed sensors. The output probability would be degraded, but not up the point to lost the control.
litz
Fri Nov 30, 2018 7:43 pm
Several interesting points in this article, linked a few times above : https://theaircurrent.com/aviation-safe ... max-fleet/
1) comparing AOA indicators during takeoff roll (after sufficient speed has been gained for the sensors to start reporting), as well as a DISAGREE warning, would have prevented this accident, as the crew would have RTO'd.
2) Lion Air's specific model has neither flight display AOA indicators or a DISAGREE warning. So 1) wouldn't have applied on their flight anyways.
stratclub
Fri Nov 30, 2018 7:53 pm
Interested wrote:
Should those pilots not be suspended etc for not turning back during that flight. Had they turned back would we be even in a thread about a disaster now? Them turning back would have shown the plane not airworthy and maybe got a better maintenance job done etc?
Without a doubt. I'm sure that if their bodies are ever found they will be sitting in front of HR with their union rep.
jetmatt777
Fri Nov 30, 2018 7:58 pm
I think he’s talking about the pilots from the prior flight who flew the entire trip with stick shaker activated and manually trimming.
klkla
Sat Dec 01, 2018 1:31 am
Congratulation to Southwest for there excellent reaction and communication to improve safety, even if there unfortunately can't magically change the old 737 design. Frankly, that kind of improvement should have been pushed directly by Boeing to all operators. We have more information about Boeing possible plans from journalists than from the company itself. Depressive.
I don't know why Southwest should be congratulated. They could have made this decision years ago according to the same article quoted:
"An American Airlines spokesman said AOA indicators on the primary flight displays have been a feature on it's Next Generation aircraft since the late 1990's and are featured on it's 737MAX aircraft as well."
It sounds like Southwest was too cheap to install the feature until now.
zippy
Sat Dec 01, 2018 1:54 am
The Bournemouth incident was a 733, so even the 737 Classics can pitch up dangerously if you apply thrust in the right conditions.
1989worstyear
Sat Dec 01, 2018 2:11 am
PixelFlight wrote:
WIederling wrote:
PixelFlight wrote:
It's knowable with predictor algorithms based on flight dynamic model feed by all information available on the aircraft. Each inputs values modify the probability output of the predictor with it own probability to fit the result. If all information but a single sensor agree on a probability, the one that disagree will be almost rejected. Sadly this kind of algorithm is still not used for aircraft air data sensors.
Advanced systems beyond steam gauges on the 737 have been layered on over time. And each layer and techno splotch probably is more or less standalone, has limited inputs, a "NEW" function output.
There is no holistic access to system input to do what you propose.
( and it is afaics not a desired function. Analysis of complex systems explodes with number of components/inputs.)
Exactly, the 737 design is so old that it's virtually impossible. High level system sensors fusion is only possible with modern AFDX aircraft networking, but this technology is now very well implemented in all major new aircraft design: https://etr2017.sciencesconf.org/data/p ... tr2017.pdf
It a desired function. I even hope it will be a required function in the near future. The complexity of a flight dynamic predictor is not that great, every single aircraft simulator, from engineering design to pilot training, have this algorithms since decades. It's really the opposite compared to adding a quickly ill designed hidden lethal MCAS.
Another reason why we need a clean-sheet NB design from both manufacturers. System design is still stuck in the 1988 mindset thanks to the A320-200.
Stuck at age 15 thanks to the certification date of the A320-200 and my parents' decision to postpone having a kid by 3 years. At least there's Dignitas...
Sat Dec 01, 2018 2:26 am
And yet:
This is true. For better or worse, the aircraft can only act on information fed to it by sensors, and if the sensors are wrong, problems happen... Rather unfortunate when you get the same failure on two independent sensors, and also rather unlikely.
That being said, there are procedures for such events.
Not really. An A350 is way more advanced than an A330 or A320 when it comes to systems, and that includes air data redundancy and switching.
zippy
Sat Dec 01, 2018 2:38 am
From the article:
“Currently, the MAX and NG have an AOA disagree light that provides an alert of erroneous AOA data,” a Southwest Airlines spokeswoman said in a brief statement confirming the upcoming change. “The AOA indicator will provide a valuable supplemental cross-check in the event there is an erroneous AOA signal present.”
They opted for perhaps the most important piece which is the AoA disagree alert.
2175301
Sat Dec 01, 2018 4:40 am
Perhaps I'm confused. I thought the A350 was a widebody aircraft. How does a recent widebody with modern controls negate the idea that we need a cleansheet narrow-body - also with modern controls?...
Have a great day,
Sat Dec 01, 2018 7:43 am
Have a great day,
I was responding to the comment stating "System design is still stuck in the 1988 mindset thanks to the A320-200". It isn't, and not even on the A320 irself, which has several new design features introduced mid-life.
I'd argue that the A320 is still a "modern" aircraft control systems wise. The basic flight control logic is the same as on the A350, a clean sheet design, showing that the fundamentals were sound.
ferpe
Sat Dec 01, 2018 8:24 am
fadecfault wrote:
A Couple things regarding the Leeham article :
1) The Chart has Pitch force labeled as CCFORCE_PITCHCWSLOCAL_FDR and CCFORCE_PITCHCWSFOREIGN_FDR. We can not tell which CWS pitch sensor is being displayed. The captains or f/o's sensor will display as local or foreign.
This is seen in the DFCS bite as:
P CWS-LCL (LBS)
CH A CH B
and
P CWS-FGN (LBS).
CH A CH B
I have tested it and each sensor feeds the local and foreign data display.
2) You can't equate force with elevator position. You can pull the column full aft and have a 50lb split between the f/o and captain. This can happen when one pilot felt the aircraft wasn't responding to nose up command of the other pilot and pulled harder. The column won't move anymore but force on it will be greater. You also push and pull in opposite directions and one sensor will read negative pounds. I registered a 70lb split (-30/+40) when I pushed /pulled the columns with one hand on each. The Graph doesn't show one line in positive and one line in negative, so the authors suggestion that the pilots worked against each other is wrong.
Thanks fadecfault. For you to actually go in the aircraft and check it out is brilliant and really helpful! The split in the trace then means, for instance, the F/O started pulling as he was asked to help the captain or thought he wasn't keeping the nose up and dug in. The strange thing is still that his trace, the green, goes down when the red goes up when the dive starts. We need more sensor traces to understand this.
Great job!
Non French in France
ferpe
Sat Dec 01, 2018 11:16 am
I guess my question remains. fadecfault or someone else:
Is the Stall ID information in the SYMD and FCC different? As is now clear from the traces we are not facing an MCAS range AoA situation for JT610 (or previous flight), the SYMD must have full Stall ID to start the stick shaker. It means the aircraft is flying in the stall AoA range the whole previous flight and for all the fatal flight except a short moment. With this AoA, does the FCC have Stall ID?
A) If not the Stall trim loop in the FCC has other trigger criteria than the pre-Stall MCAS loop. Why in such a case is MCAS allowed to have laxer rules than Stall? The trim authority seems to be the same, other than it's not clear if the Stall trim is stopped after 10s, waits and then continues. It might continue until the AoA goes below stall value.
B) If the Stall criteria in the FCC is the same for MCAS and Stall trim the Lion Air scenario is not a concern for the 737 MAX but for both 737 NG and MAX.
The absence of FAA being active on the NG points to A. But is this the case really? Or is there something wrong in my logic?
PixelFlight
Correct, but why only take in account 2 or maybe 3 redundant sensors ? Flight dynamic predictors filters can take in account a lot more sensors to produce a probability histogram of the output variables. Failed sensors will only degrade the probability, reducing the safety domain, but still allow to flight. You can view this as a smooth transition from the actual automation down to an automated "pitch and power" control that at least allow to save the aircraft.
Sensors are not the only source of information, flight dynamic model can provides a lot of information too, especially in situations with a reduced set of sensors.
Sat Dec 01, 2018 11:19 am
PixelFlight wrote:
Correct, but why only take in account 2 or maybe 3 redundant sensors ? Flight dynamic predictors filters can take in account a lot more sensors to produce a probability histogram of the output variables. Failed sensors will only degrade the probability, reducing the safety domain, but still allow to flight. You can view this as a smooth transition from the actual automation down to an automated "pitch and power" control that at least allow to save that at aircraft.
Certainly. The issue of undetected failures still remains, however. Sensors sometimes give an inaccurate output that still seems correct.
WIederling
Sat Dec 01, 2018 11:50 am
you are quite funny.
We are talking about the ancient core of the 737 and you bring up the A320 setup ( which saw continuous refinement but not paradigm changing step changes in the A330/A340, A380 and A350XWB.
A new airbus NB craft will with high probability show further refinements.
The bigger question is if Boeing will ever disassociate itself from the layer cake approach of "history embalming" paradigms.
( Still a core part of the 787 layout.)
kalvado
Sat Dec 01, 2018 11:51 am
There is always such an issue, including inaccurate human eyes - aka pilot disorientation in this context.
This is more about maximizing error detection and ensuring flight safety than anything else. Sensor network doesn't have to be perfect, it has to be good enough for pax and crew to walk away from landing site with as few exceptions as possible.
Interested
I'm talking about the earlier flight ??
Interested
Sat Dec 01, 2018 11:53 am
Yep
I wonder their thoughts when they heard the news of the crash on the next flight?
Could they have done more to prevent this?
What would you expect from pilots leaving a plane having experienced the above scenario?
PixelFlight
Sat Dec 01, 2018 11:56 am
This is not an issue: the predictor filters was precisely designed to work with inaccurate sensors. The Kalman filter is the simplest of them and was designed for the Apollo missions. Since that time, the predictive filters family have grow and includes today some some very advanced concepts like the particle filter. There are studies about aircraft sensors redundancy using predictor filter and there show that a flight dynamic model is required into the predictor. And the flight dynamic model algorithm already exists in all simulators.
All the technologies to make the next generation of "sensors + predictors" redundancy already exists.
patplan
Sat Dec 01, 2018 12:16 pm
Interested wrote:
Yep
I have heard rumor [unconfirmed...] that the head MX who jotted down his signature and gave the clean bill of health for the plane for that fateful flight was under watchful eyes of psychologist(s). I'm sure he's in a tremendous state of shock.
I would imagine the two pilots from the previous flight were probably in similar state of shock- notwithstanding the omission of the stick-shaker during the flight in their log/report.
PixelFlight
Sat Dec 01, 2018 12:50 pm
[joke] 737AAA : Advanced AFDX Avionic :-D
dakota123
Sat Dec 01, 2018 3:29 pm
P CWS-LCL (LBS)
CH A CH B
and
P CWS-FGN (LBS).
CH A CH B
Great job!
We need the CVR. The traces are completely consistent with the captain giving control to the FO and then taking it back. (Suggest reading the Boeing paper on how the traces are interpreted in the link I posted back on page 36 or so.) He apparently didn’t ask the FO to help pull, or the FO’s harness wasn’t tight and he slid forward, or he was terrified, or who knows what.
wingman
Sat Dec 01, 2018 5:11 pm
zippy wrote:
From the article:
Conversely, it's Boeing that will be blamed for not making this a standard feature. I guarantee it will be now but sadly too late for the crash victims.
dakota123
Sat Dec 01, 2018 6:01 pm
Pilots have traditionally been taught airspeeds, with not stalling almost as an indirect goal; AOA is a different mindset, even if ultimately it’s the correct one. During primary training, AOA rarely enters the conversation (it does in the classroom, but not in the plane, and that’s where it counts). Change takes time, or something tragic happening like this.
FAA hasn’t been called the tombstone agency for nothing.
