dcajet
Changes on AA937/938 MIA-VVI-MIA
Sat Nov 24, 2018 10:15 pm
Similar to the changes on MIA-BSB, AA's daily service to Santa Cruz de la Sierra, VVI, Bolivia, changes to the MAX 8 from the 757-200 and will be day time departure on both segments, effective May 3, 2019.
AA937 MIA 17:45 VVI 01:24+1 7M8 D
AA938 VVI 08:45 MIA 15:45 7M8 D
Cubsrule
Re: Changes on AA937/938 MIA-VVI-MIA
Sat Nov 24, 2018 10:22 pm
Product decline aside, that 0125 arrival is rough. That puts bedtime at 0300 even if everything runs relatively smoothly. Northbound times aren’t bad (and also aren’t changing much).
jfk777
Sat Nov 24, 2018 10:57 pm
At least the Max 8 used to Latin America are not overnight, so far. AA should learn from the Copa Max 9, lie flat seats.
maps4ltd
Sun Nov 25, 2018 1:38 am
I wonder what routes we will see the MAX 8 take over next from MIA. I'm thinking of routes operated by 752s or long A319 routes. Could Manaus cut it? It would be a strong upgauge in seats, but it would also mean 16 F instead of 8 (even though it's basically a PE seat, I'm sure the doubled F cabin would see decent sales simply because of the flight's 5+ hour duration).
I see Guayaquil getting 7M8s also. You currently see 738s and 763s out of there. In fact, I'm taking the morning 738 on GYE-MIA in March.
There are more I could mention, but then this post would ramble.
Does anyone know where the displaced 752s from BSB and VVI are going? They're probably up for retirement soon anyway.
All opinions expressed herein are mine and do not represent the views of Cape Air
chepos
Sun Nov 25, 2018 2:21 am
If AA ever decides to go back to NE Brazil I would imagine the MAX would be the preferred option. MAO started with the 738 and appearently it was too much aircraft so I doubt they will change it to the MAX. I wish they would give Cuzco another try, the MAX would be perfect for those missions.
Fly the Flag!!!!
RyanairGuru
Sun Nov 25, 2018 2:57 am
7h21m isn't sufficient crew downtime, is it? If so do they intend for the crew to spend 31 hours on the ground? That seems highly inefficient when a slightly earlier arrival/later departure would bring it within minimum rest requirements.
Worked Hard, Flew Right
Tikchik
Sun Nov 25, 2018 2:59 am
I flew MIA-VVI-MIA this Fall. Outgoing was 16/16. Return flight cancelled before boarding, but they said it was full.
Love the 757. My favorite ride when it doesn't cancel.
Not a fan of how AA configured the Max.
aemoreira1981
Sun Nov 25, 2018 4:53 am
American should really consider moving up the MIA departure to 15:15 or so so that the same crew can operate the forward and return flights with 8 hours off duty. As scheduled, that's less than 6 hours of scheduled rest, given that the crew would likely get to the hotel around 2 AM and have to wake up at 6:30 AM to get ready and return to VVI by 8 AM. By moving up the flight 2.5 hours, 7 hours of sleep is realistic. The scheduling here is to avoid using a second plane, but you will have a crew spending a day in Bolivia.
SCQ83
Sun Nov 25, 2018 6:58 am
I wonder if the Max could open new secondary destinations in Latin America from MIA? I can't think of many cities "worth" of a flight to MIA that currently does not have one on AA, but I am sure there are some "medium" cities out there. For instance, could Cusco cut it? Interestingly I found this:
https://en.wikipedia.org/wiki/Alejandro ... al_Airport
The airport was served by American Airlines from New York City on a JFK-LIM-CUZ-LIM-JFK routing from 1998–1999 using Boeing 757-200 aircraft. However, these flights were discontinued due to a number of factors, including the airport's limited services and facilities, as well as the Peruvian government's refusal to grant passenger transportation rights between Lima] and Cuzco. American still holds the rights to this route and can resume flights at the company's discretion.
On February 3, 2017, President Kuczynski announced the beginning of the construction of the new Chinchero International Airport,[2] which will be located in the suburb of Chinchero, 30 minutes from Cusco city. It is estimated that the new airport, will be completed by 2021 when Velasco Astete Airport will be closed. It is expected to receive up to 6 million passengers upon its opening.
It seems that MIA-CUZ on AA will be a given, at least when the airport opens. US - Machu Picchu non-stop.
Maybe Bucaramanga or Cúcuta? Those are close to the Venezuelan border, so it might make sense to serve MIA from there. Copa already serves Bucaramanga from Panamá.
N757ST
Sun Nov 25, 2018 11:54 am
Far 117 minimum rest is 10 hours, and no one schedules test that tightly. Either way they will be spending a long layover down there.
Cubsrule
Sun Nov 25, 2018 1:54 pm
For me the bigger problem with the new schedule is that it no longer gives AA a clear advantage in schedule. MIA local passengers will presumably prefer the nonstop, but the clear majority of passengers connecting over MIA have access to CM and many have other options too.
When CM offers a superior schedule (actually multiple superior schedules) and better product on something like IAD-VVI, what is the incentive to fly AA? So many of us look immediately to AA for our secondary South America needs because traditionally AA has made the most sense unless it is obscenely expensive. Increasingly, that is no longer true.
aemoreira1981
Sun Nov 25, 2018 2:33 pm
I didn't think about that. Over time, the MAX 9, with lie flat, will be used on the premium routes, while the older NGs go back to lessors (Copa financed many of its B738 acquisitions with sale-leasebacks). Copa could open up a lot of secondary destinations in South America with the excess B738s that are owned or newer-leased. I could see CM getting as big as 150 planes.
MIflyer12
Sun Nov 25, 2018 3:10 pm
One can hope for that - rather than just 757 downgauging.
HeeseokKoo
Sun Nov 25, 2018 3:32 pm
I'd take 30" non-redeye over 31" redeye any day. 1:25am arrival is still better than a redeye for some (or many) Y passengers. Losing PTV is bad though.
UIO-MIA overnight flight has been 7M8 for several months. To be fair, it was 738 before.
