dcajet
AR1293 GIG-EZE 24/11 severe turbulence w. 1 injured pax
Tue Nov 27, 2018 12:09 am
This past Saturday, 24/11 Aerolineas Argentinas AR1293 737-800 LV-GGQ encountered severe turbulence en route from Rio de Janeiro GIG to Buenos Aires EZE, with one passenger injured while he was in the bathroom requiring medical assistance upon arrival at EZE.
BWIAirport
Re: AR1293 GIG-EZE 24/11 severe turbulence w. 1 injured pax
Tue Nov 27, 2018 4:28 am
Is it me or do many of the recent "extreme turbulence" cases happen over South America? Probably a case of correlation =/= causation but it certainly seems to be a trend
Next flight: 3/1 DL2834 BWI-ATL B739
3/1 DL661 ATL-STT B752
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
NYPECO
Tue Nov 27, 2018 4:46 am
How does the interior cabin always fall apart like that in turbulence?
Aeroflot777
Tue Nov 27, 2018 5:39 am
Looks like the passenger was thrown up and probably hit the panel with his head or another body part. Hope they are ok after medical assistance.
prchan
Tue Nov 27, 2018 8:35 am
I don’t know the reason to explain, but on my experience the route to EZE (from GRU/GIG) is usually bumpy at some point...
Jomar777
Tue Nov 27, 2018 9:52 am
Actually, if you fly Northern Hemisphere to South, you will always s get turbulence when crossing the Equator. Europe to South America flights are particularly vulnerable and some of those can be severe.
Also, if you fly between Europe and US/Canada, this is fairly common as well as the inbound and outbound length of the flights be quite different.
All this is related to climate and Slipstreams/Wind Conditions.
I think that if you Google it, you may find something on YouTube or elsewhere which explains the factors and will give you an insight on why some routes are heavily affected and others not...
cedars747
Tue Nov 27, 2018 10:09 am
My worst experience with the turbulence was on board the AR B747 from Rome to Buenos Aires with a stop in Rio de Janeiro. Half an hour before landing at EZE, the plane entered one of the worst turbulence of my life. What I remember is that everyone shouted and asked Madonna and Jesus to save them from this turbulence. What I also remember is that the assistant on board told me that these turbulences usually occur before arriving in Buenos Aires over a region called Catalinas.
Tengo una pasion por la aviacion /لدي شغف للطيران / I have a passion for aviation /Jeg har en lidenskap for luftfart/ J'ai une passion pour l'aviation.
boerje
Tue Nov 27, 2018 11:02 am
What are the requirements for the ceiling panels, are the panels required to be energy absorbing?
dcajet
Tue Nov 27, 2018 4:09 pm
South America is a continent of geographical extremes, from the Amazon to the highest peaks in the Americas, from the plains of central Argentina to the southernmost inhabited cities in the world to the highest airport in the world. Weather goes hand in hand with this diversity. It is also spring time in South America and this is the time when masses of warm air from the Amazon and Brazil and collide with masses of cold air coming from Antarctica over central Argentina and southern Brazil, much like tornado alley in the US.
This incident happened abeam of Porto Alegre, RS in southern Brazil.
dcajet
Thu Nov 29, 2018 3:17 pm
stratclub
Thu Nov 29, 2018 3:48 pm
There is no requirement for making ceiling panels energy absorbent. This a good example why you should keep your seatbelt on and not leave your seat if the "Fasten Seat Belt" sign is turned on. Prior to severe turbulence most likely the pilot turned on the "Fasten Seat Belt" sign and made an announcement regarding expected turbulence.
It does look like the passenger hit his head pretty hard to cause that much damage. Ouch...........
