enilria
OAG Changes 12/9/2018:DL Adds BOS-EWR/DCA/ORD, AM Adds DTW-GDL, UA Drops BOS-CLE
Mon Dec 10, 2018 3:36 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: Another week where there were technical issues with the data. Hopefully this will resolve itself soon. I may do an update later on if the data is released again.
*3M DAB-FLL JAN 0>0.5[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
AA AZO-ORD JUN 3>1.2[3]
AA ORD-YQB SEP 0.1>1.0[0]
AA PHL-ROC MAR 5>6[5]
AA PHX-TUS MAR 8>7[8]
AC BDL-YYZ MAY 4>3[4] JUN 4>3[4] JUL 4>3[4] AUG 4>3[4] SEP 4>3[4]
AC BOS-YVR MAY 0.5>0[0.5] SEP 0.7>0.5[0.8]
AC BOS-YYZ MAY 8>7[8] JUN 8>7[8] JUL 8>7[8] AUG 8>7[8] SEP 8>7[8]
AC LAX-YYZ MAY 6>5[6] SEP 6>5[5]
AC PDX-YYC JAN 0.9>0.7[0.5] JUN 1.4>1.0[1.8] JUL 1.9>1.0[1.9] AUG 1.8>1.0[1.8] SEP 1.9>1.0[1.7]
AC PDX-YYZ MAY 0.5>0.2[0.4]
AC SFO-YYZ MAY 5>4[5]
*AM DTW-GDL MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0]
AS ABQ-SEA APR 1.7>1.0[2]
AS ANC-SEA MAY 17>16[16]
AS BOI-SLC MAR 0.8>0.2[1.0] APR 0.9>0[1.0] MAY 0.9>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.9>0[0.8]
AS BOS-PDX APR 1.5>1.0[1.0]
AS LAX-LIR JUN 0.7>0.9[1.0] JUL 0.7>1.0[1.0]
AS PDX-SEA MAR 19>17[23] APR 18>16[23] MAY 19>16[24]
DL ABQ-ATL SEP 2>3[3]
DL AGS-LGA APR 0>0.3[0.2]
DL AMS-TPA SEP 1.0>0.7[0]
DL ANC-SLC JUN 0.8>0.5[0.5]
DL ATH-JFK MAY 1.3>1.0[1.3]
DL ATL-AUS AUG 8>9[8]
DL ATL-BDL SEP 7>6[6]
DL ATL-BHM SEP 10>9[9]
DL ATL-BOS SEP 13>12[11]
DL ATL-BWI SEP 12>11[11]
DL ATL-CHA SEP 10>9[9]
DL ATL-CHS SEP 11>10[10]
DL ATL-CLT SEP 10>9[9]
DL ATL-CMH SEP 9>8[7]
DL ATL-COS MAY 0.9>0.7[0.8]
DL ATL-DAB AUG 6>5[5]
DL ATL-DCA SEP 12>11[11]
DL ATL-DFW MAY 11>10[11] JUN 11>10[11] AUG 12>11[11] SEP 11>10[10]
DL ATL-FLL SEP 14>13[11]
DL ATL-HOU SEP 6>7[6]
DL ATL-HPN SEP 7>6[6]
DL ATL-HSV SEP 8>7[7]
DL ATL-IAD SEP 7>6[6]
DL ATL-IAH SEP 8>7[7]
DL ATL-IND SEP 10>9[9]
DL ATL-LAX SEP 12>11[10]
DL ATL-LFT APR 4>5[4] MAY 4>5[4] JUN 4>5[4] AUG 4>5[4]
DL ATL-LGA SEP 17>14[14]
DL ATL-LNK SEP 1.0>0.8[0.6]
DL ATL-MCI SEP 9>8[7]
DL ATL-MGM SEP 7>6[6]
DL ATL-MOB SEP 7>6[6]
DL ATL-MSY SEP 11>10[10]
DL ATL-ONT SEP 1.6>1.0[0]
DL ATL-PBI MAY 10>11[10]
DL ATL-PHL SEP 10>9[9]
DL ATL-PIT SEP 9>8[8]
DL ATL-RDU SEP 13>12[11]
DL ATL-SAN SEP 6>7[6]
DL ATL-SBN APR 5>4[4] MAY 5>4[4]
DL ATL-SFO SEP 9>7[7]
DL ATL-TRI SEP 7>6[5]
DL ATL-YVR SEP 0.5>0.7[0.4]
DL ATL-YYZ SEP 7>6[6]
DL ATL-ZRH SEP 0.1>1.0[0.7]
DL AUS-CVG SEP 1.0>0.7[0.6]
DL AUS-RDU SEP 1.0>0.6[0.6]
DL AZO-MSP SEP 2>1.5[1.5]
DL BNA-LGA SEP 6>5[5]
DL BNA-RDU SEP 2>1.5[1.4]
DL BOS-BUF SEP 3>2[2]
DL BOS-CMH SEP 3>2[2]
DL BOS-DCA SEP 0>4[0]
DL BOS-EWR SEP 0>3[0]
DL BOS-IND JUN 3>4[3] AUG 3>4[3]
DL BOS-LGA SEP 17>14[12]
DL BOS-ORD SEP 0>3[0]
DL BOS-PHL JUN 4>5[0] JUL 3>5[0] AUG 4>5[0]
DL BWI-CVG SEP 3>2[2]
DL CHA-DTW JUN 1.5>2[1.5] JUL 1.4>2[1.2] AUG 1.7>3[1.6] SEP 1.9>3[1.3]
DL CHS-DTW MAY 3>1.9[1.8]
DL CHS-MSP JUN 0.4>0.1[0]
DL CLE-LGA SEP 6>5[5]
DL CLE-RDU SEP 1.0>0.8[0.7]
DL CLT-CVG SEP 3>2[2]
DL CLT-LGA SEP 8>7[7]
DL CMH-LGA SEP 6>5[5]
DL CVG-DCA SEP 4>3[3]
DL CVG-DFW SEP 3>2[1.9]
DL CVG-EWR SEP 3>2[1.9]
DL CVG-IAH SEP 2>1.4[1.2]
DL CVG-LGA SEP 6>5[5]
DL CVG-MCI SEP 2>1.4[1.2]
DL CVG-PHL SEP 3>2[2]
DL CVG-STL SEP 2>1.4[1.3]
DL CVG-YYZ SEP 2>1.4[1.3]
DL DCA-DTW SEP 7>6[6]
DL DCA-LGA SEP 12>10[9]
DL DCA-RDU SEP 4>3[3]
DL DEN-LGA JUN 3>2.0[2]
DL DFW-LGA SEP 7>6[6]
DL DFW-MSP SEP 7>6[6]
DL DFW-SLC JUN 5>6[5] JUL 4>5[4] AUG 5>6[5]
DL DTW-HNL SEP 0.6>0.1[0]
DL DTW-LAS SEP 6>5[5]
DL DTW-LAX SEP 7>5[6]
DL DTW-LIT SEP 0.9>0.6[0.7]
DL DTW-SEA SEP 5>6[5]
DL DTW-SFO SEP 4>5[4]
DL EWR-RDU SEP 4>3[3]
DL FAR-MSP SEP 8>7[7]
DL FCA-SLC JUL 3>4[3] AUG 3>4[3] SEP 3>4[3]
DL FSD-MSP SEP 7>6[5]
DL GEG-MSP SEP 2>3[3]
DL GRR-LGA SEP 3>2[1.9]
DL IAH-LGA SEP 6>4[4]
DL IAH-MSP SEP 6>4[4]
DL IND-RDU SEP 2>1.6[1.5]
DL LAX-MSP AUG 9>8[8] SEP 8>7[7]
DL LAX-RDU SEP 2>1.5[1.4]
DL LAX-SLC SEP 8>7[7]
DL LGA-MCI SEP 5>4[4]
DL LGA-MSN SEP 3>2[2.0]
DL LGA-ORD SEP 14>12[11]
DL LGA-ORF SEP 5>4[4]
DL LGA-RDU SEP 8>7[7]
DL LGA-RIC SEP 5>4[4]
DL LGA-STL SEP 6>5[5]
DL LGA-YUL SEP 5>4[4]
DL MDW-MSP SEP 7>6[6]
DL MKE-MSP SEP 6>5[5]
DL MSN-MSP SEP 6>5[5]
DL MSP-OMA SEP 7>6[6]
DL MSP-PSC SEP 1.0>2[1.8]
DL MSP-TUS MAY 1.0>0.4[1.0] JUN 0.2>0[0.2]
DL MSP-XNA SEP 2>1.5[1.4]
DL OKC-SLC SEP 2>3[2]
DL OMA-SLC SEP 3>1.9[1.8]
DL PDX-SEA SEP 7>8[7]
DL PHL-RDU SEP 3>2[2]
DL SEA-SJC SEP 4>6[5]
DL SEA-YVR SEP 5>6[6]
DL SLC-SUN SEP 2>3[3]
HA HNL-KOA JAN 19>18[18] FEB 19>18[18]
HA HNL-PPG JUN 0.2>0.4[0.2] JUL 0.2>0.4[0.2] AUG 0.2>0.4[0.2]
SY ANC-MSP JUN 0.0>0.3[1.4] JUL 0>0.3[1.7] AUG 0>0.3[1.4] SEP 0>0.3[0.1]
SY AUS-MSP JUL 0>0.3[0.4] AUG 0>0.3[0.4] SEP 0>0.3[0.2]
SY BNA-MSP JUN 0.1>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0] SEP 0>0.6[0]
SY BOS-MSP JUN 0.1>0.6[1.8] JUL 0>0.5[1.9] AUG 0>0.6[1.9] SEP 0>0.6[1.4]
SY CUN-DFW JUN 0.1>1.0[3] JUL 0>1.0[2] AUG 0>1.0[1.4] SEP 0>1.0[0.4]
SY CUN-MSP JUN 0.0>0.3[0.5] JUL 0>0.3[0.2] AUG 0>0.3[0.1] SEP 0>0.3[0.2]
SY DFW-LAS JUN 0.1>0.6[0.5] JUL 0>0.5[0.6] AUG 0>0.6[0.5] SEP 0>0.6[0.4]
SY HNL-LAX JUN 0.1>0.6[0.6] JUL 0>0.5[0.7] AUG 0>0.6[0.7] SEP 0>0.6[0.1]
SY LAS-PDX JUN 0.1>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0] SEP 0>0.6[0]
SY LAX-MSP JUN 0.3>2[3] JUL 0>2.0[3] AUG 0>2.0[3] SEP 0>2[1.9]
SY MCO-MSP JUN 0.2>1.5[1.2] JUL 0>1.5[1.0] AUG 0>1.5[1.0] SEP 0>1.5[1.1]
SY MSN-RSW MAR 0.3>0.6[0]
SY MSP-MYR JUN 0.0>0.3[0.1] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
SY MSP-PDX JUN 0.1>1.0[1.2] JUL 0>1.0[1.6] AUG 0>1.0[1.4] SEP 0>1.0[0.9]
SY MSP-PHX JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.7[0.5] SEP 0>0.7[0.9]
SY MSP-RSW JUN 0.1>0.9[0.9] JUL 0>0.8[1.0] SEP 0>0.9[0.6]
SY MSP-SAN JUN 0.1>0.8[1.0] JUL 0>0.9[1.0] AUG 0>0.8[1.0] SEP 0>0.9[0.8]
SY MSP-SEA JUN 0.2>2[1.9] JUL 0>2[3] AUG 0>2[3] SEP 0>2[1.3]
SY MSP-SFO JUN 0.2>1.7[2] JUL 0>1.7[2] AUG 0>1.7[2] SEP 0>1.7[1.3]
SY MSP-STS JUN 0.0>0.3[0.0] SEP 0>0.3[0.2]
SY PDX-SFO JUN 0.0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0]
SY RSW-STL MAR 0.3>0.5[0]
UA ACT-IAH JAN 0.3>0[0.3]
UA BMG-ORD JAN 0.2>0[0.1]
*UA BOS-CLE APR 3>0[2] MAY 3>0[2] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[3]
UA BQN-EWR JAN 0.5>1.0[0.1] FEB 0.5>1.0[0.1] MAR 0.5>1.0[0.4] APR 0.5>1.0[0.5] MAY 0.5>1.0[0.5] JUN 0.5>1.0[0.5] JUL 0.5>1.0[0.5] AUG 0.5>1.0[0.5] SEP 0.5>1.0[0.5]
UA CGI-PAH JAN 1.5>1.1[0] FEB 1.9>1.4[0] MAR 1.8>1.3[0] APR 1.9>1.4[0] MAY 1.9>1.4[0] JUN 1.8>1.3[0] JUL 1.9>1.4[0] AUG 1.9>1.4[0] SEP 1.9>1.4[0]
UA DEN-MCO JUN 4>5[4] JUL 4>5[4]
UA DEN-ORD MAY 11>10[11]
UA DVL-JMS JAN 1.4>0.9[1.3] FEB 1.4>0.9[1.4] MAR 1.4>0.9[1.4] APR 1.4>0.9[1.4] MAY 1.4>0.9[1.3] JUN 1.4>0.9[1.4] JUL 1.4>0.9[1.3] AUG 1.4>0.9[1.4] SEP 1.4>0.9[1.4]
UA EGE-SFO MAR 1.0>0.7[0.3]
UA HYS-SLN JAN 1.7>1.3[0] FEB 1.7>1.3[0] MAR 1.7>1.3[0] APR 1.7>1.3[1.3] MAY 1.7>1.3[1.7] JUN 1.7>1.3[1.7] JUL 1.7>1.3[1.7] AUG 1.7>1.3[1.7] SEP 1.7>1.3[1.7]
UA IAH-MHK JAN 0.2>0[0.1]
UA IAH-MOT JAN 0.2>0[0.2]
UA IAH-SJU JAN 1.1>2[0.5] FEB 1.0>2[0.5] MAR 1.1>2[0.6] APR 0.6>1.3[0.6] MAY 0.6>1.3[0.6] JUN 0.9>1.9[1.0] JUL 1.0>2[1.1] AUG 0.8>1.6[0.9] SEP 0.5>1.0[0.5]
UA IAH-STT JUL 0.5>1.0[0] AUG 0.3>0.6[0]
UA IAH-SWO FEB 0.2>0[0.1]
UA RDM-SFO MAY 4>5[4]
Reason: updated link at users request
intotheair
Re: OAG Changes 12/9/2018:AM Adds DTW-GDL, UA Drops BOS-CLE
Mon Dec 10, 2018 3:47 am
Here I was worried we'd have to call the police for a welfare check on you!
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
sargester
Mon Dec 10, 2018 3:52 am
Thanks for the info enilria, was worried that my Monday coffee read wasn't coming!
shaneam12
Mon Dec 10, 2018 3:55 am
Wow! Delta to fly up to 6x daily BOS-DCA... it’s about time. Can’t wait to book a seat!
jrkmsp
Mon Dec 10, 2018 3:56 am
These all seem like significant adds to the burgeoning BOS hub, in particular the add to DCA and ORD. They'll be up against the American shuttle on the DCA route, I believe, and a whole lot of B6, UA, AA and WN on BOS-ORD. BOS-ORD has been one of the biggest holes in the DL BOS network for a while...
PHLspecial
Mon Dec 10, 2018 4:01 am
I guessing the PHL-BOS is doing well or more likely beefing up the BOS hub. Here's to trying Delta next year.
stl07
Mon Dec 10, 2018 4:03 am
How is there such a high frequency on inter island routes out of HNL given the fact that many of the other islands have their own nonstop to the US and Asia as well as the fact that these other islands are not very populous.
Instead of typing in "mods", consider using the report function.
Love how every "travel blogger" says they will never fly AA/Ethihad again and then says it again and again on subsequent flights.
BenflysDTW
Mon Dec 10, 2018 4:06 am
DTW-HNL cuts aren’t suprising. Prices are below $400 round trip for many dates. It’ll be like MSP where there isn’t service from Labor Day to November. We will see if this sticks, and my grant was wished for GDL!
NickolayAv
Mon Dec 10, 2018 4:09 am
Ahh, my Sunday is complete. Thank you Enilria.
Now for some BOS analysis.
WOW...DL entering 3 new business markets from BOS, they are not playing games with their expansion from BOS. Further increases on PHL, IND. They are really starting to put up a fight in BOS, I wonder if we are going to see any responses in the upcoming weeks from AA, UA, and B6. I'm sure these will catch their eye.
Interesting, UA/CO has flown this route for a long time, loads also seem okay. I wouldn't be surprised to see DL to hop in on this route in the future. UA has really shrunk in BOS, close to insignificance.
"If you want to be a millionaire, start with a billion dollars and launch a new airline"-Richard Branson
tlecam
Mon Dec 10, 2018 4:12 am
What???
BOS-LGA-JFK | A:319/20/21, 332/3, 346 || B:717, 735, 737, 738, 739, 752, 753, 762, 763, 764, 787, 772, 744 || MD80, MD90
MichaelMke99
Mon Dec 10, 2018 4:16 am
I’ve been to Hawaii a few times, a lot of these routes are flown for work/business, shopping, and families, since there is no other transport between islands other than chartering a boat.
jrkmsp
Mon Dec 10, 2018 4:20 am
Looks like BOS-DCA is 6x daily, all operated by Republic E175s, BOS-EWR is 4x daily, all operated by Republic E175s, BOS-ORD is 5x daily, operated by Republic E175s.
ericm2031
Mon Dec 10, 2018 4:48 am
I'm not sure I would consider 35 flights a day (almost entirely mainline) insignificant...they also put their premium transcon product on SFO-BOS and run domestic 777's to SFO. For not being a hub or focus city, they serve BOS quite well.
CLE-BOS sees fares drop as low as $100 and the ERJ probably scares off most business travelers. Not many connecting passengers either as the options to connect on either end are the same cities already served from each city.
Jouhou
Mon Dec 10, 2018 4:53 am
I'm disappointed that BOS-YVR is being trimmed. I wonder if the route will be better served when AC gets the a220.
情報
Midwestindy
Mon Dec 10, 2018 4:59 am
Very interesting, but this raises a few questions:
1. Where are the DCA slots coming from?
2. What retaliation will we see?
BOS-DCA/ORD were a long time coming though, great that they are finally started though
ORD & IND
AA & DL
N649DL
Mon Dec 10, 2018 5:05 am
tlecam wrote:
What???
I can't read this, is DL adding or dropping BOS-EWR/ORD based on the arrows? If adding, that's awesome. DL hasn't operated BOS-EWR since around 2001. Interesting they're trimming EWR-CVG though.
UA dropping BOS-CLE is just sad. That was mainline for a long time up until recently.
EDIT: I just checked Delta.com and BOS-EWR is bookable in September on E-175s. It seems like DL's BOS expansion is mirroring their 2000-2001 expansion (then retraction) of the focus city. That said, I'd love to see the recent dumps of EWR-AMS/CDG replaced with EWR-LAX/SEA or something like that. Cool stuff!
NickolayAv
Mon Dec 10, 2018 5:15 am
For a non-hub city, I understand BOS gets a lot of love from UA, however, I am comparing UA today, to the ops UA previously had at BOS after the CO merger. For the past 4 years, their market share in BOS has been falling, they used to fly to some non-hub routes, however, but now they have cut all those routes and their largest focus city. As a Boston native, UA + *A partners used to be the most powerful alliance in BOS, however today, they are probably the weakest, in terms of destinations served and frequency. It is very evident when speaking to FF's many of whom have transitioned from *A loyalty to OW and ST loyalty programs, usually with AA and DL respectively.
enilria
Mon Dec 10, 2018 5:17 am
Yes, OAG is killing me.
Yes, I value reliability. Sorry, the source is souring that.
tlecam wrote:
What???
I didn't see those. Wow, they are loaded far in the future.
joeblow10
Hunting through Google Flights... it looks like DCA-LGA is down 2 flights from summer and CVG is down 1, haven’t found the other 3 yet...
EDIT: looks like they are also displayed in Enilria’s report: CVG, RDU, DTW, ATL losing one; LGA losing two
N649DL
Mon Dec 10, 2018 5:20 am
Agreed but BOS-CLE was a major business route for UA and CO. The fact that CLE-LGA is still served and they're dropping CLE-BOS is weird to me.
Also, look at all the CLE seasonal routes they just added on UA according to Wikipedia - Seasonal: Charleston, Fort Lauderdale (begins March 9, 2019), Fort Myers (begins March 9, 2019), Tampa (resumes March 9, 2019)
Sad UAL gave up the CLE hub, they had nearly an 80% retention rate.
Runway28L
Mon Dec 10, 2018 5:48 am
I really wonder where all of those YX E170/175s are coming from. I imagine it has to do with OO pushing a lot of E175 flying out east to places like LGA and freeing up the YX frames.
stl07
Mon Dec 10, 2018 6:12 am
So it is pretty much a bridge? Interesting
TWA772LR
Mon Dec 10, 2018 6:17 am
Are these college charters?
When wasn't America great?
Bobloblaw
Mon Dec 10, 2018 8:27 am
ORD-BMG and IAH-MHK on United? Why where these in the schedule last year? Did sports charters some how get inthe OAG?
jordanh
Mon Dec 10, 2018 9:48 am
I am guessing they will come off routes where they are being replaced by the A220.
ADent
Mon Dec 10, 2018 9:54 am
N649DL wrote:
tlecam wrote:
What???
In the latest OAG report DL is showing 4 flights per day in September on BOS-DCA - it was 0 previously. Last year in SEP they flew 0 flights on this route.
BOS-EWR/ORD are going from 0 to 3 in SEP, and was 0 last year.
iyerhari
Mon Dec 10, 2018 11:29 am
tlecam wrote:
What???
DL is expected to get their WN gates sometime im June or July timeframe- this is all in anticipation of that. DL wants and is keen to be the carrier of choice in BOS and too good of a market for them. They are now entering the other US2 fortress hubs. There are very few US2 hubs remaining where DL does not fly to with all these adds. There are still missing hub links.
DEN, IAH, CLT, IAD ( although they will now fly to DCA), PHX, DFW, MIA.
It looks likely they will start adding all these stations slow and steady and also continue to add international stations at a gradual pace.
chrisnh
Re: OAG Changes 12/9/2018:DL Adds BOS-EWR/DCA/ORD, AM Adds DTW-GDL, UA Drops BOS-CLE
Mon Dec 10, 2018 11:30 am
I wonder how many of those UA BOS-LAX and BOS-SFO flights have Hawaii-bound people on them, and whether they’ll suffer in April when HA comes waltzing in.
iyerhari
Mon Dec 10, 2018 11:49 am
UA has not flown to any non hub destinations with the exception of CLE from BOS. CLE route was an exception as it used to be a UA hub and there was still business ties between the two cities. UA is extremely regimented in their business approach IMO - with the exception of CLE and maybe one offs they only fly hubs. AA is also becoming similar to UA and I believe it is just a matter of time when they shutdown the 4 non hub routes.
RWA380
Mon Dec 10, 2018 12:26 pm
Quite the drop in frequency, long gone are the days of the every 30 minute shuttle. I chose random Wednesdays in April, there are only 11 daily Q-400 flights now. Peak times have 3 AS mainline flights daily (1 738, 1 739 & 1 320), an additional 3 E-175 flights operated by QX, OO offers no flights between SEA & PDX with this schedule. I see a total of 17 dailies on AS.com.
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
jfklganyc
Mon Dec 10, 2018 12:48 pm
Big play against B6 in BOS.
Wonder what B6 does to respond
adamh8297
Mon Dec 10, 2018 1:11 pm
This may be the pre-announcement response to B6 BOS-IND if this is indeed happening at 10am.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
flyguy84
Mon Dec 10, 2018 2:02 pm
Yes.
SFO
B757capt
Mon Dec 10, 2018 2:12 pm
Continue to cry that the big 3 are always out maneuvering them..... what else is new?
The views written by this user are in no manner the views of my employer and should not be thought as such.
DiamondFlyer
Mon Dec 10, 2018 2:26 pm
The OO 175s pushing east aren’t the original OO 175 Delta order, but rather the replacement of the ASA/ExpressJet CR7s. Sure they’re out east, but they aren’t growth.
From my cold, dead hands
aaflyer777
Mon Dec 10, 2018 2:32 pm
DL has confirmed they are starting BOS-CLE on April 1, flights just haven't been loaded yet. Might explain why UA bailed, no sense fighting DL and B6
SgtBarone
Mon Dec 10, 2018 2:33 pm
AGP ATL BCN BNA BOS CLE CLT DCA DEN FLG FLL FRA IAD IAH JAX LAS LAX LGB MAD MCI MDW MKE MUC PHX RDU RSW SEA SJU SLC SNA TPA
jrkmsp
Mon Dec 10, 2018 2:40 pm
Delta confirms the adds we're discussing, and also announces that it will add BOS-CLE as of April 1. That's not available for booking yet, which leads me to believe they saw UA pull out this weekend and decided to add it to their big announcement.
Details: https://news.delta.com/delta-adds-more- ... hington-dc
Summary of 2019 Daily Market Expansion
Starting April 2019, Delta and partners are adding three international and four domestic destinations for Boston customers, with frequency increases in another seven markets.
Destination
Date
Market Increase
Amsterdam, Netherlands
March 31
KLM launches new service
London-Heathrow
April 1
Additional daylight trip by Virgin Atlantic
Cleveland
April 1
Delta launches new 3x daily service*
Pittsburgh
April 2
Delta increases from 4x to 5x trips
Seoul-Incheon, South Korea
April 12
Korean launches 5x weekly service
Jacksonville, Fla.
April 14
Delta increases from 2x to 3x trips
Nashville, Tenn.
April 15
Delta increases from 3x to 4x trips
Edinburgh, Scotland
May 23
Delta launches seasonal daily service
Lisbon, Portugal
May 23
Indianapolis
June 8
Philadelphia
June 8
Delta increases from 4x to 6x trips
Chicago O’Hare
Sept. 9**
Delta launches new 5x daily service
Newark, N.J.
Sept. 9
Delta launches new 4x daily service
Washington, D.C. (Reagan National)
Sept. 9**
Delta launches new 6x daily service
jrkmsp
Mon Dec 10, 2018 2:42 pm
I suspect it's the other way around — UA bailed and so Delta decided to jump in the market. Flights haven't been loaded because they didn't know it was coming until yesterday.
Dominion301
Mon Dec 10, 2018 2:45 pm
Well BOS is now without a doubt becoming SEA 2.0.
I wonder how gradual the BOS buildup will be? I'd imagine DL will also add things like transborder routes that B6 won't touch in order to try and become dominant at BOS.
jplatts
Mon Dec 10, 2018 2:48 pm
One big difference between BOS-CLE and LGA-CLE is that UA has a hub at EWR and a FF base on the NYC side to support LGA-CLE nonstop service whereas UA has no hub in Greater Boston. Likewise, UA also has a hub at IAD and a FF base on the DC side to support DCA-CLE nonstop service.
hiflyeras
Mon Dec 10, 2018 2:54 pm
Waiting to see what they have next in store for B6....uh...I mean BOS. Fine with me...takes attention away from SEA.
enilria
Mon Dec 10, 2018 2:59 pm
They let go of a lot of people recently. I could have spilled the beans.
And really without the intl justification they had with SEA.
chrisnh
Mon Dec 10, 2018 3:00 pm
IMO this pushes B6 closer to being acquired. Also, the TATL fruit will all be picked over by the time they get around to ordering planes, never mind going through ETOPS and then launching service.
STT757
Mon Dec 10, 2018 3:17 pm
I think it's time for UA to do something else with their LGA and DCA slots instead of flying 50 seaters to CLE. Heck why not launch MCO, FLL, TPA, PBI , RSW etc.. with mainline.
They've been boosting their Florida service from EWR with year round service to Key West, 3x daily to Sarasota and new service to Pensacola.
Sightseer
Mon Dec 10, 2018 3:26 pm
Thanks Enilria!
And, of course, LGA has slots whereas BOS doesn't.
LAXBUR
Mon Dec 10, 2018 4:35 pm
4x at Paine coming. Maybe this will give a litte more gate space at SEA. Every 30 minutes always seemed a bit extreme.
jmscsc
Mon Dec 10, 2018 4:39 pm
N649DL wrote:
tlecam wrote:
What???
It's read as: Delta is going from 0 flights in SEP to 4. The number in brackets indicates how many flights they operated at the same time last year, so in each case none. Therefore, these are all adds for DL.
evank516
Mon Dec 10, 2018 5:03 pm
Waiting for this to go to A220s.
flymco753
Mon Dec 10, 2018 5:11 pm
I'm expecting a potential B6 reaction to these new DL routes by adding MSP/DTW-JFK on E190's.
...the carriage of liquids, gels, and aerosols are prohibited through the screening checkpoint except for travel size toiletries of 3 ounces or less...
